RF transmission problem with nRF52840 QFAA
Hi, I am developing a board with an nRF52840 QFAA, which needs to communicate via BLE. I tried loading the test code 'ble_app_hrs' from the 'nRF5_SDK_17.1.0_ddde560' folder, but when using a spectrum analyzer, I can’t detect the Bluetooth signal, which I can detect when using the nRF52840-DK evaluation board with the nRF52840 QIAA microcontroller.
When using an oscilloscope, I can see RF power consumption from the chip on the evaluation board, but there’s no RF power consumption on the custom board.
What could be causing this?
I’m using SEGGER Embedded Studio to program the microcontroller. Is there anything I need to configure differently since I’m using a QFAA instead of a QIAA, or should Bluetooth communication work the same way?
Let me know, thanks!
  • Ok, done!
    Regarding the possibility of generating a fixed carrier frequency, is that possible?
    I'm connecting the antenna connector directly to the spectrum analyzer, so no RF is being generated at all from the microcontroller.
    Thanks!
    We will review your hardware files and reply back on that in the private ticked after the weekend, but I am also interested in basic debugging as there could be non-RF related issues here as well (for instance indicated by your measurement of DEC3, I would expect you see somethign there when the radio is active), and basic debugging may tell us things about that. Essentially verifying that the application runs without error.
    Yes. You can use the radio test example for that. You only need to modify the UART pins to match your hardware (some pins you can access and hook up to a UART-USB bridge or similar), and then controll it via UART. This is the exampe that we normally recomend for basic radio testing.
    I added a pin toggle in the heart_rate_meas_timeout_handler function to see if the firmware runs correctly on the microprocessor.
    That is a good indication. However, can you also check with a debugger? If you have not checked, it coudl for instance be that the device is in a reset loop where the pin is toggeled before resetting (though in that case it would be unlikely that the frequency of the toggling would match the correct frequency which is 1 Hz here unless you have modified it (the HEART_RATE_MEAS_INTERVAL is 1000 ms). If you have problems debugging or observing logging, a simple way to check this is to also add pin toggling in the start of main that would toggle on every reset. If yo see the pin in heart_rate_meas_timeout_handler toggle continiously and the one in the start of main only once, that would indicate that the application is working (and that we need to focus on your hardware design).
    Do you know what the DEC3 pin is connected to? The internet mentions it is something related to RF, but it doesn’t specify what exactly. Also, what is DEC1 connected to?
    We have not documented this publicaly so I cannot share details.
  • Thank you very much, Einar, for the information. The problem with using the radio test example code is that on the board I need to test, I don't have any accessible microcontroller pins that I can connect to a UART-USB converter to control it from a terminal. Is there a way in the test code that uses BLE to utilize a single channel and thus a single frequency, or is frequency hopping between channels mandatory? From what I've read online, they suggested using masks in the 'ble_advertising_start' function to transmit only on one channel, but I tried that and didn’t notice any difference. Let me know if this option exists so that we can know exactly what to expect on the spectrum analyzer.
    Regarding the debug pin toggle inside the 'heart_rate_meas_timeout_handler' function, I tried changing the HEART_RATE_MEAS_INTERVAL several times, and each time I reprogrammed the microcontroller, I saw the toggle frequency of the pin change as well (I tried 500ms and 50ms). If necessary, I can run more tests next week.
    Let me know, and thanks again for your help!
    Gabriele
  • Hi Gabriele,
    I see you are getting feedback on your hardware design in the private ticket.
    Frequency hopping is mandatory in Bluetooth (thoug you don't have to advertise on all channels).
    I don't think that will help much. Even if you only advertice on a single channel the advertising packet is short in time and this is not appropriate for simple RF testing.
    Regarding radio test without UART, you could use the radio test sample from the nRF Connect SDK and do the adjustments described in this post to control it via Segger RTT as long as you have a Segger debugger (which could be a DK using the debug out port).
    Note that you can also use RTT logging in the nRF5 SDK, in order to understand more about what is happening in your application. The ble_app_hrs sample support it out of the box if you set NRF_LOG_BACKEND_RTT_ENABLED in sdk_config.h to 1 (you also need to make sure NRF_LOG_ENABLED is 1 in case you have set that to 0 before).
    This would happen also if the device reset after the HEART_RATE_MEAS_INTERVAL elabsed once and then an error reset the board. That may not be the case, and probably it is not, but it is worth ruling out. Either with a LED toggling only at startup, or even better by getting logging up and running (you can use RTT as mentionned as you don't have access to pins for UART).
