nrf52840 capture security level negotiation
I am using a nrf52840 dongle. I have my own device which has BLE and I am connecting to an app in mobile phone our bluetooth. My goal is to check for the security level what my device has and when it's getting connected with app I was trying to find if there is any security negotiation. To check this I am using the nrf52840 dongle for bluetooth sniffing so that I can check for the security negotiation.
Based on this link I followed all the steps https://academy.nordicsemi.com/courses/bluetooth-low-energy-fundamentals/lessons/lesson-6-bluetooth-le-sniffer/topic/nrf-sniffer-for-bluetooth-le/
I have flashed firmware 4.1.1 version.
I get the PDU type as 0x08
In documentation there is nothing referencing to Packet ID 0x08. It says security level error and CRC is bad wanted to understand more on this.
Also how to check for security level negotiation which packet should I look for specifically? Also with the firmware version 4.1.1 can I get to know the security negotiation?
  • Hi Hung,
    I am looking at the logs in wireshark during the device connection I observed few things,
    • Always the encryption is "No"
    • Authentication signature is false
    • There are no logs with LL_enc_req during the entire connection.
      I am using justworks pairing mechanism so no intervention of any keys or nothing how do I figure out this security level or any security level negotiation.
      Could you help me in this?
  • Please send the full sniffer trace. You can convert the ticket to private if there is confidential information.
    For the pairing to be triggered, the central should try to read/write a characteristic that has security requirement. After it receive the rejection from the peer, the central will initiate the pairing process.
  • No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
          1 0.000000       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 1: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 23660
        Length of packet: 10
        Flags: 0x01
            .... ...1 = CRC: Ok
            .... ..0. = Reserved: 0
            .... .0.. = Reserved: 0
            .... 0... = Address Resolved: No
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 37
        RSSI: -50 dBm
        Event counter: 0
        Timestamp: 1888698441µs
        [Packet time (start to end): 296µs]
    Bluetooth Low Energy Link Layer
        Access Address: 0x8e89bed6
        Packet Header: 0x1b00 (PDU Type: ADV_IND, ChSel: #1, TxAdd: Public)
        Advertising Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)
        Advertising Data
        CRC: 0x1fbbb8
          2 0.000662       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 2: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23661
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 38
        RSSI: -49 dBm
        Event counter: 0
        Timestamp: 1888699103µs
        [Delta time (end to start): 366µs]
        [Delta time (start to start): 662µs]
        Advertising Data
        CRC: 0x1fbbb8
          3 0.001324       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 3: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23662
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 39
        RSSI: -45 dBm
        Event counter: 0
        Timestamp: 1888699765µs
        Advertising Data
        CRC: 0x1fbbb8
          4 1.280027       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 4: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23669
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 37
        RSSI: -50 dBm
        Event counter: 0
        Timestamp: 1889978468µs
        [Delta time (end to start): 1278407µs]
        [Delta time (start to start): 1278703µs]
        Advertising Data
        CRC: 0x1fbbb8
          5 1.280689       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 5: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23670
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 38
        RSSI: -48 dBm
        Event counter: 0
        Timestamp: 1889979130µs
        Advertising Data
        CRC: 0x1fbbb8
          6 1.281351       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 6: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23671
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 39
        RSSI: -45 dBm
        Event counter: 0
        Timestamp: 1889979792µs
        Advertising Data
        CRC: 0x1fbbb8
          7 2.562561       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 7: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23678
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 37
        RSSI: -50 dBm
        Event counter: 0
        Timestamp: 1891261002µs
        [Delta time (end to start): 1280914µs]
        [Delta time (start to start): 1281210µs]
        Advertising Data
        CRC: 0x1fbbb8
          8 2.563223       ublox_a2:93:3c        Broadcast             LE LL    53     0x0                                            ADV_IND
    Frame 8: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23679
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 38
        RSSI: -48 dBm
        Event counter: 0
        Timestamp: 1891261664µs
        Advertising Data
        CRC: 0x1fbbb8
          9 2.563669       6c:0f:c0:61:21:72     ublox_a2:93:3c        LE LL    60     0x5                                            CONNECT_IND
    Frame 9: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23680
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 38
        RSSI: -62 dBm
        Event counter: 0
        Timestamp: 1891262110µs
        [Packet time (start to end): 352µs]
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 446µs]
        Packet Header: 0x2245 (PDU Type: CONNECT_IND, ChSel: #1, TxAdd: Random, RxAdd: Public)
        Initiator Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)
        Link Layer Data
        CRC: 0xe26e49
         10 2.592417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    35                No                                  Control Opcode: LL_FEATURE_REQ
    Frame 10: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23681
        Flags: 0x03
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
            .... .0.. = Encrypted: No
            .... 0... = MIC (not relevant): 0
        Channel Index: 7
        RSSI: -63 dBm
        Event counter: 0
        Timestamp: 1891290858µs
        [Packet time (start to end): 152µs]
        [Delta time (end to start): 28396µs]
        [Delta time (start to start): 28748µs]
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        Control Opcode: LL_FEATURE_REQ (0x08)
        Feature Set: 0x00000000030079ef
            .... ...1 = LE Encryption: True
            .... ..1. = Connection Parameters Request Procedure: True
            .... .1.. = Extended Reject Indication: True
            .... 1... = Slave Initiated Features Exchange: True
            ...0 .... = LE Ping: False
            ..1. .... = LE Data Packet Length Extension: True
            .1.. .... = LL Privacy: True
            1... .... = Extended Scanner Filter Policies: True
            .... ...1 = LE 2M PHY: True
            .... ..0. = Stable Modulation Index - Transmitter: False
            .... .0.. = Stable Modulation Index - Receiver: False
            .... 1... = LE Coded PHY: True
            ...1 .... = LE Extended Advertising: True
            ..1. .... = LE Periodic Advertising: True
            .1.. .... = Channel Selection Algorithm #2: True
            0... .... = LE Power Class 1: False
            .... ...0 = Minimum Number of Used Channels Procedure: False
            .... ..0. = Connection CTE Request: False
            .... .0.. = Connection CTE Response: False
            .... 0... = Connectionless CTE Transmitter: False
            ...0 .... = Connectionless CTE Receiver: False
            ..0. .... = Antenna Switching During CTE Transmission (AoD): False
            .0.. .... = Antenna Switching During CTE Reception (AoA): False
            0... .... = Receiving Constant Tone Extensions: False
            .... ...1 = Periodic Advertising Sync Transfer - Sender: True
            .... ..1. = Periodic Advertising Sync Transfer - Receiver: True
            .... .0.. = Sleep Clock Accuracy Updates: False
            .... 0... = Remote Public Key Validation: False
            ...0 .... = Connected Isochronous Stream - Central: False
            ..0. .... = Connected Isochronous Stream - Peripheral: False
            .0.. .... = Isochronous Broadcaster: False
            0... .... = Synchronized Receiver: False
            .... ...0 = Connected Isochronous Stream (Host Support): False
            .... ..0. = LE Power Control Request: False
            .... .0.. = LE Power Control Request: False
            .... 0... = LE Path Loss Monitoring: False
            ...0 .... = Periodic Advertising ADI support: False
            ..0. .... = Connection Subrating: False
            .0.. .... = Connection Subrating (Host Support): False
            0... .... = Channel Classification: False
            .... ...0 = Advertising Coding Selection: False
            .... ..0. = Advertising Coding Selection (Host Support): False
            .... .0.. = Periodic Advertising with Responses - Advertiser: False
            .... 0... = Periodic Advertising with Responses - Scanner: False
            0000 .... = Reserved bits: 0
            Reserved: 000030
        [Response in Frame: 19]
        [Connection Parameters in: 9]
        CRC: 0x0c5e3e
         11 2.592719       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 11: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23682
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
            .... 1... = MIC (not relevant): 1
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 0
        Timestamp: 1891291160µs
        [Packet time (start to end): 80µs]
        [Delta time (start to start): 302µs]
        Data Header
        CRC: 0x87ece4
         12 2.592949       Master_0x4d08532d     Slave_0x4d08532d      LE LL    35                No                                  Control Opcode: LL_FEATURE_REQ
    Frame 12: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23683
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -63 dBm
        Event counter: 0
        Timestamp: 1891291390µs
        [Delta time (start to start): 230µs]
        Data Header
            Reserved: 0000f6
        CRC: 0x6fdf74
         13 2.593251       Slave_0x4d08532d      Master_0x4d08532d     LE LL    35                No                                  Control Opcode: LL_LENGTH_REQ
    Frame 13: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23684
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 0
        Timestamp: 1891291692µs
        Data Header
        Control Opcode: LL_LENGTH_REQ (0x14)
        Max RX octets: 251
        Max RX time: 2120 microseconds
        Max TX octets: 251
        Max TX time: 2120 microseconds
        [Response in Frame: 16]
        CRC: 0xdf0012
         14 2.637417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    35                No                                  Control Opcode: LL_FEATURE_REQ
    Frame 14: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23685
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -62 dBm
        Event counter: 1
        Timestamp: 1891335858µs
        [Delta time (end to start): 44014µs]
        [Delta time (start to start): 44166µs]
        Data Header
            Reserved: 000029
        CRC: 0x94bd41
         15 2.637720       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 15: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23686
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 1
        Timestamp: 1891336161µs
        [Delta time (end to start): 151µs]
        [Delta time (start to start): 303µs]
        Data Header
        CRC: 0x7e54e4
         16 2.637950       Master_0x4d08532d     Slave_0x4d08532d      LE LL    35                No                                  Control Opcode: LL_LENGTH_RSP
    Frame 16: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23687
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -62 dBm
        Event counter: 1
        Timestamp: 1891336391µs
        Data Header
        Control Opcode: LL_LENGTH_RSP (0x15)
        Max RX octets: 251
        Max TX octets: 27
        Max TX time: 328 microseconds
        [Request in Frame: 13]
        CRC: 0xdf0012
         17 2.638253       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 17: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23688
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 1
        Timestamp: 1891336693µs
        Data Header
        CRC: 0xd084e4
         18 2.682417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 18: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23689
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -67 dBm
        Event counter: 2
        Timestamp: 1891380858µs
        [Delta time (end to start): 44085µs]
        [Delta time (start to start): 44165µs]
        Data Header
        CRC: 0xb534e4
         19 2.682648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    35                No                                  Control Opcode: LL_FEATURE_RSP
    Frame 19: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23690
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 2
        Timestamp: 1891381089µs
        [Delta time (start to start): 231µs]
        Data Header
        Control Opcode: LL_FEATURE_RSP (0x09)
        Feature Set: 0x00000000000000ef
            .... ...0 = LE 2M PHY: False
            .... 0... = LE Coded PHY: False
            ...0 .... = LE Extended Advertising: False
            ..0. .... = LE Periodic Advertising: False
            .0.. .... = Channel Selection Algorithm #2: False
            .... ...0 = Periodic Advertising Sync Transfer - Sender: False
            .... ..0. = Periodic Advertising Sync Transfer - Receiver: False
            Reserved: 000029
        [Request in Frame: 10]
        CRC: 0x945a0c
         20 2.772417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    32                No                                  Control Opcode: LL_VERSION_IND
    Frame 20: 32 bytes on wire (256 bits), 32 bytes captured (256 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23691
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -69 dBm
        Event counter: 4
        Timestamp: 1891470858µs
        [Packet time (start to end): 128µs]
        [Delta time (end to start): 89617µs]
        [Delta time (start to start): 89769µs]
        Data Header
        Control Opcode: LL_VERSION_IND (0x0c)
        Version Number: 5.1 (0x0a)
        Company Id: Qualcomm (0x001d)
        Subversion Number: 0x39b6
        [Response in Frame: 27]
        CRC: 0x1417a9
         21 2.772695       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 21: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23692
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 4
        Timestamp: 1891471136µs
        [Delta time (start to start): 278µs]
        Data Header
        CRC: 0xd084e4
         22 2.817417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 22: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23693
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -64 dBm
        Event counter: 5
        Timestamp: 1891515858µs
        [Delta time (end to start): 44642µs]
        [Delta time (start to start): 44722µs]
        Data Header
        CRC: 0xb534e4
         23 2.817647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    35                No                                  Control Opcode: LL_SLAVE_FEATURE_REQ
    Frame 23: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23694
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 5
        Timestamp: 1891516088µs
        Data Header
        Control Opcode: LL_SLAVE_FEATURE_REQ (0x0e)
        Feature Set: 0x00000000000000ff
            ...1 .... = LE Ping: True
            Reserved: 000028
        [Response in Frame: 24]
        CRC: 0x141bf7
         24 2.862417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    35                No                                  Control Opcode: LL_FEATURE_RSP
    Frame 24: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23695
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -62 dBm
        Event counter: 6
        Timestamp: 1891560858µs
        [Delta time (end to start): 44618µs]
        [Delta time (start to start): 44770µs]
        Data Header
            Reserved: 000082
        [Request in Frame: 23]
        CRC: 0x41c619
         25 2.862721       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 25: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23696
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -46 dBm
        Event counter: 6
        Timestamp: 1891561161µs
        Data Header
        CRC: 0xd084e4
         26 2.907418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 26: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23697
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -63 dBm
        Event counter: 7
        Timestamp: 1891605858µs
        [Delta time (end to start): 44617µs]
        [Delta time (start to start): 44697µs]
        Data Header
        CRC: 0xb534e4
         27 2.907648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    32                No                                  Control Opcode: LL_VERSION_IND
    Frame 27: 32 bytes on wire (256 bits), 32 bytes captured (256 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23698
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 7
        Timestamp: 1891606088µs
        Data Header
        Version Number: 4.2 (0x08)
        Company Id: Broadcom Corporation (0x000f)
        Subversion Number: 0x420d
        [Request in Frame: 20]
        CRC: 0x2054cf
         28 3.042418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    38                No                                  Control Opcode: LL_CONNECTION_UPDATE_IND
    Frame 28: 38 bytes on wire (304 bits), 38 bytes captured (304 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23699
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -67 dBm
        Event counter: 10
        Timestamp: 1891740858µs
        [Packet time (start to end): 176µs]
        [Delta time (end to start): 134642µs]
        [Delta time (start to start): 134770µs]
        Data Header
        Control Opcode: LL_CONNECTION_UPDATE_IND (0x00)
        Window Size: 1 (1.25 msec)
        Window Offset: 0 (0 msec)
        Interval: 6 (7.5 msec)
        Latency: 0
        Timeout: 500 (5000 msec)
        Instant: 19
        CRC: 0x7e256c
         29 3.042745       Slave_0x4d08532d      Master_0x4d08532d     ATT      50                No         False                    Rcvd Read By Group Type Response, Attribute List Length: 3
    Frame 29: 50 bytes on wire (400 bits), 50 bytes captured (400 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23700
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 10
        Timestamp: 1891741185µs
        [Packet time (start to end): 272µs]
        [Delta time (start to start): 327µs]
        Data Header
        [L2CAP Index: 0]
        CRC: 0x16d875
    Bluetooth L2CAP Protocol
    Bluetooth Attribute Protocol
        Opcode: Read By Group Type Response (0x11)
            0... .... = Authentication Signature: False
            .0.. .... = Command: False
            ..01 0001 = Method: Read By Group Type Response (0x11)
        Length: 6
        Attribute Data, Handle: 0x0001, Group End Handle: 0x0005
            Handle: 0x0001 (Unknown)
            Value: 0018
        Attribute Data, Handle: 0x0006, Group End Handle: 0x000f
            Handle: 0x0006 (Unknown)
            Value: 0118
        Attribute Data, Handle: 0x0010, Group End Handle: 0x0012
            Handle: 0x0010 (Unknown)
            Value: 0a18
         30 3.043166       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 30: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23701
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -67 dBm
        Event counter: 10
        Timestamp: 1891741606µs
        [Delta time (end to start): 149µs]
        [Delta time (start to start): 421µs]
        Data Header
        CRC: 0x1be4e4
         31 3.043397       Slave_0x4d08532d      Master_0x4d08532d     ATT      33                No         False                    Rcvd Read Request, Handle: 0x0016 (Unknown)
    Frame 31: 33 bytes on wire (264 bits), 33 bytes captured (264 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23702
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 10
        Timestamp: 1891741837µs
        [Packet time (start to end): 136µs]
        Data Header
        [L2CAP Index: 1]
        CRC: 0xc92756
        Opcode: Read Request (0x0a)
            ..00 1010 = Method: Read Request (0x0a)
         32 3.087418       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Group Type Request, Primary Service, Handles: 0x0013..0xffff
    Frame 32: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23703
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -63 dBm
        Event counter: 11
        Timestamp: 1891785858µs
        [Packet time (start to end): 168µs]
        [Delta time (end to start): 43885µs]
        [Delta time (start to start): 44021µs]
        Data Header
        [L2CAP Index: 2]
        CRC: 0x68064a
        Opcode: Read By Group Type Request (0x10)
            ..01 0000 = Method: Read By Group Type Request (0x10)
        Starting Handle: 0x0013
        Ending Handle: 0xffff
        UUID: Primary Service (0x2800)
         33 3.087736       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 33: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23704
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -50 dBm
        Event counter: 11
        Timestamp: 1891786176µs
        [Delta time (start to start): 318µs]
        Data Header
        CRC: 0x7e54e4
         34 3.087966       Master_0x4d08532d     Slave_0x4d08532d      ATT      49                No         False                    Sent Read Response, Handle: 0x0016 (Unknown)
    Frame 34: 49 bytes on wire (392 bits), 49 bytes captured (392 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23705
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -63 dBm
        Event counter: 11
        Timestamp: 1891786406µs
        [Packet time (start to end): 264µs]
        Data Header
        [L2CAP Index: 3]
        CRC: 0x48e14f
        Opcode: Read Response (0x0b)
            ..00 1011 = Method: Read Response (0x0b)
        [Handle: 0x0016 (Unknown)]
        Value: 5265646d69204e6f7465203130204c697465
        [Request in Frame: 31]
         35 3.088380       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 35: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23706
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 11
        Timestamp: 1891786820µs
        [Delta time (start to start): 414µs]
        Data Header
        CRC: 0xd084e4
         36 3.132418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 36: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23707
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -64 dBm
        Event counter: 12
        Timestamp: 1891830858µs
        [Delta time (end to start): 43958µs]
        [Delta time (start to start): 44038µs]
        Data Header
        CRC: 0xb534e4
         37 3.132648       Slave_0x4d08532d      Master_0x4d08532d     ATT      52                No         False                    Rcvd Read By Group Type Response, Attribute List Length: 1, Unknown
    Frame 37: 52 bytes on wire (416 bits), 52 bytes captured (416 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23708
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -45 dBm
        Event counter: 12
        Timestamp: 1891831088µs
        [Packet time (start to end): 288µs]
        Data Header
        [L2CAP Index: 4]
        CRC: 0x9a0580
        Length: 20
        Attribute Data, Handle: 0x0013, Group End Handle: 0x0018, UUID128: Unknown
            Handle: 0x0013 (Unknown)
                [UUID: 00001811000210018011008044332211]
            UUID: 11223344800011800110020011180000
        [UUID: Primary Service (0x2800)]
        [Request in Frame: 32]
         38 3.133086       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 38: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23709
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -63 dBm
        Event counter: 12
        Timestamp: 1891831526µs
        [Delta time (start to start): 438µs]
        Data Header
        CRC: 0x1be4e4
         39 3.133316       Slave_0x4d08532d      Master_0x4d08532d     ATT      33                No         False                    Rcvd Read Request, Handle: 0x0018 (Unknown: Unknown)
    Frame 39: 33 bytes on wire (264 bits), 33 bytes captured (264 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23710
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 12
        Timestamp: 1891831756µs
        Data Header
        [L2CAP Index: 5]
        CRC: 0xf1310d
            [Service UUID: 00001811000210018011008044332211]
         40 3.177418       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Group Type Request, Primary Service, Handles: 0x0019..0xffff
    Frame 40: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23711
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -70 dBm
        Event counter: 13
        Timestamp: 1891875858µs
        [Delta time (end to start): 43966µs]
        [Delta time (start to start): 44102µs]
        Data Header
        [L2CAP Index: 6]
        CRC: 0x9c2fd5
        Starting Handle: 0x0019
         41 3.177736       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 41: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23712
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 13
        Timestamp: 1891876176µs
        Data Header
        CRC: 0x7e54e4
         42 3.177966       Master_0x4d08532d     Slave_0x4d08532d      ATT      33                No         False                    Sent Read Response, Handle: 0x0018 (Unknown: Unknown)
    Frame 42: 33 bytes on wire (264 bits), 33 bytes captured (264 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23713
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -70 dBm
        Event counter: 13
        Timestamp: 1891876406µs
        Data Header
        [L2CAP Index: 7]
        CRC: 0x2ba4f0
        [Handle: 0x0018 (Unknown: Unknown)]
        Value: 0000
        [Request in Frame: 39]
         43 3.178252       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 43: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23714
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 13
        Timestamp: 1891876692µs
        [Delta time (start to start): 286µs]
        Data Header
        CRC: 0xd084e4
         44 3.267418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 44: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23715
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -70 dBm
        Event counter: 15
        Timestamp: 1891965858µs
        [Delta time (end to start): 89086µs]
        [Delta time (start to start): 89166µs]
        Data Header
        CRC: 0xb534e4
         45 3.267648       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0019 (Unknown: Unknown)
    Frame 45: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23716
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 15
        Timestamp: 1891966088µs
        Data Header
        [L2CAP Index: 8]
        CRC: 0x5f6324
        Opcode: Error Response (0x01)
            ..00 0001 = Method: Error Response (0x01)
        Request Opcode in Error: Read By Group Type Request (0x10)
        Handle in Error: 0x0019 (Unknown: Unknown)
        Error Code: Attribute Not Found (0x0a)
         46 3.267950       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 46: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23717
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -70 dBm
        Event counter: 15
        Timestamp: 1891966390µs
        Data Header
        CRC: 0x1be4e4
         47 3.268180       Slave_0x4d08532d      Master_0x4d08532d     ATT      37                No         False                    Rcvd Read By Group Type Request, Primary Service, Handles: 0x0001..0xffff
    Frame 47: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23718
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -49 dBm
        Event counter: 15
        Timestamp: 1891966620µs
        Data Header
        [L2CAP Index: 9]
        CRC: 0xc28aeb
        Starting Handle: 0x0001
         48 3.312418       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Include, Handles: 0x0001..0x0005
    Frame 48: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23719
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -64 dBm
        Event counter: 16
        Timestamp: 1892010858µs
        [Delta time (end to start): 44070µs]
        [Delta time (start to start): 44238µs]
        Data Header
        [L2CAP Index: 10]
        CRC: 0x1cfd49
        Opcode: Read By Type Request (0x08)
            ..00 1000 = Method: Read By Type Request (0x08)
        Ending Handle: 0x0005
        UUID: Include (0x2802)
         49 3.312736       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 49: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23720
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 16
        Timestamp: 1892011176µs
        Data Header
        CRC: 0x7e54e4
         50 3.312966       Master_0x4d08532d     Slave_0x4d08532d      ATT      44                No         False                    Sent Read By Group Type Response, Attribute List Length: 2, Generic Attribute, Generic Access
    Frame 50: 44 bytes on wire (352 bits), 44 bytes captured (352 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23721
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -64 dBm
        Event counter: 16
        Timestamp: 1892011406µs
        [Packet time (start to end): 224µs]
        Data Header
        [L2CAP Index: 11]
        CRC: 0xc1c417
        Length: 6
        Attribute Data, Handle: 0x0001, Group End Handle: 0x0007, UUID: Generic Attribute
            Handle: 0x0001 (Generic Attribute)
                [UUID: Generic Attribute (0x1801)]
        Attribute Data, Handle: 0x0014, Group End Handle: 0x001a, UUID: Generic Access
            Handle: 0x0014 (Generic Access)
                [UUID: Generic Access (0x1800)]
        [Request in Frame: 47]
         51 3.313340       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 51: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23722
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 16
        Timestamp: 1892011780µs
        [Delta time (start to start): 374µs]
        Data Header
        CRC: 0xd084e4
         52 3.357419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 52: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23723
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -62 dBm
        Event counter: 17
        Timestamp: 1892055858µs
        [Delta time (end to start): 43998µs]
        [Delta time (start to start): 44078µs]
        Data Header
        CRC: 0xb534e4
         53 3.402419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 53: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23724
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -64 dBm
        Event counter: 18
        Timestamp: 1892100858µs
        [Delta time (end to start): 44920µs]
        [Delta time (start to start): 45000µs]
        Data Header
        CRC: 0xb534e4
         54 3.402649       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0001 (Generic Attribute)
    Frame 54: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23725
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 18
        Timestamp: 1892101088µs
        Data Header
        [L2CAP Index: 12]
        CRC: 0xd71bf6
        Request Opcode in Error: Read By Type Request (0x08)
        Handle in Error: 0x0001 (Generic Attribute)
        [UUID: Include (0x2802)]
         55 3.402951       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 55: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23726
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -65 dBm
        Event counter: 18
        Timestamp: 1892101390µs
        Data Header
        CRC: 0x1be4e4
         56 3.403181       Slave_0x4d08532d      Master_0x4d08532d     ATT      37                No         False                    Rcvd Read By Group Type Request, Primary Service, Handles: 0x001b..0xffff
    Frame 56: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23727
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 18
        Timestamp: 1892101620µs
        Data Header
        [L2CAP Index: 13]
        CRC: 0xfb5a77
        Starting Handle: 0x001b
         57 3.447419       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x0001..0x0005
    Frame 57: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23728
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -73 dBm
        Event counter: 19
        Timestamp: 1892145858µs
        Data Header
        [L2CAP Index: 14]
        [Connection Parameters in: 28]
        CRC: 0x3177a4
        UUID: Characteristic (0x2803)
         58 3.447738       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 58: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23729
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -44 dBm
        Event counter: 19
        Timestamp: 1892146177µs
        [Delta time (start to start): 319µs]
        Data Header
        CRC: 0x7e54e4
         59 3.447968       Master_0x4d08532d     Slave_0x4d08532d      ATT      52                No         False                    Sent Read By Group Type Response, Attribute List Length: 1, Unknown
    Frame 59: 52 bytes on wire (416 bits), 52 bytes captured (416 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23730
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -73 dBm
        Event counter: 19
        Timestamp: 1892146407µs
        Data Header
        [L2CAP Index: 15]
        CRC: 0x508911
        Length: 20
        Attribute Data, Handle: 0x0028, Group End Handle: 0xffff, UUID128: Unknown
            Handle: 0x0028 (Unknown)
                [UUID: a3c87600000510008000001a11000100]
            UUID: 000100111a000080001005000076c8a3
        [Request in Frame: 56]
         60 3.448406       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 60: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23731
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 19
        Timestamp: 1892146845µs
        Data Header
        CRC: 0xd084e4
         61 3.454919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    35                No                                  Control Opcode: LL_LENGTH_REQ
    Frame 61: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23732
        Flags: 0x02
            .... ...0 = CRC: Error
                [Expert Info (Error/Checksum): CRC is bad]
                    [CRC is bad]
                    [Severity level: Error]
                    [Group: Checksum]
        Channel Index: 36
        RSSI: -75 dBm
        Event counter: 20
        Timestamp: 1892153358µs
        [Delta time (end to start): 6433µs]
        [Delta time (start to start): 6513µs]
        Data Header
        Max RX octets: 251
        Max TX octets: 251
        [Response in Frame: 66]
        CRC: 0xdf0012
            [Expert Info (Warning/Checksum): Incorrect CRC]
                [Incorrect CRC]
                [Severity level: Warning]
                [Group: Checksum]
         62 3.455222       Slave_0x4d08532d      Master_0x4d08532d     ATT      46                No         False                    Rcvd Read By Type Response, Attribute List Length: 2, Device Name, Appearance
    Frame 62: 46 bytes on wire (368 bits), 46 bytes captured (368 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23733
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 20
        Timestamp: 1892153661µs
        [Packet time (start to end): 240µs]
        Data Header
        [L2CAP Index: 16]
        CRC: 0xa7245f
        Opcode: Read By Type Response (0x09)
            ..00 1001 = Method: Read By Type Response (0x09)
        Length: 7
        Attribute Data, Handle: 0x0002, Characteristic Handle: 0x0003, UUID: Device Name
            Handle: 0x0002 (Generic Attribute: Characteristic)
                [Service UUID: Generic Attribute (0x1801)]
                [UUID: Characteristic (0x2803)]
            Characteristic Properties: 0x02, Read
            Characteristic Value Handle: 0x0003 (Generic Attribute: Device Name)
                [UUID: Device Name (0x2a00)]
        Attribute Data, Handle: 0x0004, Characteristic Handle: 0x0005, UUID: Appearance
            Handle: 0x0004 (Generic Attribute: Device Name: Characteristic)
                [Characteristic UUID: Device Name (0x2a00)]
            Characteristic Value Handle: 0x0005 (Generic Attribute: Appearance)
                [UUID: Appearance (0x2a01)]
        [Request in Frame: 57]
         63 3.462419       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x0005..0x0005
    Frame 63: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23734
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -69 dBm
        Event counter: 21
        Timestamp: 1892160858µs
        [Delta time (end to start): 6957µs]
        [Delta time (start to start): 7197µs]
        Data Header
        [L2CAP Index: 17]
        CRC: 0x1051a5
        Starting Handle: 0x0005
         64 3.462738       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 64: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23735
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -57 dBm
        Event counter: 21
        Timestamp: 1892161177µs
        Data Header
        CRC: 0xd084e4
         65 3.469919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 65: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23736
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -63 dBm
        Event counter: 22
        Timestamp: 1892168358µs
        [Delta time (end to start): 7101µs]
        [Delta time (start to start): 7181µs]
        Data Header
        CRC: 0xb534e4
         66 3.470149       Slave_0x4d08532d      Master_0x4d08532d     LE LL    35                No                                  Control Opcode: LL_LENGTH_RSP
    Frame 66: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23737
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 22
        Timestamp: 1892168588µs
        Data Header
        Max RX octets: 251
        Max TX octets: 251
        [Request in Frame: 61]
        CRC: 0xdf0012
         67 3.477419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 67: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23738
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -63 dBm
        Event counter: 23
        Timestamp: 1892175858µs
        [Delta time (end to start): 7118µs]
        [Delta time (start to start): 7270µs]
        Data Header
        CRC: 0x1be4e4
         68 3.477649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 68: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23739
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 23
        Timestamp: 1892176088µs
        Data Header
        CRC: 0xd084e4
         69 3.484919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 69: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23740
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -71 dBm
        Event counter: 24
        Timestamp: 1892183358µs
        [Delta time (end to start): 7190µs]
        Data Header
        CRC: 0xb534e4
         70 3.485149       Slave_0x4d08532d      Master_0x4d08532d     ATT      34                No         False                    Rcvd Write Request, Handle: 0x0007 (Generic Attribute: Appearance: Unknown)
    Frame 70: 34 bytes on wire (272 bits), 34 bytes captured (272 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23741
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -44 dBm
        Event counter: 24
        Timestamp: 1892183588µs
        [Packet time (start to end): 144µs]
        Data Header
        [L2CAP Index: 18]
        CRC: 0xea7c4c
        Opcode: Write Request (0x12)
            ..01 0010 = Method: Write Request (0x12)
            [Characteristic UUID: Appearance (0x2a01)]
        Value: 07
         71 3.485443       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 71: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23742
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -72 dBm
        Event counter: 24
        Timestamp: 1892183882µs
        [Delta time (start to start): 294µs]
        Data Header
        CRC: 0x1be4e4
         72 3.492419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 72: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23743
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -76 dBm
        Event counter: 25
        Timestamp: 1892190858µs
        [Delta time (end to start): 6896µs]
        [Delta time (start to start): 6976µs]
        Data Header
        CRC: 0x1be4e4
         73 3.492650       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0005 (Generic Attribute: Appearance)
    Frame 73: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23744
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 25
        Timestamp: 1892191089µs
        Data Header
        [L2CAP Index: 19]
        CRC: 0x7f3a13
        Handle in Error: 0x0005 (Generic Attribute: Appearance)
         74 3.499919       Master_0x4d08532d     Slave_0x4d08532d      ATT      31                No         False                    Sent Write Response, Handle: 0x0007 (Generic Attribute: Appearance: Unknown)
    Frame 74: 31 bytes on wire (248 bits), 31 bytes captured (248 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23745
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -70 dBm
        Event counter: 26
        Timestamp: 1892198358µs
        [Packet time (start to end): 120µs]
        [Delta time (end to start): 7117µs]
        [Delta time (start to start): 7269µs]
        Data Header
        [L2CAP Index: 20]
        CRC: 0xa5d15c
        Opcode: Write Response (0x13)
            ..01 0011 = Method: Write Response (0x13)
        [Handle: 0x0007 (Generic Attribute: Appearance: Unknown)]
        [Request in Frame: 70]
         75 3.500189       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 75: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23746
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 26
        Timestamp: 1892198628µs
        [Delta time (start to start): 270µs]
        Data Header
        CRC: 0x7e54e4
         76 3.500419       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Include, Handles: 0x0006..0x000f
    Frame 76: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23747
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -70 dBm
        Event counter: 26
        Timestamp: 1892198858µs
        Data Header
        [L2CAP Index: 21]
        CRC: 0xc8e172
        Starting Handle: 0x0006
        Ending Handle: 0x000f
         77 3.507419       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Include, Handles: 0x0006..0x000f
    Frame 77: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23748
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -64 dBm
        Event counter: 27
        Timestamp: 1892205858µs
        [Delta time (end to start): 6832µs]
        [Delta time (start to start): 7000µs]
        Data Header
        [L2CAP Index: 22]
        CRC: 0xc8e172
         78 3.507738       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 78: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23749
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 27
        Timestamp: 1892206177µs
        Data Header
        CRC: 0xd084e4
         79 3.514919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 79: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23750
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -63 dBm
        Event counter: 28
        Timestamp: 1892213358µs
        Data Header
        CRC: 0xb534e4
         80 3.515149       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0006 (Generic Attribute: Appearance: Unknown)
    Frame 80: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23751
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -43 dBm
        Event counter: 28
        Timestamp: 1892213588µs
        Data Header
        [L2CAP Index: 23]
        CRC: 0x627699
        Handle in Error: 0x0006 (Generic Attribute: Appearance: Unknown)
         81 3.522419       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x0006..0x000f
    Frame 81: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23752
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -70 dBm
        Event counter: 29
        Timestamp: 1892220858µs
        Data Header
        [L2CAP Index: 24]
        CRC: 0xe56b9f
         82 3.522737       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 82: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23753
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 29
        Timestamp: 1892221176µs
        Data Header
        CRC: 0xd084e4
         83 3.529919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 83: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23754
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -77 dBm
        Event counter: 30
        Timestamp: 1892228358µs
        [Delta time (end to start): 7102µs]
        [Delta time (start to start): 7182µs]
        Data Header
        CRC: 0xb534e4
         84 3.530149       Slave_0x4d08532d      Master_0x4d08532d     ATT      53                No         False                    Rcvd Read By Type Response, Attribute List Length: 3, Service Changed, Client Supported Features, Server Supported Features
    Frame 84: 53 bytes on wire (424 bits), 53 bytes captured (424 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23755
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 30
        Timestamp: 1892228588µs
        Data Header
        [L2CAP Index: 25]
        CRC: 0x9b9746
        Length: 7
        Attribute Data, Handle: 0x0007, Characteristic Handle: 0x0008, UUID: Service Changed
            Handle: 0x0007 (Generic Attribute: Appearance: Characteristic)
            Characteristic Properties: 0x20, Indicate
            Characteristic Value Handle: 0x0008 (Generic Attribute: Service Changed)
                [UUID: Service Changed (0x2a05)]
        Attribute Data, Handle: 0x000a, Characteristic Handle: 0x000b, UUID: Client Supported Features
            Handle: 0x000a (Generic Attribute: Service Changed: Characteristic)
                [Characteristic UUID: Service Changed (0x2a05)]
            Characteristic Properties: 0x0a, Write, Read
            Characteristic Value Handle: 0x000b (Generic Attribute: Client Supported Features)
                [UUID: Client Supported Features (0x2b29)]
        Attribute Data, Handle: 0x000c, Characteristic Handle: 0x000d, UUID: Server Supported Features
            Handle: 0x000c (Generic Attribute: Client Supported Features: Characteristic)
                [Characteristic UUID: Client Supported Features (0x2b29)]
            Characteristic Value Handle: 0x000d (Generic Attribute: Server Supported Features)
                [UUID: Server Supported Features (0x2b3a)]
        [Request in Frame: 81]
         85 3.537419       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x000d..0x000f
    Frame 85: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23756
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -71 dBm
        Event counter: 31
        Timestamp: 1892235858µs
        [Delta time (end to start): 6974µs]
        Data Header
        [L2CAP Index: 26]
        CRC: 0xcef984
        Starting Handle: 0x000d
         86 3.537738       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 86: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23757
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 31
        Timestamp: 1892236177µs
        Data Header
        CRC: 0xd084e4
         87 3.544919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 87: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23758
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -65 dBm
        Event counter: 32
        Timestamp: 1892243358µs
        Data Header
        CRC: 0xb534e4
         88 3.545149       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x000d (Generic Attribute: Server Supported Features)
    Frame 88: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23759
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 32
        Timestamp: 1892243588µs
        Data Header
        [L2CAP Index: 27]
        CRC: 0x9c396b
        Handle in Error: 0x000d (Generic Attribute: Server Supported Features)
         89 3.552419       Master_0x4d08532d     Slave_0x4d08532d      ATT      35                No         False                    Sent Find Information Request, Handles: 0x0009..0x0009
    Frame 89: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23760
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -64 dBm
        Event counter: 33
        Timestamp: 1892250858µs
        Data Header
        [L2CAP Index: 28]
        CRC: 0x0e8d3e
        Opcode: Find Information Request (0x04)
            ..00 0100 = Method: Find Information Request (0x04)
        Starting Handle: 0x0009
        Ending Handle: 0x0009
         90 3.552722       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 90: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23761
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 33
        Timestamp: 1892251161µs
        Data Header
        CRC: 0xd084e4
         91 3.559919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 91: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23762
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -68 dBm
        Event counter: 34
        Timestamp: 1892258358µs
        Data Header
        CRC: 0xb534e4
         92 3.560149       Slave_0x4d08532d      Master_0x4d08532d     ATT      36                No         False                    Rcvd Find Information Response, Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)
    Frame 92: 36 bytes on wire (288 bits), 36 bytes captured (288 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23763
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 34
        Timestamp: 1892258588µs
        [Packet time (start to end): 160µs]
        Data Header
        [L2CAP Index: 29]
        CRC: 0x1a2c3b
        Opcode: Find Information Response (0x05)
            ..00 0101 = Method: Find Information Response (0x05)
        UUID Format: 16-bit UUIDs (0x01)
        Information Data, Handle: 0x0009, UUID: Client Characteristic Configuration
                [UUID: Client Characteristic Configuration (0x2902)]
        [Request in Frame: 89]
         93 3.574919       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 93: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23764
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -72 dBm
        Event counter: 36
        Timestamp: 1892273358µs
        [Delta time (end to start): 14610µs]
        [Delta time (start to start): 14770µs]
        Data Header
        CRC: 0xb534e4
         94 3.575150       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x000e (Generic Attribute: Server Supported Features: Unknown)
    Frame 94: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23765
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -49 dBm
        Event counter: 36
        Timestamp: 1892273588µs
        Data Header
        [L2CAP Index: 30]
        CRC: 0x100213
        Request Opcode in Error: Find Information Request (0x04)
        Handle in Error: 0x000e (Generic Attribute: Server Supported Features: Unknown)
            [Characteristic UUID: Server Supported Features (0x2b3a)]
         95 3.582420       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Include, Handles: 0x0010..0x0012
    Frame 95: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23766
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -67 dBm
        Event counter: 37
        Timestamp: 1892280858µs
        Data Header
        [L2CAP Index: 31]
        CRC: 0x360b89
        Starting Handle: 0x0010
        Ending Handle: 0x0012
         96 3.582739       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 96: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23767
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 37
        Timestamp: 1892281177µs
        Data Header
        CRC: 0xd084e4
         97 3.589920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 97: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23768
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -64 dBm
        Event counter: 38
        Timestamp: 1892288358µs
        Data Header
        CRC: 0xb534e4
         98 3.590150       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0010 (Generic Attribute: Server Supported Features: Unknown)
    Frame 98: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23769
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 38
        Timestamp: 1892288588µs
        Data Header
        [L2CAP Index: 32]
        CRC: 0x1d5160
        Handle in Error: 0x0010 (Generic Attribute: Server Supported Features: Unknown)
         99 3.597420       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x0010..0x0012
    Frame 99: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23770
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -65 dBm
        Event counter: 39
        Timestamp: 1892295858µs
        Data Header
        [L2CAP Index: 33]
        CRC: 0x1b8164
        100 3.597739       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 100: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23771
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 39
        Timestamp: 1892296177µs
        Data Header
        CRC: 0xd084e4
        101 3.604920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 101: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23772
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -75 dBm
        Event counter: 40
        Timestamp: 1892303358µs
        Data Header
        CRC: 0xb534e4
        102 3.605150       Slave_0x4d08532d      Master_0x4d08532d     ATT      39                No         False                    Rcvd Read By Type Response, Attribute List Length: 1, PnP ID
    Frame 102: 39 bytes on wire (312 bits), 39 bytes captured (312 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23773
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -44 dBm
        Event counter: 40
        Timestamp: 1892303588µs
        [Packet time (start to end): 184µs]
        Data Header
        [L2CAP Index: 34]
        CRC: 0x21e510
        Length: 7
        Attribute Data, Handle: 0x0011, Characteristic Handle: 0x0012, UUID: PnP ID
            Handle: 0x0011 (Generic Attribute: Server Supported Features: Characteristic)
            Characteristic Value Handle: 0x0012 (Generic Attribute: PnP ID)
                [UUID: PnP ID (0x2a50)]
        [Request in Frame: 99]
        103 3.612420       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x0012..0x0012
    Frame 103: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23774
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -75 dBm
        Event counter: 41
        Timestamp: 1892310858µs
        [Delta time (end to start): 7086µs]
        Data Header
        [L2CAP Index: 35]
        CRC: 0x745ca6
        Starting Handle: 0x0012
        104 3.612739       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 104: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23775
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 41
        Timestamp: 1892311177µs
        Data Header
        CRC: 0xd084e4
        105 3.619920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 105: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23776
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -70 dBm
        Event counter: 42
        Timestamp: 1892318358µs
        Data Header
        CRC: 0xb534e4
        106 3.620151       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0012 (Generic Attribute: PnP ID)
    Frame 106: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23777
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 42
        Timestamp: 1892318589µs
        Data Header
        [L2CAP Index: 36]
        CRC: 0xd8578a
        Handle in Error: 0x0012 (Generic Attribute: PnP ID)
        107 3.627420       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Include, Handles: 0x0013..0x0018
    Frame 107: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23778
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -64 dBm
        Event counter: 43
        Timestamp: 1892325858µs
        Data Header
        [L2CAP Index: 37]
        CRC: 0xc331b3
        Ending Handle: 0x0018
        108 3.627738       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 108: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23779
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 43
        Timestamp: 1892326176µs
        Data Header
        CRC: 0xd084e4
        109 3.634920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 109: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23780
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -62 dBm
        Event counter: 44
        Timestamp: 1892333358µs
        Data Header
        CRC: 0xb534e4
        110 3.635150       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0013 (Unknown)
    Frame 110: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23781
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 44
        Timestamp: 1892333588µs
        Data Header
        [L2CAP Index: 38]
        CRC: 0x525c05
        Handle in Error: 0x0013 (Unknown)
        111 3.642420       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x0013..0x0018
    Frame 111: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23782
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -72 dBm
        Event counter: 45
        Timestamp: 1892340858µs
        Data Header
        [L2CAP Index: 39]
        CRC: 0xeebb5e
        112 3.642739       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 112: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23783
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -44 dBm
        Event counter: 45
        Timestamp: 1892341177µs
        Data Header
        CRC: 0xd084e4
        113 3.649920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU[Malformed Packet]
    Frame 113: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23784
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 33
        RSSI: -76 dBm
        Event counter: 46
        Timestamp: 1892348358µs
        Data Header
    [Malformed Packet: BT LE LL]
        [Expert Info (Error/Malformed): Malformed Packet (Exception occurred)]
            [Malformed Packet (Exception occurred)]
            [Group: Malformed]
        114 3.650151       Slave_0x4d08532d      Master_0x4d08532d     ATT      74                No         False                    Rcvd Read By Type Response, Attribute List Length: 2, Unknown, Unknown
    Frame 114: 74 bytes on wire (592 bits), 74 bytes captured (592 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23785
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 46
        Timestamp: 1892348589µs
        [Packet time (start to end): 464µs]
        Data Header
        [L2CAP Index: 40]
        CRC: 0x42feb6
        [Expert Info (Warning/Protocol): Packet size exceed current ATT_MTU]
            [Packet size exceed current ATT_MTU]
            [Group: Protocol]
        Length: 21
        Attribute Data, Handle: 0x0014, Characteristic Handle: 0x0015, UUID128: Unknown
            Handle: 0x0014 (Unknown: Characteristic)
            Characteristic Properties: 0x04, Write without Response
            Characteristic Value Handle: 0x0015 (Unknown: Unknown)
                [UUID: 00001811000310018022008044332211]
            UUID: 11223344800022800110030011180000
        Attribute Data, Handle: 0x0016, Characteristic Handle: 0x0017, UUID128: Unknown
            Handle: 0x0016 (Unknown: Unknown: Characteristic)
                [Characteristic UUID: 00001811000310018022008044332211]
            Characteristic Properties: 0x12, Notify, Read
            Characteristic Value Handle: 0x0017 (Unknown: Unknown)
                [UUID: 00001811000210018022008044332211]
            UUID: 11223344800022800110020011180000
        [Request in Frame: 111]
        115 3.657420       Master_0x4d08532d     Slave_0x4d08532d      ATT      37                No         False                    Sent Read By Type Request, Characteristic, Handles: 0x0017..0x0018
    Frame 115: 37 bytes on wire (296 bits), 37 bytes captured (296 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23786
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -70 dBm
        Event counter: 47
        Timestamp: 1892355858µs
        [Delta time (end to start): 6805µs]
        Data Header
        [L2CAP Index: 41]
        CRC: 0xd955bf
        Starting Handle: 0x0017
        116 3.657738       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 116: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23787
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -49 dBm
        Event counter: 47
        Timestamp: 1892356176µs
        Data Header
        CRC: 0xd084e4
        117 3.664920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 117: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23788
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -65 dBm
        Event counter: 48
        Timestamp: 1892363358µs
        Data Header
        CRC: 0xb534e4
        118 3.665151       Slave_0x4d08532d      Master_0x4d08532d     ATT      35                No         False,False              Rcvd Error Response - Attribute Not Found, Handle: 0x0017 (Unknown: Unknown)
    Frame 118: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23789
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 48
        Timestamp: 1892363589µs
        Data Header
        [L2CAP Index: 42]
        CRC: 0x30df70
        Handle in Error: 0x0017 (Unknown: Unknown)
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
        119 3.672420       Master_0x4d08532d     Slave_0x4d08532d      ATT      35                No         False                    Sent Find Information Request, Handles: 0x0018..0x0018
    Frame 119: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 23790
        Length of packet: 10
        Flags: 0x03
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 17
        RSSI: -64 dBm
        Event counter: 49
        Timestamp: 1892370858µs
    Bluetooth Low Energy Link Layer
        Data Header
        [L2CAP Index: 43]
        CRC: 0xb9c915
        Starting Handle: 0x0018
        120 3.672722       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 120: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23791
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 49
        Timestamp: 1892371160µs
        Data Header
        CRC: 0xd084e4
        121 3.679920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 121: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23792
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -69 dBm
        Event counter: 50
        Timestamp: 1892378358µs
        [Delta time (start to start): 7198µs]
        Data Header
        CRC: 0xb534e4
        122 3.680150       Slave_0x4d08532d      Master_0x4d08532d     ATT      36                No         False                    Rcvd Find Information Response, Handle: 0x0018 (Unknown: Unknown: Client Characteristic Configuration)
    Frame 122: 36 bytes on wire (288 bits), 36 bytes captured (288 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23793
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -45 dBm
        Event counter: 50
        Timestamp: 1892378588µs
        Data Header
        [L2CAP Index: 44]
        CRC: 0xb23afd
        Information Data, Handle: 0x0018, UUID: Client Characteristic Configuration
                [Characteristic UUID: 00001811000210018022008044332211]
        [Request in Frame: 119]
        123 3.687420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    50                No                                  Control Opcode: LL_REJECT_IND
    Frame 123: 50 bytes on wire (400 bits), 50 bytes captured (400 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23794
        Flags: 0x02
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 31
        RSSI: -78 dBm
        Event counter: 51
        Timestamp: 1892385858µs
        [Delta time (end to start): 7110µs]
        Data Header
        Control Opcode: LL_REJECT_IND (0x0d)
            [Expert Info (Error/Protocol): Incorrect control procedure packet sequencing or direction]
                [Incorrect control procedure packet sequencing or direction]
                [Group: Protocol]
        Error Code: LMP PDU Not Allowed (0x24)
        CRC: 0x002400
                [Incorrect CRC]
                [Group: Checksum]
        124 3.687842       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 124: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23795
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -44 dBm
        Event counter: 51
        Timestamp: 1892386280µs
        [Delta time (start to start): 422µs]
        Data Header
        CRC: 0xd084e4
        125 3.694920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 125: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23796
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -71 dBm
        Event counter: 52
        Timestamp: 1892393358µs
        [Delta time (end to start): 6998µs]
        [Delta time (start to start): 7078µs]
        Data Header
        CRC: 0xb534e4
        126 3.695151       Slave_0x4d08532d      Master_0x4d08532d     LE LL    50                No                                  Control Opcode: LL_CONNECTION_PARAM_RSP
    Frame 126: 50 bytes on wire (400 bits), 50 bytes captured (400 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23797
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -49 dBm
        Event counter: 52
        Timestamp: 1892393589µs
        Data Header
        Control Opcode: LL_CONNECTION_PARAM_RSP (0x10)
                [Group: Protocol]
        Interval Min: 36
        Interval Max: 36
        Latency: 0
        Timeout: 500
        Preferred Periodicity: 0
        Reference Connection Event Count: 51
        Offset 0: 24
        Offset 1: 65535
        Offset 2: 65535
        Offset 3: 65535
        Offset 4: 65535
        Offset 5: 65535
        CRC: 0x5b225c
        127 3.702420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    38                No                                  Control Opcode: LL_CONNECTION_UPDATE_IND
    Frame 127: 38 bytes on wire (304 bits), 38 bytes captured (304 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23798
        Flags: 0x03
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
            .... .0.. = Encrypted: No
            .... 0... = MIC (not relevant): 0
        Channel Index: 8
        RSSI: -66 dBm
        Event counter: 53
        Timestamp: 1892400858µs
        [Delta time (end to start): 6997µs]
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        Window Offset: 30 (37.5 msec)
        Interval: 36 (45 msec)
        Latency: 0
        Instant: 62
        CRC: 0xdf73bf
        128 3.702746       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 128: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23799
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 53
        Timestamp: 1892401184µs
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 326µs]
        Data Header
        CRC: 0xd084e4
        129 3.709920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 129: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23800
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -65 dBm
        Event counter: 54
        Timestamp: 1892408358µs
        [Delta time (end to start): 7094µs]
        [Delta time (start to start): 7174µs]
        Data Header
        CRC: 0xb534e4
        130 3.710150       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 130: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23801
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 54
        Timestamp: 1892408588µs
        Data Header
        CRC: 0x7e54e4
        131 3.717420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 131: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23802
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -66 dBm
        Event counter: 55
        Timestamp: 1892415858µs
        Data Header
        CRC: 0x1be4e4
        132 3.717650       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 132: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23803
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 55
        Timestamp: 1892416088µs
        Data Header
        CRC: 0xd084e4
        133 3.724920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 133: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23804
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
            .... 1... = MIC (not relevant): 1
        Channel Index: 29
        RSSI: -78 dBm
        Event counter: 56
        Timestamp: 1892423358µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0xb534e0
                [Incorrect CRC]
                [Group: Checksum]
        134 3.725151       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 134: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23805
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 56
        Timestamp: 1892423589µs
        Data Header
        CRC: 0x7e54e4
        135 3.732420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 135: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23806
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -77 dBm
        Event counter: 57
        Timestamp: 1892430858µs
        [Delta time (end to start): 7189µs]
        Data Header
        CRC: 0x1be4e4
        136 3.732650       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 136: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23807
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 57
        Timestamp: 1892431088µs
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0xd084e4
        137 3.739920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 137: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23808
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -69 dBm
        Event counter: 58
        Timestamp: 1892438358µs
        Data Header
        CRC: 0xb534e4
        138 3.740151       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 138: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23809
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -55 dBm
        Event counter: 58
        Timestamp: 1892438589µs
        [Delta time (end to start): 151µs]
        Data Header
        CRC: 0x7e54e4
        139 3.747420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 139: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23810
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -64 dBm
        Event counter: 59
        Timestamp: 1892445858µs
        Data Header
        CRC: 0x1be4e4
        140 3.747650       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 140: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23811
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 59
        Timestamp: 1892446088µs
        Data Header
        CRC: 0xd084e4
        141 3.754920       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 141: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23812
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -63 dBm
        Event counter: 60
        Timestamp: 1892453358µs
        Data Header
        CRC: 0xb534e4
        142 3.755150       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 142: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23813
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 60
        Timestamp: 1892453588µs
        Data Header
        CRC: 0x7e54e4
        143 3.762420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 143: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23814
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -73 dBm
        Event counter: 61
        Timestamp: 1892460858µs
        [Delta time (end to start): 7190%C2%B5s]
        Data Header
        CRC: 0x1be4e4
        144 3.762651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 144: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23815
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -43 dBm
        Event counter: 61
        Timestamp: 1892461088µs
        Data Header
        CRC: 0xd084e4
        145 3.807421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 145: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23816
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 34
        RSSI: -76 dBm
        Event counter: 62
        Timestamp: 1892505858µs
        [Delta time (end to start): 44690µs]
        Data Header
        [Connection Parameters in: 127]
        CRC: 0xf534e4
                [Incorrect CRC]
                [Group: Checksum]
        146 3.807651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 146: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23817
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 62
        Timestamp: 1892506088µs
        Data Header
        CRC: 0x7e54e4
        147 3.852421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 147: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23818
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -70 dBm
        Event counter: 63
        Timestamp: 1892550858µs
        Data Header
        CRC: 0x1be4e4
        148 3.852651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 148: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23819
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 63
        Timestamp: 1892551088µs
        Data Header
        CRC: 0xd084e4
        149 3.897421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 149: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23820
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -64 dBm
        Event counter: 64
        Timestamp: 1892595858µs
        Data Header
        CRC: 0xb534e4
        150 3.897651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 150: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23821
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 64
        Timestamp: 1892596088µs
        Data Header
        CRC: 0x7e54e4
        151 3.942421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 151: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23822
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -63 dBm
        Event counter: 65
        Timestamp: 1892640858µs
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0x1be4e4
        152 3.942651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 152: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23823
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 65
        Timestamp: 1892641088µs
        Data Header
        CRC: 0xd084e4
        153 3.987421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 153: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23824
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -66 dBm
        Event counter: 66
        Timestamp: 1892685858µs
        Data Header
        CRC: 0xb534e4
        154 3.987651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 154: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23825
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 66
        Timestamp: 1892686088µs
        Data Header
        CRC: 0x7e54e4
        155 4.032421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 155: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23826
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -72 dBm
        Event counter: 67
        Timestamp: 1892730858µs
        Data Header
        CRC: 0x1be4e4
        156 4.032652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 156: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23827
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 67
        Timestamp: 1892731089µs
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0xd084e4
        157 4.077421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 157: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23828
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -70 dBm
        Event counter: 68
        Timestamp: 1892775858µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0xb534e4
        158 4.077652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 158: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23829
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 68
        Timestamp: 1892776089µs
        Data Header
        CRC: 0x7e54e4
        159 4.122421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 159: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23830
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -65 dBm
        Event counter: 69
        Timestamp: 1892820858µs
        Data Header
        CRC: 0x1be4e4
        160 4.122651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 160: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23831
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 69
        Timestamp: 1892821088µs
        Data Header
        CRC: 0xd084e4
        161 4.167421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 161: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23832
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -63 dBm
        Event counter: 70
        Timestamp: 1892865858µs
        Data Header
        CRC: 0xb534e4
        162 4.167652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 162: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23833
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -43 dBm
        Event counter: 70
        Timestamp: 1892866089µs
        Data Header
        CRC: 0x7e54e4
        163 4.212421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 163: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23834
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -65 dBm
        Event counter: 71
        Timestamp: 1892910858µs
        Data Header
        CRC: 0x1be4e4
        164 4.212651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 164: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23835
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 71
        Timestamp: 1892911088µs
        Data Header
        CRC: 0xd084e4
        165 4.302421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 165: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23836
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -73 dBm
        Event counter: 73
        Timestamp: 1893000858µs
        [Delta time (end to start): 89690µs]
        [Delta time (start to start): 89770µs]
        Data Header
        CRC: 0x1be4e4
        166 4.302651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 166: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23837
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -49 dBm
        Event counter: 73
        Timestamp: 1893001088µs
        Data Header
        CRC: 0xd084e4
        167 4.347421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 167: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23838
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -66 dBm
        Event counter: 74
        Timestamp: 1893045858µs
        Data Header
        CRC: 0xb534e4
        168 4.347652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 168: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23839
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 74
        Timestamp: 1893046089µs
        Data Header
        CRC: 0x7e54e4
        169 4.392421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 169: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23840
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -63 dBm
        Event counter: 75
        Timestamp: 1893090858µs
        Data Header
        CRC: 0x1be4e4
        170 4.392653       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 170: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23841
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 75
        Timestamp: 1893091089µs
        Data Header
        CRC: 0xd084e4
        171 4.437422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 171: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23842
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -66 dBm
        Event counter: 76
        Timestamp: 1893135858µs
        Data Header
        CRC: 0xb534e4
        172 4.437652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 172: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23843
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 76
        Timestamp: 1893136088µs
        Data Header
        CRC: 0x7e54e4
        173 4.527422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 173: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23844
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -76 dBm
        Event counter: 78
        Timestamp: 1893225858µs
        Data Header
        CRC: 0xb534e4
        174 4.527652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 174: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23845
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -51 dBm
        Event counter: 78
        Timestamp: 1893226088µs
        Data Header
        CRC: 0x7e54e4
        175 4.572422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 175: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23846
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -67 dBm
        Event counter: 79
        Timestamp: 1893270858µs
        Data Header
        CRC: 0x1be4e4
        176 4.572653       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 176: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23847
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 79
        Timestamp: 1893271089µs
        Data Header
        CRC: 0xd084e4
        177 4.617422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 177: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23848
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -62 dBm
        Event counter: 80
        Timestamp: 1893315858µs
        Data Header
        CRC: 0xb534e4
        178 4.617652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 178: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23849
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -46 dBm
        Event counter: 80
        Timestamp: 1893316088µs
        Data Header
        CRC: 0x7e54e4
        179 4.662422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 179: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23850
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -61 dBm
        Event counter: 81
        Timestamp: 1893360858µs
        Data Header
        CRC: 0x1be4e4
        180 4.662652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 180: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23851
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 81
        Timestamp: 1893361088µs
        Data Header
        CRC: 0xd084e4
        181 4.707422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 181: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23852
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -70 dBm
        Event counter: 82
        Timestamp: 1893405858µs
        Data Header
        CRC: 0xb534e4
        182 4.707653       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 182: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23853
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 82
        Timestamp: 1893406089µs
        Data Header
        CRC: 0x7e54e4
        183 4.752422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 183: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23854
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -77 dBm
        Event counter: 83
        Timestamp: 1893450858µs
        Data Header
        CRC: 0x1be4e4
        184 4.752652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 184: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23855
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 83
        Timestamp: 1893451088µs
        Data Header
        CRC: 0xd084e4
        185 4.797422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 185: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23856
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -71 dBm
        Event counter: 84
        Timestamp: 1893495858µs
        Data Header
        CRC: 0xb534e4
        186 4.797652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 186: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23857
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -51 dBm
        Event counter: 84
        Timestamp: 1893496088µs
        Data Header
        CRC: 0x7e54e4
        187 4.842422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 187: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23858
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -63 dBm
        Event counter: 85
        Timestamp: 1893540858µs
        Data Header
        CRC: 0x1be4e4
        188 4.842652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 188: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23859
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 85
        Timestamp: 1893541088µs
        Data Header
        CRC: 0xd084e4
        189 4.887421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 189: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23860
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -63 dBm
        Event counter: 86
        Timestamp: 1893585857µs
        Data Header
        CRC: 0xb534e4
        190 4.887652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 190: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23861
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 86
        Timestamp: 1893586088µs
        Data Header
        CRC: 0x7e54e4
        191 4.932421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 191: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23862
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -69 dBm
        Event counter: 87
        Timestamp: 1893630857µs
        Data Header
        CRC: 0x1be4e4
        192 4.932652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 192: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23863
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 87
        Timestamp: 1893631087µs
        Data Header
        CRC: 0xd084e4
        193 4.977422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 193: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23864
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 31
        RSSI: -79 dBm
        Event counter: 88
        Timestamp: 1893675857µs
        Data Header
        CRC: 0xb524e4
                [Incorrect CRC]
                [Group: Checksum]
        194 4.977652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 194: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23865
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -47 dBm
        Event counter: 88
        Timestamp: 1893676087µs
        Data Header
        CRC: 0x7e54e4
        195 5.022422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 195: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23866
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -74 dBm
        Event counter: 89
        Timestamp: 1893720857µs
        Data Header
        CRC: 0x1be4e4
        196 5.022652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 196: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23867
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 89
        Timestamp: 1893721087µs
        Data Header
        CRC: 0xd084e4
        197 5.067421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 197: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23868
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -64 dBm
        Event counter: 90
        Timestamp: 1893765856µs
        Data Header
        CRC: 0xb534e4
        198 5.067651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 198: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23869
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 90
        Timestamp: 1893766086µs
        Data Header
        CRC: 0x7e54e4
        199 5.112421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 199: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23870
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -64 dBm
        Event counter: 91
        Timestamp: 1893810856µs
        Data Header
        CRC: 0x1be4e4
        200 5.112652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 200: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23871
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 91
        Timestamp: 1893811087µs
        Data Header
        CRC: 0xd084e4
        201 5.157421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 201: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23872
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -68 dBm
        Event counter: 92
        Timestamp: 1893855856µs
        Data Header
        CRC: 0xb534e4
        202 5.157652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 202: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23873
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 92
        Timestamp: 1893856087µs
        Data Header
        CRC: 0x7e54e4
        203 5.247422       Master_0x4d08532d     Slave_0x4d08532d      LE LL    74                No                                  L2CAP Fragment[BoundErrorUnreassembled Packet]
    Frame 203: 74 bytes on wire (592 bits), 74 bytes captured (592 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23874
        Flags: 0x02
            .... ...0 = CRC: Error
                [Expert Info (Error/Checksum): CRC is bad]
                    [CRC is bad]
                    [Severity level: Error]
                    [Group: Checksum]
        Channel Index: 36
        RSSI: -80 dBm
        Event counter: 94
        Timestamp: 1893945857µs
        Data Header
        L2CAP Fragment
    [BoundError Unreassembled Packet: BT LE LL]
        [Expert Info (Note/Reassemble): Unreassembled fragment (change preferences to enable reassembly)]
            [Unreassembled fragment (change preferences to enable reassembly)]
            [Severity level: Note]
            [Group: Reassemble]
        204 5.292421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 204: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23875
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -68 dBm
        Event counter: 95
        Timestamp: 1893990856µs
        [Delta time (end to start): 44535µs]
        [Delta time (start to start): 44999µs]
        Data Header
        CRC: 0x1be4e4
        205 5.292652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 205: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23876
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -57 dBm
        Event counter: 95
        Timestamp: 1893991087µs
        Data Header
        CRC: 0xd084e4
        206 5.337421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 206: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23877
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -63 dBm
        Event counter: 96
        Timestamp: 1894035856µs
        Data Header
        CRC: 0xb534e4
        207 5.337652       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 207: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23878
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 96
        Timestamp: 1894036087µs
        Data Header
        CRC: 0x7e54e4
        208 5.382421       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 208: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23879
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -64 dBm
        Event counter: 97
        Timestamp: 1894080856µs
        Data Header
        CRC: 0x1be4e4
        209 5.382651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 209: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23880
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 97
        Timestamp: 1894081086µs
        Data Header
        CRC: 0xd084e4
        210 5.517420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 210: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23881
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -70 dBm
        Event counter: 100
        Timestamp: 1894215855µs
        [Delta time (end to start): 134689µs]
        [Delta time (start to start): 134769µs]
        Data Header
        CRC: 0xb534e4
        211 5.517650       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 211: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23882
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 100
        Timestamp: 1894216085µs
        Data Header
        CRC: 0x7e54e4
        212 5.562420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 212: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23883
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -64 dBm
        Event counter: 101
        Timestamp: 1894260855µs
        Data Header
        CRC: 0x1be4e4
        213 5.562651       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 213: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23884
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -47 dBm
        Event counter: 101
        Timestamp: 1894261086µs
        Data Header
        CRC: 0xd084e4
        214 5.607420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 214: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23885
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -63 dBm
        Event counter: 102
        Timestamp: 1894305855µs
        Data Header
        CRC: 0xb534e4
        215 5.607650       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 215: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23886
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 102
        Timestamp: 1894306085µs
        Data Header
        CRC: 0x7e54e4
        216 5.652420       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 216: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23887
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -70 dBm
        Event counter: 103
        Timestamp: 1894350855µs
        Data Header
        CRC: 0x1be4e4
        217 5.652650       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 217: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23888
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 103
        Timestamp: 1894351085µs
        Data Header
        CRC: 0xd084e4
        218 5.742419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    30                No                                  L2CAP Fragment
    Frame 218: 30 bytes on wire (240 bits), 30 bytes captured (240 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23889
        Flags: 0x02
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 2
        RSSI: -78 dBm
        Event counter: 105
        Timestamp: 1894440854µs
        [Packet time (start to end): 112µs]
        [Delta time (end to start): 89689µs]
        [Delta time (start to start): 89769µs]
        Data Header
        L2CAP Fragment
        CRC: 0x2d088a
            [Expert Info (Warning/Checksum): Incorrect CRC]
                [Incorrect CRC]
                [Severity level: Warning]
                [Group: Checksum]
        219 5.787419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 219: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23890
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -64 dBm
        Event counter: 106
        Timestamp: 1894485854µs
        [Delta time (end to start): 44888µs]
        [Delta time (start to start): 45000µs]
        Data Header
        CRC: 0xb534e4
        220 5.787649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 220: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23891
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 106
        Timestamp: 1894486084µs
        Data Header
        CRC: 0x7e54e4
        221 5.832419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 221: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23892
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -63 dBm
        Event counter: 107
        Timestamp: 1894530854µs
        Data Header
        CRC: 0x1be4e4
        222 5.832649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 222: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23893
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 107
        Timestamp: 1894531084µs
        Data Header
        CRC: 0xd084e4
        223 5.877419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 223: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23894
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -68 dBm
        Event counter: 108
        Timestamp: 1894575854µs
        Data Header
        CRC: 0xb534e4
        224 5.877648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 224: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23895
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -43 dBm
        Event counter: 108
        Timestamp: 1894576083µs
        [Delta time (end to start): 149µs]
        [Delta time (start to start): 229µs]
        Data Header
        CRC: 0x7e54e4
        225 5.922419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 225: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23896
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -77 dBm
        Event counter: 109
        Timestamp: 1894620854µs
        [Delta time (end to start): 44691µs]
        [Delta time (start to start): 44771µs]
        Data Header
        CRC: 0x1be4e4
        226 5.922648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 226: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23897
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -45 dBm
        Event counter: 109
        Timestamp: 1894621083µs
        Data Header
        CRC: 0xd084e4
        227 5.967419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 227: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23898
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -70 dBm
        Event counter: 110
        Timestamp: 1894665854µs
        Data Header
        CRC: 0xb534e4
        228 5.967649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 228: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23899
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 110
        Timestamp: 1894666084µs
        Data Header
        CRC: 0x7e54e4
        229 6.012419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 229: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23900
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -61 dBm
        Event counter: 111
        Timestamp: 1894710854µs
        Data Header
        CRC: 0x1be4e4
        230 6.012649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 230: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23901
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 111
        Timestamp: 1894711084µs
        Data Header
        CRC: 0xd084e4
        231 6.057418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 231: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23902
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -65 dBm
        Event counter: 112
        Timestamp: 1894755853µs
        Data Header
        CRC: 0xb534e4
        232 6.057649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 232: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23903
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 112
        Timestamp: 1894756084µs
        Data Header
        CRC: 0x7e54e4
        233 6.102418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 233: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23904
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -65 dBm
        Event counter: 113
        Timestamp: 1894800853µs
        Data Header
        CRC: 0x1be4e4
        234 6.102649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 234: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23905
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 113
        Timestamp: 1894801083µs
        Data Header
        CRC: 0xd084e4
        235 6.147419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 235: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23906
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -61 dBm
        Event counter: 114
        Timestamp: 1894845853µs
        Data Header
        CRC: 0xb534e4
        236 6.147649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 236: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23907
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -45 dBm
        Event counter: 114
        Timestamp: 1894846083µs
        Data Header
        CRC: 0x7e54e4
        237 6.192419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 237: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23908
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -60 dBm
        Event counter: 115
        Timestamp: 1894890853µs
        Data Header
        CRC: 0x1be4e4
        238 6.192649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 238: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23909
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -45 dBm
        Event counter: 115
        Timestamp: 1894891083µs
        Data Header
        CRC: 0xd084e4
        239 6.237419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 239: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23910
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -59 dBm
        Event counter: 116
        Timestamp: 1894935853µs
        Data Header
        CRC: 0xb534e4
        240 6.237649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 240: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23911
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 116
        Timestamp: 1894936083µs
        Data Header
        CRC: 0x7e54e4
        241 6.282419       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 241: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23912
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -70 dBm
        Event counter: 117
        Timestamp: 1894980853µs
        Data Header
        CRC: 0x1be4e4
        242 6.282649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 242: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23913
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 117
        Timestamp: 1894981083µs
        Data Header
        CRC: 0xd084e4
        243 6.327418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 243: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23914
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -66 dBm
        Event counter: 118
        Timestamp: 1895025852µs
        Data Header
        CRC: 0xb534e4
        244 6.327648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 244: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23915
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -45 dBm
        Event counter: 118
        Timestamp: 1895026082µs
        Data Header
        CRC: 0x7e54e4
        245 6.372418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 245: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23916
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -62 dBm
        Event counter: 119
        Timestamp: 1895070852µs
        Data Header
        CRC: 0x1be4e4
        246 6.372648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 246: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23917
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -44 dBm
        Event counter: 119
        Timestamp: 1895071082µs
        Data Header
        CRC: 0xd084e4
        247 6.417418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 247: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23918
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -67 dBm
        Event counter: 120
        Timestamp: 1895115852µs
        Data Header
        CRC: 0xb534e4
        248 6.417648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 248: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23919
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 120
        Timestamp: 1895116082µs
        Data Header
        CRC: 0x7e54e4
        249 6.462418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 249: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23920
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -62 dBm
        Event counter: 121
        Timestamp: 1895160852µs
        Data Header
        CRC: 0x1be4e4
        250 6.462648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 250: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23921
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 121
        Timestamp: 1895161082µs
        Data Header
        CRC: 0xd084e4
        251 6.507418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 251: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23922
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -63 dBm
        Event counter: 122
        Timestamp: 1895205852µs
        Data Header
        CRC: 0xb534e4
        252 6.507648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 252: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23923
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -51 dBm
        Event counter: 122
        Timestamp: 1895206082µs
        Data Header
        CRC: 0x7e54e4
        253 6.552418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 253: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23924
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -75 dBm
        Event counter: 123
        Timestamp: 1895250852µs
        Data Header
        CRC: 0x1be4e4
        254 6.552648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 254: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23925
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 123
        Timestamp: 1895251082µs
        Data Header
        CRC: 0xd084e4
        255 6.597418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 255: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23926
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -67 dBm
        Event counter: 124
        Timestamp: 1895295852µs
        Data Header
        CRC: 0xb534e4
        256 6.597648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 256: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23927
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 124
        Timestamp: 1895296082µs
        Data Header
        CRC: 0x7e54e4
        257 6.642418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 257: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23928
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -70 dBm
        Event counter: 125
        Timestamp: 1895340852µs
        Data Header
        CRC: 0x1be4e4
        258 6.642648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 258: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23929
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -43 dBm
        Event counter: 125
        Timestamp: 1895341082µs
        Data Header
        CRC: 0xd084e4
        259 6.687418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 259: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23930
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -68 dBm
        Event counter: 126
        Timestamp: 1895385851µs
        Data Header
        CRC: 0xb534e4
        260 6.687649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 260: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23931
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 126
        Timestamp: 1895386082µs
        Data Header
        CRC: 0x7e54e4
        261 6.732418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 261: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23932
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -63 dBm
        Event counter: 127
        Timestamp: 1895430851µs
        Data Header
        CRC: 0x1be4e4
        262 6.732649       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 262: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23933
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 127
        Timestamp: 1895431082µs
        Data Header
        CRC: 0xd084e4
        263 6.777418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 263: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23934
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -66 dBm
        Event counter: 128
        Timestamp: 1895475851µs
        Data Header
        CRC: 0xb534e4
        264 6.777648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 264: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23935
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 128
        Timestamp: 1895476081µs
        Data Header
        CRC: 0x7e54e4
        265 6.822418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 265: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23936
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -67 dBm
        Event counter: 129
        Timestamp: 1895520851µs
        Data Header
        CRC: 0x1be4e4
        266 6.822648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 266: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23937
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 129
        Timestamp: 1895521081µs
        Data Header
        CRC: 0xd084e4
        267 6.867418       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 267: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23938
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -70 dBm
        Event counter: 130
        Timestamp: 1895565851µs
        Data Header
        CRC: 0xb534e4
        268 6.867648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 268: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23939
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -44 dBm
        Event counter: 130
        Timestamp: 1895566081µs
        Data Header
        CRC: 0x7e54e4
        269 6.912417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 269: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23940
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -64 dBm
        Event counter: 131
        Timestamp: 1895610850µs
        Data Header
        CRC: 0x1be4e4
        270 6.912648       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 270: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23941
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -45 dBm
        Event counter: 131
        Timestamp: 1895611081µs
        Data Header
        CRC: 0xd084e4
        271 6.957417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 271: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23942
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -68 dBm
        Event counter: 132
        Timestamp: 1895655850µs
        Data Header
        CRC: 0xb534e4
        272 6.957647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 272: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23943
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -51 dBm
        Event counter: 132
        Timestamp: 1895656080µs
        Data Header
        CRC: 0x7e54e4
        273 7.002417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 273: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23944
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -70 dBm
        Event counter: 133
        Timestamp: 1895700850µs
        Data Header
        CRC: 0x1be4e4
        274 7.002647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 274: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23945
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 133
        Timestamp: 1895701080µs
        Data Header
        CRC: 0xd084e4
        275 7.047417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 275: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23946
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -71 dBm
        Event counter: 134
        Timestamp: 1895745850µs
        Data Header
        CRC: 0xb534e4
        276 7.047647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 276: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23947
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -44 dBm
        Event counter: 134
        Timestamp: 1895746080µs
        Data Header
        CRC: 0x7e54e4
        277 7.137416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 277: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23948
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -64 dBm
        Event counter: 136
        Timestamp: 1895835849µs
        Data Header
        CRC: 0xb534e4
        278 7.137647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 278: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23949
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 136
        Timestamp: 1895836080µs
        Data Header
        CRC: 0x7e54e4
        279 7.182416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 279: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23950
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -71 dBm
        Event counter: 137
        Timestamp: 1895880849µs
        Data Header
        CRC: 0x1be4e4
        280 7.182647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 280: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23951
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 137
        Timestamp: 1895881080µs
        Data Header
        CRC: 0xd084e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
        281 7.227416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 281: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 23952
        Length of packet: 10
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 11
        RSSI: -70 dBm
        Event counter: 138
        Timestamp: 1895925849µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0xb534e4
        282 7.227647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 282: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23953
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 138
        Timestamp: 1895926080µs
        Data Header
        CRC: 0x7e54e4
        283 7.272416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 283: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23954
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -69 dBm
        Event counter: 139
        Timestamp: 1895970849µs
        Data Header
        CRC: 0x1be4e4
        284 7.272646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 284: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23955
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 139
        Timestamp: 1895971079µs
        Data Header
        CRC: 0xd084e4
        285 7.317416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 285: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23956
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -68 dBm
        Event counter: 140
        Timestamp: 1896015849µs
        Data Header
        CRC: 0xb534e4
        286 7.317647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 286: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23957
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 140
        Timestamp: 1896016079µs
        Data Header
        CRC: 0x7e54e4
        287 7.362417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 287: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23958
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -64 dBm
        Event counter: 141
        Timestamp: 1896060849µs
        Data Header
        CRC: 0x1be4e4
        288 7.362647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 288: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23959
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 141
        Timestamp: 1896061079µs
        Data Header
        CRC: 0xd084e4
        289 7.407417       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 289: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23960
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -69 dBm
        Event counter: 142
        Timestamp: 1896105849µs
        Data Header
        CRC: 0xb534e4
        290 7.407647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 290: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23961
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 142
        Timestamp: 1896106079µs
        Data Header
        CRC: 0x7e54e4
        291 7.452416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 291: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23962
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -72 dBm
        Event counter: 143
        Timestamp: 1896150848µs
        Data Header
        CRC: 0x1be4e4
        292 7.452647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 292: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23963
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 143
        Timestamp: 1896151079µs
        Data Header
        CRC: 0xd084e4
        293 7.497416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 293: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23964
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 16
        RSSI: -74 dBm
        Event counter: 144
        Timestamp: 1896195848µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0xb534e4
        294 7.497647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 294: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23965
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 144
        Timestamp: 1896196079µs
        Data Header
        CRC: 0x7e54e4
        295 7.542416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 295: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23966
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -70 dBm
        Event counter: 145
        Timestamp: 1896240848µs
        Data Header
        CRC: 0x1be4e4
        296 7.542647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 296: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23967
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 145
        Timestamp: 1896241079µs
        Data Header
        CRC: 0xd084e4
        297 7.587416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 297: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23968
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -67 dBm
        Event counter: 146
        Timestamp: 1896285848µs
        Data Header
        CRC: 0xb534e4
        298 7.587646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 298: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23969
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -45 dBm
        Event counter: 146
        Timestamp: 1896286078µs
        [Delta time (end to start): 150µs]
        Data Header
        CRC: 0x7e54e4
        299 7.632416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 299: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23970
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 0
        RSSI: -64 dBm
        Event counter: 147
        Timestamp: 1896330848µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0x1be4e4
        300 7.632646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 300: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23971
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 147
        Timestamp: 1896331078µs
        Data Header
        CRC: 0xd084e4
        301 7.677416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 301: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23972
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -73 dBm
        Event counter: 148
        Timestamp: 1896375848µs
        Data Header
        CRC: 0xb534e4
        302 7.677646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 302: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23973
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 148
        Timestamp: 1896376078µs
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0x7e54e4
        303 7.722415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 303: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23974
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -77 dBm
        Event counter: 149
        Timestamp: 1896420847µs
        Data Header
        CRC: 0x1be4e4
        304 7.722645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 304: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23975
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 149
        Timestamp: 1896421077µs
        Data Header
        CRC: 0xd084e4
        305 7.767415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 305: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23976
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -72 dBm
        Event counter: 150
        Timestamp: 1896465847µs
        Data Header
        CRC: 0xb534e4
        306 7.767646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 306: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23977
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 150
        Timestamp: 1896466078µs
        [Delta time (end to start): 151µs]
        Data Header
        CRC: 0x7e54e4
        307 7.812415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 307: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23978
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 28
        RSSI: -72 dBm
        Event counter: 151
        Timestamp: 1896510847µs
        Data Header
        CRC: 0x1be4e4
                [Incorrect CRC]
                [Group: Checksum]
        308 7.812645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 308: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23979
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -44 dBm
        Event counter: 151
        Timestamp: 1896511077µs
        Data Header
        CRC: 0xd084e4
        309 7.857415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 309: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23980
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -64 dBm
        Event counter: 152
        Timestamp: 1896555847µs
        Data Header
        CRC: 0xb534e4
        310 7.857646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 310: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23981
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 152
        Timestamp: 1896556078µs
        Data Header
        CRC: 0x7e54e4
        311 7.902416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 311: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23982
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -71 dBm
        Event counter: 153
        Timestamp: 1896600847µs
        Data Header
        [Connection Parameters in: 127]
        CRC: 0x1be4e4
        312 7.902647       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 312: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23983
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 153
        Timestamp: 1896601078µs
        Data Header
        CRC: 0xd084e4
        313 7.947416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    90                No                                  L2CAP Fragment
    Frame 313: 90 bytes on wire (720 bits), 90 bytes captured (720 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23984
        Flags: 0x02
                    [CRC is bad]
                    [Group: Checksum]
            .... 0... = MIC (not relevant): 0
        Channel Index: 12
        RSSI: -69 dBm
        Event counter: 154
        Timestamp: 1896645847µs
        [Packet time (start to end): 592µs]
        Data Header
        L2CAP Fragment
            [Expert Info (Warning/Sequence): Missing Fragment Start]
                [Missing Fragment Start]
                [Group: Sequence]
        [L2CAP Index: 45]
        CRC: 0x7c3137
                [Incorrect CRC]
                [Group: Checksum]
        314 7.992416       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 314: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23985
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -65 dBm
        Event counter: 155
        Timestamp: 1896690847µs
        [Delta time (end to start): 44408µs]
        Data Header
        CRC: 0x1be4e4
        315 7.992646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 315: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23986
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -43 dBm
        Event counter: 155
        Timestamp: 1896691077µs
        Data Header
        CRC: 0xd084e4
        316 8.037415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 316: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23987
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -67 dBm
        Event counter: 156
        Timestamp: 1896735846µs
        Data Header
        CRC: 0xb534e4
        317 8.037646       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 317: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23988
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -44 dBm
        Event counter: 156
        Timestamp: 1896736077µs
        Data Header
        CRC: 0x7e54e4
        318 8.082415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 318: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23989
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -67 dBm
        Event counter: 157
        Timestamp: 1896780846µs
        Data Header
        CRC: 0x1be4e4
        319 8.082645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 319: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23990
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 157
        Timestamp: 1896781076µs
        Data Header
        CRC: 0xd084e4
        320 8.127415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 320: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23991
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -67 dBm
        Event counter: 158
        Timestamp: 1896825846µs
        [Delta time (end to start): 44690µs]
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0xb534e4
        321 8.127645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 321: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23992
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 158
        Timestamp: 1896826076µs
        Data Header
        CRC: 0x7e54e4
        322 8.172415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 322: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23993
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -69 dBm
        Event counter: 159
        Timestamp: 1896870846µs
        Data Header
        CRC: 0x1be4e4
        323 8.172645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 323: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23994
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 159
        Timestamp: 1896871076µs
        Data Header
        CRC: 0xd084e4
        324 8.217415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 324: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23995
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -72 dBm
        Event counter: 160
        Timestamp: 1896915846µs
        Data Header
        CRC: 0xb534e4
        325 8.217645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 325: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23996
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 160
        Timestamp: 1896916076µs
        Data Header
        CRC: 0x7e54e4
        326 8.262414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 326: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23997
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -66 dBm
        Event counter: 161
        Timestamp: 1896960845µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0x1be4e4
        327 8.262645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 327: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23998
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 161
        Timestamp: 1896961076µs
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0xd084e4
        328 8.307414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 328: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 23999
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -70 dBm
        Event counter: 162
        Timestamp: 1897005845µs
        Data Header
        CRC: 0xb534e4
        329 8.307645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 329: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24000
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -43 dBm
        Event counter: 162
        Timestamp: 1897006076µs
        Data Header
        CRC: 0x7e54e4
        330 8.352414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 330: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24001
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 163
        Timestamp: 1897050845µs
        Data Header
        CRC: 0x1be4e4
        331 8.352644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 331: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24002
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 163
        Timestamp: 1897051075µs
        Data Header
        CRC: 0xd084e4
        332 8.397414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 332: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24003
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -73 dBm
        Event counter: 164
        Timestamp: 1897095845µs
        Data Header
        CRC: 0xb534e4
        333 8.397645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 333: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24004
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -51 dBm
        Event counter: 164
        Timestamp: 1897096075µs
        Data Header
        CRC: 0x7e54e4
        334 8.487415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 334: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24005
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -70 dBm
        Event counter: 166
        Timestamp: 1897185845µs
        [Delta time (end to start): 89690µs]
        [Delta time (start to start): 89770µs]
        Data Header
        CRC: 0x1be4e4
        335 8.487645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 335: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24006
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 166
        Timestamp: 1897186075µs
        Data Header
        CRC: 0xd084e4
        336 8.577415       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 336: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24007
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -65 dBm
        Event counter: 168
        Timestamp: 1897275845µs
        Data Header
        CRC: 0x1be4e4
        337 8.577645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 337: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24008
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 168
        Timestamp: 1897276075µs
        Data Header
        CRC: 0xd084e4
        338 8.622414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 338: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24009
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -74 dBm
        Event counter: 169
        Timestamp: 1897320844µs
        Data Header
        CRC: 0xb534e4
        339 8.622645       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 339: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24010
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -52 dBm
        Event counter: 169
        Timestamp: 1897321075µs
        Data Header
        CRC: 0x7e54e4
        340 8.667414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 340: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24011
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -69 dBm
        Event counter: 170
        Timestamp: 1897365844µs
        Data Header
        CRC: 0x1be4e4
        341 8.667644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 341: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24012
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 170
        Timestamp: 1897366074µs
        Data Header
        CRC: 0xd084e4
        342 8.712414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 342: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24013
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -73 dBm
        Event counter: 171
        Timestamp: 1897410844µs
        Data Header
        CRC: 0xb534e4
        343 8.712644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 343: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24014
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -44 dBm
        Event counter: 171
        Timestamp: 1897411074µs
        Data Header
        CRC: 0x7e54e4
        344 8.757414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 344: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24015
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -72 dBm
        Event counter: 172
        Timestamp: 1897455844µs
        Data Header
        CRC: 0x1be4e4
        345 8.757644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 345: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24016
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -44 dBm
        Event counter: 172
        Timestamp: 1897456074µs
        Data Header
        CRC: 0xd084e4
        346 8.802414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 346: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24017
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -66 dBm
        Event counter: 173
        Timestamp: 1897500844µs
        Data Header
        CRC: 0xb534e4
        347 8.802644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 347: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24018
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 173
        Timestamp: 1897501074µs
        Data Header
        CRC: 0x7e54e4
        348 8.847414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 348: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24019
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -71 dBm
        Event counter: 174
        Timestamp: 1897545844µs
        Data Header
        CRC: 0x1be4e4
        349 8.847644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 349: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24020
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 174
        Timestamp: 1897546074µs
        Data Header
        CRC: 0xd084e4
        350 8.892413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 350: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24021
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -67 dBm
        Event counter: 175
        Timestamp: 1897590843µs
        Data Header
        CRC: 0xb534e4
        351 8.892644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 351: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24022
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 175
        Timestamp: 1897591074µs
        Data Header
        CRC: 0x7e54e4
        352 8.937413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 352: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24023
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -74 dBm
        Event counter: 176
        Timestamp: 1897635843µs
        Data Header
        CRC: 0x1be4e4
        353 8.937644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 353: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24024
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 176
        Timestamp: 1897636074µs
        Data Header
        CRC: 0xd084e4
        354 8.982414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 354: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24025
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -68 dBm
        Event counter: 177
        Timestamp: 1897680843µs
        Data Header
        CRC: 0xb534e4
        355 8.982644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 355: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24026
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 177
        Timestamp: 1897681073µs
        Data Header
        CRC: 0x7e54e4
        356 9.027414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 356: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24027
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -67 dBm
        Event counter: 178
        Timestamp: 1897725843µs
        Data Header
        CRC: 0x1be4e4
        357 9.027644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 357: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24028
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 178
        Timestamp: 1897726073µs
        Data Header
        CRC: 0xd084e4
        358 9.072414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 358: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24029
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -66 dBm
        Event counter: 179
        Timestamp: 1897770843µs
        Data Header
        CRC: 0xb534e4
        359 9.072644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 359: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24030
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 179
        Timestamp: 1897771073µs
        Data Header
        CRC: 0x7e54e4
        360 9.117414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 360: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24031
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -72 dBm
        Event counter: 180
        Timestamp: 1897815843µs
        Data Header
        CRC: 0x1be4e4
        361 9.117644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 361: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24032
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 180
        Timestamp: 1897816073µs
        Data Header
        CRC: 0xd084e4
        362 9.207414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 362: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24033
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -68 dBm
        Event counter: 182
        Timestamp: 1897905843µs
        Data Header
        CRC: 0x1be4e4
        363 9.207644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 363: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24034
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 182
        Timestamp: 1897906073µs
        Data Header
        CRC: 0xd084e4
        364 9.252414       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 364: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24035
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -69 dBm
        Event counter: 183
        Timestamp: 1897950843µs
        Data Header
        CRC: 0xb534e4
        365 9.252643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 365: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24036
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -44 dBm
        Event counter: 183
        Timestamp: 1897951072µs
        Data Header
        CRC: 0x7e54e4
        366 9.297413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 366: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24037
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -64 dBm
        Event counter: 184
        Timestamp: 1897995842µs
        Data Header
        CRC: 0x1be4e4
        367 9.297644       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 367: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24038
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 184
        Timestamp: 1897996073µs
        Data Header
        CRC: 0xd084e4
        368 9.342413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 368: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24039
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -76 dBm
        Event counter: 185
        Timestamp: 1898040842µs
        Data Header
        CRC: 0xb534e4
        369 9.342643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 369: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24040
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -53 dBm
        Event counter: 185
        Timestamp: 1898041072µs
        Data Header
        CRC: 0x7e54e4
        370 9.387413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 370: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24041
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -74 dBm
        Event counter: 186
        Timestamp: 1898085842µs
        Data Header
        CRC: 0x1be4e4
        371 9.387643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 371: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24042
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -44 dBm
        Event counter: 186
        Timestamp: 1898086072µs
        Data Header
        CRC: 0xd084e4
        372 9.432413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 372: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24043
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -71 dBm
        Event counter: 187
        Timestamp: 1898130842µs
        Data Header
        CRC: 0xb534e4
        373 9.432643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 373: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24044
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 187
        Timestamp: 1898131072µs
        Data Header
        CRC: 0x7e54e4
        374 9.522412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 374: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24045
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -66 dBm
        Event counter: 189
        Timestamp: 1898220841µs
        Data Header
        CRC: 0xb534e4
        375 9.522642       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 375: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24046
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 189
        Timestamp: 1898221071µs
        Data Header
        CRC: 0x7e54e4
        376 9.567412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 376: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24047
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -72 dBm
        Event counter: 190
        Timestamp: 1898265841µs
        Data Header
        CRC: 0x1be4e4
        377 9.567643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 377: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24048
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 190
        Timestamp: 1898266072µs
        Data Header
        CRC: 0xd084e4
        378 9.612412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 378: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24049
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -68 dBm
        Event counter: 191
        Timestamp: 1898310841µs
        Data Header
        CRC: 0xb534e4
        379 9.612643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 379: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24050
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 191
        Timestamp: 1898311072µs
        Data Header
        CRC: 0x7e54e4
        380 9.657412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 380: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24051
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -75 dBm
        Event counter: 192
        Timestamp: 1898355841µs
        Data Header
        CRC: 0x1be4e4
        381 9.657642       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 381: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24052
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -43 dBm
        Event counter: 192
        Timestamp: 1898356071µs
        Data Header
        CRC: 0xd084e4
        382 9.702412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 382: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24053
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -69 dBm
        Event counter: 193
        Timestamp: 1898400841µs
        Data Header
        CRC: 0xb534e4
        383 9.702642       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 383: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24054
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -44 dBm
        Event counter: 193
        Timestamp: 1898401071µs
        Data Header
        CRC: 0x7e54e4
        384 9.747412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 384: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24055
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -66 dBm
        Event counter: 194
        Timestamp: 1898445841µs
        Data Header
        CRC: 0x1be4e4
        385 9.747643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 385: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24056
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 194
        Timestamp: 1898446071µs
        Data Header
        CRC: 0xd084e4
        386 9.792413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 386: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24057
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -70 dBm
        Event counter: 195
        Timestamp: 1898490841µs
        Data Header
        CRC: 0xb534e4
        387 9.792643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 387: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24058
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 195
        Timestamp: 1898491071µs
        Data Header
        CRC: 0x7e54e4
        388 9.837413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 388: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24059
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -69 dBm
        Event counter: 196
        Timestamp: 1898535841µs
        Data Header
        CRC: 0x1be4e4
        389 9.837643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 389: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24060
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 196
        Timestamp: 1898536071µs
        Data Header
        CRC: 0xd084e4
        390 9.882413       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 390: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24061
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -74 dBm
        Event counter: 197
        Timestamp: 1898580841µs
        Data Header
        CRC: 0xb534e4
        391 9.882643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 391: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24062
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -43 dBm
        Event counter: 197
        Timestamp: 1898581071µs
        Data Header
        CRC: 0x7e54e4
        392 9.927412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 392: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24063
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -65 dBm
        Event counter: 198
        Timestamp: 1898625840µs
        Data Header
        CRC: 0x1be4e4
        393 9.927643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 393: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24064
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 198
        Timestamp: 1898626071µs
        Data Header
        CRC: 0xd084e4
        394 9.972412       Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 394: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24065
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -67 dBm
        Event counter: 199
        Timestamp: 1898670840µs
        Data Header
        CRC: 0xb534e4
        395 9.972643       Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 395: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24066
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -43 dBm
        Event counter: 199
        Timestamp: 1898671071µs
        Data Header
        CRC: 0x7e54e4
        396 10.017412      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 396: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24067
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 200
        Timestamp: 1898715840µs
        Data Header
        CRC: 0x1be4e4
        397 10.017642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 397: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24068
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 200
        Timestamp: 1898716070µs
        Data Header
        CRC: 0xd084e4
        398 10.062412      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 398: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24069
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -73 dBm
        Event counter: 201
        Timestamp: 1898760840µs
        Data Header
        CRC: 0xb534e4
        399 10.062642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 399: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24070
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -51 dBm
        Event counter: 201
        Timestamp: 1898761070µs
        Data Header
        CRC: 0x7e54e4
        400 10.152412      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 400: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24071
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -69 dBm
        Event counter: 203
        Timestamp: 1898850840µs
        Data Header
        CRC: 0xb534e4
        401 10.152641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 401: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24072
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 203
        Timestamp: 1898851069µs
        [Delta time (end to start): 149µs]
        [Delta time (start to start): 229µs]
        Data Header
        CRC: 0x7e54e4
        402 10.197411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 402: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24073
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -71 dBm
        Event counter: 204
        Timestamp: 1898895839µs
        Data Header
        CRC: 0x1be4e4
        403 10.197642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 403: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24074
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 204
        Timestamp: 1898896070µs
        Data Header
        CRC: 0xd084e4
        404 10.242411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 404: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24075
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -65 dBm
        Event counter: 205
        Timestamp: 1898940839µs
        Data Header
        CRC: 0xb534e4
        405 10.242641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 405: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24076
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 205
        Timestamp: 1898941069µs
        Data Header
        CRC: 0x7e54e4
        406 10.287411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 406: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24077
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -74 dBm
        Event counter: 206
        Timestamp: 1898985839µs
        Data Header
        CRC: 0x1be4e4
        407 10.287641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 407: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24078
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -58 dBm
        Event counter: 206
        Timestamp: 1898986069µs
        Data Header
        CRC: 0xd084e4
        408 10.332411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 408: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24079
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -71 dBm
        Event counter: 207
        Timestamp: 1899030839µs
        Data Header
        CRC: 0xb534e4
        409 10.332642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 409: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24080
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 207
        Timestamp: 1899031070µs
        Data Header
        CRC: 0x7e54e4
        410 10.377411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 410: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24081
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -74 dBm
        Event counter: 208
        Timestamp: 1899075839µs
        Data Header
        CRC: 0x1be4e4
        411 10.377641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 411: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24082
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 208
        Timestamp: 1899076069µs
        Data Header
        CRC: 0xd084e4
        412 10.422411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 412: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24083
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -71 dBm
        Event counter: 209
        Timestamp: 1899120839µs
        Data Header
        CRC: 0xb534e4
        413 10.422642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 413: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24084
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -45 dBm
        Event counter: 209
        Timestamp: 1899121069µs
        Data Header
        CRC: 0x7e54e4
        414 10.467412      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 414: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24085
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -66 dBm
        Event counter: 210
        Timestamp: 1899165839µs
        Data Header
        CRC: 0x1be4e4
        415 10.467642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 415: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24086
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 210
        Timestamp: 1899166069µs
        Data Header
        CRC: 0xd084e4
        416 10.512412      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 416: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24087
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -72 dBm
        Event counter: 211
        Timestamp: 1899210839µs
        Data Header
        CRC: 0xb534e4
        417 10.512642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 417: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24088
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 211
        Timestamp: 1899211069µs
        Data Header
        CRC: 0x7e54e4
        418 10.557411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 418: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24089
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -68 dBm
        Event counter: 212
        Timestamp: 1899255838µs
        Data Header
        CRC: 0x1be4e4
        419 10.557642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 419: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24090
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -47 dBm
        Event counter: 212
        Timestamp: 1899256069µs
        Data Header
        CRC: 0xd084e4
        420 10.602411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 420: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24091
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -75 dBm
        Event counter: 213
        Timestamp: 1899300838µs
        Data Header
        CRC: 0xb534e4
        421 10.602642      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 421: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24092
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 213
        Timestamp: 1899301069µs
        Data Header
        CRC: 0x7e54e4
        422 10.647411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 422: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24093
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -69 dBm
        Event counter: 214
        Timestamp: 1899345838µs
        Data Header
        CRC: 0x1be4e4
        423 10.647641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 423: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24094
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -45 dBm
        Event counter: 214
        Timestamp: 1899346068µs
        Data Header
        CRC: 0xd084e4
        424 10.692411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 424: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24095
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -67 dBm
        Event counter: 215
        Timestamp: 1899390838µs
        Data Header
        CRC: 0xb534e4
        425 10.692641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 425: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24096
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 215
        Timestamp: 1899391068µs
        Data Header
        CRC: 0x7e54e4
        426 10.737411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 426: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24097
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -68 dBm
        Event counter: 216
        Timestamp: 1899435838µs
        Data Header
        CRC: 0x1be4e4
        427 10.737641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 427: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24098
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 216
        Timestamp: 1899436068µs
        Data Header
        CRC: 0xd084e4
        428 10.782410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 428: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24099
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -72 dBm
        Event counter: 217
        Timestamp: 1899480837µs
        Data Header
        CRC: 0xb534e4
        429 10.782641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 429: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24100
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 217
        Timestamp: 1899481068µs
        Data Header
        CRC: 0x7e54e4
        430 10.872410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 430: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24101
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -68 dBm
        Event counter: 219
        Timestamp: 1899570837µs
        [Delta time (end to start): 89689µs]
        [Delta time (start to start): 89769µs]
        Data Header
        CRC: 0xb534e4
        431 10.872641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 431: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24102
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 219
        Timestamp: 1899571068µs
        Data Header
        CRC: 0x7e54e4
        432 10.917410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 432: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24103
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -69 dBm
        Event counter: 220
        Timestamp: 1899615837µs
        Data Header
        CRC: 0x1be4e4
        433 10.917640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 433: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24104
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -44 dBm
        Event counter: 220
        Timestamp: 1899616067µs
        Data Header
        CRC: 0xd084e4
        434 10.962410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 434: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24105
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -64 dBm
        Event counter: 221
        Timestamp: 1899660837µs
        Data Header
        CRC: 0xb534e4
        435 10.962640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 435: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24106
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 221
        Timestamp: 1899661067µs
        Data Header
        CRC: 0x7e54e4
        436 11.007410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 436: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24107
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -75 dBm
        Event counter: 222
        Timestamp: 1899705837µs
        Data Header
        CRC: 0x1be4e4
        437 11.007640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 437: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24108
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -54 dBm
        Event counter: 222
        Timestamp: 1899706067µs
        Data Header
        CRC: 0xd084e4
        438 11.052410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 438: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24109
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -76 dBm
        Event counter: 223
        Timestamp: 1899750837µs
        Data Header
        CRC: 0xb534e4
        439 11.052640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 439: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24110
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 223
        Timestamp: 1899751067µs
        Data Header
        CRC: 0x7e54e4
        440 11.097410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 440: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24111
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -74 dBm
        Event counter: 224
        Timestamp: 1899795837µs
        Data Header
        CRC: 0x1be4e4
        441 11.097641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 441: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24112
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 224
        Timestamp: 1899796067µs
        Data Header
        CRC: 0xd084e4
        442 11.142411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 442: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24113
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -72 dBm
        Event counter: 225
        Timestamp: 1899840837µs
        Data Header
        CRC: 0xb534e4
        443 11.142641      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 443: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24114
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -45 dBm
        Event counter: 225
        Timestamp: 1899841067µs
        Data Header
        CRC: 0x7e54e4
        444 11.187411      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 444: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24115
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -65 dBm
        Event counter: 226
        Timestamp: 1899885837µs
        Data Header
        CRC: 0x1be4e4
        445 11.187639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 445: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24116
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 226
        Timestamp: 1899886066µs
        Data Header
        CRC: 0xd084e4
        446 11.232410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 446: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24117
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -72 dBm
        Event counter: 227
        Timestamp: 1899930837µs
        [Delta time (end to start): 44691µs]
        [Delta time (start to start): 44771µs]
        Data Header
        CRC: 0xb534e4
        447 11.232639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 447: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24118
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 227
        Timestamp: 1899931066µs
        Data Header
        CRC: 0x7e54e4
        448 11.277409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 448: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24119
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -69 dBm
        Event counter: 228
        Timestamp: 1899975836µs
        Data Header
        CRC: 0x1be4e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
        449 11.277639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 449: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 24120
        Length of packet: 10
        Flags: 0x09
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 228
        Timestamp: 1899976066µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0xd084e4
        450 11.322409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 450: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24121
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -73 dBm
        Event counter: 229
        Timestamp: 1900020836µs
        Data Header
        CRC: 0xb534e4
        451 11.322640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 451: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24122
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -48 dBm
        Event counter: 229
        Timestamp: 1900021067µs
        Data Header
        CRC: 0x7e54e4
        452 11.367409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 452: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24123
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -70 dBm
        Event counter: 230
        Timestamp: 1900065836µs
        Data Header
        CRC: 0x1be4e4
        453 11.367640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 453: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24124
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -44 dBm
        Event counter: 230
        Timestamp: 1900066066µs
        Data Header
        CRC: 0xd084e4
        454 11.412410      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 454: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24125
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -65 dBm
        Event counter: 231
        Timestamp: 1900110836µs
        Data Header
        CRC: 0xb534e4
        455 11.412640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 455: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24126
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 231
        Timestamp: 1900111066µs
        Data Header
        CRC: 0x7e54e4
        456 11.457409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 456: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24127
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -70 dBm
        Event counter: 232
        Timestamp: 1900155835µs
        Data Header
        CRC: 0x1be4e4
        457 11.457640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 457: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24128
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 232
        Timestamp: 1900156066µs
        Data Header
        CRC: 0xd084e4
        458 11.502409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 458: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24129
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -70 dBm
        Event counter: 233
        Timestamp: 1900200835µs
        Data Header
        CRC: 0xb534e4
        459 11.502639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 459: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24130
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -50 dBm
        Event counter: 233
        Timestamp: 1900201065µs
        Data Header
        CRC: 0x7e54e4
        460 11.547409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 460: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24131
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 17
        RSSI: -75 dBm
        Event counter: 234
        Timestamp: 1900245835µs
        Data Header
        CRC: 0x1be4e4
        461 11.547639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 461: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24132
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -43 dBm
        Event counter: 234
        Timestamp: 1900246065µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0xd084e4
        462 11.592409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 462: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24133
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 24
        RSSI: -68 dBm
        Event counter: 235
        Timestamp: 1900290835µs
        Data Header
        CRC: 0xb534e4
        463 11.592639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 463: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24134
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 235
        Timestamp: 1900291065µs
        Data Header
        CRC: 0x7e54e4
        464 11.637409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 464: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24135
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -67 dBm
        Event counter: 236
        Timestamp: 1900335835µs
        Data Header
        CRC: 0x1be4e4
        465 11.637640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 465: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24136
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -44 dBm
        Event counter: 236
        Timestamp: 1900336066µs
        Data Header
        CRC: 0xd084e4
        466 11.682409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 466: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24137
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -66 dBm
        Event counter: 237
        Timestamp: 1900380835µs
        Data Header
        CRC: 0xb534e4
        467 11.682640      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 467: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24138
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 237
        Timestamp: 1900381066µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0x7e54e4
        468 11.727409      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 468: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24139
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -75 dBm
        Event counter: 238
        Timestamp: 1900425835µs
        Data Header
        CRC: 0x1be4e4
        469 11.727639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 469: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24140
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 8
        RSSI: -51 dBm
        Event counter: 238
        Timestamp: 1900426065µs
        [Delta time (end to start): 150µs]
        Data Header
        CRC: 0xd084e4
        470 11.817408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 470: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24141
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -71 dBm
        Event counter: 240
        Timestamp: 1900515834µs
        Data Header
        CRC: 0x1be4e4
        471 11.817638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 471: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24142
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 240
        Timestamp: 1900516064µs
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0xd084e4
        472 11.862408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 472: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24143
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -70 dBm
        Event counter: 241
        Timestamp: 1900560834µs
        Data Header
        CRC: 0xb534e4
        473 11.862638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 473: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24144
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 241
        Timestamp: 1900561064µs
        Data Header
        CRC: 0x7e54e4
        474 11.907408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 474: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24145
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -65 dBm
        Event counter: 242
        Timestamp: 1900605834µs
        Data Header
        CRC: 0x1be4e4
        475 11.907638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 475: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24146
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 242
        Timestamp: 1900606064µs
        Data Header
        CRC: 0xd084e4
        476 11.952408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 476: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24147
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -74 dBm
        Event counter: 243
        Timestamp: 1900650834µs
        Data Header
        CRC: 0xb534e4
        477 11.952638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 477: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24148
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -53 dBm
        Event counter: 243
        Timestamp: 1900651064µs
        Data Header
        CRC: 0x7e54e4
        478 11.997407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 478: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24149
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -71 dBm
        Event counter: 244
        Timestamp: 1900695833µs
        Data Header
        CRC: 0x1be4e4
        479 11.997638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 479: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24150
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 244
        Timestamp: 1900696064µs
        [Delta time (end to start): 151µs]
        Data Header
        [Connection Parameters in: 127]
        CRC: 0xd084e4
        480 12.042408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 480: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24151
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -72 dBm
        Event counter: 245
        Timestamp: 1900740833µs
        Data Header
        CRC: 0xb534e4
        481 12.042639      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 481: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24152
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -44 dBm
        Event counter: 245
        Timestamp: 1900741064µs
        Data Header
        CRC: 0x7e54e4
        482 12.087408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 482: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24153
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -71 dBm
        Event counter: 246
        Timestamp: 1900785833µs
        Data Header
        CRC: 0x1be4e4
        483 12.087638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 483: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24154
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -44 dBm
        Event counter: 246
        Timestamp: 1900786063µs
        Data Header
        CRC: 0xd084e4
        484 12.132408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 484: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24155
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -65 dBm
        Event counter: 247
        Timestamp: 1900830833µs
        Data Header
        CRC: 0xb534e4
        485 12.132638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 485: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24156
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 247
        Timestamp: 1900831063µs
        Data Header
        CRC: 0x7e54e4
        486 12.177408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 486: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24157
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -72 dBm
        Event counter: 248
        Timestamp: 1900875833µs
        Data Header
        CRC: 0x1be4e4
        487 12.177638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 487: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24158
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 248
        Timestamp: 1900876063µs
        Data Header
        CRC: 0xd084e4
        488 12.222407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 488: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24159
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -67 dBm
        Event counter: 249
        Timestamp: 1900920832µs
        Data Header
        CRC: 0xb534e4
        489 12.222638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 489: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24160
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 249
        Timestamp: 1900921063µs
        Data Header
        CRC: 0x7e54e4
        490 12.267407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 490: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24161
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -73 dBm
        Event counter: 250
        Timestamp: 1900965832µs
        Data Header
        CRC: 0x1be4e4
        491 12.267638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 491: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24162
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 250
        Timestamp: 1900966063µs
        Data Header
        CRC: 0xd084e4
        492 12.312407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 492: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24163
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -65 dBm
        Event counter: 251
        Timestamp: 1901010832µs
        Data Header
        CRC: 0xb534e4
        493 12.312638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 493: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24164
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 251
        Timestamp: 1901011063µs
        Data Header
        CRC: 0x7e54e4
        494 12.357407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 494: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24165
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -67 dBm
        Event counter: 252
        Timestamp: 1901055832µs
        Data Header
        CRC: 0x1be4e4
        495 12.357638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 495: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24166
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 252
        Timestamp: 1901056063µs
        Data Header
        CRC: 0xd084e4
        496 12.402407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 496: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24167
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -68 dBm
        Event counter: 253
        Timestamp: 1901100832µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0xb534e4
        497 12.402638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 497: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24168
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 253
        Timestamp: 1901101063µs
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0x7e54e4
        498 12.447407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 498: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24169
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -67 dBm
        Event counter: 254
        Timestamp: 1901145832µs
        Data Header
        CRC: 0x1be4e4
        499 12.447637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 499: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24170
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 254
        Timestamp: 1901146062µs
        Data Header
        CRC: 0xd084e4
        500 12.492407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 500: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24171
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -73 dBm
        Event counter: 255
        Timestamp: 1901190832µs
        [Delta time (end to start): 44690µs]
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0xb534e4
        501 12.492637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 501: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24172
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 255
        Timestamp: 1901191062µs
        Data Header
        CRC: 0x7e54e4
        502 12.537407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 502: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24173
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -65 dBm
        Event counter: 256
        Timestamp: 1901235832µs
        Data Header
        CRC: 0x1be4e4
        503 12.537637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 503: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24174
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 256
        Timestamp: 1901236062µs
        Data Header
        CRC: 0xd084e4
        504 12.582407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 504: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24175
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -68 dBm
        Event counter: 257
        Timestamp: 1901280832µs
        Data Header
        CRC: 0xb534e4
        505 12.582638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 505: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24176
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -43 dBm
        Event counter: 257
        Timestamp: 1901281062µs
        Data Header
        CRC: 0x7e54e4
        506 12.627408      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 506: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24177
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -62 dBm
        Event counter: 258
        Timestamp: 1901325832µs
        Data Header
        CRC: 0x1be4e4
        507 12.627638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 507: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24178
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 258
        Timestamp: 1901326062µs
        Data Header
        CRC: 0xd084e4
        508 12.672407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 508: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24179
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -68 dBm
        Event counter: 259
        Timestamp: 1901370831µs
        Data Header
        CRC: 0xb534e4
        509 12.672638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 509: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24180
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 259
        Timestamp: 1901371062µs
        Data Header
        CRC: 0x7e54e4
        510 12.717407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 510: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24181
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -67 dBm
        Event counter: 260
        Timestamp: 1901415831µs
        Data Header
        CRC: 0x1be4e4
        511 12.717637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 511: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24182
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 260
        Timestamp: 1901416061µs
        Data Header
        CRC: 0xd084e4
        512 12.762407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 512: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24183
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -73 dBm
        Event counter: 261
        Timestamp: 1901460831µs
        Data Header
        CRC: 0xb534e4
        513 12.762638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 513: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24184
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 261
        Timestamp: 1901461062µs
        Data Header
        CRC: 0x7e54e4
        514 12.807407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 514: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24185
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -71 dBm
        Event counter: 262
        Timestamp: 1901505831µs
        Data Header
        CRC: 0x1be4e4
        515 12.807638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 515: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24186
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -44 dBm
        Event counter: 262
        Timestamp: 1901506062µs
        Data Header
        CRC: 0xd084e4
        516 12.852407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 516: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24187
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -66 dBm
        Event counter: 263
        Timestamp: 1901550831µs
        Data Header
        CRC: 0xb534e4
        517 12.852637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 517: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24188
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 263
        Timestamp: 1901551061µs
        Data Header
        CRC: 0x7e54e4
        518 12.897407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 518: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24189
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -66 dBm
        Event counter: 264
        Timestamp: 1901595831µs
        Data Header
        CRC: 0x1be4e4
        519 12.897637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 519: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24190
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 264
        Timestamp: 1901596061µs
        Data Header
        CRC: 0xd084e4
        520 12.942407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 520: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24191
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -65 dBm
        Event counter: 265
        Timestamp: 1901640831µs
        Data Header
        CRC: 0xb534e4
        521 12.942637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 521: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24192
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 265
        Timestamp: 1901641061µs
        Data Header
        CRC: 0x7e54e4
        522 12.987407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 522: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24193
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -73 dBm
        Event counter: 266
        Timestamp: 1901685831µs
        Data Header
        CRC: 0x1be4e4
        523 12.987637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 523: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24194
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -43 dBm
        Event counter: 266
        Timestamp: 1901686061µs
        Data Header
        CRC: 0xd084e4
        524 13.032407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 524: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24195
        Flags: 0x0a
            .... ...0 = CRC: Error
                [Expert Info (Error/Checksum): CRC is bad]
                    [CRC is bad]
                    [Severity level: Error]
                    [Group: Checksum]
        Channel Index: 26
        RSSI: -67 dBm
        Event counter: 267
        Timestamp: 1901730831µs
        Data Header
        CRC: 0xb534e2
            [Expert Info (Warning/Checksum): Incorrect CRC]
                [Incorrect CRC]
                [Severity level: Warning]
                [Group: Checksum]
        525 13.032637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 525: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24196
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 267
        Timestamp: 1901731061µs
        Data Header
        CRC: 0x7e54e4
        526 13.077406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 526: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24197
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -68 dBm
        Event counter: 268
        Timestamp: 1901775830µs
        Data Header
        CRC: 0x1be4e4
        527 13.077637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 527: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24198
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 268
        Timestamp: 1901776061µs
        Data Header
        CRC: 0xd084e4
        528 13.122406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 528: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24199
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -64 dBm
        Event counter: 269
        Timestamp: 1901820830µs
        Data Header
        CRC: 0xb534e4
        529 13.122638      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 529: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24200
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 269
        Timestamp: 1901821061µs
        Data Header
        CRC: 0x7e54e4
        530 13.167407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 530: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24201
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -68 dBm
        Event counter: 270
        Timestamp: 1901865830µs
        Data Header
        CRC: 0x1be4e4
        531 13.167637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 531: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24202
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 270
        Timestamp: 1901866060µs
        Data Header
        CRC: 0xd084e4
        532 13.212407      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 532: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24203
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 17
        RSSI: -75 dBm
        Event counter: 271
        Timestamp: 1901910830µs
        Data Header
        CRC: 0xb534c4
                [Incorrect CRC]
                [Group: Checksum]
        533 13.212637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 533: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24204
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 271
        Timestamp: 1901911060µs
        Data Header
        CRC: 0x7e54e4
        534 13.257406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 534: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24205
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -65 dBm
        Event counter: 272
        Timestamp: 1901955829µs
        Data Header
        CRC: 0x1be4e4
        535 13.257636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 535: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24206
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 272
        Timestamp: 1901956059µs
        Data Header
        CRC: 0xd084e4
        536 13.302406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 536: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24207
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -70 dBm
        Event counter: 273
        Timestamp: 1902000829µs
        Data Header
        CRC: 0xb534e4
        537 13.302637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 537: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24208
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -43 dBm
        Event counter: 273
        Timestamp: 1902001060µs
        Data Header
        CRC: 0x7e54e4
        538 13.347406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 538: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24209
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -62 dBm
        Event counter: 274
        Timestamp: 1902045829µs
        Data Header
        CRC: 0x1be4e4
        539 13.347636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 539: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24210
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 274
        Timestamp: 1902046059µs
        Data Header
        CRC: 0xd084e4
        540 13.437406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 540: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24211
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -75 dBm
        Event counter: 276
        Timestamp: 1902135829µs
        [Delta time (end to start): 89690µs]
        [Delta time (start to start): 89770µs]
        Data Header
        CRC: 0x1be4e4
        541 13.437637      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 541: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24212
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 276
        Timestamp: 1902136060µs
        Data Header
        CRC: 0xd084e4
        542 13.482406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 542: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24213
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -68 dBm
        Event counter: 277
        Timestamp: 1902180829µs
        Data Header
        CRC: 0xb534e4
        543 13.482635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 543: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24214
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 277
        Timestamp: 1902181058µs
        Data Header
        CRC: 0x7e54e4
        544 13.527406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 544: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24215
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -69 dBm
        Event counter: 278
        Timestamp: 1902225829µs
        Data Header
        CRC: 0x1be4e4
        545 13.527636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 545: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24216
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 278
        Timestamp: 1902226059µs
        [Delta time (start to start): 230%C2%B5s]
        Data Header
        CRC: 0xd084e4
        546 13.572406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 546: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24217
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -66 dBm
        Event counter: 279
        Timestamp: 1902270829µs
        Data Header
        CRC: 0xb534e4
        547 13.572636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 547: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24218
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 279
        Timestamp: 1902271059µs
        Data Header
        CRC: 0x7e54e4
        548 13.617405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 548: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24219
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -67 dBm
        Event counter: 280
        Timestamp: 1902315828µs
        Data Header
        CRC: 0x1be4e4
        549 13.617636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 549: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24220
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -52 dBm
        Event counter: 280
        Timestamp: 1902316059µs
        Data Header
        CRC: 0xd084e4
        550 13.662405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 550: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24221
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -68 dBm
        Event counter: 281
        Timestamp: 1902360828µs
        Data Header
        CRC: 0xb534e4
        551 13.662636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 551: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24222
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -46 dBm
        Event counter: 281
        Timestamp: 1902361059µs
        Data Header
        CRC: 0x7e54e4
        552 13.707405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 552: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24223
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -70 dBm
        Event counter: 282
        Timestamp: 1902405828µs
        Data Header
        CRC: 0x1be4e4
        553 13.707635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 553: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24224
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 282
        Timestamp: 1902406058µs
        Data Header
        CRC: 0xd084e4
        554 13.797405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 554: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24225
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -68 dBm
        Event counter: 284
        Timestamp: 1902495828µs
        Data Header
        CRC: 0x1be4e4
        555 13.797636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 555: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24226
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 284
        Timestamp: 1902496058µs
        Data Header
        CRC: 0xd084e4
        556 13.842406      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 556: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24227
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -66 dBm
        Event counter: 285
        Timestamp: 1902540828µs
        Data Header
        CRC: 0xb534e4
        557 13.842636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 557: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24228
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 285
        Timestamp: 1902541058µs
        Data Header
        CRC: 0x7e54e4
        558 13.887405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 558: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24229
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -66 dBm
        Event counter: 286
        Timestamp: 1902585827µs
        Data Header
        CRC: 0x1be4e4
        559 13.887636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 559: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24230
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 286
        Timestamp: 1902586058µs
        Data Header
        CRC: 0xd084e4
        560 13.932405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 560: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24231
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -72 dBm
        Event counter: 287
        Timestamp: 1902630827µs
        Data Header
        CRC: 0xb534e4
        561 13.932635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 561: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24232
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -47 dBm
        Event counter: 287
        Timestamp: 1902631057µs
        Data Header
        CRC: 0x7e54e4
        562 13.977405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 562: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24233
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -65 dBm
        Event counter: 288
        Timestamp: 1902675827µs
        Data Header
        CRC: 0x1be4e4
        563 13.977635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 563: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24234
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -45 dBm
        Event counter: 288
        Timestamp: 1902676057µs
        Data Header
        CRC: 0xd084e4
        564 14.022405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 564: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24235
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -69 dBm
        Event counter: 289
        Timestamp: 1902720827µs
        Data Header
        CRC: 0xb534e4
        565 14.022635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 565: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24236
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 289
        Timestamp: 1902721057µs
        Data Header
        CRC: 0x7e54e4
        566 14.067405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 566: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24237
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -66 dBm
        Event counter: 290
        Timestamp: 1902765827µs
        Data Header
        CRC: 0x1be4e4
        567 14.067635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 567: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24238
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 290
        Timestamp: 1902766057µs
        Data Header
        CRC: 0xd084e4
        568 14.112404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 568: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24239
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -70 dBm
        Event counter: 291
        Timestamp: 1902810826µs
        Data Header
        CRC: 0xb534e4
        569 14.112634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 569: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24240
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 291
        Timestamp: 1902811056µs
        Data Header
        CRC: 0x7e54e4
        570 14.202404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 570: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24241
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -67 dBm
        Event counter: 293
        Timestamp: 1902900826µs
        Data Header
        CRC: 0xb534e4
        571 14.202635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 571: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24242
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 293
        Timestamp: 1902901057µs
        Data Header
        CRC: 0x7e54e4
        572 14.247404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 572: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24243
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -71 dBm
        Event counter: 294
        Timestamp: 1902945826µs
        Data Header
        CRC: 0x1be4e4
        573 14.247634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 573: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24244
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -43 dBm
        Event counter: 294
        Timestamp: 1902946056µs
        Data Header
        CRC: 0xd084e4
        574 14.292404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 574: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24245
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -61 dBm
        Event counter: 295
        Timestamp: 1902990826µs
        Data Header
        CRC: 0xb534e4
        575 14.292634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 575: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24246
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 295
        Timestamp: 1902991056µs
        Data Header
        CRC: 0x7e54e4
        576 14.337405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 576: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24247
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -70 dBm
        Event counter: 296
        Timestamp: 1903035826µs
        Data Header
        CRC: 0x1be4e4
        577 14.337636      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 577: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24248
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 296
        Timestamp: 1903036057µs
        Data Header
        CRC: 0xd084e4
        578 14.382405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 578: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24249
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -72 dBm
        Event counter: 297
        Timestamp: 1903080826µs
        Data Header
        CRC: 0xb534e4
        579 14.382635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 579: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24250
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 297
        Timestamp: 1903081056µs
        Data Header
        CRC: 0x7e54e4
        580 14.427405      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 580: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24251
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -69 dBm
        Event counter: 298
        Timestamp: 1903125826µs
        Data Header
        CRC: 0x1be4e4
        581 14.427635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 581: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24252
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 298
        Timestamp: 1903126056µs
        Data Header
        CRC: 0xd084e4
        582 14.472404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 582: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24253
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -68 dBm
        Event counter: 299
        Timestamp: 1903170825µs
        Data Header
        CRC: 0xb534e4
        583 14.472635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 583: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24254
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -45 dBm
        Event counter: 299
        Timestamp: 1903171056µs
        Data Header
        CRC: 0x7e54e4
        584 14.517404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 584: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24255
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -66 dBm
        Event counter: 300
        Timestamp: 1903215825µs
        Data Header
        CRC: 0x1be4e4
        585 14.517634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 585: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24256
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 300
        Timestamp: 1903216055µs
        Data Header
        CRC: 0xd084e4
        586 14.562404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 586: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24257
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -66 dBm
        Event counter: 301
        Timestamp: 1903260825µs
        Data Header
        CRC: 0xb534e4
        587 14.562634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 587: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24258
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 301
        Timestamp: 1903261055µs
        Data Header
        CRC: 0x7e54e4
        588 14.607404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 588: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24259
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -66 dBm
        Event counter: 302
        Timestamp: 1903305825µs
        Data Header
        CRC: 0x1be4e4
        589 14.607634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 589: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24260
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 302
        Timestamp: 1903306055µs
        Data Header
        CRC: 0xd084e4
        590 14.652404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 590: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24261
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -73 dBm
        Event counter: 303
        Timestamp: 1903350825µs
        Data Header
        CRC: 0xb534e4
        591 14.652634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 591: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24262
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 303
        Timestamp: 1903351055µs
        Data Header
        CRC: 0x7e54e4
        592 14.697403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 592: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24263
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -66 dBm
        Event counter: 304
        Timestamp: 1903395824µs
        Data Header
        CRC: 0x1be4e4
        593 14.697633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 593: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24264
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 304
        Timestamp: 1903396054µs
        Data Header
        CRC: 0xd084e4
        594 14.742403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 594: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24265
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -67 dBm
        Event counter: 305
        Timestamp: 1903440824µs
        Data Header
        CRC: 0xb534e4
        595 14.742634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 595: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24266
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 305
        Timestamp: 1903441055µs
        Data Header
        CRC: 0x7e54e4
        596 14.787403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 596: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24267
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -65 dBm
        Event counter: 306
        Timestamp: 1903485824µs
        Data Header
        CRC: 0x1be4e4
        597 14.787633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 597: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24268
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -49 dBm
        Event counter: 306
        Timestamp: 1903486054µs
        Data Header
        CRC: 0xd084e4
        598 14.832403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 598: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24269
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -68 dBm
        Event counter: 307
        Timestamp: 1903530824µs
        Data Header
        CRC: 0xb534e4
        599 14.832634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 599: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24270
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -50 dBm
        Event counter: 307
        Timestamp: 1903531054µs
        Data Header
        CRC: 0x7e54e4
        600 14.922404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 600: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24271
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -66 dBm
        Event counter: 309
        Timestamp: 1903620824µs
        Data Header
        CRC: 0xb534e4
        601 14.922634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 601: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24272
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -45 dBm
        Event counter: 309
        Timestamp: 1903621054µs
        Data Header
        CRC: 0x7e54e4
        602 14.967404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 602: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24273
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -69 dBm
        Event counter: 310
        Timestamp: 1903665824µs
        Data Header
        CRC: 0x1be4e4
        603 14.967635      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 603: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24274
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -48 dBm
        Event counter: 310
        Timestamp: 1903666055µs
        Data Header
        CRC: 0xd084e4
        604 15.012404      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 604: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24275
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -62 dBm
        Event counter: 311
        Timestamp: 1903710824µs
        Data Header
        CRC: 0xb534e4
        605 15.012634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 605: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24276
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 311
        Timestamp: 1903711054µs
        Data Header
        CRC: 0x7e54e4
        606 15.057403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 606: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24277
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -70 dBm
        Event counter: 312
        Timestamp: 1903755823µs
        Data Header
        CRC: 0x1be4e4
        607 15.057634      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 607: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24278
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 312
        Timestamp: 1903756054µs
        Data Header
        CRC: 0xd084e4
        608 15.102403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 608: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24279
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 15
        RSSI: -76 dBm
        Event counter: 313
        Timestamp: 1903800823µs
        Data Header
        CRC: 0xb504c4
                [Incorrect CRC]
                [Group: Checksum]
        609 15.102633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 609: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24280
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 313
        Timestamp: 1903801053µs
        Data Header
        CRC: 0x7e54e4
        610 15.147403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 610: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24281
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -68 dBm
        Event counter: 314
        Timestamp: 1903845823µs
        Data Header
        CRC: 0x1be4e4
        611 15.147633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 611: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24282
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 314
        Timestamp: 1903846053µs
        Data Header
        CRC: 0xd084e4
        612 15.192403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 612: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24283
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -71 dBm
        Event counter: 315
        Timestamp: 1903890823µs
        Data Header
        CRC: 0xb534e4
        613 15.192633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 613: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24284
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -44 dBm
        Event counter: 315
        Timestamp: 1903891053µs
        Data Header
        CRC: 0x7e54e4
        614 15.237403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 614: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24285
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -64 dBm
        Event counter: 316
        Timestamp: 1903935823µs
        Data Header
        CRC: 0x1be4e4
        615 15.237633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 615: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24286
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 316
        Timestamp: 1903936053µs
        Data Header
        CRC: 0xd084e4
        616 15.282402      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 616: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24287
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -69 dBm
        Event counter: 317
        Timestamp: 1903980822µs
        Data Header
        CRC: 0xb534e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
        617 15.282633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 617: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 24288
        Length of packet: 10
        Flags: 0x09
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 6
        RSSI: -51 dBm
        Event counter: 317
        Timestamp: 1903981053µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0x7e54e4
        618 15.327402      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 618: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24289
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -68 dBm
        Event counter: 318
        Timestamp: 1904025822µs
        Data Header
        CRC: 0x1be4e4
        619 15.327632      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 619: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24290
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 318
        Timestamp: 1904026052µs
        Data Header
        CRC: 0xd084e4
        620 15.372402      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 620: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24291
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -72 dBm
        Event counter: 319
        Timestamp: 1904070822µs
        Data Header
        CRC: 0xb534e4
        621 15.372633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 621: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24292
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -44 dBm
        Event counter: 319
        Timestamp: 1904071053µs
        Data Header
        CRC: 0x7e54e4
        622 15.417403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 622: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24293
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -68 dBm
        Event counter: 320
        Timestamp: 1904115822µs
        Data Header
        CRC: 0x1be4e4
        623 15.417633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 623: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24294
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -44 dBm
        Event counter: 320
        Timestamp: 1904116052µs
        Data Header
        CRC: 0xd084e4
        624 15.462403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 624: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24295
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -67 dBm
        Event counter: 321
        Timestamp: 1904160822µs
        Data Header
        CRC: 0xb534e4
        625 15.462633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 625: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24296
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 321
        Timestamp: 1904161052µs
        Data Header
        CRC: 0x7e54e4
        626 15.507403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 626: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24297
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -66 dBm
        Event counter: 322
        Timestamp: 1904205822µs
        Data Header
        CRC: 0x1be4e4
        627 15.507633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 627: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24298
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 322
        Timestamp: 1904206052µs
        Data Header
        CRC: 0xd084e4
        628 15.552403      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 628: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24299
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 11
        RSSI: -65 dBm
        Event counter: 323
        Timestamp: 1904250822µs
        Data Header
        CRC: 0xb534e4
        629 15.552633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 629: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24300
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 323
        Timestamp: 1904251052µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0x7e54e4
        630 15.642402      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 630: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24301
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 25
        RSSI: -66 dBm
        Event counter: 325
        Timestamp: 1904340821µs
        [Delta time (end to start): 89689µs]
        [Delta time (start to start): 89769µs]
        Data Header
        CRC: 0xb534e4
        631 15.642633      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 631: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24302
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 325
        Timestamp: 1904341052µs
        Data Header
        CRC: 0x7e54e4
        632 15.687402      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 632: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24303
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -68 dBm
        Event counter: 326
        Timestamp: 1904385821µs
        Data Header
        CRC: 0x1be4e4
        633 15.687632      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 633: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24304
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 326
        Timestamp: 1904386051µs
        Data Header
        CRC: 0xd084e4
        634 15.732402      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 634: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24305
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -63 dBm
        Event counter: 327
        Timestamp: 1904430821µs
        Data Header
        CRC: 0xb534e4
        635 15.732632      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 635: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24306
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 327
        Timestamp: 1904431051µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0x7e54e4
        636 15.777402      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 636: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24307
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -70 dBm
        Event counter: 328
        Timestamp: 1904475821µs
        Data Header
        CRC: 0x1be4e4
        637 15.777631      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 637: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24308
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 328
        Timestamp: 1904476050µs
        [Delta time (end to start): 149µs]
        [Delta time (start to start): 229µs]
        Data Header
        CRC: 0xd084e4
        638 15.822401      Master_0x4d08532d     Slave_0x4d08532d      LE LL    29                No                                  L2CAP Fragment
    Frame 638: 29 bytes on wire (232 bits), 29 bytes captured (232 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24309
        Flags: 0x02
                    [CRC is bad]
                    [Group: Checksum]
            .... 0... = MIC (not relevant): 0
        Channel Index: 16
        RSSI: -80 dBm
        Event counter: 329
        Timestamp: 1904520820µs
        [Packet time (start to end): 104µs]
        Data Header
        L2CAP Fragment
            [Expert Info (Warning/Sequence): Missing Fragment Start]
                [Missing Fragment Start]
                [Group: Sequence]
        [L2CAP Index: 46]
        CRC: 0x134e80
                [Incorrect CRC]
                [Group: Checksum]
        639 15.867401      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 639: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24310
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -68 dBm
        Event counter: 330
        Timestamp: 1904565820µs
        [Delta time (end to start): 44896µs]
        [Delta time (start to start): 45000µs]
        Data Header
        CRC: 0x1be4e4
        640 15.867632      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 640: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24311
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 330
        Timestamp: 1904566051µs
        Data Header
        CRC: 0xd084e4
        641 15.912401      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 641: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24312
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -70 dBm
        Event counter: 331
        Timestamp: 1904610820µs
        Data Header
        CRC: 0xb534e4
        642 15.912632      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 642: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24313
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -44 dBm
        Event counter: 331
        Timestamp: 1904611051µs
        Data Header
        CRC: 0x7e54e4
        643 15.957401      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 643: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24314
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -62 dBm
        Event counter: 332
        Timestamp: 1904655820µs
        Data Header
        CRC: 0x1be4e4
        644 15.957632      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 644: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24315
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 332
        Timestamp: 1904656051µs
        Data Header
        CRC: 0xd084e4
        645 16.002400      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 645: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24316
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -70 dBm
        Event counter: 333
        Timestamp: 1904700819µs
        [Delta time (end to start): 44688µs]
        [Delta time (start to start): 44768µs]
        Data Header
        CRC: 0xb534e4
        646 16.002631      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 646: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24317
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 333
        Timestamp: 1904701050µs
        [Delta time (end to start): 151µs]
        Data Header
        [Connection Parameters in: 127]
        CRC: 0x7e54e4
        647 16.047400      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 647: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24318
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -70 dBm
        Event counter: 334
        Timestamp: 1904745819µs
        Data Header
        CRC: 0x1be4e4
        648 16.047631      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 648: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24319
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 334
        Timestamp: 1904746050µs
        Data Header
        CRC: 0xd084e4
        649 16.182400      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 649: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24320
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -65 dBm
        Event counter: 337
        Timestamp: 1904880819µs
        [Delta time (end to start): 134689µs]
        [Delta time (start to start): 134769µs]
        Data Header
        CRC: 0xb534e4
        650 16.182631      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 650: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24321
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 337
        Timestamp: 1904881050µs
        Data Header
        CRC: 0x7e54e4
        651 16.227400      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 651: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24322
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -65 dBm
        Event counter: 338
        Timestamp: 1904925819µs
        Data Header
        CRC: 0x1be4e4
        652 16.227631      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 652: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24323
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 338
        Timestamp: 1904926050µs
        Data Header
        CRC: 0xd084e4
        653 16.272400      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 653: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24324
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -66 dBm
        Event counter: 339
        Timestamp: 1904970819µs
        Data Header
        CRC: 0xb534e4
        654 16.272630      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 654: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24325
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 339
        Timestamp: 1904971049µs
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0x7e54e4
        655 16.362401      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 655: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24326
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -68 dBm
        Event counter: 341
        Timestamp: 1905060819µs
        Data Header
        CRC: 0xb534e4
        656 16.362629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 656: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24327
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -44 dBm
        Event counter: 341
        Timestamp: 1905061048µs
        Data Header
        CRC: 0x7e54e4
        657 16.407399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 657: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24328
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -66 dBm
        Event counter: 342
        Timestamp: 1905105818µs
        Data Header
        CRC: 0x1be4e4
        658 16.407630      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 658: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24329
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 342
        Timestamp: 1905106048µs
        Data Header
        CRC: 0xd084e4
        659 16.452400      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 659: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24330
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -65 dBm
        Event counter: 343
        Timestamp: 1905150818µs
        Data Header
        CRC: 0xb534e4
        660 16.452631      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 660: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24331
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 343
        Timestamp: 1905151049µs
        Data Header
        CRC: 0x7e54e4
        661 16.497400      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 661: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24332
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -67 dBm
        Event counter: 344
        Timestamp: 1905195818µs
        Data Header
        CRC: 0x1be4e4
        662 16.497631      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 662: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24333
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 344
        Timestamp: 1905196049µs
        Data Header
        CRC: 0xd084e4
        663 16.587399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 663: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24334
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -67 dBm
        Event counter: 346
        Timestamp: 1905285817µs
        [Delta time (end to start): 89688µs]
        [Delta time (start to start): 89768µs]
        Data Header
        CRC: 0x1be4e4
        664 16.587630      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 664: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24335
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 346
        Timestamp: 1905286048µs
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0xd084e4
        665 16.632399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 665: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24336
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -68 dBm
        Event counter: 347
        Timestamp: 1905330817µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0xb534e4
        666 16.632630      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 666: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24337
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -43 dBm
        Event counter: 347
        Timestamp: 1905331048µs
        Data Header
        CRC: 0x7e54e4
        667 16.677399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 667: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24338
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -62 dBm
        Event counter: 348
        Timestamp: 1905375817µs
        Data Header
        CRC: 0x1be4e4
        668 16.677629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 668: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24339
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 348
        Timestamp: 1905376047µs
        Data Header
        CRC: 0xd084e4
        669 16.722399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 669: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24340
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -71 dBm
        Event counter: 349
        Timestamp: 1905420817µs
        [Delta time (end to start): 44690µs]
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0xb534e4
        670 16.722630      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 670: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24341
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 349
        Timestamp: 1905421048µs
        Data Header
        CRC: 0x7e54e4
        671 16.812399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 671: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24342
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -66 dBm
        Event counter: 351
        Timestamp: 1905510817µs
        Data Header
        CRC: 0xb534e4
        672 16.812629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 672: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24343
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 351
        Timestamp: 1905511047µs
        Data Header
        CRC: 0x7e54e4
        673 16.902399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 673: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24344
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -73 dBm
        Event counter: 353
        Timestamp: 1905600817µs
        Data Header
        CRC: 0xb534e4
        674 16.902629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 674: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24345
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 353
        Timestamp: 1905601047µs
        Data Header
        CRC: 0x7e54e4
        675 16.947399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 675: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24346
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -65 dBm
        Event counter: 354
        Timestamp: 1905645817µs
        Data Header
        CRC: 0x1be4e4
        676 16.947629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 676: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24347
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -58 dBm
        Event counter: 354
        Timestamp: 1905646047µs
        Data Header
        CRC: 0xd084e4
        677 16.992399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 677: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24348
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -62 dBm
        Event counter: 355
        Timestamp: 1905690817µs
        Data Header
        CRC: 0xb534e4
        678 16.992629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 678: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24349
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -44 dBm
        Event counter: 355
        Timestamp: 1905691047µs
        Data Header
        CRC: 0x7e54e4
        679 17.037398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 679: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24350
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -60 dBm
        Event counter: 356
        Timestamp: 1905735816µs
        Data Header
        CRC: 0x1be4e4
        680 17.037629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 680: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24351
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 356
        Timestamp: 1905736047µs
        Data Header
        CRC: 0xd084e4
        681 17.127398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 681: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24352
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -82 dBm
        Event counter: 358
        Timestamp: 1905825816µs
        Data Header
        CRC: 0x1be4e4
        682 17.127628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 682: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24353
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 358
        Timestamp: 1905826046µs
        Data Header
        CRC: 0xd084e4
        683 17.172398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 683: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24354
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -63 dBm
        Event counter: 359
        Timestamp: 1905870816µs
        Data Header
        CRC: 0xb534e4
        684 17.172628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 684: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24355
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 359
        Timestamp: 1905871046µs
        Data Header
        CRC: 0x7e54e4
        685 17.217397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 685: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24356
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -63 dBm
        Event counter: 360
        Timestamp: 1905915815µs
        Data Header
        CRC: 0x1be4e4
        686 17.217627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 686: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24357
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 360
        Timestamp: 1905916045µs
        Data Header
        CRC: 0xd084e4
        687 17.262397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 687: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24358
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -60 dBm
        Event counter: 361
        Timestamp: 1905960815µs
        Data Header
        CRC: 0xb534e4
        688 17.262627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 688: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24359
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -47 dBm
        Event counter: 361
        Timestamp: 1905961045µs
        Data Header
        CRC: 0x7e54e4
        689 17.307397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 689: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24360
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -66 dBm
        Event counter: 362
        Timestamp: 1906005815µs
        Data Header
        CRC: 0x1be4e4
        690 17.307628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 690: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24361
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -45 dBm
        Event counter: 362
        Timestamp: 1906006046µs
        Data Header
        CRC: 0xd084e4
        691 17.352397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 691: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24362
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -79 dBm
        Event counter: 363
        Timestamp: 1906050815µs
        Data Header
        CRC: 0xb534e4
        692 17.352628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 692: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24363
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 363
        Timestamp: 1906051045µs
        Data Header
        CRC: 0x7e54e4
        693 17.397398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 693: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24364
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -62 dBm
        Event counter: 364
        Timestamp: 1906095815µs
        Data Header
        CRC: 0x1be4e4
        694 17.397628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 694: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24365
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 364
        Timestamp: 1906096045µs
        Data Header
        CRC: 0xd084e4
        695 17.442398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 695: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24366
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -67 dBm
        Event counter: 365
        Timestamp: 1906140815µs
        Data Header
        CRC: 0xb534e4
        696 17.442628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 696: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24367
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 365
        Timestamp: 1906141045µs
        Data Header
        CRC: 0x7e54e4
        697 17.487398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 697: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24368
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -62 dBm
        Event counter: 366
        Timestamp: 1906185815µs
        Data Header
        CRC: 0x1be4e4
        698 17.487628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 698: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24369
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -46 dBm
        Event counter: 366
        Timestamp: 1906186045µs
        Data Header
        CRC: 0xd084e4
        699 17.532398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 699: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24370
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -63 dBm
        Event counter: 367
        Timestamp: 1906230815µs
        Data Header
        CRC: 0xb534e4
        700 17.532628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 700: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24371
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 367
        Timestamp: 1906231045µs
        Data Header
        CRC: 0x7e54e4
        701 17.577397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 701: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24372
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -67 dBm
        Event counter: 368
        Timestamp: 1906275814µs
        Data Header
        CRC: 0x1be4e4
        702 17.577628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 702: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24373
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -45 dBm
        Event counter: 368
        Timestamp: 1906276045µs
        Data Header
        CRC: 0xd084e4
        703 17.622397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 703: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24374
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -61 dBm
        Event counter: 369
        Timestamp: 1906320814µs
        Data Header
        CRC: 0xb534e4
        704 17.622628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 704: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24375
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 369
        Timestamp: 1906321045µs
        Data Header
        CRC: 0x7e54e4
        705 17.667397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 705: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24376
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -65 dBm
        Event counter: 370
        Timestamp: 1906365814µs
        Data Header
        CRC: 0x1be4e4
        706 17.667627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 706: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24377
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 370
        Timestamp: 1906366044µs
        Data Header
        CRC: 0xd084e4
        707 17.712397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 707: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24378
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -62 dBm
        Event counter: 371
        Timestamp: 1906410814µs
        Data Header
        CRC: 0xb534e4
        708 17.757397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 708: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24379
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -61 dBm
        Event counter: 372
        Timestamp: 1906455814µs
        [Delta time (end to start): 44920µs]
        Data Header
        CRC: 0xb534e4
        709 17.757627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 709: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24380
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 372
        Timestamp: 1906456044µs
        Data Header
        CRC: 0x7e54e4
        710 17.802397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 710: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24381
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -63 dBm
        Event counter: 373
        Timestamp: 1906500814µs
        Data Header
        CRC: 0x1be4e4
        711 17.802627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 711: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24382
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -44 dBm
        Event counter: 373
        Timestamp: 1906501044µs
        Data Header
        CRC: 0xd084e4
        712 17.847396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 712: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24383
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -70 dBm
        Event counter: 374
        Timestamp: 1906545813µs
        Data Header
        CRC: 0xb534e4
        713 17.847626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 713: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24384
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -46 dBm
        Event counter: 374
        Timestamp: 1906546043µs
        Data Header
        CRC: 0x7e54e4
        714 17.892396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 714: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24385
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -66 dBm
        Event counter: 375
        Timestamp: 1906590813µs
        Data Header
        CRC: 0x1be4e4
        715 17.892627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 715: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24386
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 375
        Timestamp: 1906591044µs
        Data Header
        CRC: 0xd084e4
        716 17.937397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 716: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24387
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -60 dBm
        Event counter: 376
        Timestamp: 1906635813µs
        Data Header
        CRC: 0xb534e4
        717 17.937627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 717: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24388
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 376
        Timestamp: 1906636043µs
        Data Header
        CRC: 0x7e54e4
        718 17.982397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 718: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24389
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -58 dBm
        Event counter: 377
        Timestamp: 1906680813µs
        Data Header
        CRC: 0x1be4e4
        719 17.982627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 719: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24390
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 377
        Timestamp: 1906681043µs
        Data Header
        CRC: 0xd084e4
        720 18.027396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 720: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24391
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -58 dBm
        Event counter: 378
        Timestamp: 1906725812µs
        Data Header
        CRC: 0xb534e4
        721 18.027626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 721: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24392
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 378
        Timestamp: 1906726042µs
        Data Header
        CRC: 0x7e54e4
        722 18.072396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 722: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24393
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -61 dBm
        Event counter: 379
        Timestamp: 1906770812µs
        Data Header
        CRC: 0x1be4e4
        723 18.072627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 723: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24394
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 379
        Timestamp: 1906771043µs
        Data Header
        CRC: 0xd084e4
        724 18.117396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 724: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24395
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -62 dBm
        Event counter: 380
        Timestamp: 1906815812µs
        Data Header
        CRC: 0xb534e4
        725 18.117627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 725: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24396
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 380
        Timestamp: 1906816043µs
        Data Header
        CRC: 0x7e54e4
        726 18.162396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 726: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24397
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -66 dBm
        Event counter: 381
        Timestamp: 1906860812µs
        Data Header
        CRC: 0x1be4e4
        727 18.162627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 727: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24398
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 381
        Timestamp: 1906861043µs
        Data Header
        CRC: 0xd084e4
        728 18.207396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 728: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24399
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -58 dBm
        Event counter: 382
        Timestamp: 1906905812µs
        Data Header
        CRC: 0xb534e4
        729 18.207627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 729: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24400
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 382
        Timestamp: 1906906043µs
        Data Header
        CRC: 0x7e54e4
        730 18.252396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 730: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24401
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -57 dBm
        Event counter: 383
        Timestamp: 1906950812µs
        Data Header
        CRC: 0x1be4e4
        731 18.252626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 731: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24402
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 383
        Timestamp: 1906951042µs
        Data Header
        CRC: 0xd084e4
        732 18.297396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 732: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24403
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -64 dBm
        Event counter: 384
        Timestamp: 1906995812µs
        Data Header
        CRC: 0xb534e4
        733 18.342396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 733: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24404
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -60 dBm
        Event counter: 385
        Timestamp: 1907040812µs
        Data Header
        CRC: 0xb534e4
        734 18.342626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 734: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24405
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 385
        Timestamp: 1907041042µs
        Data Header
        CRC: 0x7e54e4
        735 18.387395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 735: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24406
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -64 dBm
        Event counter: 386
        Timestamp: 1907085811µs
        Data Header
        CRC: 0x1be4e4
        736 18.387626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 736: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24407
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 386
        Timestamp: 1907086042µs
        Data Header
        CRC: 0xd084e4
        737 18.432395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 737: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24408
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -66 dBm
        Event counter: 387
        Timestamp: 1907130811µs
        Data Header
        CRC: 0xb534e4
        738 18.432626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 738: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24409
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 387
        Timestamp: 1907131042µs
        Data Header
        CRC: 0x7e54e4
        739 18.477396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 739: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24410
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -63 dBm
        Event counter: 388
        Timestamp: 1907175811µs
        Data Header
        CRC: 0x1be4e4
        740 18.477626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 740: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24411
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 388
        Timestamp: 1907176041µs
        Data Header
        CRC: 0xd084e4
        741 18.522396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 741: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24412
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -73 dBm
        Event counter: 389
        Timestamp: 1907220811µs
        Data Header
        CRC: 0xb534e4
        742 18.522626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 742: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24413
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 389
        Timestamp: 1907221041µs
        Data Header
        CRC: 0x7e54e4
        743 18.567396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 743: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24414
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -65 dBm
        Event counter: 390
        Timestamp: 1907265811µs
        Data Header
        CRC: 0x1be4e4
        744 18.567626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 744: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24415
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 390
        Timestamp: 1907266041µs
        Data Header
        CRC: 0xd084e4
        745 18.612395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 745: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24416
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -70 dBm
        Event counter: 391
        Timestamp: 1907310810µs
        Data Header
        CRC: 0xb534e4
        746 18.612626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 746: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24417
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -54 dBm
        Event counter: 391
        Timestamp: 1907311041µs
        Data Header
        CRC: 0x7e54e4
        747 18.657395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 747: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24418
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -68 dBm
        Event counter: 392
        Timestamp: 1907355810µs
        Data Header
        CRC: 0x1be4e4
        748 18.657626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 748: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24419
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 392
        Timestamp: 1907356041µs
        Data Header
        CRC: 0xd084e4
        749 18.702395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 749: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24420
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -64 dBm
        Event counter: 393
        Timestamp: 1907400810µs
        Data Header
        CRC: 0xb534e4
        750 18.702626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 750: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24421
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 393
        Timestamp: 1907401041µs
        Data Header
        CRC: 0x7e54e4
        751 18.747395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 751: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24422
        Flags: 0x0a
            .... ...0 = CRC: Error
                [Expert Info (Error/Checksum): CRC is bad]
                    [CRC is bad]
                    [Severity level: Error]
                    [Group: Checksum]
        Channel Index: 27
        RSSI: -78 dBm
        Event counter: 394
        Timestamp: 1907445810µs
        Data Header
        CRC: 0x1be4e5
            [Expert Info (Warning/Checksum): Incorrect CRC]
                [Incorrect CRC]
                [Severity level: Warning]
                [Group: Checksum]
        752 18.747625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 752: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24423
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -44 dBm
        Event counter: 394
        Timestamp: 1907446040µs
        Data Header
        CRC: 0xd084e4
        753 18.792395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 753: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24424
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -64 dBm
        Event counter: 395
        Timestamp: 1907490810µs
        Data Header
        CRC: 0xb534e4
        754 18.792625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 754: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24425
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 395
        Timestamp: 1907491040µs
        Data Header
        CRC: 0x7e54e4
        755 18.837395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 755: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24426
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -69 dBm
        Event counter: 396
        Timestamp: 1907535810µs
        Data Header
        CRC: 0x1be4e4
        756 18.837626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 756: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24427
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 396
        Timestamp: 1907536041µs
        Data Header
        CRC: 0xd084e4
        757 18.882395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 757: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24428
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -68 dBm
        Event counter: 397
        Timestamp: 1907580810µs
        Data Header
        CRC: 0xb534e4
        758 18.882625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 758: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24429
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 397
        Timestamp: 1907581040µs
        Data Header
        CRC: 0x7e54e4
        759 18.927395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 759: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24430
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -64 dBm
        Event counter: 398
        Timestamp: 1907625810µs
        Data Header
        CRC: 0x1be4e4
        760 18.927625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 760: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24431
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 398
        Timestamp: 1907626040µs
        Data Header
        CRC: 0xd084e4
        761 18.972395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 761: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24432
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -75 dBm
        Event counter: 399
        Timestamp: 1907670810µs
        Data Header
        CRC: 0xb534e4
        762 18.972626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 762: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24433
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 399
        Timestamp: 1907671040µs
        Data Header
        CRC: 0x7e54e4
        763 19.017396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 763: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24434
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -64 dBm
        Event counter: 400
        Timestamp: 1907715810µs
        Data Header
        CRC: 0x1be4e4
        764 19.017626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 764: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24435
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 400
        Timestamp: 1907716040µs
        Data Header
        CRC: 0xd084e4
        765 19.062395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 765: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24436
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -69 dBm
        Event counter: 401
        Timestamp: 1907760809µs
        Data Header
        CRC: 0xb534e4
        766 19.062625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 766: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24437
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 401
        Timestamp: 1907761039µs
        Data Header
        CRC: 0x7e54e4
        767 19.152395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 767: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24438
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -62 dBm
        Event counter: 403
        Timestamp: 1907850809µs
        [Delta time (end to start): 89690µs]
        [Delta time (start to start): 89770µs]
        Data Header
        CRC: 0x1be4e4
        768 19.152625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 768: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24439
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 403
        Timestamp: 1907851039µs
        Data Header
        CRC: 0xd084e4
        769 19.197395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 769: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24440
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -64 dBm
        Event counter: 404
        Timestamp: 1907895809µs
        Data Header
        CRC: 0xb534e4
        770 19.197625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 770: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24441
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -45 dBm
        Event counter: 404
        Timestamp: 1907896039µs
        Data Header
        CRC: 0x7e54e4
        771 19.242395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 771: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24442
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -64 dBm
        Event counter: 405
        Timestamp: 1907940809µs
        Data Header
        CRC: 0x1be4e4
        772 19.242625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 772: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24443
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -46 dBm
        Event counter: 405
        Timestamp: 1907941039µs
        Data Header
        CRC: 0xd084e4
        773 19.287395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 773: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24444
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -69 dBm
        Event counter: 406
        Timestamp: 1907985809µs
        Data Header
        CRC: 0xb534e4
        774 19.287626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 774: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24445
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 406
        Timestamp: 1907986040µs
        Data Header
        CRC: 0x7e54e4
        775 19.332395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 775: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24446
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -63 dBm
        Event counter: 407
        Timestamp: 1908030809µs
        Data Header
        CRC: 0x1be4e4
        776 19.332625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 776: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24447
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 407
        Timestamp: 1908031039µs
        Data Header
        CRC: 0xd084e4
        777 19.377395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 777: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24448
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -62 dBm
        Event counter: 408
        Timestamp: 1908075809µs
        Data Header
        CRC: 0xb534e4
        778 19.377625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 778: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24449
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 408
        Timestamp: 1908076039µs
        Data Header
        CRC: 0x7e54e4
        779 19.422395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 779: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24450
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -63 dBm
        Event counter: 409
        Timestamp: 1908120809µs
        Data Header
        CRC: 0x1be4e4
        780 19.422625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 780: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24451
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 409
        Timestamp: 1908121039µs
        Data Header
        CRC: 0xd084e4
        781 19.467395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 781: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24452
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -70 dBm
        Event counter: 410
        Timestamp: 1908165809µs
        Data Header
        CRC: 0xb534e4
        782 19.467625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 782: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24453
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -45 dBm
        Event counter: 410
        Timestamp: 1908166039µs
        Data Header
        CRC: 0x7e54e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
        783 19.557395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 783: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 24454
        Length of packet: 10
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 5
        RSSI: -65 dBm
        Event counter: 412
        Timestamp: 1908255809µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0x1be4e4
        784 19.557626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 784: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24455
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 412
        Timestamp: 1908256039µs
        Data Header
        CRC: 0xd084e4
        785 19.602396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 785: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24456
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -62 dBm
        Event counter: 413
        Timestamp: 1908300809µs
        Data Header
        CRC: 0xb534e4
        786 19.602626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 786: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24457
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 413
        Timestamp: 1908301039µs
        Data Header
        CRC: 0x7e54e4
        787 19.647396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 787: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24458
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -60 dBm
        Event counter: 414
        Timestamp: 1908345809µs
        Data Header
        CRC: 0x1be4e4
        788 19.647626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 788: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24459
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 414
        Timestamp: 1908346039µs
        Data Header
        CRC: 0xd084e4
        789 19.692396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 789: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24460
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -68 dBm
        Event counter: 415
        Timestamp: 1908390809µs
        Data Header
        CRC: 0xb534e4
        790 19.692626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 790: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24461
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 415
        Timestamp: 1908391039µs
        Data Header
        CRC: 0x7e54e4
        791 19.737396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 791: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24462
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -62 dBm
        Event counter: 416
        Timestamp: 1908435809µs
        Data Header
        CRC: 0x1be4e4
        792 19.737626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 792: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24463
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -42 dBm
        Event counter: 416
        Timestamp: 1908436039µs
        Data Header
        CRC: 0xd084e4
        793 19.782396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 793: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24464
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -69 dBm
        Event counter: 417
        Timestamp: 1908480809µs
        Data Header
        CRC: 0xb534e4
        794 19.782626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 794: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24465
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 417
        Timestamp: 1908481039µs
        Data Header
        CRC: 0x7e54e4
        795 19.827396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 795: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24466
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -63 dBm
        Event counter: 418
        Timestamp: 1908525809µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0x1be4e4
        796 19.827626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 796: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24467
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 418
        Timestamp: 1908526039µs
        Data Header
        CRC: 0xd084e4
        797 19.872396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 797: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24468
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 17
        RSSI: -61 dBm
        Event counter: 419
        Timestamp: 1908570809µs
        Data Header
        CRC: 0xb534e4
        798 19.872626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 798: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24469
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 419
        Timestamp: 1908571039µs
        Data Header
        CRC: 0x7e54e4
        799 19.917396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 799: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24470
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -63 dBm
        Event counter: 420
        Timestamp: 1908615809µs
        Data Header
        CRC: 0x1be4e4
        800 19.917626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 800: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24471
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 420
        Timestamp: 1908616039µs
        Data Header
        CRC: 0xd084e4
        801 19.962396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 801: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24472
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 31
        RSSI: -63 dBm
        Event counter: 421
        Timestamp: 1908660809µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0xb534e4
        802 19.962626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 802: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24473
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -43 dBm
        Event counter: 421
        Timestamp: 1908661039µs
        Data Header
        CRC: 0x7e54e4
        803 20.007396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 803: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24474
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -65 dBm
        Event counter: 422
        Timestamp: 1908705809µs
        Data Header
        CRC: 0x1be4e4
        804 20.007626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 804: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24475
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 1
        RSSI: -49 dBm
        Event counter: 422
        Timestamp: 1908706039µs
        Data Header
        CRC: 0xd084e4
        805 20.052396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 805: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24476
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -60 dBm
        Event counter: 423
        Timestamp: 1908750809µs
        Data Header
        CRC: 0xb534e4
        806 20.052626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 806: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24477
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -51 dBm
        Event counter: 423
        Timestamp: 1908751039µs
        Data Header
        CRC: 0x7e54e4
        807 20.097396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 807: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24478
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -61 dBm
        Event counter: 424
        Timestamp: 1908795809µs
        Data Header
        CRC: 0x1be4e4
        808 20.097626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 808: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24479
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 424
        Timestamp: 1908796039µs
        Data Header
        CRC: 0xd084e4
        809 20.142396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 809: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24480
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -63 dBm
        Event counter: 425
        Timestamp: 1908840809µs
        Data Header
        CRC: 0xb534e4
        810 20.142627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 810: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24481
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 425
        Timestamp: 1908841040µs
        Data Header
        CRC: 0x7e54e4
        811 20.187397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 811: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24482
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -68 dBm
        Event counter: 426
        Timestamp: 1908885809µs
        Data Header
        CRC: 0x1be4e4
        812 20.187627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 812: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24483
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 426
        Timestamp: 1908886039µs
        Data Header
        CRC: 0xd084e4
        813 20.232397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 813: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24484
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -63 dBm
        Event counter: 427
        Timestamp: 1908930809µs
        Data Header
        CRC: 0xb534e4
        814 20.232627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 814: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24485
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 427
        Timestamp: 1908931039µs
        Data Header
        [Connection Parameters in: 127]
        CRC: 0x7e54e4
        815 20.277397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 815: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24486
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -64 dBm
        Event counter: 428
        Timestamp: 1908975809µs
        Data Header
        CRC: 0x1be4e4
        816 20.277627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 816: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24487
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -59 dBm
        Event counter: 428
        Timestamp: 1908976039µs
        Data Header
        CRC: 0xd084e4
        817 20.322397      Master_0x4d08532d     Slave_0x4d08532d      ATT      33                No         False                    Sent Read Request, Handle: 0x0012 (Generic Attribute: PnP ID)
    Frame 817: 33 bytes on wire (264 bits), 33 bytes captured (264 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24488
        Flags: 0x03
            .... ...1 = CRC: Ok
            .... 0... = MIC (not relevant): 0
        Channel Index: 13
        RSSI: -60 dBm
        Event counter: 429
        Timestamp: 1909020809µs
        [Packet time (start to end): 136µs]
        Data Header
        [L2CAP Index: 47]
        CRC: 0x01bc6f
    Bluetooth L2CAP Protocol
    Bluetooth Attribute Protocol
        Opcode: Read Request (0x0a)
            0... .... = Authentication Signature: False
            .0.. .... = Command: False
            ..00 1010 = Method: Read Request (0x0a)
            [Service UUID: Generic Attribute (0x1801)]
            [UUID: PnP ID (0x2a50)]
        818 20.322684      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 818: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24489
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -46 dBm
        Event counter: 429
        Timestamp: 1909021096µs
        [Delta time (end to start): 151µs]
        [Delta time (start to start): 287µs]
        Data Header
        CRC: 0x7e54e4
        819 20.367397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 819: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24490
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -61 dBm
        Event counter: 430
        Timestamp: 1909065809µs
        [Delta time (end to start): 44633µs]
        [Delta time (start to start): 44713µs]
        Data Header
        CRC: 0x1be4e4
        820 20.367628      Slave_0x4d08532d      Master_0x4d08532d     ATT      38                No         False                    Rcvd Read Response, Handle: 0x0012 (Generic Attribute: PnP ID)
    Frame 820: 38 bytes on wire (304 bits), 38 bytes captured (304 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24491
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 430
        Timestamp: 1909066040µs
        [Packet time (start to end): 176µs]
        Data Header
        [L2CAP Index: 48]
        CRC: 0x4159b9
        Opcode: Read Response (0x0b)
            ..00 1011 = Method: Read Response (0x0b)
        [Handle: 0x0012 (Generic Attribute: PnP ID)]
        Vendor ID Source: USB Implementer's Forum (0x0002)
        Vendor ID: Linux Foundation (0x1d6b)
        Product ID: 0x0246
        Version: 0x0537
        [Request in Frame: 817]
        821 20.412397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 821: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24492
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -64 dBm
        Event counter: 431
        Timestamp: 1909110809µs
        [Delta time (end to start): 44593µs]
        Data Header
        CRC: 0xb534e4
        822 20.412628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 822: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24493
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -45 dBm
        Event counter: 431
        Timestamp: 1909111040µs
        Data Header
        CRC: 0x7e54e4
        823 20.457397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 823: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24494
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -65 dBm
        Event counter: 432
        Timestamp: 1909155809µs
        Data Header
        CRC: 0x1be4e4
        824 20.457627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 824: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24495
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 432
        Timestamp: 1909156039µs
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0xd084e4
        825 20.502397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 825: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24496
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -64 dBm
        Event counter: 433
        Timestamp: 1909200809µs
        Data Header
        CRC: 0xb534e4
        826 20.502627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 826: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24497
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 433
        Timestamp: 1909201039µs
        Data Header
        CRC: 0x7e54e4
        827 20.547397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 827: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24498
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -61 dBm
        Event counter: 434
        Timestamp: 1909245809µs
        Data Header
        CRC: 0x1be4e4
        828 20.547627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 828: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24499
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 434
        Timestamp: 1909246039µs
        Data Header
        CRC: 0xd084e4
        829 20.592397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 829: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24500
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -60 dBm
        Event counter: 435
        Timestamp: 1909290809µs
        Data Header
        CRC: 0xb534e4
        830 20.592627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 830: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24501
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -45 dBm
        Event counter: 435
        Timestamp: 1909291039µs
        Data Header
        CRC: 0x7e54e4
        831 20.637397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 831: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24502
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -63 dBm
        Event counter: 436
        Timestamp: 1909335809µs
        Data Header
        CRC: 0x1be4e4
        832 20.637628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 832: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24503
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -45 dBm
        Event counter: 436
        Timestamp: 1909336040µs
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0xd084e4
        833 20.682397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 833: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24504
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -63 dBm
        Event counter: 437
        Timestamp: 1909380809µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0xb534e4
        834 20.682628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 834: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24505
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 437
        Timestamp: 1909381040µs
        Data Header
        CRC: 0x7e54e4
        835 20.727397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 835: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24506
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -64 dBm
        Event counter: 438
        Timestamp: 1909425809µs
        Data Header
        CRC: 0x1be4e4
        836 20.727628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 836: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24507
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -49 dBm
        Event counter: 438
        Timestamp: 1909426039µs
        Data Header
        CRC: 0xd084e4
        837 20.772398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 837: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24508
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -60 dBm
        Event counter: 439
        Timestamp: 1909470809µs
        [Delta time (end to start): 44690µs]
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0xb534e4
        838 20.772628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 838: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24509
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 439
        Timestamp: 1909471039µs
        Data Header
        CRC: 0x7e54e4
        839 20.817398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 839: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24510
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -61 dBm
        Event counter: 440
        Timestamp: 1909515809µs
        Data Header
        CRC: 0x1be4e4
        840 20.817628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 840: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24511
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 440
        Timestamp: 1909516039µs
        Data Header
        CRC: 0xd084e4
        841 20.862398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 841: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24512
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -63 dBm
        Event counter: 441
        Timestamp: 1909560809µs
        Data Header
        CRC: 0xb534e4
        842 20.862628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 842: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24513
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 441
        Timestamp: 1909561039µs
        Data Header
        CRC: 0x7e54e4
        843 20.907398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 843: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24514
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -64 dBm
        Event counter: 442
        Timestamp: 1909605809µs
        Data Header
        CRC: 0x1be4e4
        844 20.907628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 844: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24515
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -44 dBm
        Event counter: 442
        Timestamp: 1909606039µs
        Data Header
        CRC: 0xd084e4
        845 20.952398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 845: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24516
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -63 dBm
        Event counter: 443
        Timestamp: 1909650809µs
        Data Header
        CRC: 0xb534e4
        846 20.952629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 846: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24517
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 443
        Timestamp: 1909651040µs
        Data Header
        CRC: 0x7e54e4
        847 20.997398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 847: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24518
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -61 dBm
        Event counter: 444
        Timestamp: 1909695809µs
        Data Header
        CRC: 0x1be4e4
        848 20.997629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 848: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24519
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 444
        Timestamp: 1909696040µs
        Data Header
        CRC: 0xd084e4
        849 21.042398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 849: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24520
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -61 dBm
        Event counter: 445
        Timestamp: 1909740809µs
        Data Header
        CRC: 0xb534e4
        850 21.042628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 850: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24521
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 445
        Timestamp: 1909741039µs
        Data Header
        CRC: 0x7e54e4
        851 21.087398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 851: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24522
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -62 dBm
        Event counter: 446
        Timestamp: 1909785809µs
        Data Header
        CRC: 0x1be4e4
        852 21.087628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 852: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24523
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 446
        Timestamp: 1909786039µs
        Data Header
        CRC: 0xd084e4
        853 21.132398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 853: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24524
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -66 dBm
        Event counter: 447
        Timestamp: 1909830809µs
        Data Header
        CRC: 0xb534e4
        854 21.132628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 854: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24525
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 28
        RSSI: -45 dBm
        Event counter: 447
        Timestamp: 1909831039µs
        Data Header
        CRC: 0x7e54e4
        855 21.177398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 855: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24526
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -63 dBm
        Event counter: 448
        Timestamp: 1909875809µs
        Data Header
        CRC: 0x1be4e4
        856 21.177628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 856: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24527
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 448
        Timestamp: 1909876039µs
        Data Header
        CRC: 0xd084e4
        857 21.222398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 857: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24528
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -63 dBm
        Event counter: 449
        Timestamp: 1909920809µs
        Data Header
        CRC: 0xb534e4
        858 21.222628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 858: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24529
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 449
        Timestamp: 1909921039µs
        Data Header
        CRC: 0x7e54e4
        859 21.267398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 859: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24530
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -60 dBm
        Event counter: 450
        Timestamp: 1909965809µs
        Data Header
        CRC: 0x1be4e4
        860 21.267629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 860: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24531
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 450
        Timestamp: 1909966040µs
        Data Header
        CRC: 0xd084e4
        861 21.312398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 861: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24532
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -60 dBm
        Event counter: 451
        Timestamp: 1910010809µs
        Data Header
        CRC: 0xb534e4
        862 21.312629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 862: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24533
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 451
        Timestamp: 1910011039µs
        Data Header
        CRC: 0x7e54e4
        863 21.357399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 863: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24534
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -64 dBm
        Event counter: 452
        Timestamp: 1910055809µs
        Data Header
        CRC: 0x1be4e4
        864 21.357629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 864: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24535
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 452
        Timestamp: 1910056039µs
        Data Header
        CRC: 0xd084e4
        865 21.402399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 865: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24536
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -62 dBm
        Event counter: 453
        Timestamp: 1910100809µs
        Data Header
        CRC: 0xb534e4
        866 21.402629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 866: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24537
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 453
        Timestamp: 1910101039µs
        Data Header
        CRC: 0x7e54e4
        867 21.447399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 867: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24538
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -64 dBm
        Event counter: 454
        Timestamp: 1910145809µs
        Data Header
        CRC: 0x1be4e4
        868 21.447629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 868: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24539
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -49 dBm
        Event counter: 454
        Timestamp: 1910146039µs
        Data Header
        CRC: 0xd084e4
        869 21.492399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 869: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24540
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -61 dBm
        Event counter: 455
        Timestamp: 1910190809µs
        Data Header
        CRC: 0xb534e4
        870 21.492630      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 870: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24541
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 455
        Timestamp: 1910191040µs
        Data Header
        CRC: 0x7e54e4
        871 21.537399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 871: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24542
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -60 dBm
        Event counter: 456
        Timestamp: 1910235809µs
        Data Header
        CRC: 0x1be4e4
        872 21.537629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 872: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24543
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 456
        Timestamp: 1910236039µs
        Data Header
        CRC: 0xd084e4
        873 21.582399      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 873: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24544
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -62 dBm
        Event counter: 457
        Timestamp: 1910280809µs
        Data Header
        CRC: 0xb534e4
        874 21.582629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 874: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24545
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -45 dBm
        Event counter: 457
        Timestamp: 1910281039µs
        Data Header
        CRC: 0x7e54e4
        875 21.627398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 875: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24546
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -63 dBm
        Event counter: 458
        Timestamp: 1910325808µs
        Data Header
        CRC: 0x1be4e4
        876 21.627628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 876: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24547
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -44 dBm
        Event counter: 458
        Timestamp: 1910326038µs
        Data Header
        CRC: 0xd084e4
        877 21.672398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 877: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24548
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 459
        Timestamp: 1910370808µs
        Data Header
        CRC: 0xb534e4
        878 21.672628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 878: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24549
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 459
        Timestamp: 1910371038µs
        Data Header
        CRC: 0x7e54e4
        879 21.717398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 879: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24550
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -60 dBm
        Event counter: 460
        Timestamp: 1910415808µs
        Data Header
        CRC: 0x1be4e4
        880 21.717629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 880: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24551
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 460
        Timestamp: 1910416039µs
        Data Header
        CRC: 0xd084e4
        881 21.762398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 881: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24552
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -61 dBm
        Event counter: 461
        Timestamp: 1910460808µs
        Data Header
        CRC: 0xb534e4
        882 21.762628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 882: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24553
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -44 dBm
        Event counter: 461
        Timestamp: 1910461038µs
        Data Header
        CRC: 0x7e54e4
        883 21.807397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 883: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24554
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -62 dBm
        Event counter: 462
        Timestamp: 1910505807µs
        Data Header
        CRC: 0x1be4e4
        884 21.807628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 884: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24555
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 462
        Timestamp: 1910506038µs
        Data Header
        CRC: 0xd084e4
        885 21.852397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 885: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24556
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -65 dBm
        Event counter: 463
        Timestamp: 1910550807µs
        Data Header
        CRC: 0xb534e4
        886 21.852628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 886: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24557
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 463
        Timestamp: 1910551037µs
        Data Header
        CRC: 0x7e54e4
        887 21.897398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 887: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24558
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -63 dBm
        Event counter: 464
        Timestamp: 1910595807µs
        Data Header
        CRC: 0x1be4e4
        888 21.897628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 888: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24559
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 464
        Timestamp: 1910596037µs
        Data Header
        CRC: 0xd084e4
        889 21.942398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 889: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24560
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -62 dBm
        Event counter: 465
        Timestamp: 1910640807µs
        Data Header
        CRC: 0xb534e4
        890 21.942629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 890: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24561
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -51 dBm
        Event counter: 465
        Timestamp: 1910641038µs
        Data Header
        CRC: 0x7e54e4
        891 21.987398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 891: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24562
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -60 dBm
        Event counter: 466
        Timestamp: 1910685807µs
        Data Header
        CRC: 0x1be4e4
        892 21.987629      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 892: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24563
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 466
        Timestamp: 1910686038µs
        Data Header
        CRC: 0xd084e4
        893 22.032398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 893: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24564
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -61 dBm
        Event counter: 467
        Timestamp: 1910730807µs
        Data Header
        CRC: 0xb534e4
        894 22.032628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 894: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24565
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 467
        Timestamp: 1910731037µs
        Data Header
        CRC: 0x7e54e4
        895 22.077398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 895: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24566
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -66 dBm
        Event counter: 468
        Timestamp: 1910775807µs
        Data Header
        CRC: 0x1be4e4
        896 22.077628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 896: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24567
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -45 dBm
        Event counter: 468
        Timestamp: 1910776037µs
        Data Header
        CRC: 0xd084e4
        897 22.122398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 897: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24568
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -64 dBm
        Event counter: 469
        Timestamp: 1910820807µs
        Data Header
        CRC: 0xb534e4
        898 22.122628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 898: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24569
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 469
        Timestamp: 1910821037µs
        Data Header
        CRC: 0x7e54e4
        899 22.167398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 899: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24570
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -65 dBm
        Event counter: 470
        Timestamp: 1910865807µs
        Data Header
        CRC: 0x1be4e4
        900 22.167628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 900: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24571
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 470
        Timestamp: 1910866037µs
        Data Header
        CRC: 0xd084e4
        901 22.212398      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 901: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24572
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -61 dBm
        Event counter: 471
        Timestamp: 1910910807µs
        Data Header
        CRC: 0xb534e4
        902 22.212628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 902: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24573
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 471
        Timestamp: 1910911037µs
        Data Header
        CRC: 0x7e54e4
        903 22.257397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 903: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24574
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -60 dBm
        Event counter: 472
        Timestamp: 1910955806µs
        Data Header
        CRC: 0x1be4e4
        904 22.257627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 904: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24575
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 472
        Timestamp: 1910956036µs
        Data Header
        CRC: 0xd084e4
        905 22.302397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 905: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24576
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -64 dBm
        Event counter: 473
        Timestamp: 1911000806µs
        Data Header
        CRC: 0xb534e4
        906 22.302627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 906: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24577
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -45 dBm
        Event counter: 473
        Timestamp: 1911001036µs
        Data Header
        CRC: 0x7e54e4
        907 22.347397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 907: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24578
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -63 dBm
        Event counter: 474
        Timestamp: 1911045806µs
        Data Header
        CRC: 0x1be4e4
        908 22.347627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 908: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24579
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 474
        Timestamp: 1911046036µs
        Data Header
        CRC: 0xd084e4
        909 22.392397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 909: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24580
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -66 dBm
        Event counter: 475
        Timestamp: 1911090806µs
        Data Header
        CRC: 0xb534e4
        910 22.392627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 910: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24581
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 475
        Timestamp: 1911091036µs
        Data Header
        CRC: 0x7e54e4
        911 22.437397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 911: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24582
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -61 dBm
        Event counter: 476
        Timestamp: 1911135805µs
        Data Header
        CRC: 0x1be4e4
        912 22.437628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 912: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24583
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 476
        Timestamp: 1911136036µs
        Data Header
        CRC: 0xd084e4
        913 22.482397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 913: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24584
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -61 dBm
        Event counter: 477
        Timestamp: 1911180805µs
        Data Header
        CRC: 0xb534e4
        914 22.482628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 914: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24585
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 477
        Timestamp: 1911181036µs
        Data Header
        CRC: 0x7e54e4
        915 22.527397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 915: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24586
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -64 dBm
        Event counter: 478
        Timestamp: 1911225805µs
        Data Header
        CRC: 0x1be4e4
        916 22.527627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 916: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24587
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -45 dBm
        Event counter: 478
        Timestamp: 1911226035µs
        Data Header
        CRC: 0xd084e4
        917 22.572397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 917: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24588
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -66 dBm
        Event counter: 479
        Timestamp: 1911270805µs
        Data Header
        CRC: 0xb534e4
        918 22.572627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 918: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24589
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 30
        RSSI: -44 dBm
        Event counter: 479
        Timestamp: 1911271035µs
        Data Header
        CRC: 0x7e54e4
        919 22.617397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 919: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24590
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -65 dBm
        Event counter: 480
        Timestamp: 1911315805µs
        Data Header
        CRC: 0x1be4e4
        920 22.617628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 920: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24591
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 480
        Timestamp: 1911316036µs
        Data Header
        CRC: 0xd084e4
        921 22.662397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 921: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24592
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -61 dBm
        Event counter: 481
        Timestamp: 1911360805µs
        Data Header
        CRC: 0xb534e4
        922 22.662627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 922: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24593
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 481
        Timestamp: 1911361035µs
        Data Header
        CRC: 0x7e54e4
        923 22.707397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 923: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24594
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -61 dBm
        Event counter: 482
        Timestamp: 1911405805µs
        Data Header
        CRC: 0x1be4e4
        924 22.707627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 924: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24595
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 482
        Timestamp: 1911406035µs
        Data Header
        CRC: 0xd084e4
        925 22.752397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 925: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24596
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -64 dBm
        Event counter: 483
        Timestamp: 1911450805µs
        Data Header
        CRC: 0xb534e4
        926 22.752627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 926: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24597
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 483
        Timestamp: 1911451035µs
        Data Header
        CRC: 0x7e54e4
        927 22.842397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 927: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24598
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -63 dBm
        Event counter: 485
        Timestamp: 1911540805µs
        Data Header
        CRC: 0xb534e4
        928 22.842627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 928: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24599
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 485
        Timestamp: 1911541035µs
        Data Header
        CRC: 0x7e54e4
        929 22.887396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 929: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24600
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -64 dBm
        Event counter: 486
        Timestamp: 1911585804µs
        Data Header
        CRC: 0x1be4e4
        930 22.887627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 930: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24601
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 486
        Timestamp: 1911586035µs
        Data Header
        CRC: 0xd084e4
        931 22.932396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 931: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24602
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -68 dBm
        Event counter: 487
        Timestamp: 1911630804µs
        Data Header
        CRC: 0xb534e4
        932 22.932626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 932: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24603
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 487
        Timestamp: 1911631034µs
        Data Header
        CRC: 0x7e54e4
        933 23.022397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 933: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24604
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -65 dBm
        Event counter: 489
        Timestamp: 1911720804µs
        [Delta time (end to start): 89690µs]
        [Delta time (start to start): 89770µs]
        Data Header
        CRC: 0xb534e4
        934 23.022628      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 934: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24605
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 489
        Timestamp: 1911721035µs
        Data Header
        CRC: 0x7e54e4
        935 23.067397      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 935: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24606
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -70 dBm
        Event counter: 490
        Timestamp: 1911765804µs
        Data Header
        CRC: 0x1be4e4
        936 23.067627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 936: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24607
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 490
        Timestamp: 1911766034µs
        Data Header
        CRC: 0xd084e4
        937 23.112396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 937: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24608
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -64 dBm
        Event counter: 491
        Timestamp: 1911810803µs
        Data Header
        CRC: 0xb534e4
        938 23.112626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 938: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24609
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -51 dBm
        Event counter: 491
        Timestamp: 1911811033µs
        Data Header
        CRC: 0x7e54e4
        939 23.157396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 939: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24610
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -65 dBm
        Event counter: 492
        Timestamp: 1911855803µs
        Data Header
        CRC: 0x1be4e4
        940 23.157626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 940: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24611
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -48 dBm
        Event counter: 492
        Timestamp: 1911856033µs
        Data Header
        CRC: 0xd084e4
        941 23.202396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 941: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24612
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -62 dBm
        Event counter: 493
        Timestamp: 1911900803µs
        Data Header
        CRC: 0xb534e4
        942 23.202627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 942: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24613
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -48 dBm
        Event counter: 493
        Timestamp: 1911901034µs
        Data Header
        CRC: 0x7e54e4
        943 23.247396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 943: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24614
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -56 dBm
        Event counter: 494
        Timestamp: 1911945803µs
        Data Header
        CRC: 0x1be4e4
        944 23.247626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 944: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24615
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 494
        Timestamp: 1911946033µs
        Data Header
        CRC: 0xd084e4
        945 23.292396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 945: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24616
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -60 dBm
        Event counter: 495
        Timestamp: 1911990803µs
        Data Header
        CRC: 0xb534e4
        946 23.292626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 946: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24617
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 31
        RSSI: -44 dBm
        Event counter: 495
        Timestamp: 1911991033µs
        Data Header
        CRC: 0x7e54e4
        947 23.337396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 947: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24618
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 496
        Timestamp: 1912035803µs
        Data Header
        CRC: 0x1be4e4
        948 23.337626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 948: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24619
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 496
        Timestamp: 1912036033µs
        Data Header
        CRC: 0xd084e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
        949 23.382396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 949: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 24620
        Length of packet: 10
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 8
        RSSI: -70 dBm
        Event counter: 497
        Timestamp: 1912080803µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0xb534e4
        950 23.382626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 950: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24621
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 497
        Timestamp: 1912081033µs
        Data Header
        CRC: 0x7e54e4
        951 23.427395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 951: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24622
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -72 dBm
        Event counter: 498
        Timestamp: 1912125802µs
        Data Header
        CRC: 0x1be4e4
        952 23.427626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 952: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24623
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 498
        Timestamp: 1912126033µs
        Data Header
        CRC: 0xd084e4
        953 23.472395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 953: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24624
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -58 dBm
        Event counter: 499
        Timestamp: 1912170802µs
        Data Header
        CRC: 0xb534e4
        954 23.472626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 954: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24625
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 499
        Timestamp: 1912171032µs
        Data Header
        CRC: 0x7e54e4
        955 23.517396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 955: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24626
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -65 dBm
        Event counter: 500
        Timestamp: 1912215802µs
        Data Header
        CRC: 0x1be4e4
        956 23.517626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 956: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24627
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 29
        RSSI: -45 dBm
        Event counter: 500
        Timestamp: 1912216032µs
        Data Header
        CRC: 0xd084e4
        957 23.562396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 957: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24628
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -64 dBm
        Event counter: 501
        Timestamp: 1912260802µs
        Data Header
        CRC: 0xb534e4
        958 23.562627      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 958: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24629
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 501
        Timestamp: 1912261033µs
        Data Header
        CRC: 0x7e54e4
        959 23.607396      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 959: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24630
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -67 dBm
        Event counter: 502
        Timestamp: 1912305802µs
        Data Header
        CRC: 0x1be4e4
        960 23.607626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 960: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24631
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 6
        RSSI: -57 dBm
        Event counter: 502
        Timestamp: 1912306032µs
        Data Header
        CRC: 0xd084e4
        961 23.652395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 961: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24632
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -65 dBm
        Event counter: 503
        Timestamp: 1912350801µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0xb534e4
        962 23.652626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 962: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24633
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 503
        Timestamp: 1912351032µs
        Data Header
        CRC: 0x7e54e4
        963 23.697395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    34                No                                  Control Opcode: LL_CHANNEL_MAP_IND
    Frame 963: 34 bytes on wire (272 bits), 34 bytes captured (272 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24634
        Flags: 0x03
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 20
        RSSI: -64 dBm
        Event counter: 504
        Timestamp: 1912395801µs
        [Packet time (start to end): 144µs]
        Data Header
        Control Opcode: LL_CHANNEL_MAP_IND (0x01)
        Channel Map: ffffff071f
        Instant: 513
        CRC: 0x97abd5
        964 23.697689      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 964: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24635
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 504
        Timestamp: 1912396095µs
        [Delta time (start to start): 294µs]
        Data Header
        CRC: 0xd084e4
        965 23.742395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 965: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24636
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -64 dBm
        Event counter: 505
        Timestamp: 1912440801µs
        [Delta time (end to start): 44626µs]
        [Delta time (start to start): 44706µs]
        Data Header
        CRC: 0xb534e4
        966 23.742626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 966: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24637
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 27
        RSSI: -45 dBm
        Event counter: 505
        Timestamp: 1912441032µs
        Data Header
        CRC: 0x7e54e4
        967 23.787395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 967: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24638
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 34
        RSSI: -69 dBm
        Event counter: 506
        Timestamp: 1912485801µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0x1be4e4
        968 23.787625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 968: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24639
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 506
        Timestamp: 1912486031µs
        Data Header
        CRC: 0xd084e4
        969 23.832395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 969: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24640
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -70 dBm
        Event counter: 507
        Timestamp: 1912530801µs
        Data Header
        CRC: 0xb534e4
        970 23.832626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 970: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24641
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 507
        Timestamp: 1912531032µs
        Data Header
        CRC: 0x7e54e4
        971 23.877395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 971: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24642
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -73 dBm
        Event counter: 508
        Timestamp: 1912575801µs
        Data Header
        CRC: 0x1be4e4
        972 23.877625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 972: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24643
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 508
        Timestamp: 1912576031µs
        Data Header
        CRC: 0xd084e4
        973 23.922395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 973: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24644
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -69 dBm
        Event counter: 509
        Timestamp: 1912620801µs
        Data Header
        CRC: 0xb534e4
        974 23.922625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 974: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24645
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -46 dBm
        Event counter: 509
        Timestamp: 1912621031µs
        Data Header
        CRC: 0x7e54e4
        975 23.967395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 975: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24646
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -63 dBm
        Event counter: 510
        Timestamp: 1912665801µs
        Data Header
        CRC: 0x1be4e4
        976 23.967625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 976: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24647
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -44 dBm
        Event counter: 510
        Timestamp: 1912666031µs
        Data Header
        CRC: 0xd084e4
        977 24.012394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 977: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24648
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -63 dBm
        Event counter: 511
        Timestamp: 1912710800µs
        Data Header
        CRC: 0xb534e4
        978 24.012625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 978: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24649
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 511
        Timestamp: 1912711031µs
        Data Header
        CRC: 0x7e54e4
        979 24.057395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 979: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24650
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -66 dBm
        Event counter: 512
        Timestamp: 1912755800µs
        Data Header
        CRC: 0x1be4e4
        980 24.057626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 980: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24651
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -51 dBm
        Event counter: 512
        Timestamp: 1912756031µs
        Data Header
        [Connection Parameters in: 127]
        CRC: 0xd084e4
        981 24.102395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 981: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24652
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -78 dBm
        Event counter: 513
        Timestamp: 1912800800µs
        Data Header
        CRC: 0xb534e4
        982 24.102626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 982: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24653
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 513
        Timestamp: 1912801031µs
        Data Header
        CRC: 0x7e54e4
        983 24.147395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 983: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24654
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -64 dBm
        Event counter: 514
        Timestamp: 1912845800µs
        Data Header
        CRC: 0x1be4e4
        984 24.147626      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 984: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24655
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 514
        Timestamp: 1912846031µs
        Data Header
        CRC: 0xd084e4
        985 24.192395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 985: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24656
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -62 dBm
        Event counter: 515
        Timestamp: 1912890800µs
        Data Header
        CRC: 0xb534e4
        986 24.192625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 986: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24657
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 515
        Timestamp: 1912891030µs
        Data Header
        CRC: 0x7e54e4
        987 24.237395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 987: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24658
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -62 dBm
        Event counter: 516
        Timestamp: 1912935800µs
        Data Header
        CRC: 0x1be4e4
        988 24.237625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 988: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24659
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 516
        Timestamp: 1912936030µs
        Data Header
        CRC: 0xd084e4
        989 24.282395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 989: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24660
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -62 dBm
        Event counter: 517
        Timestamp: 1912980800µs
        Data Header
        CRC: 0xb534e4
        990 24.282625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 990: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24661
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -51 dBm
        Event counter: 517
        Timestamp: 1912981030µs
        Data Header
        CRC: 0x7e54e4
        991 24.327394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 991: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24662
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -65 dBm
        Event counter: 518
        Timestamp: 1913025799µs
        Data Header
        CRC: 0x1be4e4
        992 24.327624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 992: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24663
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 518
        Timestamp: 1913026029µs
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0xd084e4
        993 24.372394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 993: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24664
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -65 dBm
        Event counter: 519
        Timestamp: 1913070799µs
        Data Header
        CRC: 0xb534e4
        994 24.372624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 994: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24665
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 519
        Timestamp: 1913071029µs
        Data Header
        CRC: 0x7e54e4
        995 24.417394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 995: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24666
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -58 dBm
        Event counter: 520
        Timestamp: 1913115799µs
        Data Header
        CRC: 0x1be4e4
        996 24.417624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 996: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24667
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 520
        Timestamp: 1913116029µs
        Data Header
        CRC: 0xd084e4
        997 24.462394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 997: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24668
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -58 dBm
        Event counter: 521
        Timestamp: 1913160799µs
        Data Header
        CRC: 0xb534e4
        998 24.462624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 998: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24669
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 521
        Timestamp: 1913161029µs
        Data Header
        CRC: 0x7e54e4
        999 24.507394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 999: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24670
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -60 dBm
        Event counter: 522
        Timestamp: 1913205799µs
        Data Header
        CRC: 0x1be4e4
       1000 24.507624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1000: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24671
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 522
        Timestamp: 1913206029µs
        Data Header
        CRC: 0xd084e4
       1001 24.597394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1001: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24672
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -60 dBm
        Event counter: 524
        Timestamp: 1913295799µs
        Data Header
        CRC: 0xb534e4
       1002 24.597625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1002: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24673
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -44 dBm
        Event counter: 524
        Timestamp: 1913296029µs
        Data Header
        CRC: 0x7e54e4
       1003 24.642395      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1003: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24674
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -56 dBm
        Event counter: 525
        Timestamp: 1913340799µs
        Data Header
        CRC: 0x1be4e4
       1004 24.642623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1004: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24675
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 525
        Timestamp: 1913341028µs
        [Delta time (end to start): 149µs]
        [Delta time (start to start): 229µs]
        Data Header
        CRC: 0xd084e4
       1005 24.687394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1005: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24676
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -59 dBm
        Event counter: 526
        Timestamp: 1913385799µs
        [Delta time (end to start): 44691µs]
        [Delta time (start to start): 44771µs]
        Data Header
        CRC: 0xb534e4
       1006 24.687624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1006: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24677
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 26
        RSSI: -45 dBm
        Event counter: 526
        Timestamp: 1913386029µs
        Data Header
        CRC: 0x7e54e4
       1007 24.732394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1007: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24678
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -71 dBm
        Event counter: 527
        Timestamp: 1913430798µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0x1be4e4
       1008 24.732625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1008: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24679
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 527
        Timestamp: 1913431029µs
        [Delta time (end to start): 151µs]
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0xd084e4
       1009 24.777394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1009: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24680
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -62 dBm
        Event counter: 528
        Timestamp: 1913475798µs
        Data Header
        CRC: 0xb534e4
       1010 24.777624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1010: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24681
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -51 dBm
        Event counter: 528
        Timestamp: 1913476028µs
        Data Header
        CRC: 0x7e54e4
       1011 24.822394      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1011: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24682
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -64 dBm
        Event counter: 529
        Timestamp: 1913520798µs
        [Delta time (end to start): 44690µs]
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0x1be4e4
       1012 24.822625      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1012: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24683
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -48 dBm
        Event counter: 529
        Timestamp: 1913521029µs
        Data Header
        CRC: 0xd084e4
       1013 24.957393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1013: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24684
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -64 dBm
        Event counter: 532
        Timestamp: 1913655797µs
        [Delta time (end to start): 134688µs]
        [Delta time (start to start): 134768µs]
        Data Header
        CRC: 0xb534e4
       1014 24.957624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1014: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24685
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 532
        Timestamp: 1913656028µs
        Data Header
        CRC: 0x7e54e4
       1015 25.002393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1015: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24686
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -71 dBm
        Event counter: 533
        Timestamp: 1913700797µs
        Data Header
        CRC: 0x1be4e4
       1016 25.002624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1016: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24687
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 533
        Timestamp: 1913701028µs
        Data Header
        CRC: 0xd084e4
       1017 25.047393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1017: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24688
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -72 dBm
        Event counter: 534
        Timestamp: 1913745797µs
        Data Header
        CRC: 0xb534e4
       1018 25.047623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1018: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24689
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 534
        Timestamp: 1913746027µs
        Data Header
        CRC: 0x7e54e4
       1019 25.137393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1019: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24690
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -66 dBm
        Event counter: 536
        Timestamp: 1913835797µs
        Data Header
        CRC: 0xb534e4
       1020 25.137623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1020: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24691
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 536
        Timestamp: 1913836027µs
        Data Header
        CRC: 0x7e54e4
       1021 25.182393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1021: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24692
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -64 dBm
        Event counter: 537
        Timestamp: 1913880797µs
        Data Header
        CRC: 0x1be4e4
       1022 25.182623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1022: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24693
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 537
        Timestamp: 1913881027µs
        Data Header
        CRC: 0xd084e4
       1023 25.227393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1023: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24694
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -62 dBm
        Event counter: 538
        Timestamp: 1913925797µs
        Data Header
        CRC: 0xb534e4
       1024 25.227624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1024: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24695
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 538
        Timestamp: 1913926028µs
        Data Header
        CRC: 0x7e54e4
       1025 25.272393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1025: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24696
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -77 dBm
        Event counter: 539
        Timestamp: 1913970797µs
        Data Header
        CRC: 0x1be4e4
       1026 25.272623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1026: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24697
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -55 dBm
        Event counter: 539
        Timestamp: 1913971027µs
        Data Header
        CRC: 0xd084e4
       1027 25.317393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1027: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24698
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -69 dBm
        Event counter: 540
        Timestamp: 1914015797µs
        Data Header
        CRC: 0xb534e4
       1028 25.317623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1028: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24699
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -44 dBm
        Event counter: 540
        Timestamp: 1914016027µs
        Data Header
        CRC: 0x7e54e4
       1029 25.362393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1029: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24700
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -64 dBm
        Event counter: 541
        Timestamp: 1914060797µs
        Data Header
        CRC: 0x1be4e4
       1030 25.362623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1030: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24701
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 541
        Timestamp: 1914061027µs
        Data Header
        CRC: 0xd084e4
       1031 25.407393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1031: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24702
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -64 dBm
        Event counter: 542
        Timestamp: 1914105796µs
        Data Header
        CRC: 0xb534e4
       1032 25.407624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1032: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24703
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 542
        Timestamp: 1914106027µs
        Data Header
        CRC: 0x7e54e4
       1033 25.452393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1033: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24704
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -63 dBm
        Event counter: 543
        Timestamp: 1914150796µs
        Data Header
        CRC: 0x1be4e4
       1034 25.452623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1034: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24705
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 543
        Timestamp: 1914151026µs
        Data Header
        CRC: 0xd084e4
       1035 25.497393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1035: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24706
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -75 dBm
        Event counter: 544
        Timestamp: 1914195796µs
        Data Header
        CRC: 0xb534e4
       1036 25.497623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1036: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24707
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 544
        Timestamp: 1914196026µs
        Data Header
        CRC: 0x7e54e4
       1037 25.542393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1037: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24708
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -70 dBm
        Event counter: 545
        Timestamp: 1914240796µs
        Data Header
        CRC: 0x1be4e4
       1038 25.542623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1038: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24709
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 545
        Timestamp: 1914241026µs
        Data Header
        CRC: 0xd084e4
       1039 25.587393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1039: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24710
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -62 dBm
        Event counter: 546
        Timestamp: 1914285796µs
        Data Header
        CRC: 0xb534e4
       1040 25.587623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1040: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24711
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -46 dBm
        Event counter: 546
        Timestamp: 1914286026µs
        Data Header
        CRC: 0x7e54e4
       1041 25.632392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1041: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24712
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -66 dBm
        Event counter: 547
        Timestamp: 1914330795µs
        Data Header
        CRC: 0x1be4e4
       1042 25.632622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1042: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24713
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 25
        RSSI: -45 dBm
        Event counter: 547
        Timestamp: 1914331025µs
        Data Header
        CRC: 0xd084e4
       1043 25.677392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1043: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24714
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -63 dBm
        Event counter: 548
        Timestamp: 1914375795µs
        Data Header
        CRC: 0xb534e4
       1044 25.677622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1044: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24715
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 548
        Timestamp: 1914376025µs
        Data Header
        CRC: 0x7e54e4
       1045 25.722392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1045: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24716
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -68 dBm
        Event counter: 549
        Timestamp: 1914420795µs
        Data Header
        CRC: 0x1be4e4
       1046 25.722623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1046: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24717
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 549
        Timestamp: 1914421026µs
        Data Header
        CRC: 0xd084e4
       1047 25.767392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1047: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24718
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -68 dBm
        Event counter: 550
        Timestamp: 1914465795µs
        Data Header
        CRC: 0xb534e4
       1048 25.767622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1048: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24719
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 550
        Timestamp: 1914466025µs
        Data Header
        CRC: 0x7e54e4
       1049 25.812392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1049: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24720
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -63 dBm
        Event counter: 551
        Timestamp: 1914510795µs
        Data Header
        CRC: 0x1be4e4
       1050 25.812622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1050: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24721
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 551
        Timestamp: 1914511025µs
        Data Header
        CRC: 0xd084e4
       1051 25.857392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1051: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24722
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -63 dBm
        Event counter: 552
        Timestamp: 1914555795µs
        Data Header
        CRC: 0xb534e4
       1052 25.857622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1052: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24723
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -45 dBm
        Event counter: 552
        Timestamp: 1914556025µs
        Data Header
        CRC: 0x7e54e4
       1053 25.902392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1053: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24724
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -62 dBm
        Event counter: 553
        Timestamp: 1914600795µs
        Data Header
        CRC: 0x1be4e4
       1054 25.902622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1054: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24725
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 553
        Timestamp: 1914601025µs
        Data Header
        CRC: 0xd084e4
       1055 25.947392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    34                No                                  Control Opcode: LL_CHANNEL_MAP_IND
    Frame 1055: 34 bytes on wire (272 bits), 34 bytes captured (272 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24726
        Flags: 0x03
            .... ...1 = CRC: Ok
            .... 0... = MIC (not relevant): 0
        Channel Index: 0
        RSSI: -70 dBm
        Event counter: 554
        Timestamp: 1914645795µs
        Data Header
        Channel Map: ffffff011f
        Instant: 563
        CRC: 0xa1e183
       1056 25.947686      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1056: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24727
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 554
        Timestamp: 1914646089µs
        Data Header
        CRC: 0x7e54e4
       1057 25.992393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1057: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24728
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -70 dBm
        Event counter: 555
        Timestamp: 1914690795µs
        Data Header
        CRC: 0x1be4e4
       1058 25.992623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1058: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24729
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 555
        Timestamp: 1914691025µs
        Data Header
        CRC: 0xd084e4
       1059 26.037392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1059: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24730
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -66 dBm
        Event counter: 556
        Timestamp: 1914735794µs
        Data Header
        CRC: 0xb534e4
       1060 26.037623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1060: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24731
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -44 dBm
        Event counter: 556
        Timestamp: 1914736025µs
        Data Header
        CRC: 0x7e54e4
       1061 26.082392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1061: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24732
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -62 dBm
        Event counter: 557
        Timestamp: 1914780794µs
        Data Header
        CRC: 0x1be4e4
       1062 26.082622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1062: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24733
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 557
        Timestamp: 1914781024µs
        Data Header
        CRC: 0xd084e4
       1063 26.127392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1063: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24734
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -62 dBm
        Event counter: 558
        Timestamp: 1914825794µs
        Data Header
        CRC: 0xb534e4
       1064 26.127622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1064: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24735
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 558
        Timestamp: 1914826024µs
        Data Header
        CRC: 0x7e54e4
       1065 26.172392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1065: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24736
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -62 dBm
        Event counter: 559
        Timestamp: 1914870794µs
        Data Header
        CRC: 0x1be4e4
       1066 26.172622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1066: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24737
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 559
        Timestamp: 1914871024µs
        Data Header
        CRC: 0xd084e4
       1067 26.217392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1067: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24738
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -72 dBm
        Event counter: 560
        Timestamp: 1914915794µs
        Data Header
        CRC: 0xb534e4
       1068 26.217622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1068: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24739
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 560
        Timestamp: 1914916024µs
        Data Header
        CRC: 0x7e54e4
       1069 26.262392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1069: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24740
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -65 dBm
        Event counter: 561
        Timestamp: 1914960794µs
        Data Header
        CRC: 0x1be4e4
       1070 26.262622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1070: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24741
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 561
        Timestamp: 1914961024µs
        Data Header
        CRC: 0xd084e4
       1071 26.307391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1071: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24742
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -61 dBm
        Event counter: 562
        Timestamp: 1915005793µs
        Data Header
        CRC: 0xb534e4
       1072 26.307622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1072: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24743
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 562
        Timestamp: 1915006024µs
        Data Header
        CRC: 0x7e54e4
       1073 26.352391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1073: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24744
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -63 dBm
        Event counter: 563
        Timestamp: 1915050793µs
        Data Header
        CRC: 0x1be4e4
       1074 26.352622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1074: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24745
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 563
        Timestamp: 1915051024µs
        Data Header
        CRC: 0xd084e4
       1075 26.397391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1075: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24746
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -64 dBm
        Event counter: 564
        Timestamp: 1915095793µs
        Data Header
        CRC: 0xb534e4
       1076 26.397621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1076: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24747
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 564
        Timestamp: 1915096023µs
        Data Header
        CRC: 0x7e54e4
       1077 26.442391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1077: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24748
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -65 dBm
        Event counter: 565
        Timestamp: 1915140793µs
        Data Header
        CRC: 0x1be4e4
       1078 26.442622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1078: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24749
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -49 dBm
        Event counter: 565
        Timestamp: 1915141024µs
        Data Header
        CRC: 0xd084e4
       1079 26.487391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1079: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24750
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -68 dBm
        Event counter: 566
        Timestamp: 1915185793µs
        Data Header
        CRC: 0xb534e4
       1080 26.487622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1080: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24751
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 566
        Timestamp: 1915186023µs
        Data Header
        CRC: 0x7e54e4
       1081 26.532392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1081: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24752
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -65 dBm
        Event counter: 567
        Timestamp: 1915230793µs
        Data Header
        CRC: 0x1be4e4
       1082 26.532622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1082: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24753
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 567
        Timestamp: 1915231023µs
        Data Header
        CRC: 0xd084e4
       1083 26.577392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1083: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24754
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -70 dBm
        Event counter: 568
        Timestamp: 1915275793µs
        Data Header
        CRC: 0xb534e4
       1084 26.577622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1084: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24755
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -45 dBm
        Event counter: 568
        Timestamp: 1915276023µs
        Data Header
        CRC: 0x7e54e4
       1085 26.622392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1085: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24756
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -63 dBm
        Event counter: 569
        Timestamp: 1915320793µs
        Data Header
        CRC: 0x1be4e4
       1086 26.622623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1086: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24757
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 569
        Timestamp: 1915321024µs
        Data Header
        CRC: 0xd084e4
       1087 26.667392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1087: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24758
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -63 dBm
        Event counter: 570
        Timestamp: 1915365793µs
        Data Header
        CRC: 0xb534e4
       1088 26.667623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1088: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24759
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 570
        Timestamp: 1915366024µs
        Data Header
        CRC: 0x7e54e4
       1089 26.712391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1089: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24760
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -63 dBm
        Event counter: 571
        Timestamp: 1915410792µs
        [Delta time (end to start): 44688µs]
        [Delta time (start to start): 44768µs]
        Data Header
        CRC: 0x1be4e4
       1090 26.712622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1090: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24761
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 571
        Timestamp: 1915411023µs
        Data Header
        CRC: 0xd084e4
       1091 26.757391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1091: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24762
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -64 dBm
        Event counter: 572
        Timestamp: 1915455792µs
        Data Header
        CRC: 0xb534e4
       1092 26.757622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1092: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24763
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 572
        Timestamp: 1915456023µs
        Data Header
        CRC: 0x7e54e4
       1093 26.802391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1093: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24764
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -70 dBm
        Event counter: 573
        Timestamp: 1915500792µs
        Data Header
        CRC: 0x1be4e4
       1094 26.802621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1094: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24765
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 573
        Timestamp: 1915501022µs
        Data Header
        CRC: 0xd084e4
       1095 26.847391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1095: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24766
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -64 dBm
        Event counter: 574
        Timestamp: 1915545792µs
        Data Header
        CRC: 0xb534e4
       1096 26.847621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1096: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24767
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 574
        Timestamp: 1915546022µs
        Data Header
        CRC: 0x7e54e4
       1097 26.892391      Master_0x4d08532d     Slave_0x4d08532d      ATT      35                No         False                    Sent Write Request, Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)
    Frame 1097: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24768
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -63 dBm
        Event counter: 575
        Timestamp: 1915590792µs
        [Packet time (start to end): 152µs]
        Data Header
        [L2CAP Index: 49]
        CRC: 0x30e632
    Bluetooth L2CAP Protocol
    Bluetooth Attribute Protocol
        Opcode: Write Request (0x12)
            0... .... = Authentication Signature: False
            .0.. .... = Command: False
            ..01 0010 = Method: Write Request (0x12)
            [Service UUID: Generic Attribute (0x1801)]
            [Characteristic UUID: Service Changed (0x2a05)]
            [UUID: Client Characteristic Configuration (0x2902)]
        Characteristic Configuration Client: 0x0002, Indication
       1098 26.892694      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1098: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24769
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 575
        Timestamp: 1915591095µs
        [Delta time (start to start): 303µs]
        Data Header
        CRC: 0xd084e4
       1099 26.937391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1099: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24770
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -65 dBm
        Event counter: 576
        Timestamp: 1915635792µs
        [Delta time (end to start): 44617µs]
        [Delta time (start to start): 44697µs]
        Data Header
        CRC: 0xb534e4
       1100 26.937622      Slave_0x4d08532d      Master_0x4d08532d     ATT      31                No         False                    Rcvd Write Response, Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)
    Frame 1100: 31 bytes on wire (248 bits), 31 bytes captured (248 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24771
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -51 dBm
        Event counter: 576
        Timestamp: 1915636023µs
        [Packet time (start to end): 120µs]
        Data Header
        [L2CAP Index: 50]
        CRC: 0xb018a2
        Opcode: Write Response (0x13)
            ..01 0011 = Method: Write Response (0x13)
        [Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)]
        [Request in Frame: 1097]
       1101 26.982391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1101: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24772
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -64 dBm
        Event counter: 577
        Timestamp: 1915680792µs
        [Delta time (end to start): 44649µs]
        Data Header
        CRC: 0x1be4e4
       1102 26.982621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1102: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24773
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 577
        Timestamp: 1915681022µs
        Data Header
        CRC: 0xd084e4
       1103 27.027391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1103: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24774
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -63 dBm
        Event counter: 578
        Timestamp: 1915725792µs
        Data Header
        CRC: 0xb534e4
       1104 27.027622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1104: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24775
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -44 dBm
        Event counter: 578
        Timestamp: 1915726022µs
        Data Header
        CRC: 0x7e54e4
       1105 27.072392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1105: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24776
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -68 dBm
        Event counter: 579
        Timestamp: 1915770792µs
        Data Header
        CRC: 0x1be4e4
       1106 27.072622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1106: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24777
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 579
        Timestamp: 1915771022µs
        Data Header
        CRC: 0xd084e4
       1107 27.117392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1107: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24778
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -64 dBm
        Event counter: 580
        Timestamp: 1915815792µs
        Data Header
        CRC: 0xb534e4
       1108 27.117622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1108: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24779
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 580
        Timestamp: 1915816022µs
        Data Header
        CRC: 0x7e54e4
       1109 27.162392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1109: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24780
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -64 dBm
        Event counter: 581
        Timestamp: 1915860792µs
        Data Header
        CRC: 0x1be4e4
       1110 27.162623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1110: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24781
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 581
        Timestamp: 1915861023µs
        Data Header
        CRC: 0xd084e4
       1111 27.207392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1111: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24782
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -64 dBm
        Event counter: 582
        Timestamp: 1915905792µs
        Data Header
        CRC: 0xb534e4
       1112 27.207622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1112: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24783
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 582
        Timestamp: 1915906022µs
        Data Header
        CRC: 0x7e54e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
       1113 27.252392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1113: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 24784
        Length of packet: 10
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 18
        RSSI: -62 dBm
        Event counter: 583
        Timestamp: 1915950792µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0x1be4e4
       1114 27.252622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1114: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24785
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -43 dBm
        Event counter: 583
        Timestamp: 1915951022µs
        Data Header
        CRC: 0xd084e4
       1115 27.297392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1115: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24786
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -66 dBm
        Event counter: 584
        Timestamp: 1915995792µs
        Data Header
        CRC: 0xb534e4
       1116 27.297622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1116: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24787
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 584
        Timestamp: 1915996022µs
        Data Header
        CRC: 0x7e54e4
       1117 27.342392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1117: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24788
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -66 dBm
        Event counter: 585
        Timestamp: 1916040792µs
        Data Header
        CRC: 0x1be4e4
       1118 27.342622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1118: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24789
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 585
        Timestamp: 1916041022µs
        Data Header
        CRC: 0xd084e4
       1119 27.387392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1119: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24790
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -63 dBm
        Event counter: 586
        Timestamp: 1916085792µs
        Data Header
        CRC: 0xb534e4
       1120 27.387623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1120: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24791
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -51 dBm
        Event counter: 586
        Timestamp: 1916086023µs
        Data Header
        CRC: 0x7e54e4
       1121 27.432392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1121: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24792
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -64 dBm
        Event counter: 587
        Timestamp: 1916130792µs
        Data Header
        CRC: 0x1be4e4
       1122 27.432622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1122: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24793
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 587
        Timestamp: 1916131022µs
        Data Header
        CRC: 0xd084e4
       1123 27.477392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1123: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24794
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -62 dBm
        Event counter: 588
        Timestamp: 1916175792µs
        Data Header
        CRC: 0xb534e4
       1124 27.477623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1124: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24795
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 16
        RSSI: -43 dBm
        Event counter: 588
        Timestamp: 1916176023µs
        Data Header
        CRC: 0x7e54e4
       1125 27.522392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1125: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24796
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -69 dBm
        Event counter: 589
        Timestamp: 1916220792µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0x1be4e4
       1126 27.522622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1126: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24797
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 589
        Timestamp: 1916221022µs
        Data Header
        CRC: 0xd084e4
       1127 27.567392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1127: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24798
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 0
        RSSI: -63 dBm
        Event counter: 590
        Timestamp: 1916265792µs
        Data Header
        CRC: 0xb534e4
       1128 27.567622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1128: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24799
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -51 dBm
        Event counter: 590
        Timestamp: 1916266022µs
        Data Header
        CRC: 0x7e54e4
       1129 27.612392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1129: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24800
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -63 dBm
        Event counter: 591
        Timestamp: 1916310792µs
        Data Header
        CRC: 0x1be4e4
       1130 27.612623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1130: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24801
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -51 dBm
        Event counter: 591
        Timestamp: 1916311022µs
        Data Header
        CRC: 0xd084e4
       1131 27.657393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1131: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24802
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 7
        RSSI: -65 dBm
        Event counter: 592
        Timestamp: 1916355792µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0xb534e4
       1132 27.657624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1132: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24803
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 592
        Timestamp: 1916356023µs
        Data Header
        CRC: 0x7e54e4
       1133 27.702393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1133: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24804
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -63 dBm
        Event counter: 593
        Timestamp: 1916400792µs
        Data Header
        CRC: 0x1be4e4
       1134 27.702623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1134: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24805
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 593
        Timestamp: 1916401022µs
        Data Header
        CRC: 0xd084e4
       1135 27.747393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1135: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24806
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -69 dBm
        Event counter: 594
        Timestamp: 1916445792µs
        Data Header
        CRC: 0xb534e4
       1136 27.747624      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1136: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24807
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 594
        Timestamp: 1916446023µs
        Data Header
        CRC: 0x7e54e4
       1137 27.792393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1137: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24808
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -63 dBm
        Event counter: 595
        Timestamp: 1916490792µs
        Data Header
        CRC: 0x1be4e4
       1138 27.792623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1138: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24809
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 595
        Timestamp: 1916491022µs
        Data Header
        CRC: 0xd084e4
       1139 27.837393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1139: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24810
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -63 dBm
        Event counter: 596
        Timestamp: 1916535792µs
        Data Header
        CRC: 0xb534e4
       1140 27.837623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1140: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24811
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -51 dBm
        Event counter: 596
        Timestamp: 1916536022µs
        Data Header
        CRC: 0x7e54e4
       1141 27.882393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1141: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24812
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -64 dBm
        Event counter: 597
        Timestamp: 1916580792µs
        Data Header
        CRC: 0x1be4e4
       1142 27.882623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1142: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24813
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -51 dBm
        Event counter: 597
        Timestamp: 1916581022µs
        Data Header
        CRC: 0xd084e4
       1143 27.927393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1143: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24814
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -65 dBm
        Event counter: 598
        Timestamp: 1916625792µs
        Data Header
        CRC: 0xb534e4
       1144 27.927623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1144: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24815
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 598
        Timestamp: 1916626022µs
        Data Header
        [Connection Parameters in: 127]
        CRC: 0x7e54e4
       1145 27.972393      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1145: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24816
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -62 dBm
        Event counter: 599
        Timestamp: 1916670792µs
        Data Header
        CRC: 0x1be4e4
       1146 27.972623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1146: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24817
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 599
        Timestamp: 1916671022µs
        Data Header
        CRC: 0xd084e4
       1147 28.017392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1147: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24818
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -65 dBm
        Event counter: 600
        Timestamp: 1916715791µs
        Data Header
        CRC: 0xb534e4
       1148 28.017623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1148: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24819
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 600
        Timestamp: 1916716022µs
        Data Header
        CRC: 0x7e54e4
       1149 28.062392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1149: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24820
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -65 dBm
        Event counter: 601
        Timestamp: 1916760791µs
        Data Header
        CRC: 0x1be4e4
       1150 28.062623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1150: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24821
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 601
        Timestamp: 1916761022µs
        Data Header
        CRC: 0xd084e4
       1151 28.107392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1151: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24822
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -63 dBm
        Event counter: 602
        Timestamp: 1916805791µs
        Data Header
        CRC: 0xb534e4
       1152 28.107622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1152: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24823
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -53 dBm
        Event counter: 602
        Timestamp: 1916806021µs
        Data Header
        CRC: 0x7e54e4
       1153 28.152392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1153: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24824
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -64 dBm
        Event counter: 603
        Timestamp: 1916850791µs
        Data Header
        CRC: 0x1be4e4
       1154 28.152622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1154: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24825
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -48 dBm
        Event counter: 603
        Timestamp: 1916851021µs
        Data Header
        CRC: 0xd084e4
       1155 28.197392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1155: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24826
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -63 dBm
        Event counter: 604
        Timestamp: 1916895790µs
        Data Header
        CRC: 0xb534e4
       1156 28.197623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1156: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24827
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -43 dBm
        Event counter: 604
        Timestamp: 1916896021µs
        Data Header
        CRC: 0x7e54e4
       1157 28.242392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1157: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24828
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -71 dBm
        Event counter: 605
        Timestamp: 1916940790µs
        Data Header
        CRC: 0x1be4e4
       1158 28.242623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1158: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24829
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 605
        Timestamp: 1916941021µs
        Data Header
        CRC: 0xd084e4
       1159 28.287392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1159: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24830
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -62 dBm
        Event counter: 606
        Timestamp: 1916985790µs
        Data Header
        CRC: 0xb534e4
       1160 28.287622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1160: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24831
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -51 dBm
        Event counter: 606
        Timestamp: 1916986020µs
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0x7e54e4
       1161 28.332392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1161: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24832
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -62 dBm
        Event counter: 607
        Timestamp: 1917030790µs
        Data Header
        CRC: 0x1be4e4
       1162 28.332623      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1162: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24833
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -51 dBm
        Event counter: 607
        Timestamp: 1917031021µs
        Data Header
        CRC: 0xd084e4
       1163 28.377392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1163: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24834
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -64 dBm
        Event counter: 608
        Timestamp: 1917075790µs
        Data Header
        CRC: 0xb534e4
       1164 28.377622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1164: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24835
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 608
        Timestamp: 1917076020µs
        Data Header
        CRC: 0x7e54e4
       1165 28.422392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1165: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24836
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -63 dBm
        Event counter: 609
        Timestamp: 1917120790µs
        Data Header
        CRC: 0x1be4e4
       1166 28.422622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1166: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24837
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 609
        Timestamp: 1917121020µs
        Data Header
        CRC: 0xd084e4
       1167 28.467392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1167: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24838
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -66 dBm
        Event counter: 610
        Timestamp: 1917165790µs
        Data Header
        CRC: 0xb534e4
       1168 28.467622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1168: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24839
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 610
        Timestamp: 1917166020µs
        Data Header
        CRC: 0x7e54e4
       1169 28.512392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1169: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24840
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -62 dBm
        Event counter: 611
        Timestamp: 1917210790µs
        Data Header
        CRC: 0x1be4e4
       1170 28.512622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1170: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24841
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 611
        Timestamp: 1917211020µs
        Data Header
        CRC: 0xd084e4
       1171 28.557392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1171: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24842
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -62 dBm
        Event counter: 612
        Timestamp: 1917255790µs
        Data Header
        CRC: 0xb534e4
       1172 28.557622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1172: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24843
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 612
        Timestamp: 1917256020µs
        Data Header
        CRC: 0x7e54e4
       1173 28.602392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1173: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24844
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -65 dBm
        Event counter: 613
        Timestamp: 1917300790µs
        Data Header
        CRC: 0x1be4e4
       1174 28.602622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1174: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24845
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -57 dBm
        Event counter: 613
        Timestamp: 1917301020µs
        Data Header
        CRC: 0xd084e4
       1175 28.647391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1175: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24846
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -64 dBm
        Event counter: 614
        Timestamp: 1917345789µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0xb534e4
       1176 28.647622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1176: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24847
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 614
        Timestamp: 1917346020µs
        [Delta time (end to start): 151µs]
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0x7e54e4
       1177 28.692391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1177: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24848
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -63 dBm
        Event counter: 615
        Timestamp: 1917390789µs
        Data Header
        CRC: 0x1be4e4
       1178 28.692621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1178: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24849
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 615
        Timestamp: 1917391019µs
        Data Header
        CRC: 0xd084e4
       1179 28.737391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1179: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24850
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -64 dBm
        Event counter: 616
        Timestamp: 1917435789µs
        [Delta time (end to start): 44690µs]
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0xb534e4
       1180 28.737622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1180: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24851
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 616
        Timestamp: 1917436019µs
        Data Header
        CRC: 0x7e54e4
       1181 28.782392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1181: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24852
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -67 dBm
        Event counter: 617
        Timestamp: 1917480789µs
        Data Header
        CRC: 0x1be4e4
       1182 28.782622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1182: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24853
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -46 dBm
        Event counter: 617
        Timestamp: 1917481019µs
        Data Header
        CRC: 0xd084e4
       1183 28.827391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1183: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24854
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -65 dBm
        Event counter: 618
        Timestamp: 1917525788µs
        Data Header
        CRC: 0xb534e4
       1184 28.827622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1184: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24855
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 618
        Timestamp: 1917526019µs
        Data Header
        CRC: 0x7e54e4
       1185 28.872391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1185: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24856
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -65 dBm
        Event counter: 619
        Timestamp: 1917570788µs
        Data Header
        CRC: 0x1be4e4
       1186 28.872622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1186: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24857
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 619
        Timestamp: 1917571019µs
        Data Header
        CRC: 0xd084e4
       1187 28.917391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1187: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24858
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -63 dBm
        Event counter: 620
        Timestamp: 1917615788µs
        Data Header
        CRC: 0xb534e4
       1188 28.917621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1188: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24859
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 620
        Timestamp: 1917616018µs
        Data Header
        CRC: 0x7e54e4
       1189 28.962391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1189: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24860
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -66 dBm
        Event counter: 621
        Timestamp: 1917660788µs
        Data Header
        CRC: 0x1be4e4
       1190 28.962621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1190: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24861
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 621
        Timestamp: 1917661018µs
        Data Header
        CRC: 0xd084e4
       1191 29.007391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1191: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24862
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -66 dBm
        Event counter: 622
        Timestamp: 1917705788µs
        Data Header
        CRC: 0xb534e4
       1192 29.007621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1192: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24863
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 622
        Timestamp: 1917706018µs
        Data Header
        CRC: 0x7e54e4
       1193 29.052391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1193: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24864
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -65 dBm
        Event counter: 623
        Timestamp: 1917750788µs
        Data Header
        CRC: 0x1be4e4
       1194 29.052622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1194: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24865
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -51 dBm
        Event counter: 623
        Timestamp: 1917751019µs
        Data Header
        CRC: 0xd084e4
       1195 29.097391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1195: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24866
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -65 dBm
        Event counter: 624
        Timestamp: 1917795788µs
        Data Header
        CRC: 0xb534e4
       1196 29.097621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1196: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24867
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 624
        Timestamp: 1917796018µs
        Data Header
        CRC: 0x7e54e4
       1197 29.142391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1197: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24868
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -63 dBm
        Event counter: 625
        Timestamp: 1917840788µs
        Data Header
        CRC: 0x1be4e4
       1198 29.142622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1198: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24869
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 625
        Timestamp: 1917841019µs
        Data Header
        CRC: 0xd084e4
       1199 29.187391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1199: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24870
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -69 dBm
        Event counter: 626
        Timestamp: 1917885788µs
        Data Header
        CRC: 0xb534e4
       1200 29.187620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1200: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24871
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -45 dBm
        Event counter: 626
        Timestamp: 1917886017µs
        [Delta time (end to start): 149µs]
        [Delta time (start to start): 229µs]
        Data Header
        CRC: 0x7e54e4
       1201 29.232390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1201: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24872
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -64 dBm
        Event counter: 627
        Timestamp: 1917930787µs
        Data Header
        CRC: 0x1be4e4
       1202 29.232620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1202: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24873
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -51 dBm
        Event counter: 627
        Timestamp: 1917931017µs
        Data Header
        CRC: 0xd084e4
       1203 29.277390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1203: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24874
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -64 dBm
        Event counter: 628
        Timestamp: 1917975787µs
        Data Header
        CRC: 0xb534e4
       1204 29.277620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1204: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24875
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -51 dBm
        Event counter: 628
        Timestamp: 1917976017µs
        Data Header
        CRC: 0x7e54e4
       1205 29.322390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1205: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24876
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -65 dBm
        Event counter: 629
        Timestamp: 1918020787µs
        Data Header
        CRC: 0x1be4e4
       1206 29.322621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1206: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24877
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 629
        Timestamp: 1918021018µs
        Data Header
        CRC: 0xd084e4
       1207 29.367390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1207: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24878
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -64 dBm
        Event counter: 630
        Timestamp: 1918065787µs
        Data Header
        CRC: 0xb534e4
       1208 29.367621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1208: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24879
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 630
        Timestamp: 1918066018µs
        Data Header
        CRC: 0x7e54e4
       1209 29.412390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1209: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24880
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -64 dBm
        Event counter: 631
        Timestamp: 1918110787µs
        Data Header
        CRC: 0x1be4e4
       1210 29.412621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1210: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24881
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 631
        Timestamp: 1918111017µs
        Data Header
        CRC: 0xd084e4
       1211 29.457391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1211: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24882
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -63 dBm
        Event counter: 632
        Timestamp: 1918155787µs
        Data Header
        CRC: 0xb534e4
       1212 29.457621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1212: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24883
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 632
        Timestamp: 1918156017µs
        Data Header
        CRC: 0x7e54e4
       1213 29.502390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1213: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24884
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -63 dBm
        Event counter: 633
        Timestamp: 1918200786µs
        Data Header
        CRC: 0x1be4e4
       1214 29.502621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1214: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24885
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 633
        Timestamp: 1918201017µs
        Data Header
        CRC: 0xd084e4
       1215 29.547390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1215: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24886
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -64 dBm
        Event counter: 634
        Timestamp: 1918245786µs
        Data Header
        CRC: 0xb534e4
       1216 29.547620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1216: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24887
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 634
        Timestamp: 1918246016µs
        Data Header
        CRC: 0x7e54e4
       1217 29.592390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1217: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24888
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -64 dBm
        Event counter: 635
        Timestamp: 1918290786µs
        Data Header
        CRC: 0x1be4e4
       1218 29.592621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1218: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24889
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 635
        Timestamp: 1918291017µs
        Data Header
        CRC: 0xd084e4
       1219 29.637390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1219: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24890
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -62 dBm
        Event counter: 636
        Timestamp: 1918335786µs
        Data Header
        CRC: 0xb534e4
       1220 29.637621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1220: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24891
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 636
        Timestamp: 1918336017µs
        Data Header
        CRC: 0x7e54e4
       1221 29.682390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1221: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24892
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -65 dBm
        Event counter: 637
        Timestamp: 1918380786µs
        Data Header
        CRC: 0x1be4e4
       1222 29.682620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1222: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24893
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 637
        Timestamp: 1918381016µs
        Data Header
        CRC: 0xd084e4
       1223 29.727390      Master_0x4d08532d     Slave_0x4d08532d      ATT      35                No         False                    Sent Write Request, Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)
    Frame 1223: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24894
        Flags: 0x03
            .... ...1 = CRC: Ok
            .... 0... = MIC (not relevant): 0
        Channel Index: 33
        RSSI: -66 dBm
        Event counter: 638
        Timestamp: 1918425786µs
        Data Header
        [L2CAP Index: 51]
        CRC: 0xf46186
        Characteristic Configuration Client: 0x0000
       1224 29.727692      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1224: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24895
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 638
        Timestamp: 1918426088µs
        [Delta time (start to start): 302µs]
        Data Header
        CRC: 0x7e54e4
       1225 29.772390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1225: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24896
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -64 dBm
        Event counter: 639
        Timestamp: 1918470786µs
        [Delta time (end to start): 44618µs]
        [Delta time (start to start): 44698µs]
        Data Header
        CRC: 0x1be4e4
       1226 29.772621      Slave_0x4d08532d      Master_0x4d08532d     ATT      31                No         False                    Rcvd Write Response, Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)
    Frame 1226: 31 bytes on wire (248 bits), 31 bytes captured (248 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24897
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 639
        Timestamp: 1918471017µs
        Data Header
        [L2CAP Index: 52]
        CRC: 0xa969f6
        [Request in Frame: 1223]
       1227 29.817390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1227: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24898
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -65 dBm
        Event counter: 640
        Timestamp: 1918515786µs
        Data Header
        CRC: 0xb534e4
       1228 29.817620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1228: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24899
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -54 dBm
        Event counter: 640
        Timestamp: 1918516016µs
        Data Header
        CRC: 0x7e54e4
       1229 29.862390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1229: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24900
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -62 dBm
        Event counter: 641
        Timestamp: 1918560786µs
        Data Header
        CRC: 0x1be4e4
       1230 29.862620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1230: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24901
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 641
        Timestamp: 1918561016µs
        Data Header
        CRC: 0xd084e4
       1231 29.907390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1231: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24902
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -70 dBm
        Event counter: 642
        Timestamp: 1918605786µs
        Data Header
        CRC: 0xb534e4
       1232 29.907620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1232: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24903
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 642
        Timestamp: 1918606016µs
        Data Header
        CRC: 0x7e54e4
       1233 29.952390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1233: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24904
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -63 dBm
        Event counter: 643
        Timestamp: 1918650786µs
        Data Header
        CRC: 0x1be4e4
       1234 29.952621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1234: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24905
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 643
        Timestamp: 1918651017µs
        Data Header
        CRC: 0xd084e4
       1235 29.997391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1235: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24906
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 644
        Timestamp: 1918695786µs
        Data Header
        CRC: 0xb534e4
       1236 29.997622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1236: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24907
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 644
        Timestamp: 1918696017µs
        Data Header
        CRC: 0x7e54e4
       1237 30.042391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1237: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24908
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -65 dBm
        Event counter: 645
        Timestamp: 1918740786µs
        Data Header
        CRC: 0x1be4e4
       1238 30.042622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1238: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24909
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -49 dBm
        Event counter: 645
        Timestamp: 1918741017µs
        Data Header
        CRC: 0xd084e4
       1239 30.087391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1239: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24910
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -63 dBm
        Event counter: 646
        Timestamp: 1918785786µs
        Data Header
        CRC: 0xb534e4
       1240 30.087622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1240: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24911
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -44 dBm
        Event counter: 646
        Timestamp: 1918786017µs
        Data Header
        CRC: 0x7e54e4
       1241 30.132391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1241: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24912
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -65 dBm
        Event counter: 647
        Timestamp: 1918830786µs
        Data Header
        CRC: 0x1be4e4
       1242 30.132621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1242: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24913
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 647
        Timestamp: 1918831016µs
        Data Header
        CRC: 0xd084e4
       1243 30.177391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1243: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24914
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -63 dBm
        Event counter: 648
        Timestamp: 1918875786µs
        Data Header
        CRC: 0xb534e4
       1244 30.177621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1244: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24915
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 648
        Timestamp: 1918876016µs
        Data Header
        CRC: 0x7e54e4
       1245 30.222391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1245: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24916
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -63 dBm
        Event counter: 649
        Timestamp: 1918920786µs
        Data Header
        CRC: 0x1be4e4
       1246 30.222622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1246: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24917
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -46 dBm
        Event counter: 649
        Timestamp: 1918921017µs
        Data Header
        CRC: 0xd084e4
       1247 30.312391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1247: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24918
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -65 dBm
        Event counter: 651
        Timestamp: 1919010786µs
        [Delta time (end to start): 89689µs]
        [Delta time (start to start): 89769µs]
        Data Header
        CRC: 0xb534e4
       1248 30.312622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1248: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24919
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 651
        Timestamp: 1919011017µs
        Data Header
        CRC: 0x7e54e4
       1249 30.357391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1249: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24920
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -63 dBm
        Event counter: 652
        Timestamp: 1919055786µs
        Data Header
        CRC: 0x1be4e4
       1250 30.357622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1250: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24921
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -44 dBm
        Event counter: 652
        Timestamp: 1919056017µs
        Data Header
        CRC: 0xd084e4
       1251 30.402391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1251: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24922
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -65 dBm
        Event counter: 653
        Timestamp: 1919100786µs
        Data Header
        CRC: 0xb534e4
       1252 30.402622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1252: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24923
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 653
        Timestamp: 1919101017µs
        Data Header
        CRC: 0x7e54e4
       1253 30.447391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1253: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24924
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -65 dBm
        Event counter: 654
        Timestamp: 1919145786µs
        Data Header
        CRC: 0x1be4e4
       1254 30.447621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1254: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24925
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 654
        Timestamp: 1919146016µs
        Data Header
        CRC: 0xd084e4
       1255 30.492391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1255: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24926
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -66 dBm
        Event counter: 655
        Timestamp: 1919190786µs
        Data Header
        CRC: 0xb534e4
       1256 30.492621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1256: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24927
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 655
        Timestamp: 1919191016µs
        Data Header
        CRC: 0x7e54e4
       1257 30.537391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1257: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24928
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -67 dBm
        Event counter: 656
        Timestamp: 1919235786µs
        Data Header
        CRC: 0x1be4e4
       1258 30.537622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1258: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24929
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 656
        Timestamp: 1919236017µs
        Data Header
        CRC: 0xd084e4
       1259 30.582391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1259: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24930
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -64 dBm
        Event counter: 657
        Timestamp: 1919280786µs
        Data Header
        CRC: 0xb534e4
       1260 30.582622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1260: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24931
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 657
        Timestamp: 1919281017µs
        Data Header
        CRC: 0x7e54e4
       1261 30.627391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1261: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24932
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -68 dBm
        Event counter: 658
        Timestamp: 1919325786µs
        Data Header
        CRC: 0x1be4e4
       1262 30.627622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1262: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24933
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 658
        Timestamp: 1919326017µs
        Data Header
        CRC: 0xd084e4
       1263 30.717391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1263: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24934
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -65 dBm
        Event counter: 660
        Timestamp: 1919415786µs
        Data Header
        CRC: 0x1be4e4
       1264 30.717621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1264: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24935
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 660
        Timestamp: 1919416016µs
        Data Header
        CRC: 0xd084e4
       1265 30.762391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1265: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24936
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -66 dBm
        Event counter: 661
        Timestamp: 1919460786µs
        Data Header
        CRC: 0xb534e4
       1266 30.762622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1266: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24937
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 661
        Timestamp: 1919461017µs
        Data Header
        CRC: 0x7e54e4
       1267 30.807391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1267: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24938
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -65 dBm
        Event counter: 662
        Timestamp: 1919505786µs
        Data Header
        CRC: 0x1be4e4
       1268 30.807622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1268: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24939
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 662
        Timestamp: 1919506017µs
        Data Header
        CRC: 0xd084e4
       1269 30.852391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1269: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24940
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -72 dBm
        Event counter: 663
        Timestamp: 1919550786µs
        Data Header
        CRC: 0xb534e4
       1270 30.852622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1270: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24941
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 663
        Timestamp: 1919551016µs
        Data Header
        CRC: 0x7e54e4
       1271 30.897392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1271: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24942
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -64 dBm
        Event counter: 664
        Timestamp: 1919595786µs
        Data Header
        CRC: 0x1be4e4
       1272 30.897622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1272: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24943
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -51 dBm
        Event counter: 664
        Timestamp: 1919596016µs
        Data Header
        CRC: 0xd084e4
       1273 30.942392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1273: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24944
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -63 dBm
        Event counter: 665
        Timestamp: 1919640786µs
        Data Header
        CRC: 0xb534e4
       1274 30.942622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1274: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24945
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -51 dBm
        Event counter: 665
        Timestamp: 1919641016µs
        Data Header
        CRC: 0x7e54e4
       1275 30.987392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1275: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24946
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -65 dBm
        Event counter: 666
        Timestamp: 1919685786µs
        Data Header
        CRC: 0x1be4e4
       1276 30.987622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1276: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24947
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 666
        Timestamp: 1919686016µs
        Data Header
        CRC: 0xd084e4
       1277 31.032392      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1277: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24948
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -66 dBm
        Event counter: 667
        Timestamp: 1919730786µs
        Data Header
        CRC: 0xb534e4
       1278 31.032622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1278: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24949
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 667
        Timestamp: 1919731016µs
        Data Header
        CRC: 0x7e54e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
       1279 31.077391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1279: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 24950
        Length of packet: 10
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 21
        RSSI: -66 dBm
        Event counter: 668
        Timestamp: 1919775785µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0x1be4e4
       1280 31.077622      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1280: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24951
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 668
        Timestamp: 1919776016µs
        Data Header
        CRC: 0xd084e4
       1281 31.122391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1281: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24952
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -64 dBm
        Event counter: 669
        Timestamp: 1919820785µs
        Data Header
        CRC: 0xb534e4
       1282 31.122621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1282: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24953
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 669
        Timestamp: 1919821015µs
        Data Header
        CRC: 0x7e54e4
       1283 31.167391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1283: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24954
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -64 dBm
        Event counter: 670
        Timestamp: 1919865785µs
        Data Header
        CRC: 0x1be4e4
       1284 31.167621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1284: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24955
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 670
        Timestamp: 1919866015µs
        Data Header
        CRC: 0xd084e4
       1285 31.212391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1285: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24956
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -65 dBm
        Event counter: 671
        Timestamp: 1919910785µs
        Data Header
        CRC: 0xb534e4
       1286 31.212621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1286: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24957
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -52 dBm
        Event counter: 671
        Timestamp: 1919911015µs
        Data Header
        CRC: 0x7e54e4
       1287 31.257390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1287: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24958
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -68 dBm
        Event counter: 672
        Timestamp: 1919955784µs
        Data Header
        CRC: 0x1be4e4
       1288 31.257620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1288: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24959
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 672
        Timestamp: 1919956014µs
        Data Header
        CRC: 0xd084e4
       1289 31.302390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1289: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24960
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -65 dBm
        Event counter: 673
        Timestamp: 1920000784µs
        Data Header
        CRC: 0xb534e4
       1290 31.302620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1290: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24961
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 673
        Timestamp: 1920001014µs
        Data Header
        CRC: 0x7e54e4
       1291 31.347390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1291: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24962
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -65 dBm
        Event counter: 674
        Timestamp: 1920045784µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0x1be4e4
       1292 31.347621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1292: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24963
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 674
        Timestamp: 1920046015µs
        Data Header
        CRC: 0xd084e4
       1293 31.392391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1293: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24964
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 33
        RSSI: -65 dBm
        Event counter: 675
        Timestamp: 1920090784µs
        Data Header
        CRC: 0xb534e4
       1294 31.392621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1294: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24965
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 675
        Timestamp: 1920091014µs
        Data Header
        CRC: 0x7e54e4
       1295 31.437391      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1295: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24966
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -65 dBm
        Event counter: 676
        Timestamp: 1920135784µs
        Data Header
        CRC: 0x1be4e4
       1296 31.437621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1296: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24967
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 676
        Timestamp: 1920136014µs
        Data Header
        CRC: 0xd084e4
       1297 31.482390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1297: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24968
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 10
        RSSI: -69 dBm
        Event counter: 677
        Timestamp: 1920180783µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0xb534e4
       1298 31.482621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1298: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24969
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 677
        Timestamp: 1920181014µs
        Data Header
        CRC: 0x7e54e4
       1299 31.527390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1299: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24970
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -71 dBm
        Event counter: 678
        Timestamp: 1920225783µs
        Data Header
        CRC: 0x1be4e4
       1300 31.527621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1300: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24971
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 17
        RSSI: -43 dBm
        Event counter: 678
        Timestamp: 1920226014µs
        Data Header
        CRC: 0xd084e4
       1301 31.572390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1301: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24972
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -64 dBm
        Event counter: 679
        Timestamp: 1920270783µs
        Data Header
        CRC: 0xb534e4
       1302 31.572621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1302: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24973
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 679
        Timestamp: 1920271014µs
        Data Header
        CRC: 0x7e54e4
       1303 31.617390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1303: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24974
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -63 dBm
        Event counter: 680
        Timestamp: 1920315783µs
        Data Header
        CRC: 0x1be4e4
       1304 31.617620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1304: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24975
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 680
        Timestamp: 1920316013µs
        Data Header
        CRC: 0xd084e4
       1305 31.662390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1305: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24976
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 681
        Timestamp: 1920360783µs
        Data Header
        CRC: 0xb534e4
       1306 31.662620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1306: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24977
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -51 dBm
        Event counter: 681
        Timestamp: 1920361013µs
        Data Header
        CRC: 0x7e54e4
       1307 31.707390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1307: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24978
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -66 dBm
        Event counter: 682
        Timestamp: 1920405783µs
        Data Header
        CRC: 0x1be4e4
       1308 31.707621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1308: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24979
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 682
        Timestamp: 1920406014µs
        Data Header
        CRC: 0xd084e4
       1309 31.752390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1309: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24980
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -67 dBm
        Event counter: 683
        Timestamp: 1920450783µs
        Data Header
        CRC: 0xb534e4
       1310 31.752620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1310: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24981
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -44 dBm
        Event counter: 683
        Timestamp: 1920451013µs
        Data Header
        [Connection Parameters in: 127]
        CRC: 0x7e54e4
       1311 31.797390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1311: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24982
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -68 dBm
        Event counter: 684
        Timestamp: 1920495783µs
        Data Header
        CRC: 0x1be4e4
       1312 31.797620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1312: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24983
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 684
        Timestamp: 1920496013µs
        Data Header
        CRC: 0xd084e4
       1313 31.842390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1313: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24984
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -65 dBm
        Event counter: 685
        Timestamp: 1920540783µs
        Data Header
        CRC: 0xb534e4
       1314 31.842620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1314: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24985
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 685
        Timestamp: 1920541013µs
        Data Header
        CRC: 0x7e54e4
       1315 31.887389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1315: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24986
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -65 dBm
        Event counter: 686
        Timestamp: 1920585782µs
        Data Header
        CRC: 0x1be4e4
       1316 31.887620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1316: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24987
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 686
        Timestamp: 1920586012µs
        Data Header
        CRC: 0xd084e4
       1317 31.932390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1317: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24988
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -67 dBm
        Event counter: 687
        Timestamp: 1920630782µs
        Data Header
        CRC: 0xb534e4
       1318 31.932621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1318: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24989
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -54 dBm
        Event counter: 687
        Timestamp: 1920631013µs
        Data Header
        CRC: 0x7e54e4
       1319 31.977390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1319: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24990
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -66 dBm
        Event counter: 688
        Timestamp: 1920675782µs
        Data Header
        CRC: 0x1be4e4
       1320 31.977621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1320: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24991
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -44 dBm
        Event counter: 688
        Timestamp: 1920676013µs
        Data Header
        CRC: 0xd084e4
       1321 32.022390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1321: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24992
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -68 dBm
        Event counter: 689
        Timestamp: 1920720782µs
        Data Header
        CRC: 0xb534e4
       1322 32.022621      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1322: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24993
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -44 dBm
        Event counter: 689
        Timestamp: 1920721013µs
        Data Header
        CRC: 0x7e54e4
       1323 32.067390      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1323: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24994
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -68 dBm
        Event counter: 690
        Timestamp: 1920765782µs
        Data Header
        CRC: 0x1be4e4
       1324 32.067619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1324: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24995
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 690
        Timestamp: 1920766011µs
        Data Header
        CRC: 0xd084e4
       1325 32.112389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1325: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24996
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -65 dBm
        Event counter: 691
        Timestamp: 1920810781µs
        Data Header
        CRC: 0xb534e4
       1326 32.112620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1326: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24997
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 691
        Timestamp: 1920811012µs
        Data Header
        CRC: 0x7e54e4
       1327 32.157389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1327: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24998
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -66 dBm
        Event counter: 692
        Timestamp: 1920855781µs
        Data Header
        CRC: 0x1be4e4
       1328 32.157620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1328: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 24999
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -51 dBm
        Event counter: 692
        Timestamp: 1920856012µs
        Data Header
        CRC: 0xd084e4
       1329 32.202389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1329: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25000
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -64 dBm
        Event counter: 693
        Timestamp: 1920900781µs
        Data Header
        CRC: 0xb534e4
       1330 32.202619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1330: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25001
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -48 dBm
        Event counter: 693
        Timestamp: 1920901011µs
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 230µs]
        Data Header
        CRC: 0x7e54e4
       1331 32.247389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1331: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25002
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -61 dBm
        Event counter: 694
        Timestamp: 1920945781µs
        Data Header
        CRC: 0x1be4e4
       1332 32.247619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1332: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25003
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 694
        Timestamp: 1920946011µs
        Data Header
        CRC: 0xd084e4
       1333 32.292389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1333: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25004
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -62 dBm
        Event counter: 695
        Timestamp: 1920990781µs
        Data Header
        CRC: 0xb534e4
       1334 32.292620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1334: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25005
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 695
        Timestamp: 1920991012µs
        Data Header
        CRC: 0x7e54e4
       1335 32.337389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1335: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25006
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -63 dBm
        Event counter: 696
        Timestamp: 1921035781µs
        Data Header
        CRC: 0x1be4e4
       1336 32.337619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1336: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25007
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 696
        Timestamp: 1921036011µs
        Data Header
        CRC: 0xd084e4
       1337 32.382389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1337: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25008
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -68 dBm
        Event counter: 697
        Timestamp: 1921080781µs
        Data Header
        CRC: 0xb534e4
       1338 32.382619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1338: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25009
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 697
        Timestamp: 1921081011µs
        Data Header
        CRC: 0x7e54e4
       1339 32.427389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1339: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25010
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -66 dBm
        Event counter: 698
        Timestamp: 1921125781µs
        Data Header
        CRC: 0x1be4e4
       1340 32.427619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1340: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25011
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 698
        Timestamp: 1921126011µs
        Data Header
        CRC: 0xd084e4
       1341 32.472388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1341: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25012
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -67 dBm
        Event counter: 699
        Timestamp: 1921170780µs
        [Delta time (end to start): 44689µs]
        [Delta time (start to start): 44769µs]
        Data Header
        CRC: 0xb534e4
       1342 32.472618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1342: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25013
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 699
        Timestamp: 1921171010µs
        Data Header
        CRC: 0x7e54e4
       1343 32.517388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1343: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25014
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -69 dBm
        Event counter: 700
        Timestamp: 1921215780µs
        Data Header
        CRC: 0x1be4e4
       1344 32.517618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1344: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25015
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 700
        Timestamp: 1921216010µs
        Data Header
        CRC: 0xd084e4
       1345 32.562388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1345: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25016
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -75 dBm
        Event counter: 701
        Timestamp: 1921260780µs
        Data Header
        CRC: 0xb534e4
       1346 32.562619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1346: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25017
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 701
        Timestamp: 1921261011µs
        [Delta time (end to start): 151µs]
        [Delta time (start to start): 231µs]
        Data Header
        CRC: 0x7e54e4
       1347 32.607389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1347: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25018
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -71 dBm
        Event counter: 702
        Timestamp: 1921305780µs
        Data Header
        CRC: 0x1be4e4
       1348 32.607620      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1348: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25019
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -50 dBm
        Event counter: 702
        Timestamp: 1921306011µs
        Data Header
        CRC: 0xd084e4
       1349 32.697388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1349: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25020
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -73 dBm
        Event counter: 704
        Timestamp: 1921395780µs
        Data Header
        CRC: 0x1be4e4
       1350 32.697618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1350: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25021
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 14
        RSSI: -45 dBm
        Event counter: 704
        Timestamp: 1921396010µs
        Data Header
        CRC: 0xd084e4
       1351 32.742388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1351: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25022
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -72 dBm
        Event counter: 705
        Timestamp: 1921440780µs
        [Delta time (end to start): 44690µs]
        [Delta time (start to start): 44770µs]
        Data Header
        CRC: 0xb534e4
       1352 32.742619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1352: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25023
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -45 dBm
        Event counter: 705
        Timestamp: 1921441010µs
        Data Header
        CRC: 0x7e54e4
       1353 32.787388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1353: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25024
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -74 dBm
        Event counter: 706
        Timestamp: 1921485779µs
        Data Header
        CRC: 0x1be4e4
       1354 32.787618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1354: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25025
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 706
        Timestamp: 1921486009µs
        Data Header
        CRC: 0xd084e4
       1355 32.877388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1355: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25026
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -71 dBm
        Event counter: 708
        Timestamp: 1921575779µs
        [Delta time (end to start): 89690µs]
        [Delta time (start to start): 89770µs]
        Data Header
        CRC: 0x1be4e4
       1356 32.877619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1356: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25027
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 708
        Timestamp: 1921576010µs
        Data Header
        CRC: 0xd084e4
       1357 32.922388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1357: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25028
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -69 dBm
        Event counter: 709
        Timestamp: 1921620779µs
        Data Header
        CRC: 0xb534e4
       1358 32.922618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1358: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25029
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -46 dBm
        Event counter: 709
        Timestamp: 1921621009µs
        Data Header
        CRC: 0x7e54e4
       1359 32.967388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1359: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25030
        Flags: 0x0a
            .... ...0 = CRC: Error
                [Expert Info (Error/Checksum): CRC is bad]
                    [CRC is bad]
                    [Severity level: Error]
                    [Group: Checksum]
        Channel Index: 19
        RSSI: -74 dBm
        Event counter: 710
        Timestamp: 1921665779µs
        Data Header
        CRC: 0x1ae4e4
            [Expert Info (Warning/Checksum): Incorrect CRC]
                [Incorrect CRC]
                [Severity level: Warning]
                [Group: Checksum]
       1360 32.967618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1360: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25031
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 710
        Timestamp: 1921666009µs
        Data Header
        CRC: 0xd084e4
       1361 33.012388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1361: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25032
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -74 dBm
        Event counter: 711
        Timestamp: 1921710779µs
        Data Header
        CRC: 0xb534e4
       1362 33.012618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1362: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25033
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 711
        Timestamp: 1921711009µs
        Data Header
        CRC: 0x7e54e4
       1363 33.057388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1363: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25034
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -78 dBm
        Event counter: 712
        Timestamp: 1921755779µs
        Data Header
        CRC: 0x1be4e4
       1364 33.057618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1364: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25035
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 712
        Timestamp: 1921756009µs
        Data Header
        CRC: 0xd084e4
       1365 33.102387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1365: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25036
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -67 dBm
        Event counter: 713
        Timestamp: 1921800778µs
        Data Header
        CRC: 0xb534e4
       1366 33.102618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1366: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25037
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -50 dBm
        Event counter: 713
        Timestamp: 1921801009µs
        Data Header
        CRC: 0x7e54e4
       1367 33.147387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1367: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25038
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -70 dBm
        Event counter: 714
        Timestamp: 1921845778µs
        Data Header
        CRC: 0x1be4e4
       1368 33.147618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1368: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25039
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -50 dBm
        Event counter: 714
        Timestamp: 1921846009µs
        Data Header
        CRC: 0xd084e4
       1369 33.192387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1369: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25040
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -73 dBm
        Event counter: 715
        Timestamp: 1921890778µs
        Data Header
        CRC: 0xb534e4
       1370 33.192617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1370: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25041
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 715
        Timestamp: 1921891008µs
        Data Header
        CRC: 0x7e54e4
       1371 33.282388      Master_0x4d08532d     Slave_0x4d08532d      ATT      33                No         False                    Sent Read Request, Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)
    Frame 1371: 33 bytes on wire (264 bits), 33 bytes captured (264 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25042
        Flags: 0x03
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -65 dBm
        Event counter: 717
        Timestamp: 1921980778µs
        [Packet time (start to end): 136µs]
        Data Header
        [L2CAP Index: 53]
        CRC: 0xed98d9
    Bluetooth L2CAP Protocol
    Bluetooth Attribute Protocol
        Opcode: Read Request (0x0a)
            0... .... = Authentication Signature: False
            .0.. .... = Command: False
            ..00 1010 = Method: Read Request (0x0a)
            [Service UUID: Generic Attribute (0x1801)]
            [Characteristic UUID: Service Changed (0x2a05)]
            [UUID: Client Characteristic Configuration (0x2902)]
       1372 33.282674      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1372: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25043
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 717
        Timestamp: 1921981064µs
        [Delta time (start to start): 286µs]
        Data Header
        CRC: 0x7e54e4
       1373 33.327388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1373: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25044
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -65 dBm
        Event counter: 718
        Timestamp: 1922025778µs
        [Delta time (end to start): 44634µs]
        [Delta time (start to start): 44714µs]
        Data Header
        CRC: 0x1be4e4
       1374 33.327618      Slave_0x4d08532d      Master_0x4d08532d     ATT      33                No         False                    Rcvd Read Response, Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)
    Frame 1374: 33 bytes on wire (264 bits), 33 bytes captured (264 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25045
        Flags: 0x01
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -50 dBm
        Event counter: 718
        Timestamp: 1922026008µs
        Data Header
        [L2CAP Index: 54]
        CRC: 0x2c5282
        Opcode: Read Response (0x0b)
            ..00 1011 = Method: Read Response (0x0b)
        [Handle: 0x0009 (Generic Attribute: Service Changed: Client Characteristic Configuration)]
        [Request in Frame: 1371]
       1375 33.372388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1375: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25046
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -69 dBm
        Event counter: 719
        Timestamp: 1922070778µs
        Data Header
        CRC: 0xb534e4
       1376 33.372618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1376: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25047
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -51 dBm
        Event counter: 719
        Timestamp: 1922071008µs
        Data Header
        CRC: 0x7e54e4
       1377 33.417388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1377: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25048
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 15
        RSSI: -74 dBm
        Event counter: 720
        Timestamp: 1922115778µs
        Data Header
        CRC: 0x1364a4
                [Incorrect CRC]
                [Group: Checksum]
       1378 33.417618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1378: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25049
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 720
        Timestamp: 1922116008µs
        Data Header
        CRC: 0xd084e4
       1379 33.462388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1379: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25050
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -69 dBm
        Event counter: 721
        Timestamp: 1922160778µs
        Data Header
        CRC: 0xb534e4
       1380 33.462617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1380: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25051
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -45 dBm
        Event counter: 721
        Timestamp: 1922161007µs
        [Delta time (end to start): 149µs]
        [Delta time (start to start): 229µs]
        Data Header
        CRC: 0x7e54e4
       1381 33.597388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1381: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25052
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -71 dBm
        Event counter: 724
        Timestamp: 1922295778µs
        [Delta time (end to start): 134691µs]
        [Delta time (start to start): 134771µs]
        Data Header
        CRC: 0x1be4e4
       1382 33.597618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1382: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25053
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -52 dBm
        Event counter: 724
        Timestamp: 1922296008µs
        Data Header
        CRC: 0xd084e4
       1383 33.642388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1383: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25054
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -66 dBm
        Event counter: 725
        Timestamp: 1922340778µs
        Data Header
        CRC: 0xb534e4
       1384 33.642618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1384: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25055
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 725
        Timestamp: 1922341008µs
        Data Header
        CRC: 0x7e54e4
       1385 33.687388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1385: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25056
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -67 dBm
        Event counter: 726
        Timestamp: 1922385778µs
        Data Header
        CRC: 0x1be4e4
       1386 33.687618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1386: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25057
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 726
        Timestamp: 1922386008µs
        Data Header
        CRC: 0xd084e4
       1387 33.732388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1387: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25058
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -75 dBm
        Event counter: 727
        Timestamp: 1922430778µs
        Data Header
        CRC: 0xb534e4
       1388 33.732618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1388: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25059
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -43 dBm
        Event counter: 727
        Timestamp: 1922431008µs
        Data Header
        CRC: 0x7e54e4
       1389 33.777388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1389: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25060
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -75 dBm
        Event counter: 728
        Timestamp: 1922475778µs
        Data Header
        CRC: 0x1be4e4
       1390 33.777617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1390: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25061
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 728
        Timestamp: 1922476007µs
        Data Header
        CRC: 0xd084e4
       1391 33.822388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1391: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25062
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -69 dBm
        Event counter: 729
        Timestamp: 1922520778µs
        [Delta time (end to start): 44691µs]
        [Delta time (start to start): 44771µs]
        Data Header
        CRC: 0xb534e4
       1392 33.822618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1392: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25063
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 729
        Timestamp: 1922521008µs
        Data Header
        CRC: 0x7e54e4
       1393 33.867388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1393: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25064
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -66 dBm
        Event counter: 730
        Timestamp: 1922565778µs
        Data Header
        CRC: 0x1be4e4
       1394 33.867618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1394: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25065
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -46 dBm
        Event counter: 730
        Timestamp: 1922566008µs
        Data Header
        CRC: 0xd084e4
       1395 33.912388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1395: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25066
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -66 dBm
        Event counter: 731
        Timestamp: 1922610778µs
        Data Header
        CRC: 0xb534e4
       1396 33.912618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1396: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25067
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 731
        Timestamp: 1922611008µs
        Data Header
        CRC: 0x7e54e4
       1397 33.957388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1397: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25068
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -69 dBm
        Event counter: 732
        Timestamp: 1922655778µs
        Data Header
        CRC: 0x1be4e4
       1398 33.957618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1398: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25069
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 732
        Timestamp: 1922656008µs
        Data Header
        CRC: 0xd084e4
       1399 34.002388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1399: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25070
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -68 dBm
        Event counter: 733
        Timestamp: 1922700778µs
        Data Header
        CRC: 0xb534e4
       1400 34.002618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1400: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25071
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 733
        Timestamp: 1922701008µs
        Data Header
        CRC: 0x7e54e4
       1401 34.047388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1401: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25072
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -66 dBm
        Event counter: 734
        Timestamp: 1922745778µs
        Data Header
        CRC: 0x1be4e4
       1402 34.047618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1402: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25073
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 734
        Timestamp: 1922746008µs
        Data Header
        CRC: 0xd084e4
       1403 34.092388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1403: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25074
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -64 dBm
        Event counter: 735
        Timestamp: 1922790778µs
        Data Header
        CRC: 0xb534e4
       1404 34.092618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1404: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25075
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -50 dBm
        Event counter: 735
        Timestamp: 1922791008µs
        Data Header
        CRC: 0x7e54e4
       1405 34.137388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1405: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25076
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -65 dBm
        Event counter: 736
        Timestamp: 1922835778µs
        Data Header
        CRC: 0x1be4e4
       1406 34.137619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1406: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25077
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 736
        Timestamp: 1922836008µs
        Data Header
        CRC: 0xd084e4
       1407 34.182389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1407: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25078
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -68 dBm
        Event counter: 737
        Timestamp: 1922880778µs
        Data Header
        CRC: 0xb534e4
       1408 34.182619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1408: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25079
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 737
        Timestamp: 1922881008µs
        Data Header
        CRC: 0x7e54e4
       1409 34.227389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1409: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25080
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -65 dBm
        Event counter: 738
        Timestamp: 1922925778µs
        Data Header
        CRC: 0x1be4e4
       1410 34.227619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1410: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25081
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -49 dBm
        Event counter: 738
        Timestamp: 1922926008µs
        Data Header
        CRC: 0xd084e4
       1411 34.272389      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1411: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25082
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -65 dBm
        Event counter: 739
        Timestamp: 1922970778µs
        Data Header
        CRC: 0xb534e4
       1412 34.272619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1412: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25083
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -49 dBm
        Event counter: 739
        Timestamp: 1922971008µs
        Data Header
        CRC: 0x7e54e4
       1413 34.317388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1413: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25084
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -66 dBm
        Event counter: 740
        Timestamp: 1923015777µs
        Data Header
        CRC: 0x1be4e4
       1414 34.317618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1414: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25085
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 740
        Timestamp: 1923016007µs
        Data Header
        CRC: 0xd084e4
       1415 34.407388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1415: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25086
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -65 dBm
        Event counter: 742
        Timestamp: 1923105777µs
        Data Header
        CRC: 0x1be4e4
       1416 34.407619      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1416: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25087
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -44 dBm
        Event counter: 742
        Timestamp: 1923106008µs
        Data Header
        CRC: 0xd084e4
       1417 34.452388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1417: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25088
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -79 dBm
        Event counter: 743
        Timestamp: 1923150777µs
        Data Header
        CRC: 0xb534e4
       1418 34.452618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1418: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25089
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -44 dBm
        Event counter: 743
        Timestamp: 1923151007µs
        Data Header
        CRC: 0x7e54e4
       1419 34.497388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1419: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25090
        Flags: 0x0a
                    [CRC is bad]
                    [Group: Checksum]
        Channel Index: 35
        RSSI: -80 dBm
        Event counter: 744
        Timestamp: 1923195777µs
        Data Header
        CRC: 0x1b24e4
                [Incorrect CRC]
                [Group: Checksum]
       1420 34.497618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1420: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25091
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 35
        RSSI: -43 dBm
        Event counter: 744
        Timestamp: 1923196007µs
        Data Header
        CRC: 0xd084e4
       1421 34.542387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1421: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25092
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -69 dBm
        Event counter: 745
        Timestamp: 1923240776µs
        Data Header
        CRC: 0xb534e4
       1422 34.542618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1422: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25093
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 5
        RSSI: -50 dBm
        Event counter: 745
        Timestamp: 1923241007µs
        Data Header
        CRC: 0x7e54e4
       1423 34.587387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1423: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25094
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -63 dBm
        Event counter: 746
        Timestamp: 1923285776µs
        Data Header
        CRC: 0x1be4e4
       1424 34.587618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1424: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25095
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 12
        RSSI: -45 dBm
        Event counter: 746
        Timestamp: 1923286007µs
        Data Header
        CRC: 0xd084e4
       1425 34.632387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1425: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25096
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -63 dBm
        Event counter: 747
        Timestamp: 1923330776µs
        Data Header
        CRC: 0xb534e4
       1426 34.632617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1426: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25097
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 19
        RSSI: -44 dBm
        Event counter: 747
        Timestamp: 1923331006µs
        Data Header
        CRC: 0x7e54e4
       1427 34.677387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1427: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25098
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -71 dBm
        Event counter: 748
        Timestamp: 1923375776µs
        Data Header
        CRC: 0x1be4e4
       1428 34.677618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1428: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25099
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 748
        Timestamp: 1923376006µs
        Data Header
        CRC: 0xd084e4
       1429 34.722388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1429: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25100
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -71 dBm
        Event counter: 749
        Timestamp: 1923420776µs
        Data Header
        CRC: 0xb534e4
       1430 34.722618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1430: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25101
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 33
        RSSI: -43 dBm
        Event counter: 749
        Timestamp: 1923421006µs
        Data Header
        CRC: 0x7e54e4
       1431 34.767388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1431: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25102
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -66 dBm
        Event counter: 750
        Timestamp: 1923465776µs
        Data Header
        CRC: 0x1be4e4
       1432 34.767618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1432: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25103
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 3
        RSSI: -49 dBm
        Event counter: 750
        Timestamp: 1923466006µs
        Data Header
        CRC: 0xd084e4
       1433 34.812388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1433: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25104
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -63 dBm
        Event counter: 751
        Timestamp: 1923510776µs
        Data Header
        CRC: 0xb534e4
       1434 34.812618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1434: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25105
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 10
        RSSI: -49 dBm
        Event counter: 751
        Timestamp: 1923511006µs
        Data Header
        CRC: 0x7e54e4
       1435 34.857388      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1435: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25106
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -63 dBm
        Event counter: 752
        Timestamp: 1923555776µs
        Data Header
        CRC: 0x1be4e4
       1436 34.857618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1436: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25107
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 17
        RSSI: -44 dBm
        Event counter: 752
        Timestamp: 1923556006µs
        Data Header
        CRC: 0xd084e4
       1437 34.902387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1437: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25108
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -68 dBm
        Event counter: 753
        Timestamp: 1923600775µs
        Data Header
        CRC: 0xb534e4
       1438 34.902617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1438: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25109
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 24
        RSSI: -44 dBm
        Event counter: 753
        Timestamp: 1923601005µs
        Data Header
        CRC: 0x7e54e4
       1439 34.947387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1439: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25110
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 754
        Timestamp: 1923645775µs
        Data Header
        CRC: 0x1be4e4
       1440 34.947617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1440: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25111
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -49 dBm
        Event counter: 754
        Timestamp: 1923646005µs
        Data Header
        CRC: 0xd084e4
       1441 34.992387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1441: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25112
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -64 dBm
        Event counter: 755
        Timestamp: 1923690775µs
        Data Header
        CRC: 0xb534e4
       1442 34.992618      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1442: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25113
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 1
        RSSI: -49 dBm
        Event counter: 755
        Timestamp: 1923691006µs
        Data Header
        CRC: 0x7e54e4
    No.     Time           Source                Destination           Protocol Length PDU Type   Encrypted  Authentication Signature Info
       1443 35.037387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1443: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
    nRF Sniffer for Bluetooth LE
        Board: 3
        Header Version: 3, Packet counter: 25114
        Length of packet: 10
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 8
        RSSI: -64 dBm
        Event counter: 756
        Timestamp: 1923735775µs
    Bluetooth Low Energy Link Layer
        Data Header
        CRC: 0x1be4e4
       1444 35.037617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1444: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25115
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 8
        RSSI: -50 dBm
        Event counter: 756
        Timestamp: 1923736005µs
        Data Header
        CRC: 0xd084e4
       1445 35.082387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1445: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25116
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -65 dBm
        Event counter: 757
        Timestamp: 1923780775µs
        Data Header
        CRC: 0xb534e4
       1446 35.082617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1446: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25117
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 15
        RSSI: -45 dBm
        Event counter: 757
        Timestamp: 1923781005µs
        Data Header
        CRC: 0x7e54e4
       1447 35.127387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1447: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25118
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -65 dBm
        Event counter: 758
        Timestamp: 1923825775µs
        Data Header
        CRC: 0x1be4e4
       1448 35.127617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1448: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25119
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 22
        RSSI: -44 dBm
        Event counter: 758
        Timestamp: 1923826005µs
        Data Header
        CRC: 0xd084e4
       1449 35.172386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1449: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25120
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -76 dBm
        Event counter: 759
        Timestamp: 1923870774µs
        Data Header
        CRC: 0xb534e4
       1450 35.172617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1450: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25121
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -44 dBm
        Event counter: 759
        Timestamp: 1923871005µs
        Data Header
        CRC: 0x7e54e4
       1451 35.217386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1451: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25122
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -76 dBm
        Event counter: 760
        Timestamp: 1923915774µs
        Data Header
        CRC: 0x1be4e4
       1452 35.217617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1452: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25123
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 36
        RSSI: -43 dBm
        Event counter: 760
        Timestamp: 1923916004µs
        Data Header
        CRC: 0xd084e4
       1453 35.262387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1453: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25124
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 6
        RSSI: -70 dBm
        Event counter: 761
        Timestamp: 1923960774µs
        Data Header
        CRC: 0xb534e4
       1454 35.262617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1454: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25125
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... .0.. = Encrypted: No
        Channel Index: 6
        RSSI: -51 dBm
        Event counter: 761
        Timestamp: 1923961004µs
        Data Header
        CRC: 0x7e54e4
       1455 35.307387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1455: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25126
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -64 dBm
        Event counter: 762
        Timestamp: 1924005774µs
        Access Address: 0x4d08532d
        [Master Address: 6c:0f:c0:61:21:72 (6c:0f:c0:61:21:72)]
        [Slave Address: ublox_a2:93:3c (cc:f9:57:a2:93:3c)]
        Data Header
        CRC: 0x1be4e4
       1456 35.307617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1456: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25127
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 13
        RSSI: -45 dBm
        Event counter: 762
        Timestamp: 1924006004µs
        Data Header
        CRC: 0xd084e4
       1457 35.352387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1457: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25128
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... ..1. = Direction: Master -> Slave
        Channel Index: 20
        RSSI: -64 dBm
        Event counter: 763
        Timestamp: 1924050774µs
        Data Header
        CRC: 0xb534e4
       1458 35.352617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1458: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25129
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 20
        RSSI: -45 dBm
        Event counter: 763
        Timestamp: 1924051004µs
        Data Header
        CRC: 0x7e54e4
       1459 35.397386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1459: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25130
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -73 dBm
        Event counter: 764
        Timestamp: 1924095773µs
        Data Header
        CRC: 0x1be4e4
       1460 35.397617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1460: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25131
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 764
        Timestamp: 1924096004µs
        Data Header
        CRC: 0xd084e4
       1461 35.442387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1461: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25132
        Flags: 0x0b
            .... ...1 = CRC: Ok
            .... 1... = MIC (not relevant): 1
        Channel Index: 34
        RSSI: -72 dBm
        Event counter: 765
        Timestamp: 1924140774µs
        [Packet time (start to end): 80µs]
        Data Header
        CRC: 0xb534e4
       1462 35.442617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1462: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25133
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 34
        RSSI: -44 dBm
        Event counter: 765
        Timestamp: 1924141004µs
        Data Header
        CRC: 0x7e54e4
       1463 35.487386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1463: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25134
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 4
        RSSI: -69 dBm
        Event counter: 766
        Timestamp: 1924185773µs
        Data Header
        CRC: 0x1be4e4
       1464 35.487617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1464: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25135
        Flags: 0x09
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
        Channel Index: 4
        RSSI: -50 dBm
        Event counter: 766
        Timestamp: 1924186004µs
        Data Header
        CRC: 0xd084e4
       1465 35.532387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1465: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25136
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -63 dBm
        Event counter: 767
        Timestamp: 1924230774µs
        Data Header
        CRC: 0xb534e4
       1466 35.532616      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1466: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25137
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 11
        RSSI: -48 dBm
        Event counter: 767
        Timestamp: 1924231003µs
        Data Header
        CRC: 0x7e54e4
       1467 35.577387      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1467: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25138
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -63 dBm
        Event counter: 768
        Timestamp: 1924275774µs
        Data Header
        CRC: 0x1be4e4
       1468 35.577616      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1468: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25139
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 18
        RSSI: -44 dBm
        Event counter: 768
        Timestamp: 1924276003µs
        Data Header
        CRC: 0xd084e4
       1469 35.622386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1469: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25140
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -69 dBm
        Event counter: 769
        Timestamp: 1924320773µs
        Data Header
        CRC: 0xb534e4
       1470 35.622617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1470: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25141
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 769
        Timestamp: 1924321004µs
        Data Header
        CRC: 0x7e54e4
       1471 35.667386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1471: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25142
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -69 dBm
        Event counter: 770
        Timestamp: 1924365773µs
        Data Header
        CRC: 0x1be4e4
       1472 35.667617      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1472: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25143
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 32
        RSSI: -43 dBm
        Event counter: 770
        Timestamp: 1924366004µs
        Data Header
        CRC: 0xd084e4
       1473 35.712386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1473: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25144
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -65 dBm
        Event counter: 771
        Timestamp: 1924410773µs
        Data Header
        CRC: 0xb534e4
       1474 35.712616      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1474: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25145
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 2
        RSSI: -50 dBm
        Event counter: 771
        Timestamp: 1924411003µs
        Data Header
        [Connection Parameters in: 127]
        CRC: 0x7e54e4
       1475 35.757386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1475: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25146
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -64 dBm
        Event counter: 772
        Timestamp: 1924455773µs
        Data Header
        CRC: 0x1be4e4
       1476 35.757616      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1476: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25147
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 9
        RSSI: -49 dBm
        Event counter: 772
        Timestamp: 1924456003µs
        Data Header
        CRC: 0xd084e4
       1477 35.802386      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1477: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25148
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -63 dBm
        Event counter: 773
        Timestamp: 1924500773µs
        Data Header
        CRC: 0xb534e4
       1478 35.802615      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1478: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25149
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 16
        RSSI: -44 dBm
        Event counter: 773
        Timestamp: 1924501002µs
        Data Header
        CRC: 0x7e54e4
       1479 35.847385      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1479: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25150
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -66 dBm
        Event counter: 774
        Timestamp: 1924545772µs
        Data Header
        CRC: 0x1be4e4
       1480 35.847615      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1480: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25151
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 23
        RSSI: -44 dBm
        Event counter: 774
        Timestamp: 1924546002µs
        Data Header
        CRC: 0xd084e4
       1481 35.892385      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1481: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25152
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -65 dBm
        Event counter: 775
        Timestamp: 1924590772µs
        Data Header
        CRC: 0xb534e4
       1482 35.892616      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1482: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25153
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -49 dBm
        Event counter: 775
        Timestamp: 1924591003µs
        Data Header
        CRC: 0x7e54e4
       1483 35.937385      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1483: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25154
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -65 dBm
        Event counter: 776
        Timestamp: 1924635772µs
        Data Header
        CRC: 0x1be4e4
       1484 35.937616      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1484: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25155
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 0
        RSSI: -49 dBm
        Event counter: 776
        Timestamp: 1924636003µs
        Data Header
        CRC: 0xd084e4
       1485 35.982385      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1485: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25156
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -66 dBm
        Event counter: 777
        Timestamp: 1924680772µs
        Data Header
        CRC: 0xb534e4
       1486 35.982615      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1486: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25157
        Flags: 0x09
            .... ...1 = CRC: Ok
        Channel Index: 7
        RSSI: -51 dBm
        Event counter: 777
        Timestamp: 1924681002µs
        Data Header
        CRC: 0x7e54e4
       1487 36.072385      Master_0x4d08532d     Slave_0x4d08532d      LE LL    26                No                                  Empty PDU
    Frame 1487: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Header Version: 3, Packet counter: 25158
        Flags: 0x0b
            .... ...1 = CRC: Ok
        Channel Index: 21
        RSSI: -64 dBm
        Event counter: 779
        Timestamp: 1924770772µs
        Data Header
        CRC: 0x1be4e4
       1488 36.072615      Slave_0x4d08532d      Master_0x4d08532d     LE LL    26                No                                  Empty PDU
    Frame 1488: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface COM3-4.0, id 0
        Board: 3
        Hea
