sysbuild NCS 2.7 #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
Hi there, I-m trying to compile a hello world sample with an encrypted bootloader
# Sysbuild configuration file.
#see C:\D\dev\nordicsemi\v2.7.0\nrf\doc\nrf\releases_and_maturity\migration\migration_sysbuild.rst
#inmutable secure bootloader
SB_CONFIG_SECURE_BOOT_APPCORE=y
#inmutable secure bootloader for netcore
#SB_CONFIG_SECURE_BOOT_NETCORE=y
# Enable MCUboot per default for this sample.
SB_CONFIG_BOOTLOADER_MCUBOOT=y
#signing images
SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="../key15_2_ecdsa-p256.pem"
#first key is automatically added, adding future ones
SB_CONFIG_SECURE_BOOT_PUBLIC_KEY_FILES="../key15_3_pub_ecdsa-p256.pem,../key15_4_pub_ecdsa-p256.pem"
#signature & encryption keys for images
SB_CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="../NCS27_ecdsa-p256.pem"
#enable encryption
SB_CONFIG_BOOT_ENCRYPTION=y
SB_CONFIG_BOOT_ENCRYPTION_KEY_FILE="../NCS27_1_SK_ecdsa-p256.pem"
SB_CONFIG_MCUBOOT_MODE_SINGLE_APP=n
SB_CONFIG_MCUBOOT_MODE_SWAP_SCRATCH=y
SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY=n
SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP=n
SB_CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION=y
#allow netcore HCI
SB_CONFIG_NETCORE_HCI_IPC=y
System build: Use sysbuild
I'm getting these errors:
In file included from C:/D/dev/nordicsemi/v2.7.0/bootloader/mcuboot/boot/bootutil/include/bootutil/enc_key.h:33,
                 from C:/D/dev/nordicsemi/v2.7.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c:44:
C:/D/dev/nordicsemi/v2.7.0/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:19:6: error: #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
   19 |     #error "One crypto backend must be defined: either MBED_TLS or TINYCRYPT"
C:/D/dev/nordicsemi/v2.7.0/bootloader/mcuboot/boot/bootutil/include/bootutil/enc_key.h:45:5: error: unknown type name 'bootutil_aes_ctr_context'
   45 |     bootutil_aes_ctr_context aes_ctr;
and
C:/D/dev/nordicsemi/v2.7.0/bootloader/mcuboot/ext/tinycrypt/lib/source/hmac.c:33:10: fatal error: tinycrypt/hmac.h: No such file or directory
   33 | #include <tinycrypt/hmac.h>
I also tried all these settings  in sysbuild/mcuboot.conf without success:
# Example of sample specific Kconfig changes when building sample with MCUboot
# when using sysbuild.
#CONFIG_MCUBOOT_LOG_LEVEL_WRN=y
#CONFIG_BOOT_UPGRADE_ONLY=n
#CONFIG_MCUBOOT_DOWNGRADE_PREVENTION=y
#CONFIG_BOOT_ENCRYPT_IMAGE=y
#CONFIG_SINGLE_APPLICATION_SLOT=n
#CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
#CONFIG_BOOT_ECDSA_TINYCRYPT=y
edit: I've got autogen-enckey.c & autogen-pubkey.c at build/mcuboot/zephyr
I also have zephyr.bin, zephyr.signed.bin & zephyr.signed.encrypted.bin at build/myapp/zephyr
I have not more configutration except for custom board, can you help?, thanks in advance.
Running nrf connect SDK 2.7.0 and toolchain 2.7.0, VSC 1.93.1, nRF Connect for VS Code v2024.9.87,nRF Connect for VS Code Extension Pack v2024.9.5
  • Hi Dejan, I try to encrypt the images in order to be upgraded by OTA DFU
    I used the keys that  u can see in the prev messages TYPE_ECDSA_P256
    Yes I make them by myself with imgtool and are the same we are using with our released product and working for more than 50000 users with SDK 2.3.
    I've put them in a folder in the SSD , same unit as the project
    Bets,
    JMA
  • Hi JMA,
    You could try to comment out 2 lines in sysbuild.conf
    #SB_CONFIG_BOOTLOADER_MCUBOOT=y
    #SB_CONFIG_SECURE_BOOT_PUBLIC_KEY_FILES="../key15_3_ecdsa-p256.pem,../key15_4_ecdsa-p256.pem"
    Dejan
  • Are you kidding me?, can u explain to me why I need to ask those silly questions like where I put hte keys', IT IS OBVIOUS that I need to put them in a file, not sure what's your goal but mine is not to waste too much time with silly stuff so can you answer, are u able to reproduce this ERROR for nrf5340dk or not?, if YES please try to make your own tests, I'm really busy, so if you don't want to help just please give the chance to someone interested about this.
    I understand that you are very busy, and I am sorry for any inconvenience you might have had.
    I was able to reproduce your error and provided you with a suggestion in my previous reply. Have you tried it out?
    Dejan
  • Of course I tried, not working, is it working for you?
    NOT WORKING!!!
