Thread network key changes when migrating from NCS 2.4.1 to 2.6.1
nRF52840
NCS 2.4.1  to NCS 2.6.1
My project is based on the coap_server example.  When I ported it from NCS 2.4.1 to NCS 2.6.1, the network key and PSKC changed.  All other Thread credentials stayed the same (channel, channel mask,  panid, extended panid, mesh local prefix, network name, security policy).
The project supports DFU, so when upgrading from a 2.4.1 based version to a 2.6.1 based version, the network key changed and the device cannot communicate with other devices on the original network.
Both versions use identical pm_static.yml files, so the storage settings partition has not moved.
Is this a bug?  Is there a workaround?
Mary
  • I set
    CONFIG_OPENTHREAD_NETWORKKEY="00:11:22:33:44:55:66:77:88:99:aa:bb:cc:dd:ee:ff"
    in prf.conf for both 2.4.1 and 2.6.1.
    and commented out this code:
    	// if (!otDatasetIsCommissioned(instance))
    	// 	LOG_INF("Thread not commissioned. Creating dataset.");
    	// 	otDatasetCreateNewNetwork(instance, &dataset);
    	// 	// Form network name from MAC address last three bytes (16 char limit)
    	// 	// channel, panid, and networkkey will be random
    	// 	uint32_t maclo = NRF_FICR->DEVICEADDR[0];
    	// 	uint32_t machi = NRF_FICR->DEVICEADDR[1];
    	// 	uint8_t mac[3];
    	// 	mac[0] = machi;			// unique part
    	// 	mac[1] = maclo >> 24;
    	// 	mac[2] = maclo >> 16;
    	// 	snprintk(dataset.mNetworkName.m8, sizeof(dataset.mNetworkName.m8), "MyNet_%02X%02X%02X", mac[0], mac[1], mac[2]);
    	// 	dataset.mComponents.mIsNetworkNamePresent = true;
    	// 	otDatasetSetActive(instance, &dataset);
    I had to do a factory reset to see this network key appear.
    1. compiled with 2.4.1, downloaded with J-Link, and ran.  Old network key appeared
    2. Factory reset, ran.  New hard coded network key appeared
    3. Then compiled with 2.6.1, downloaded with J-Link, and ran.  New hard coded network key appeared.
    4. Factory reset, ran. New hard coded network key appeared.
    I'm not sure what this tells us.  I cannot use a hard coded network key for production.
    Mary
    Could you try to erase the board (nrfjprog --eraseall) before programming? Does it help?
  • I restored the fw to my original, so it's generating a random network key if it is not commissioned.
    1. nrfjprog --eraseall
    2. Program with fw built with NCS 2.4.1  networkkey = 916a8357f913200db83c5272ad01b2f4
    2. Program with fw built with NCS 2.6.1 networkkey = 916a8357f913200db83c5272ad01b2f4
    3. Program with fw built with NCS 2.4.1 networkkey = 00000000000000000000000000000000
    4. Program with fw built with NCS 2.6.1 networkkey = 916a8357f913200db83c5272ad01b2f4
    5. Program with fw built with NCS 2.4.1 networkkey = 00000000000000000000000000000000
    6 Program with fw built with NCS 2.6.1 networkkey = 916a8357f913200db83c5272ad01b2f4
    It seems the NCS 2.6.1 fw can read a networkkey that was written with 2.4.1.
    Once NCS 2.6.1 runs, 2.4.1 can no longer read it.
    Mary
    Why don't you use CONFIG_OPENTHREAD_NETWORKKEY in prf.conf for both 2.4.1 and 2.6.1 to ensure they can have the same networkey?
    -Amanda H.
  • Because we have devices in the field that have a randomly generated network key that need to keep using that same network key so that they can communicate with the other devices on their network.  We would update them with a 2.6.1 based version, but we can't because of this issue.
    Because we don't want ALL of our customers to have the same network key.
    Because once a device sets a network key, it should never change. Even when updating with a new SDK.
    The issue is that the network key should not change, but it did. Why?
    Mary
    P.S.  I did not mean to verify your previous response.  I hit the wrong button.
