Where is the NRF Connect told to bring in a spi or dts file?
I'm trying to just do a pristine build using the Ezurio Pinnacle 100 DVK  When I originally created this project from a dev board, the
resource "atmel,sam0-pinctrl.yaml" and spi resource "st,stm32-spi-subghz.yaml" are pulled into the project.  Where is that directed in the project use those?  Wouldn't the nrf common be the better choice for spi as this is on the nrf52840?
So when the build finishes I have multiple errors because it's using those .yaml files.
resource: "/c:/Users/User/zephyr/dts/bindings/spi/st,stm32-spi-subghz.yaml",
owner: "DeviceTree types",
severity: 8,
message: "Invalid type definition: Map keys must be unique at line 10, column 1:\n\n\r\ninclude
resource: "/c:/Users/User/zephyr/dts/bindings/pinctrl/atmel,sam0-pinctrl.yaml",
severity: 8,
message: "Invalid type definition: Map keys must be unique at line 94, column 1:\n\n\r\nproperties
I see where it is pulling them from, just not sure why those files.
  • Hello Stephen,
    Susheel is OoO, so I will take a look into this in the meantime.
    You don’t need to worry about the Intellisense errors, as they won’t affect your build. However, I’m not sure if it’s an Intellisense error, as I don’t see a screenshot with the latest SDK and toolchain. Are you able to get a clean build and flash? Please check the build logs in the terminal. I also recommend sharing the support information from the nRF Connect VS Code extension. Check this thread where I’ve explained how to generate the support information.
    Abhijith
  • I copied the support information as requested.  Let me know if that give enough data.  I also cannot find the gpio0 pin 15 overlapping error shown.  Thanks.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 11 Pro",
        "osKernel": "10.0.22631",
        "vscode": "1.93.1",
        "electron": "30.4.0",
        "node": "v20.15.1"
      "system": {
        "date": "2024-09-25T04:20:31.580Z",
        "vscodeRoot": "c:\\Users\\User\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "24:10:34",
        "osUptime": "30:53:22",
        "cpu": "12th Gen Intel(R) Core(TM) i9-12950HX"
      "workspace": {
        "name": "lte_console (Workspace)",
        "workspaceFile": "c:\\Users\\User\\Pinnacle_100_Sample_Applications\\apps\\lte_console\\src\\lte_console.code-workspace",
        "folders": [
          "c:\\Users\\User\\Pinnacle_100_Sample_Applications\\apps\\lte_console"
      "sdks": [
          "version": "v2.7.0",
          "path": "c:\\ncs\\v2.7.0"
          "version": "v2.4.1",
          "path": "c:\\Users\\User"
          "version": "v2.3.0",
          "path": "c:\\ncs\\v2.3.0"
          "version": "v3.5.99",
          "path": "c:\\Users\\User\\zephyrproject"
      "activeBuild": "c:\\Users\\User\\Pinnacle_100_Sample_Applications\\apps\\lte_console\\build",
      "apps": [
          "workspace": "c:\\Users\\User\\Pinnacle_100_Sample_Applications\\apps\\lte_console",
          "uri": "c:\\Users\\User\\Pinnacle_100_Sample_Applications\\apps\\lte_console",
          "buildConfigurations": [
              "id": "c:\\Users\\User\\Pinnacle_100_Sample_Applications\\apps\\lte_console\\build",
              "name": "build",
              "boardId": "pinnacle_100_dvk",
              "type": "Zephyr",
              "isChild": false,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "pristineBuild": [],
                "flash": [],
                "eraseAndFlash": []
      "topdir": "c:\\Users\\User",
      "workspaceState": "workspace-ready",
      "toolchains": [
          "version": "2.7.0",
          "path": "c:\\ncs\\toolchains\\ce3b5ff664"
          "version": "2.6.1",
          "path": "c:\\ncs\\toolchains\\cf2149caf2"
          "version": "2.6.0",
          "version": "0.16.4",
          "path": "c:\\Users\\User\\zephyr-sdk-0.16.4"
      "activeToolchain": {
        "type": "installation",
        "path": "c:\\ncs\\toolchains\\ce3b5ff664",
        "version": "2.7.0",
        "displayName": "nRF Connect SDK Toolchain v2.7.0"
      "connectedDevices": [
          "serialNumber": "000483068589"
      "deviceProvider": "nrfutil",
      "tools": {
        "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.5-1",
        "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.94e",
        "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
        "C:\\ncs\\toolchains\\ce3b5ff664\\cmake": "3.21.0",
        "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\Scripts\\west.exe": "1.2.0",
        "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\python.exe": "3.9.13",
        "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\ninja.exe": "1.10.2",
        "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\gperf.exe": "3.1",
        "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\dtc.exe": "1.4.7",
        "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\gn.exe": "2172",
        "C:\\ncs\\toolchains\\ce3b5ff664\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
        "arm-gdbPath": "c:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
        "riscv-gdbPath": "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.5.0",
          "binPath": "c:\\Users\\User\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device"
        "nrfutil-toolchain-manager": {
          "version": "0.14.4",
          "binPath": "c:\\Users\\User\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "HOME": "C:\\Users\\User",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\User",
          "PATH": "C:\\ncs\\toolchains\\ce3b5ff664;C:\\ncs\\toolchains\\ce3b5ff664\\mingw64\\bin;C:\\ncs\\toolchains\\ce3b5ff664\\bin;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\User\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files\\National Instruments\\Shared\\OpenVINO\\;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\WireGuard\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\IVI\\Bin\\;C:\\Program Files\\IVI Foundation\\IVI\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\site-packages;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\Scripts;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Windows Kits\\10\\bin\\x64;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\Pololu\\Tic\\bin;C:\\Program Files (x86)\\National Instruments\\Shared\\LabVIEW CLI;C:\\Program Files (x86)\\Microsoft SQL Server\\80\\Tools\\Binn\\;C:\\Program Files (x86)\\GitExtensions\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;%SystemRoot%\\system32;%SystemRoot%;%SystemRoot%\\System32\\Wbem;%SYSTEMROOT%\\System32\\WindowsPowerShell\\v1.0\\;%SYSTEMROOT%\\System32\\OpenSSH\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311-32\\Scripts\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311-32\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\User\\.dotnet\\tools;C:\\Users\\User\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\User\\AppData\\Local\\Microsoft\\WindowsApps;",
          "ZEPHYR_BASE": "c:\\Users\\User\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\zephyr-sdk",
          "PYTHONPATH": "C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\Lib;C:\\ncs\\toolchains\\ce3b5ff664\\opt\\bin\\Lib\\site-packages"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files\\National Instruments\\Shared\\OpenVINO\\;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\WireGuard\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\IVI\\Bin\\;C:\\Program Files\\IVI Foundation\\IVI\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\site-packages;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\Scripts;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Windows Kits\\10\\bin\\x64;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\Pololu\\Tic\\bin;C:\\Program Files (x86)\\National Instruments\\Shared\\LabVIEW CLI;C:\\Program Files (x86)\\Microsoft SQL Server\\80\\Tools\\Binn\\;C:\\Program Files (x86)\\GitExtensions\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;%SystemRoot%\\system32;%SystemRoot%;%SystemRoot%\\System32\\Wbem;%SYSTEMROOT%\\System32\\WindowsPowerShell\\v1.0\\;%SYSTEMROOT%\\System32\\OpenSSH\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311-32\\Scripts\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311-32\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\Scripts;C:\\Users\\User\\.dotnet\\tools;C:\\Users\\User\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\User\\AppData\\Local\\Microsoft\\WindowsApps;",
          "PATH": "C:\\Program Files\\National Instruments\\Shared\\OpenVINO\\;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\WireGuard\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\IVI\\Bin\\;C:\\Program Files\\IVI Foundation\\IVI\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\site-packages;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\Scripts;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Windows Kits\\10\\bin\\x64;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\Pololu\\Tic\\bin;C:\\Program Files (x86)\\National Instruments\\Shared\\LabVIEW CLI;C:\\Program Files (x86)\\Microsoft SQL Server\\80\\Tools\\Binn\\;C:\\Program Files (x86)\\GitExtensions\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;%SystemRoot%\\system32;%SystemRoot%;%SystemRoot%\\System32\\Wbem;%SYSTEMROOT%\\System32\\WindowsPowerShell\\v1.0\\;%SYSTEMROOT%\\System32\\OpenSSH\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311-32\\Scripts\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311-32\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311\\Scripts\\;C:\\Users\\User\\AppData\\Local\\Programs\\Python\\Python311\\;C:\\Users\\User\\AppData\\Roaming\\Python\\Python311\\Scripts;C:\\Users\\User\\.dotnet\\tools;C:\\Users\\User\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\User\\AppData\\Local\\Microsoft\\WindowsApps;"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "${nrf-connect.sdk:2.7.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.7.0}"
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": true
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": false,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask"
          "terminalMode": "character"
      "extensions": {
        "internal": {
            "version": "2024.9.87",
            "path": "c:\\Users\\User\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64",
            "isActive": true
            "version": "2024.9.14",
            "path": "c:\\Users\\User\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
            "isActive": true
            "version": "2024.9.26",
            "path": "c:\\Users\\User\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.9.26",
            "isActive": true
            "version": "2024.9.20",
            "path": "c:\\Users\\User\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.9.20",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.21.6",
          "ms-vscode.js-debug": "1.93.0",
          "ms-vscode.vscode-js-profile-table": "1.0.9",
          "circuitdojo.zephyr-tools": "0.3.3",
          "eamodio.gitlens": "15.5.1",
          "ms-python.debugpy": "2024.10.0",
          "ms-python.python": "2024.14.1",
          "ms-python.vscode-pylance": "2024.9.2",
          "rfp-canvas.xbit-vsc": "0.2.2",
          "twxs.cmake": "0.0.17"
    From the screenshot you shared, I noticed that your toolchain is version 2.7.0, while the SDK version is v2.4.1. I recommend using a corresponding toolchain that matches the SDK version or updating the SDK to the latest version for optimal compatibility.
    Abhijith
