Thingy53 Wifi Station build configuration Issue
I am building the existing WIFI station app for the Thingy53 with the nRF 7002EB board - sample code: nrf/samples/wifi/sta
In the CMakeLists.txt file, the line CONFIG_WIFI_READY_LIB=y is throwing me the error: attempt to assign the value 'y' to the undefined symbol WIFI_READY_LIB
I have tried to build the application with toolchain v2.6.0 and v2.7.0, with the board target being thingy53_nrf5340_cpuapp and thingy53_nrf5340_cpuapp_ns, adding the additional CMake argument of -DSHIELD=nrf7002eb to to configuration.
All of these options have resulted in the Fatal error.
How do I get the config_wifi_ready_lib to integrate in my workspace?
Thank you,
Jon
  • Hey Hakon, absolutely.
    Attached is the project.conf and the CMake Lists.txt file
    # Copyright (c) 2022 Nordic Semiconductor ASA
    cmake_minimum_required(VERSION 3.20.0)
    set(SHIELD nrf7002eb)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(sta)
    # Include the Wi-Fi Ready library
    list(APPEND ZEPHYR_EXTRA_MODULES ${CMAKE_CURRENT_SOURCE_DIR}/modules/lib/wifi_ready)
    target_include_directories(app PUBLIC ${ZEPHYR_BASE}/subsys/net/ip)
    target_sources(app PRIVATE
    	src/main.c
    set (SHEILD nrf7002eb)
    0284.prj.conf
    As for the log of the build, below is the output of my console
     *  Executing task: nRF Connect: Generate config thingy53_nrf5340_cpuapp for /Users/jon/Documents/smartweight_project/workspace/sta
    Building sta
    west build --build-dir /Users/jon/Documents/smartweight_project/workspace/sta/build_9 /Users/jon/Documents/smartweight_project/workspace/sta --pristine --board thingy53_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/Users/jon/Documents/smartweight_project/workspace/sta
    -- Application: /Users/jon/Documents/smartweight_project/workspace/sta
    -- CMake version: 3.21.0
    -- Found Python3: /opt/nordic/ncs/toolchains/f8037e9b83/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /Users/jon/Library/Caches/zephyr
    -- Zephyr version: 3.5.99 (/Users/jon/Documents/smartweight_project/workspace/zephyr)
    -- Board: thingy53_nrf5340_cpuapp
    -- Shield(s): nrf7002eb
    -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/f8037e9b83/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /Users/jon/Documents/smartweight_project/workspace/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp.dts
    -- Found devicetree overlay: /Users/jon/Documents/smartweight_project/workspace/nrf/boards/shields/nrf7002eb/nrf7002eb.overlay
    -- Found devicetree overlay: /Users/jon/Documents/smartweight_project/workspace/nrf/boards/shields/nrf7002eb/boards/thingy53_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: /Users/jon/Documents/smartweight_project/workspace/sta/build_9/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/jon/Documents/smartweight_project/workspace/sta/build_9/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/jon/Documents/smartweight_project/workspace/sta/build_9/zephyr/dts.cmake
    warning: Experimental symbol WIFI_CREDENTIALS is enabled.
    /Users/jon/Documents/smartweight_project/workspace/sta/prj.conf:11: warning: attempt to assign the value 'y' to the undefined symbol WIFI_READY_LIB
    error: Aborting due to Kconfig warnings
    Parsing /Users/jon/Documents/smartweight_project/workspace/sta/Kconfig
    Loaded configuration '/Users/jon/Documents/smartweight_project/workspace/zephyr/boards/arm/thingy53_nrf5340/thingy53_nrf5340_cpuapp_defconfig'
    Merged configuration '/Users/jon/Documents/smartweight_project/workspace/sta/prj.conf'
    CMake Error at /Users/jon/Documents/smartweight_project/workspace/zephyr/cmake/modules/kconfig.cmake:358 (message):
      command failed with return code: 1
      /Users/jon/Documents/smartweight_project/workspace/nrf/cmake/modules/kconfig.cmake:29 (include)
      /Users/jon/Documents/smartweight_project/workspace/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
      /Users/jon/Documents/smartweight_project/workspace/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /Users/jon/Documents/smartweight_project/workspace/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:10 (find_package)
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/f8037e9b83/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/f8037e9b83/opt/[email protected]/bin/python3.9 -B/Users/jon/Documents/smartweight_project/workspace/sta/build_9 -GNinja -DBOARD=thingy53_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/Users/jon/Documents/smartweight_project/workspace/sta -S/Users/jon/Documents/smartweight_project/workspace/sta
     *  The terminal process terminated with exit code: 1.
    Thanks Hakon,
    Jon
  • Hi Jon,
    Based on the zephyr version:
    This indicates that you're on v2.6.1 or older.
    Can you try running this on ncs v2.7.0 ?
    Håkon
