I'm currently working on NCS2.6.0 and ANT sdk v1.3.0,
I would like to know is it possible to do BLE scanning(without connection) and ANT+ heart rate searching at the same time?
Now I'm able to scan BLE manufacturer data and ANT+ heart rate pages saparately, but I need to combine it on my nRF52832 custom board with NCS platfrom.
Could you provide some suggestions? Thank you.
Here's something in my main.c code for more information:
int ant_stack_setup(void) { int err = ant_init(); if (err) { LOG_ERR("ant_init failed: %d", err); return err; } LOG_INF("ANT Version %s", ANT_VERSION_STRING); err = ant_cb_register(&ant_evt_handler); if (err) { LOG_ERR("ant_cb_register failed: %d", err); return err; } err = ant_plus_key_set(CONFIG_HRM_RX_NETWORK_NUM); if (err) { LOG_ERR("ant_plus_key_set failed: %d", err); } return err; } static int start_scan(void) { uint8_t channel_number = 0; ant_channel_config_t channel_config = { .channel_number = channel_number, .channel_type = CHANNEL_TYPE_SLAVE_RX_ONLY, .ext_assign = EXT_PARAM_ALWAYS_SEARCH, .rf_freq = 57, .transmission_type = 0, .device_type = 120, .device_number = 0, .channel_period = 8070, .network_number = CONFIG_HRM_RX_NETWORK_NUM }; int err = ant_channel_init(&channel_config); if (err) { LOG_ERR("ant_channel_init failed: %d", err); return err; } err = ant_channel_open(channel_number); if (err) { LOG_ERR("ant_channel_open failed: %d", err); return err; } LOG_INF("ANT+ scanning started on channel %d", channel_number); return 0; } int main(void) { uint32_t baudrate, dtr = 0U; int ret; int err; err = ant_stack_setup(); if (err) { goto ERROR_EXIT; } err = start_scan(); if (err) { goto ERROR_EXIT; } ret = bt_enable(NULL); if (ret) { printk("Bluetooth init failed (err %d)\n", ret); return; } if (IS_ENABLED(CONFIG_SETTINGS)) { settings_load(); } printk("Bluetooth initialized\n"); struct bt_le_scan_param scan_param = { .type = BT_LE_SCAN_TYPE_ACTIVE, .options = BT_LE_SCAN_OPT_CODED, .interval = BT_GAP_SCAN_FAST_INTERVAL, .window = BT_GAP_SCAN_FAST_WINDOW, }; ret = bt_le_scan_start(&scan_param, scan_cb); if (ret) { printk("Starting scanning failed (err %d)\n", ret); return; } printk("Scanning successfully started\n"); return 0; ERROR_EXIT: ant_state_indicator_fatal_error(); k_oops(); return 0; }
