Can nRF54H20 work with nRF7002?
Dear Nordic team,
I am currently working with the nRF54H20 and have been researching the nRF7002 (using the nRF7002-DK). I would like to ask if the nRF54H20 is compatible with the nRF7002 chip. I might need to manually connect the nRF54H20 to the nRF7002 chip on the nRF7002-DK.
** As far as I know, the nRF7002 is designed for the nRF52, nRF53, and nRF91. Is there any updated information or plans to support the nRF54H20?
www.nordicsemi.com/.../nRF7002
Thanks.
  • Excellent, I have also managed to build and flash it onto the nRF54H20DK using your method. The next task is to connect the nRF7002-EK with the nRF54H20-DK.
    Thank you.
  • Hi  ,
    Context:
    • WiFi board: nRF7002-EK
    • Host boards: nRF52840, nRF5340, and nRF54H20
    I've successfully built and flashed the Wi-Fi: Shell example for nRF52-DK and nRF53-DK, which works well with nRF7002-EK.
    uart:~$
    [00:00:00.259,460] <inf> wifi_nrf_bus: SPIM spi@4002f000: freq = 8 MHz
    [00:00:00.259,490] <inf> wifi_nrf_bus: SPIM spi@4002f000: latency = 0
    *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
    *** Using Zephyr OS v3.6.99-100befc70c74 ***
    Starting nrf52840dk with CPU frequency: 64 MHz
    [00:00:00.515,899] <inf> wpa_supp: Successfully initialized wpa_supplicant
    uart:~$ wifi
      version             ap                  connect
      disconnect          ps                  ps_mode
      scan                statistics          status
      twt                 reg_domain          mode
      packet_filter       channel             ps_timeout
      ps_listen_interval  ps_wakeup_mode      rts_threshold
    I can build and flash Wi-Fi: Shell for nRF54H20 (nrf54h20dk/nrf54h20/cpuapp) and nRF7002-EK (nrf700x_nrf54h20dk), but I'm encountering an error as shown in the log below:
    uart:~$
    [00:00:00.200,002] <inf> wifi_nrf_bus: SPIM spi@9a5000: freq = 8 MHz
    [00:00:00.200,023] <inf> wifi_nrf_bus: SPIM spi@9a5000: latency = 0
    [00:00:00.206,997] <err> wifi_nrf: hal_rpu_reg_read: Error !! Value read at addr_offset = 400 is = FFFFFFFF
    [00:00:00.207,019] <err> wifi_nrf: hal_rpu_irq_enable: Reading from Root interrupt register failed
    [00:00:00.207,034] <err> wifi_nrf: nrf_wifi_hal_dev_add: hal_rpu_irq_enable failed
    [00:00:00.207,093] <err> wifi_nrf: nrf_wifi_fmac_dev_add: nrf_wifi_hal_dev_add failed
    [00:00:00.207,102] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
    [00:00:00.207,109] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
    [00:00:00.208,131] <inf> fs_nvs: 6 Sectors of 4096 bytes
    [00:00:00.208,135] <inf> fs_nvs: alloc wra: 0, fd0
    [00:00:00.208,144] <inf> fs_nvs: data wra: 0, 0
    Starting nrf54h20dk with CPU frequency: 320 MHz
    [00:00:00.209,089] <inf> wpa_supp: Successfully initialized wpa_supplicant
    Here's my hardware connection between nRF7002-EK and nRF54H20:
    Func nRF7002-EK nRF5340-DK nRF54H20
    iovdd-ctrl-gpios IOVDD_EN P1.00 P1.00 [P1.03]
    bucken-gpios BUCK_EN P1.01 P1.00
    host-irq-gpios HOST_IRQ P1.09 P1.02
    cs SS P1.12 P1.04
    MOSI MOSI P1.13 P1.05
    MISO MISO P1.14 P1.06
    SCK CLK P1.15 P1.01
    //nrf700x_nrf54h20dk.overlay
    &pinctrl {
    	spi130_default: spi130_default {
    		group1 {
    			/* SCK has to be 0..3 and other signals can't use these pins */
    			psels = <NRF_PSEL(SPIM_SCK, 1, 1)>,
    				<NRF_PSEL(SPIM_MISO, 1, 6)>,
    				<NRF_PSEL(SPIM_MOSI, 1, 5)>;
    	spi130_sleep: spi130_sleep {
    		group1 {
    			low-power-enable;
    &spi130 {
    	status = "okay";
    	cs-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>;
    	pinctrl-0 = <&spi130_default>;
    	pinctrl-1 = <&spi130_sleep>;
    	memory-regions = <&cpuapp_dma_region>;
    	nrf700x: nrf7002@0 {
    		compatible = "nordic,nrf700x-spi";
    		status = "okay";
    		reg = <0>;
    		spi-max-frequency = <DT_FREQ_M(8)>;
    		bucken-gpios = <&gpio1 0 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
    		iovdd-ctrl-gpios = <&gpio1 0 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
    		host-irq-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>;
    &gpio1 {
    	status = "okay";
    Questions:
    1. Why are both bucken-gpios and iovdd-ctrl-gpios set to P1.00 for nrf700x_nrf54h20dk? I've tried changing iovdd-ctrl-gpios from P1.00 to P1.03, but the result remains the same.
    2. Is my connection between nRF7002-EK and nRF54H20 correct? Are there any missing pins?
    3. If the hardware connection is correct, what error am I facing? Is there a way to identify the root cause?
    Thank you in advance for any help or insights you can provide. I appreciate your time and expertise.
  • Oh, my mistake, I'm missing the IOVDD (1.8V) power supply, it might work now. But I still need to fix the iovdd-ctrl-gpios (P1.03).
    iovdd-ctrl-gpios = <&gpio1 3 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
  • Hello Lam,
    I'm surprised that this doesn't work by default. Have you modified anything in the sample or SDK?
    Could you try changing the USB cable/port, just to make sure that you are not running into the same issue as this guy?
    Elfving
  • Hi  ,
    For the example nrf/samples/wifi/shell when I build and flash in default mode (without modifications in NCS 2.7.0), below are the results, I cannot use the wifi scan cmd.
    uart:~$
    [00:00:00.211,151] <err> wifi_nrf_bus: RPU wakeup write ACK failed even after 10ms
    [00:00:00.211,154] <err> wifi_nrf_bus: Error: RDSR2 failed
    [00:00:00.211,200] <err> wifi_nrf: zep_shim_bus_qspi_dev_add: RPU enable failed with error -1
    [00:00:00.211,225] <err> wifi_nrf: nrf_wifi_bus_qspi_dev_add: nrf_wifi_osal_bus_qspi_dev_add failed
    [00:00:00.211,247] <err> wifi_nrf: nrf_wifi_bal_dev_add: Bus dev_add failed
    [00:00:00.211,266] <err> wifi_nrf: nrf_wifi_hal_dev_add: nrf_wifi_bal_dev_add failed
    [00:00:00.211,298] <err> wifi_nrf: nrf_wifi_fmac_dev_add: nrf_wifi_hal_dev_add failed
    [00:00:00.211,307] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
    [00:00:00.211,318] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
    [00:00:00.212,337] <inf> fs_nvs: 6 Sectors of 4096 bytes
    [00:00:00.212,341] <inf> fs_nvs: alloc wra: 0, fd0
    [00:00:00.212,344] <inf> fs_nvs: data wra: 0, 0
    [00:00:00.213,292] <inf> wpa_supp: Successfully initialized wpa_supplicant
    uart:~$ wifi scan
    Scan request failed
    [00:00:05.554,349] <err> wifi_nrf: nrf_wifi_disp_scan_zep: Interface not UP
    However, when I change iovdd-ctrl-gpios from P1.0 to P1.3, it works well, and below are the results:
    uart:~$
    [00:00:00.200,102] <inf> wifi_nrf_bus: SPIM spi@9a5000: freq = 8 MHz
    [00:00:00.200,122] <inf> wifi_nrf_bus: SPIM spi@9a5000: latency = 0
    [00:00:00.572,411] <inf> fs_nvs: 6 Sectors of 4096 bytes
    [00:00:00.572,416] <inf> fs_nvs: alloc wra: 0, fd0
    [00:00:00.572,419] <inf> fs_nvs: data wra: 0, 0
    [00:00:00.573,397] <inf> wpa_supp: Successfully initialized wpa_supplicant
    uart:~$ wifi scan
    Scan requested
    Num  | SSID                             (len) | Chan (Band)   | RSSI | Security        | BSSID             | MFP
    Question:
    Is it expected or an accident that both iovdd-ctrl-gpios and bucken-gpios are set to P1.0? When I change the source code and it works, could this be the cause of the issue?
