nrf5340 - FLASH overflow issue
Still working on nRF5340 with external QSPI NOR Flash model EN25QH64 (building environment: NCS 2.6.1, Zephyr 3.5.99).
I use it for slot-1 partition during DFU.
At build time the linker reports a FLASH region overflow by 15120 bytes
[153/158] Linking C executable zephyr/zephyr_pre0.elf
[154/158] Generating linker.cmd
[155/158] Generating isr_tables.c, isr_tables_vt.ld, isr_tables_swi.ld
[156/158] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[157/158] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[158/158] Linking C executable zephyr/zephyr.elf
           FLASH:       24538 B      34176 B     71.80%
             RAM:        3488 B        64 KB      5.32%
           SRAM1:          0 GB        64 KB      0.00%
        IDT_LIST:          0 GB        32 KB      0.00%
[232/243] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[233/243] Creating public key from private key used for signing
[235/243] Completed 'b0n_subimage'
[236/243] Creating data to be provisioned to the Bootloader, storing to provision.hex
[238/243] Generating zephyr/b0n_container.hex
[239/243] Linking C executable zephyr/zephyr.elf
           FLASH:      177528 B       222 KB     78.09%
             RAM:       47604 B        64 KB     72.64%
[240/243] Generating zephyr/app.hex
[240/243] Creating signature of application
[241/243] Creating validation for zephyr.hex, storing to
[243/243] Generating zephyr/merged_CPUNET.hex
[535/559] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/gabriele/spiro-dev/apps/spiro/build/zephyr/zephyr_pre0.map
: && ccache /home/gabriele/spiro-dev/nrf53sdk/sdk/gnu-arm-emb-toolchain/bin/arm-none-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/gabriele/spiro-dev/apps/spiro/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a  zephyr/boards/boards/arm/nrf5340_spiro_cpuapp/lib..__..__..__board-support__boards__arm__nrf5340_spiro.a  zephyr/subsys/fs/libsubsys__fs.a  zephyr/subsys/random/libsubsys__random.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/bluetooth/crypto/libsubsys__bluetooth__crypto.a  zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a  zephyr/subsys/net/libsubsys__net.a  zephyr/drivers/adc/libdrivers__adc.a  zephyr/drivers/bluetooth/libdrivers__bluetooth.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/display/libdrivers__display.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/i2c/libdrivers__i2c.a  zephyr/drivers/mbox/libdrivers__mbox.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/pwm/libdrivers__pwm.a  zephyr/drivers/sensor/dps310/libdrivers__sensor__dps310.a  zephyr/drivers/sensor/max30101/libdrivers__sensor__max30101.a  zephyr/drivers/sensor/sht4x/libdrivers__sensor__sht4x.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/libmetal/libmetal/lib/libmetal.a  modules/littlefs/libmodules__littlefs.a  modules/lvgl/libmodules__lvgl.a  modules/open-amp/open-amp/lib/libopen_amp.a  modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a  modules/nrf/subsys/pcd/lib..__nrf__subsys__pcd.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/gabriele/spiro-dev/nrf53sdk/sdk/gcc-arm-none-eabi-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/thumb/v8-m.main+fp/hard"  -L/home/gabriele/spiro-dev/apps/spiro/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfpu=fpv5-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -lm  -Wl,-lc  -L"/home/gabriele/spiro-dev/nrf53sdk/sdk/gnu-arm-emb-toolchain/arm-none-eabi"/lib/thumb/v8-m.main+fp/hard  -Wl,-lgcc  -lc  -specs=nano.specs  /home/gabriele/spiro-dev/nrf53sdk/ncs/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc312_platform_0.9.19.a  -lc && cd /home/gabriele/spiro-dev/apps/spiro/build/zephyr && /home/gabriele/spiro-dev/nrf53sdk/zephyr/sdk/bin/cmake -E true
/home/gabriele/spiro-dev/nrf53sdk/sdk/gcc-arm-none-eabi-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
/home/gabriele/spiro-dev/nrf53sdk/sdk/gcc-arm-none-eabi-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.bfd: region `FLASH' overflowed by 15120 bytes
I'm not sure this is related with the external or internal flash.
This is the DTS descriptor for the external flash
&qspi {
	/delete-node/ mx25r6435f@0;
	en25qh64: en25qh64@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
		sck-frequency = <8000000>;
		jedec-id = [1c 70 17];
	        size = <0x800000>;  // 8MB
		partitions {
			#address-cells = <1>;
			#size-cells = <1>;
			data_partition: partition@0 {
				label = "data";
				reg = <0x000000000 0x000100000>;
			slot1_partition: partition@100000 {
				label = "image-1";
				reg = <0x000100000 0x0001ac000>;
