nRF9161, RSP not working?
We're evaluating RSP with 1oT, and we managed to successfully swap the carrier using RSP with our nRF9160DK, running our standard application.
The nRF9161-DK, running the same application (though with an additional IMU), however, fails to respond to the RSP operations. 1oT responded that "Right now we are not getting any notification back from the card to our eSIM environment (SR - secure routing instance), which usually means that the device doesn't have eSIM support in general."
I tried flashing the Serial LTE Modem application, and enabled USAT events with AT%USATEV=1, but I don't get any events at all, and %USATINFO returns 0,0.
PDP session was open during the test, I was able to ping with AT#XPING="5.189.130.26",45,5000,5,1000 just fine.
Is there additional configuration we need to to with 9161 (as opposed to the 9160), to enable BIP and/or RSP, or do you have other ideas where the problem might be?
  • Thanks for sharing logs from your devices. This confirms the possible reason for why your device does not receive the SMS.
    On the nRF9160 there is seemingly no PSM activated, and thus the device receives the SMS as expected. With the nRF9161 the PSM is activated and thus does not receive the SMS until it is in RRC connected.
    In the "fail log" modem requests to use PSM and the configured T3324 is just 10 seconds - network accepts this request. This means that UE will enter PSM sleep 10 seconds after the RRC connection has been released after Attach procedure. So, PSM is entered a lot before the network sends the SMS to UE - at least according to the pass log, but there may be some kind of variation of course.
    We think this means that the PSM is the reason for not receiving the SMS. Of course the SMS should be received the next time modem wakes up from PSM (assuming network has already sent the SMS). You could either disable the PSM or trigger UL data about 2 minutes after the registration, to see if the SMS is received at PSM wakeup.
    Let me know how this works for you.
    Øyvind
  • Ok, disabling PSM from our application made the RSP go through on the nRF9161DK, strange though that the SMS was not previously received when the RCC connection was opened for data transmission, but that's probably operator issue.
    Regarding the PSM Kconfig, I didn't set any PSM options in the Kconfig files, and neither of the nRF916x builds has PSM -options set in the output .config.
    Does the 9161 enable PSM by default, or does it use previous settings unless overridden, and nRF9160 has PSM disabled by default?
  • I'm glad that we were able to confirm the issue on your side.
    PSM is stored in NVM, has your device been configured with PSM previously?
  • Both devices should have had PSM enabled previously, but I'm not 100 % sure on the 9160DK. Anyway, I can continue testing disabling the PSM, or just having the device push data more frequently.
