Npm1300 + nrf5340 reset configuration
i'm developing a board based on nrf5340 and i want to use npm1300 as the pmic. My board is very constrained in terms of space so i'm trying to trade-off the flexibility in terms of testability (extra buttons, test-points, leds, etc.) with this. I read a lot the documentation of both nrf5340 and npm1300 and i would like to confirm that i understood well about the reset options.
Short recap of the valuable infos:
- npm1300 resets using 1 button connected to the SHPHLD pin or using 2 buttons (one on SHPHLD, the other on GPIO0). In both cases, button(s) needs to be pressed for t>tresetbut. The mode (1 or 2 buttons) needs to be set using proper register configuration.
- nrf5340 resets using 1 button on the RESET pin.
- the reference design at Fig.49 of npm1300 Product specifications v.1.1 shows a 2 button configuration with 1 button on SHPHLD and the other button connected to both GPIO0 of npm1300 and RESET of nrf5340.
Being space constrained, i would like to add just 1 button to the board. The idea is to use it for the reset of both npm1300 and nrf5340 so, respect to the reference design, i would connect the button with both SHPHLD and RESET pin of nrf5340.
Is this a legit configuration considering that i need to program nrf5340 over and over for tests using the SWD port of a Segger J-link?
My question arises from the fact that in the boards i developed until now, the MCU (and all the stuff used for programming such as memory, etc.) was always supplied with VDD while reset pin was triggered. In this case, due to the fact that the reset of npm1300 causes a power cycle on the nrf5340, i wonder if this could cause trouble to the programming phase. In your reference design this is not an issue because if the nrf53x reset is triggered the npm1300 is still active because of the 2-buttons configuration.
Any clarification on this matter is appreciated!
Thank you,
Francesco
  • Oh, and by the way:
    Do you have an nRF5340DK and an nPM1300 EK?
  • Ok! Things are getting clearer!
    Considering all that you said and my constraints i would like to proceed like this:
    1) Reset button connected to the SHPHLD pin of nPM1300;
    2a) GPIO (GPIO0..3) pins connected to the RESET pin of the nrf5340 (no pull-up needed). In this case i can HARD RESET the nrf5340 for specific events happening on the nPM1300;
    2b) Alternatively, i can connect GPIO0..3 to a GPIO pin of the nrf5340 and manage any event interrupt from nPM1300 in the MCU software (i.e. i can trigger a SOFT RESET for an error event on nPM1300);
    3) SWD port (SWDIO & SWDCLK) connected to nrf5340 without reset line;
    In this way:
    1) When i program the nrf5340 using SWD port the programmer will send a SOFT RESET to put the board in a known state and proceed with the programming of the chip;
    2) When i want to reset my custom board MCU i can proceed in two ways:
    a) (long) push the button (>10s default). In this way the nPM1300 will reset and will cause a power cycle that will pull down VOUT1 (See Fig.49 in the previous post) for tPWRDN (= 100ms) on the nrf5340 that will reset as well;
    b) configure the INTENEVENTSSHPHLDSET register of the nPM1300 to trigger a GPIO interrupt on the EVENTSHPHLDBTNPRESS (or RELEASE) event. This interrupt can HARD RESET the nrf5340 in "2a" configuration or SOFT RESET the nrf5340 in "2b" configuration.
    This should make it. I have been a bit verbose to support the community.
    Please correct me if i wrote some bullshits Smiley
    Oh, and by the way:
    I have the nRF5340DK and ordered the nPM1300EK. I'll start experimenting in few days. I'm studying the stuff at the moment Nerd
    Sounds good.
    Maybe not all, but one of the GPIOs.
    Yep. 2a and 2b can be done at the same time, cause you can just use GPIO0 for 2a and the rest for 2b.
    Yep.
    Correct. That is the exact use-case for this feature.
    Sounds good to me, but I must admit I am not 100% sure here (cause it is a tad more complex). I recommend testing it.
    We appreciate it!
    Brilliant! I recommend that you test the setup with the DK+EK to be sure that it works. We are all human, so even though we in support here are skilled, we can be wrong sometimes as well. So if you tested it, you will know that it works for sure.
  • Nice!
    Of course i will test everything i can. There is a lot of room to play with these kits.
    Thank you again for the very fruitful discussion!
    Frax
  • I would suggest that just reset your PMIC as this would turn off all the buck and VDD_supply of your nRF53 so like this it will POR reset your whole system in one button/switch by just cutting of the input supply of your battery.
