Erasing 4kb QSPI ext flash block takes too long 700 - 900 millisec
NRF52840 running 17.1 SDK and using QSPI interface to erase a block of memory from AT25FF321A external flash IC.
When we call erase it takes 930 millisec to finish erasing a 4kb block. The IC datasheet says it should only take 45 millisec or something like that.
Why is it taking so long?
nrfx_err_t nrf_err = nrfx_qspi_erase(NRF_QSPI_ERASE_LEN_4KB, start_address);
if (NRFX_SUCCESS == nrf_err)
    while(NRFX_SUCCESS != nrf_drv_qspi_mem_busy_check());
// this usually takes 770 - 930 millisec to finish
// but the datasheet for the ext falsh says it should only take 45 ms at most
    Ok so could you provide an example process?
    would it be like this?
    nrf_qspi_addrconfig_set( WHAT GOES HERE ?);
  • Or would it be something like this?
    // save current reg value
    uint32_t config = QSPI->ADDRCONF;
    // add wren
    bool wren = true;
    config |= (wren ? 1U : 0U) << QSPI_ADDRCONF_WREN_Pos;
    // update register
    QSPI->ADDRCONF = config;
    // send erase
    // wait for completion code here
  • Hi Joshua,
    Could you try this:
        nrf_qspi_addrconfig_conf_t addr_cfg = {
            .opcode    = 0xB7,
            .byte0     = 0 ,
            .byte1     = 0,
            .mode      = 0,
            .wipwait   = true,
            .wren      = true
        nrf_qspi_addrconfig_set(NRF_QSPI,&addr_cfg);
    As I mentioned, please try to verify the operation using a logic analyzer. It would save you a lot of time.
  • Hi, we just tried that
    uint32_t                   start    = xTaskGetTickCount();
            .opcode = 0xB7, .byte0 = 0, .byte1 = 0, .mode = 0, .wipwait = true, .wren = true};
        nrf_qspi_addrconfig_set(NRF_QSPI, &addr_cfg);
        sys_delay_ms(10);
        nrfx_err_t nrf_err = nrfx_qspi_erase(NRF_QSPI_ERASE_LEN_4KB, 0x00041000);
        while (NRFX_SUCCESS != nrfx_qspi_mem_busy_check())
        uint32_t end = xTaskGetTickCount();
        NRF_LOG_INFO("Elapsed: %lu addr: %p", end - start, start_address);
    but still 920 millisec
    Also, we looked on the scope and here are the results when only using nrfx_qspi_erase (no nrf_qspi_addrconfig_set).
    It looks like the nrf sdk DOES send the 0x06 wren command during erase automatically
  • Hi Joshua,
    Could you capture longer trace to see how it goes with the erase. I would expect to see the nRF52 continuously poll the external flash for status until the status show it's ready. If it's the case I am not sure what can we do to improve that.
    Please check if there is any option in the external flash for example "high performance" more or something ?
