Enabling filesystem, disk and sdmmc makes system fail before any application code is called,
I want to enabe filessytem, diskaccess and sdmmc on nrf5340 in order to save data on a SDCARD via SPI.
I have added the following to my proj.conf
CONFIG_DISK_ACCESS=y
CONFIG_DISK_DRIVERS=y
CONFIG_DISK_DRIVER_SDMMC=y
# Enable file system support (optional, if you want to use a file system)
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_FS_FATFS_MOUNT_MKFS=y
CONFIG_FS_FATFS_LFN=y
CONFIG_FS_FATFS_EXFAT=y
I have not added anything to the development tree, nor have i added any code using any of these interfaces.
Nevertheless when i try to boot, both fs and bt_enable() fails and it is impossible to even get the debugger connected to step through the code. System is build with -Og.
[00:00:00.399,353] <err> fs: mount point not found!!
[00:00:00.399,475] <err> fs: mount point not found!!
[00:00:00.399,475] <err> bt_settings: settings_subsys_init failed (err -2)
[00:00:00.399,536] <err> Application: Bluetooth init failed (err -2)
I have tried to bump the stack to 64kB, just to see if that was the problem - no luck.
Can you please explain what the problem is?
br,brian
Top Replies
