Adding IPC to TF-M secure peripheral project
I would like to take Nordic's "TF-M secure peripheral partition" sample project, and modify it to take data received from the secure peripheral and send it wirelessly to another device. But I am running into some build errors and am unsure of how to fix it.
I'm working on a Windows 10 machine, with nRF5340DK's, and using NCS v2.5.0. I am using VS Code w/ the nRF Connect extensions for my development environment.
The "TF-M secure peripheral partition" sample project I mentioned comes from the NCS (at nrf/samples/tfm/tfm_secure_peripheral). I modified the sample slightly to get the SPI peripheral to interact with my sensor, and am able to read data from it.
Currently I am working on code to send data from the application core to the network core (before adding the wireless portion). I have previously worked with IPC for this (based off the sample project at NCS, path nrf/samples/ipc/ipc_service), so I am trying to integrate that code into this TF-M project. I tried adding the source code into the secure partition (as I assume it needs access to the data from the secure peripheral) and the build fails with the error looking like the following:
(Note that I trimmed down or modified the output slightly for brevity and privacy)
[77/224] Building C object secure_fw/partitions/partitions/secure_peripheral_partition_1/CMakeFiles/tfm_app_rot_partition_spp.dir/C_/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/common/syscalls_stub.o
[78/224] Building C object secure_fw/partitions/partitions/secure_peripheral_partition_1/CMakeFiles/tfm_app_rot_partition_spp.dir/secure_peripheral_partition.o
FAILED: (...command removed for brevity...)
In file included from C:/ncs/v2.5.0/zephyr/include/zephyr/sys/mem_manage.h:104,
                 from C:/ncs/v2.5.0/zephyr/include/zephyr/sys/device_mmio.h:47,
                 from C:/ncs/v2.5.0/zephyr/include/zephyr/device.h:15,
                 from C:/path_to_secure_peripheral_project/secure_peripheral_partition/secure_peripheral_partition.c:27:
C:/ncs/v2.5.0/zephyr/include/zephyr/sys/mem_manage.h: In function 'z_mem_phys_addr':
C:/ncs/v2.5.0/nrf/modules/tfm/tfm/boards/include/zephyr/sys/__assert.h:52:32: warning: implicit declaration of function 'tfm_core_panic' [-Wimplicit-function-declaration]
   52 | #define __ASSERT_POST_ACTION() tfm_core_panic()
C:/ncs/v2.5.0/nrf/modules/tfm/tfm/boards/include/zephyr/sys/__assert.h:93:25: note: in expansion of macro '__ASSERT_POST_ACTION'
   93 |                         __ASSERT_POST_ACTION();                                \
C:/ncs/v2.5.0/zephyr/include/zephyr/sys/mem_manage.h:158:9: note: in expansion of macro '__ASSERT'
  158 |         __ASSERT((addr >= CONFIG_SRAM_BASE_ADDRESS) &&
In file included from C:/path_to_secure_peripheral_project/secure_peripheral_partition/secure_peripheral_partition.c:28:
C:/ncs/v2.5.0/zephyr/include/zephyr/ipc/ipc_service.h: At top level:
C:/ncs/v2.5.0/zephyr/include/zephyr/ipc/ipc_service.h:368:81: error: unknown type name 'k_timeout_t'
  368 | int ipc_service_get_tx_buffer(struct ipc_ept *ept, void **data, uint32_t *size, k_timeout_t wait);
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\path_to_secure_peripheral_project\build'
To try and debug the issue, I've tried adding parts one by one to test. It seems that this error appears once I include the ipc_service.h header, like the following:
/* FILE: secure_peripheral/secure_peripheral_partition.c */
#include <psa/crypto.h>
#include <stdint.h>
/* ... (rest of includes; not shown here for brevity ... */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/ipc/ipc_service.h>    // error when add this
/* ... (rest of file) ... */
I tried briefly looking into the CMakeLists.txt files, using the PSA API instead of this IPC code, etc. So far I haven't been able to find where my exact problem is occurring. If I could get some pointers with what to look more closely at, I'd appreciate the help. Thank you in advance!
