Simultaneous communication on 2 sync libUARTe
Hi.
We are using nRF52833 (on BL653 module) where UART0 and UART1 are used for communication purposes (one with STM MUC and the other with quectel modem). Current solution uses SDK 17.0.2, softdevice and freeRTOS, where async libuarte support is used for uart communication. The main problem is that, from time to time (every couple of minutes), we get a HardFault. But only when both are active. If we disable on of them, the code looks to work as expected.
Currently, the UARTs are defined as (using app_timer):
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 1, 4, NRF_LIBUARTE_PERIPHERAL_NOT_USED, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 1024, 3);
NRF_LIBUARTE_ASYNC_DEFINE(quectel_libuarte, 0, 3, NRF_LIBUARTE_PERIPHERAL_NOT_USED, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 1024, 3);
We found out that using exact TIMER (TIMER2) works worse as before we used:
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 1, 4, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 1024, 3);
So, the first question is which TIMER is preferred to be used for UART when softdevice is present?
And while changing to app_timer made things better, HardFault still occurs. In the docs you can find: "If the TXD.PTR and the RXD.PTR are not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption.". What is the best scenario to check whether this is the cause in our case?
Also, do both interfaces share any common shared source (besides easyDMA, which should work with both of them)? For example, should UART1 wait for UART0 to finish anything it does (writing and/or reading)? We are aware that UART can not read and write at the same time. Are we missing something else?
Vojko
  • Hi.
    Unfortunately, we have a custom board and it would probably take a lot of changes to test it on DK. We will try to make a DK version.
    But in the mean time. We do use malloc and free. Would it make sense to use pvPortMalloc from freertos (heap_3 variant) or even nrf_malloc to prevent memory corruption?
    What is the best way to check memory consumption (analitically or real-life)? The solution with printing address of NULL pointer variable always returns the same address from which we are not able to detect if memory consumption is growing. Any other way to detect memory leaks? Or to at least detect that memory leak is present?
    And to check it analytically. Soft_device will take a part of memory, freertos heap will be next and in the end malloc calls, right? If there is enough space malloc should not intervene in the memory locations of other two, right? It should return NULL.
    This is never straightforward. But I once followed this long time ago on FreeRTOSv9 with some success. I do not remember the details but I bookmarked this page as it was helpful.
    Yes, if there are no stack overflows, then the memory used by softdevice or application should not split into using the reserved heap area.
