Verification of the IQ data
I am currently exploring direction finding connectionless Rx and Tx samples.
I am using two nrf52833DK. I already have an antenna array connected to one of  the development kits. Below is the code that i am using for printing the IQ data.
static void cte_recv_cb(struct bt_le_per_adv_sync *sync,
		struct bt_df_per_adv_sync_iq_samples_report const *report)
	printk("CTE[%u]: samples count %d, cte type %s, slot durations: %u [us], "
	       "packet status %s, RSSI %i\n",
	       bt_le_per_adv_sync_get_index(sync), report->sample_count,
	       cte_type2str(report->cte_type), report->slot_durations,
	       packet_status2str(report->packet_status), report->rssi);
	printk("#IQ-Samples: %d\n", report->sample_count);
	for(int i=0; i<report->sample_count; i++){
		printk("[%d]: I:%d Q:%d,\n", i, report->sample[i].i, report->sample[i].q);
		// k_sleep(K_MSEC(10));  // Add a delay of 10 milliseconds between prints
and the values I get as an IQ data seems strange.
CTE[0]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -860
#IQ-Samples: 45
[0]: I:-2 Q:-2,
[1]: I:3 Q:4,
[2]: I:-6 Q:-9,
[3]: I:4 Q:7,
[4]: I:-3 Q:-6,
[5]: I:3 Q:8,
[6]: I:-5 Q:-6,
[7]: I:-2 Q:6,
[8]: I:-2 Q:-6,
[9]: I:-1 Q:-9,
[10]: I:4 Q:-7,
[11]: I:2 Q:-7,
[12]: I:6 Q:-4,
[13]: I:3 Q:-4,
[14]: I:7 Q:-1,
[15]: I:5 Q:-4,
[16]: I:7 Q:3,
[17]: I:6 Q:4,
[18]: I:6 Q:3,
[19]: I:2 Q:2,
[20]: I:6 Q:4,
[21]: I:-1 Q:7,
[22]: I:-1 Q:6,
[23]: I:-2 Q:6,
[24]: I:-4 Q:4,
[25]: I:-4 Q:0,
[26]: I:-9 Q:0,
[27]: I:-4 Q:1,
[28]: I:-8 Q:-3,
[29]: I:-7 Q:-5,
[30]: I:-5 Q:-4,
[31]: I:-8 Q:-7,
[32]: I:-5 Q:-6,
[33]: I:-1 Q:-7,
[34]: I:-3 Q:-7,
[35]: I:-1 Q:-9,
[36]: I:0 Q:-13,
[37]: I:4 Q:-5,
[38]: I:7 Q:-3,
[39]: I:6 Q:-1,
[40]: I:4 Q:2,
[41]: I:9 Q:-1,
[42]: I:6 Q:-1,
[43]: I:5 Q:6,
[44]: I:4 Q:7,
CTE[0]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -870
#IQ-Samples: 45
[0]: I:2 Q:3,
[1]: I:-4 Q:-8,
[2]: I:2 Q:5,
[3]: I:0 Q:-6,
[4]: I:-3 Q:4,
[5]: I:0 Q:-11,
[6]: I:-2 Q:6,
[7]: I:2 Q:-8,
[8]: I:-4 Q:5,
[9]: I:-2 Q:5,
[10]: I:-3 Q:3,
[11]: I:-8 Q:-3,
[12]: I:-4 Q:-3,
[13]: I:-5 Q:-6,
[14]: I:-10 Q:-6,
[15]: I:-4 Q:-2,
[16]: I:0 Q:-5,
[17]: I:0 Q:-3,
[18]: I:0 Q:-8,
[19]: I:2 Q:-4,
[20]: I:1 Q:-7,
[21]: I:1 Q:-4,
[22]: I:5 Q:-2,
[23]: I:6 Q:-4,
[24]: I:3 Q:-1,
[25]: I:5 Q:3,
[26]: I:6 Q:0,
[27]: I:7 Q:1,
[28]: I:2 Q:4,
[29]: I:4 Q:3,
[30]: I:1 Q:6,
[31]: I:-3 Q:6,
[32]: I:-3 Q:3,
[33]: I:-5 Q:4,
[34]: I:-4 Q:1,
[35]: I:-3 Q:2,
[36]: I:-2 Q:2,
[37]: I:-7 Q:-1,
[38]: I:-5 Q:-4,
[39]: I:-9 Q:-2,
[40]: I:-7 Q:-6,
[41]: I:-5 Q:-7,
[42]: I:-4 Q:-7,
[43]: I:-4 Q:-6,
[44]: I:-3 Q:-6,
Question :
the problem is , both I and Q values seems to follow certain pattern, like it ranges between (-10,+10). According to the Direction finding whitepaper,
First 8 samples are reference samples, and from the 9th sample [sample: 8], the pattern given should be sampled.
so my understanding is, by default the CTE is 160 us, so the CTE packet structure should be like,
""" guard period [4 us] + reference samples (samples (0-7)) [8 us] + for 12 antennas it should take [48 us] until it reaches the 160 us. """
so the value from sample [8]: I:-2 Q:-6, and sample [20]: I:6 Q:4, should be similar, but it is rather way afar.
my antenna pattern is
static const uint8_t ant_patterns[] = { 0x2, 0x0, 0x5, 0x6, 0x1, 0x4,
                    0xC, 0x9, 0xE, 0xD, 0x8, 0xA };
it is by default given by nordic.
I am using a 12-patch antenna design from nordic as an antenna array to calculate the AOA.
this is the prj.conf file
# Copyright (c) 2021 Nordic Semiconductor ASA
CONFIG_BT=y
CONFIG_BT_DEVICE_NAME="DF Connectionless Locator App"
CONFIG_BT_EXT_ADV=y
CONFIG_BT_PER_ADV_SYNC=y
CONFIG_BT_OBSERVER=y
# Enable Direction Finding Feature including AoA and AoD
CONFIG_BT_DF=y
CONFIG_BT_DF_CONNECTIONLESS_CTE_RX=y
Am i missing something?
please help me understand why the IQ values doesnt follow the antenna pattern?
I look forward to the response. Thank you in advance.
Darsh.
  • Darsh said:
    Does it mean to convert them into a complex form?
    Yes.. You need to use the formulas that I have stated in the previous reply..
    Darsh said:
    do i have to build an antenna model and do the calibration of the antenna? or is it already supported in the sample code for the nordic 12 patch antenna array?
    You will have to build the antenna model and make your own algorithm..
    Swathy
