How to configure Settings?
I have the task to persistently store some (2) configuration values in a Zephyr application (Nordic Version). The final version contains some external flash memory, will make use of MCUBoot, and Bluetooth (LE). The configuration values should be stored within the internal flash memory.
The application makes directly use of the QSPI peripheral and installs an interrupt handler (IRQ_CONNECT). According to the partition report (west build -t partition_manager_report), the `
settings_storage` partition is within the internal flash memory:
  flash_primary (0x100000 - 1024kB):
| 0x0: app (0xfc000 - 1008kB)              |
| 0xfc000: settings_storage (0x2000 - 8kB) |
| 0xfe000: EMPTY_0 (0x2000 - 8kB)          |
The relevant part of the `prj.conf` file looks like this:
# Storing configuration values
CONFIG_FLASH=y
CONFIG_NVS=y
CONFIG_FLASH_MAP=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
Without the `CONFIG_FLASH_MAP` configuration, the `CONFIG_SETTINGS_NVS` will be reset and the Settings backend will be some pointless default. But, when enabling `CONFIG_FLASH_MAP`, that module also defines an irq handler for the QSPI interrupt.
What do I have to do, to configure the Settings module to store configurations in the internal flash memory?
best regards
Torsten
    Which SDK version are you using, and can you share all your Kconfigs? If you use CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y that implies CONFIG_NORDIC_QSPI_NOR also in nRF Connect SDK 2.7, but that will be fixed in 2.8 (and is fixed in main).
  • I'm on a local branch, that is based on 2.7, but contains a lot of commits after 2.7. I could update to 2.8 and see, if my required fixes are included and then report, if that also fix this issue.
    Here is the configuration:
    # Temporary workaround for https://devzone.nordicsemi.com/f/nordic-q-a/107445/colon-in-soc_cpu_idle-h-leads-to-failing-build-with-arm-none-eabi-gcc-version-12-2
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=n
    # drivers/external_pin.cpp is defining the GPIOTE interrupt handler
    CONFIG_GPIO_NRFX_INTERRUPT=n
    # Enable support for C++
    CONFIG_CPP=y
    CONFIG_REQUIRES_FULL_LIBCPP=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_STD_CPP20=y
    CONFIG_MAIN_STACK_SIZE=16384
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_LOG_MODE_MINIMAL=n
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_DEFERRED=y
    CONFIG_LOG_BUFFER_SIZE=16384
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_NRF_SECURITY=y
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    CONFIG_I2C=y
    # USB
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_USB_DEVICE_PRODUCT="Lovelace Pod"
    CONFIG_USB_DEVICE_PID=0x0001
    CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
    CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
    CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
    CONFIG_UART_LINE_CTRL=y
    # MQTT
    CONFIG_MQTT_SN_LIB=y
    CONFIG_NETWORKING=y
    CONFIG_MQTT_SN_LOG_LEVEL_DBG=y
    # Analogue Frontend uses ZERO_LATENCY IRQs to call the SPI preparation callbacks
    CONFIG_ZERO_LATENCY_IRQS=y
    # For debugging only!
    #CONFIG_LOG_MODE_IMMEDIATE=n
    CONFIG_RESET_ON_FATAL_ERROR=n
    CONFIG_ASSERT=y
    # Bootloader
    #CONFIG_BOOTLOADER_MCUBOOT=y
    # Enable SMP Server
    #CONFIG_MCUMGR=y
    #CONFIG_MCUMGR_GRP_IMG=y
    # CONFIG_MCUMGR_GRP_IMG dependencies
    #CONFIG_FLASH=y
    #CONFIG_IMG_MANAGER=y
    # CONFIG_IMG_MANAGER dependencies
    #CONFIG_STREAM_FLASH=y
    # CONFIG_MCUMGR dependencies
    #CONFIG_NET_BUF=y
    #CONFIG_ZCBOR=y
    #CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
    #CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y
    #CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
    #CONFIG_UPDATEABLE_IMAGE_NUMBER=2
    #CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
    CONFIG_FLASH=y
    CONFIG_NVS=y
    # Required to actually use the NVS backend, conflicts with QSPI usage:
    # https://devzone.nordicsemi.com/f/nordic-q-a/114760/how-to-configure-settings
    CONFIG_FLASH_MAP=y
    CONFIG_SETTINGS=y
    CONFIG_NORDIC_QSPI_NOR=n
    # Bluetooth
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="Lovelace Pod"
    #CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
    I would love to get rid of the `CONFIG_NORDIC_QSPI_NOR=n` configuration, or in general, I would love to get rid of all unused drivers (as back in the good old days where library where statically linked ;-) )
    There are (probably too) many dependencies which makes things like this a bit tricky in general, so it makes sense to set CONFIG_NORDIC_QSPI_NOR=n on your end. I agee that needing to disable something you never ment to enable in the first place is not very elegant, but in the end the key is that the generated .config file is correct.
