I'm seeing an issue when trying to program the nRF54H20 board. I have python 3.10.9 installed. Does nrfutil specifically need python 3.9? Any support with this would be appreciated
Hello Aman,
Which version of the nRF54H20 PDK are you using? You can just take a picture of the white sticker on the board for me if you want. Also, what version of the SDK and toolchain are you using again? I believe the only version of the SDK that is compatible with the nRF54H20 is v2.7.99-cs1 and that is only compatible with PCA10175 v0.8.0. I believe this may be the issue you are running into.
Thank you,
Jennifer Gibbs
Hi Jennifer,
I've attached a picture of the dev-kit below, it seems to be the correct one.
I've been using version 2.7.0 of the SDK - that would explain the issues I'm seeing. Is there an updated version of the toolchain? I only seem to see versions up to 2.7.0, even after updating the SDK to 2.7.99-cs1, and when I try to build with this combo of SDK 2.7.99-cs1 and toolchain 2.7.0, I get the below error, presumably because the versions are mismatched.
Hello Aman,
Yes, use toolchain v2.7.0 with SDK v2.7.99-cs1. You have the correct board so you should just need to update your SDK version. Let me know if you have any issues with that.
Thank you,
Jennifer Gibbs
Hi Jennifer,
I'm seeing the same behaviour laid out in this ticket by another user: Build configuration incomplete
I updated to the pre-release version as suggested in the ticket, but am seeing the same issue reported by this user, which I sent a screenshot of in my previous response (could not find a config file for nrf-regtool that matches the correct version).
The solution proposed in that ticket is to use SDK v2.7.0, which obviously won't apply here. Is there a solution for this while using SDK v2.7.99-cs1?
Aman
Hello Aman,
Which sample are you trying to build? Can you provide the full build output?
Thank you,
Jennifer
