DFU update error
There are receivers and repeaters with nRF52832 mounted on the board.
When updating with DFU from iPad, a version check error occurs in the customer's environment.
The repeater can be updated normally in the customer's environment, but the receiver gets a version check error.
The DFU file is created by creating a batch file of commands on a Windows PC.
The contents of the batch file are as follows.
nrfutil pkg generate --hw-version 52 --application-version 1 --application Ping_Pong_ISP4520-JP_SEND.hex --sd-req 0x9D --key-file ./private.key DFU_RECV8_1.00_3in1.zip
The name of the hex file remains the same even if the source is changed, so the DFU file name in the batch file is edited and executed to create the DFU file.
The apps used for the update are nRFToolbox and nRF Connect, and both result in a version check error.
What do you think could be the cause?
  • Thank you for your answer.
    When I run the command on a device that cannot be updated, I get the following error:
    (base) D:\>nrfjprog --readcode flash_readout.hex
    Reading flash.
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    I am attaching the log created with the --log option.
    nrfjprog --memrd 0x300c
    run successfully and returned the expected value.
    Do you know what the cause is?2626.log.log
    The communication between the debugger and your device appears to be a bit unstable. Did you try running the --readcode multiple times to see if it might work after a few attempts? Lowering the clock speed (--clockspeed) may also help.
  • [2024-Sept-17 18:01:54] [debug] --------------------------------------------------------------------------------
    [2024-Sept-17 18:01:54] [debug] nrfjprog --readcode flash_readout.hex --clockspeed 125 --log
    [2024-Sept-17 18:01:54] [debug] nrfjprog version 10.24.0 external
    [2024-Sept-17 18:01:54] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2024-Sept-17 18:01:54] [ info] Library loaded, loading member functions.
    [2024-Sept-17 18:01:54] [ info] Member functions succesfully loaded.
    [2024-Sept-17 18:01:55] [debug] [ Client] - open
    [2024-Sept-17 18:01:55] [debug] [ Client] - start
    [2024-Sept-17 18:01:55] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence ac10e264-bba9-447b-b5e3-8462de1f377a.
    [2024-Sept-17 18:01:55] [trace] [ Client] - Command open executed for 58 milliseconds with result 0
    [2024-Sept-17 18:01:55] [debug] [ Client] - config
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Sept-17 18:01:55] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - open
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - just_check_family
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - open_dll
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Sept-17 18:01:55] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V794e\JLink_x64.dll.
    [2024-Sept-17 18:01:55] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Sept-17 18:01:55] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Set batch mode
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - dll_version
    [2024-Sept-17 18:01:55] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
    [2024-Sept-17 18:01:55] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - config
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - enum_emu_snr
    [2024-Sept-17 18:01:55] [trace] [ Worker] - Command config executed for 5 milliseconds with result 0
    [2024-Sept-17 18:01:55] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2024-Sept-17 18:01:55] [debug] [ Client] - enum_emu_snr
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - enum_emu_con_info
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Sept-17 18:01:55] [trace] [ Worker] - Command enum_emu_con_info executed for 3 milliseconds with result 0
    [2024-Sept-17 18:01:55] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2024-Sept-17 18:01:55] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Sept-17 18:01:55] [trace] [  JLink] - Firmware: J-Link V11 compiled Dec  4 2023 10:22:45
    [2024-Sept-17 18:01:55] [trace] [  JLink] - Hardware: V11.00
    [2024-Sept-17 18:01:55] [trace] [  JLink] - S/N: 821007475
    [2024-Sept-17 18:01:55] [trace] [  JLink] - OEM: SEGGER
    [2024-Sept-17 18:01:55] [trace] [  JLink] - Feature(s): GDB
    [2024-Sept-17 18:01:55] [trace] [  JLink] - Bootloader: 2019 Jul 04
    [2024-Sept-17 18:01:55] [trace] [  JLink] - USB speed mode: High speed (480 MBit/s)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Sept-17 18:01:55] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Sept-17 18:01:55] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
    [2024-Sept-17 18:01:55] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
    [2024-Sept-17 18:01:55] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.94e "
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 71.292ms returns "O.K."
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_HasError()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_Lock()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.001ms returns 0x01
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.000ms returns 0x00
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.003ms returns 0x00
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.012ms returns 0
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 3.100ms returns 0x00
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - 180000000 Hz / n, n >= 12
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.015ms
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 15000kHz
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_SetSpeed(125)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.878ms
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.004ms returns 125
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - SWD clock set to 125kHz
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_GetSN()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.006ms returns 821007475
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - read_device_family
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.004ms returns 0x01
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - coresight_configure
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.820ms returns 0
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 137.176ms returns 0
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.522ms returns -1
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.674ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.375ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.531ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.609ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.634ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.423ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.224ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.335ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.526ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.382ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.448ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.315ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.541ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.501ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.533ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.551ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.421ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.469ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.693ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.625ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.496ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.760ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.461ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.739ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.602ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.510ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.605ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.709ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.858ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.697ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.582ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.645ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.710ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.751ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 6.040ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.500ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.417ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.537ms returns -1
    [2024-Sept-17 18:01:55] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 482 milliseconds with result -102
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.843ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.161ms
    [2024-Sept-17 18:01:55] [error] [ Worker] - An unknown error.
    [2024-Sept-17 18:01:55] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 473 milliseconds with result -102
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - close
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.023ms returns 0x01
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - close
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.010ms returns FALSE
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.434ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.233ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.415ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.486ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.574ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.289ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.361ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.398ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.557ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.459ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.483ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.691ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.523ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.698ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.729ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.894ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.781ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.961ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.831ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.542ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.564ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.684ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.613ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.594ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.589ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.488ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.895ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.711ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.516ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 6.049ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.657ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.468ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.873ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.771ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.451ms returns -1
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 5.579ms returns -1
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2024-Sept-17 18:01:55] [trace] [  JLink] - - 0.118ms
    [2024-Sept-17 18:01:55] [trace] [  JLink] - JLINK_Close()
    [2024-Sept-17 18:01:55] [debug] [SeggerBackend] - Segger Backend closed.
    [2024-Sept-17 18:01:55] [debug] [  nRFXX] - nRF family DLL closed
    [2024-Sept-17 18:01:55] [trace] [ Worker] - Command close executed for 279 milliseconds with result 0
    [2024-Sept-17 18:01:55] [trace] [ Client] - Command close executed for 294 milliseconds with result 0
    [2024-Sept-17 18:01:55] [debug] [ Client] - terminate
    [2024-Sept-17 18:01:55] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2024-Sept-17 18:01:55] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2024-Sept-17 18:01:55] [trace] [ Worker] - Executed 6 commands for 767 milliseconds
    [2024-Sept-17 18:01:56] [debug] [ Client] - Worker process exited with code: 0
    [2024-Sept-17 18:01:56] [debug] [ Client] - Child process terminated with result 0
    [2024-Sept-17 18:01:56] [trace] [ Client] - Executed 6 commands for 864 milliseconds
    [2024-Sept-17 18:01:56] [debug] [ Client] - terminate
    I ran --readcode multiple times, but the situation did not change.
    I tried --clockspeed 125, but I got an error.
    I am attaching the log file again.
  • Strange. Is there anything that could cause the chip to reset externally on this device while the flash is being read? For instance, an external watchdog or regulator? Another option is to read out the settings page and manually parse the content.
    nrfjprog --memrd <settings page address> --n 0x1000 > bl_settings.txt
  • I extracted a ZIP file from an iPad that contained files that could not be DFU'd, and checked the contents of a normal ZIP file of the same version. I found that the json and bin files were identical, but there was a difference in the dat file.
    What do you think is the reason this happens?
