Thread viewer empty during debug
I have two computers where nRF Connect for VSCode behaves differently in the sense that in one computer when I start debug it stops at the first line of the main and I see thread viewer correctly showing the threads and the other computer stops first in the debug at some setup or init script and not in the main. In addition the Thread Viewer is empty.
I use nRF Connect SDK 2.6.1 from c:\ncs\v2.6.1\nrf\west.yml
I did some cleanup by removing VSCode, Segger probe softwares, nRF Connect for Desktop and tools. Then I searched in Windows in %USERPROFILE% and %APPDATA% Local and Roaming anything I could find related to nRF, VSCode, Segger tools. Then I reinstalled and I use a shared profile and the same nRF52840DK board. In the profile is installed nRF Connect for VSCode Extension Pack, which in turn install what is needed.
Despite repeating the same cleanup  and setup, in the home computer it works, and in the workplace doesn't.
I have a feeling that there are some hidden configs which I don't know, therefore is not enough to uninstall and cleanup in  %USERPROFILE% and %APPDATA% .
I really wished to have reliable and repeatable setup. Does anybody where it is saved the configuration regarding where it stops first at the staring point of Debug session?
Where exactly have to be made manual cleanup, to completely reset the developer environment?
  • My SDK and my working folder are outside of this home folder with space and none of them have space character in the path.
    After I created the new account, the SDK and the working directory remained exactly the same.
    My findings indicates the contrary.
    The VSCode plugins as they are installed in C:\Users\My Username\AppData\....  and who know what else (cache etc) have to be accessed. Once I created the new user, everything from %AppData%, such as the nRF Connect SDK for VSCode plugin, it was installed in the new home folder, without space and it worked.
    Seem you find the solution to fix it.
  • What I found is a workaround.
    I spent a few hours to somehow move all my apps into the new account (except one, which requires new license if I need to use again).
    At the end, I don't regret moving into a new account with folder name without space because many poorly tested software can be encountered and they just malfunction partially. Safe to be outside of any options with space in the user home folder name.
