Using MCUBoot with nRF5340
I try to figure out, how to correctly setup MCUboot for an nrf5340, so that:
  • Application is updatable
  • BT Stack is updatable
  • Firmware Updates are encrypted and signed
  • Updates are stored in external flash memory
  • No need to update the bootloader itself
  • Updates are stored on the external flash by some application specific protocol.
For that task, I upgraded our project to nrfconnect/sdk-nrf version v2.7.99-cs2. My current understanding is, that I want to use Sysbuild and have to define a static partition. I haven't found any comprehensive documentation, that defines exactly, which partitions are required for the given setup. So, I search for something in the examples, that could come close to my setup. The result of this example `pm_static.yml` looks like this:
app:
  address: 0x10200
  region: flash_primary
mcuboot:
  address: 0x0
mcuboot_pad:
  address: 0x10000
mcuboot_primary:
  address: 0x10000
  span: [mcuboot_pad, app]
mcuboot_primary_app:
  address: 0x10200
  span: [app]
settings_storage:
  address: 0xf0000
mcuboot_primary_1:
  address: 0x0
  device: nordic_ram_flash_controller
  region: ram_flash
mcuboot_secondary:
  address: 0x00000
  device: DT_CHOSEN(nordic_pm_ext_flash)
  region: external_flash
mcuboot_secondary_1:
  address: 0xe0000
external_flash:
  address: 0x120000
pcd_sram:
  address: 0x20000000
  region: sram_primary
However, in the resulting `partition_manager_report`:
  external_flash (0x800000 - 8192kB):
| 0x0: mcuboot_secondary (0xe0000 - 896kB)       |
| 0xe0000: mcuboot_secondary_1 (0x40000 - 256kB) |
| 0x120000: external_flash (0x6e0000 - 7040kB)   |
  flash_primary (0x100000 - 1024kB):
| 0x0: mcuboot (0x10000 - 64kB)                    |
+---0x10000: mcuboot_primary (0xe0000 - 896kB)-----+
| 0x10000: mcuboot_pad (0x200 - 512B)              |
+---0x10200: mcuboot_primary_app (0xdfe00 - 895kB)-+
| 0x10200: app (0xdfe00 - 895kB)                   |
| 0xf0000: settings_storage (0x10000 - 64kB)       |
  otp (0x2fc - 764B):
| 0xff8100: otp (0x2fc - 764B) |
  sram_primary (0x80000 - 512kB):
| 0x20000000: pcd_sram (0x2000 - 8kB)           |
| 0x20002000: sram_primary (0x6e000 - 440kB)    |
| 0x20070000: rpmsg_nrf53_sram (0x10000 - 64kB) |
the partition `mcuboot_primary_1` is simply missing (and later the compilation of `nrf/modules/mcuboot/hooks/nrf53_hooks.c` fails with an undeclared symbol `PM_MCUBOOT_PRIMARY_1_ADDRESS`.
I found this warning in the DTS parsing:
warning: FLASH_SIMULATOR (defined at drivers/flash/Kconfig.simulator:6) was assigned the value 'y'
but got the value 'n'. Check these unsatisfied dependencies: DT_HAS_ZEPHYR_SIM_FLASH_ENABLED (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_FLASH_SIMULATOR and/or look up
FLASH_SIMULATOR in the menuconfig/guiconfig interface.
The referenced documentation just contains the sentence: "Enable the flash simulator."
What do I have to do, to use MCUBoot?
Is there any comprehensive documentation, that clearly states, what is required to completely configure the bootloader?
  • With your configuration, I was at least able to build all images without error. Now, I'm debugging the bootloader. I'm not able to enable RTT logging. But currently, the startup stops by an attempt to iterate over all images. All flash areas are opened and a few of the 11 flash areas do not have the fa_dev in struct flash_area set.
    This flash_map seem to be build in flash_map_partion_manager.c and there, fa_dev is assigned by `DEVICE_DT_GET_OR_NULL(DT_MTD_FROM_FIXED_PARTITION(part))` which somehow implies, that a value of 0 is expected for that map.
    Now, I wonder, why that member is assigned to 0, if later, at runtime, a value != 0 is expected and how can I figure out, what is going wrong.
  • Logging over RTT can be unreliable when there are multiple images in the boot chain, as the next image in the boot sequence may overwrite the RTT log buffer in RAM. However, a common reason for the bootloader failing to boot the app and entering FIH_PANIC is that there were an error in configuring the external flash. Can you provide your generated zephyr.dts and .config file? These are located in build/mcuboot/zephyr.
    Also, are you currently testing with or without a static partitioning file? Either way, please provide the partition file as well if possible.
  • Currently, I try to use a static portions. Thanks for looking into this. Files are renamed to be accepted by your forums software.4530.zephyr.dts
    app:
      address: 0x10200
    mcuboot:
      address: 0x0
    mcuboot_pad:
      address: 0x10000
    mcuboot_primary:
      address: 0x10000
      address: 0x10200
      span: [app]
    settings_storage:
      address: 0xf0000
    mcuboot_primary_1:
      address: 0x0
      region: ram_flash
    mcuboot_secondary:
      address: 0x00000
      address: 0xe0000
    external_flash:
      address: 0x120000
    pcd_sram:
      address: 0x20000000
    4034..config.txt
  • Thanks. It appears that you are missing the 'nordic,pm-ext-flash' property in your zephyr.dts. Without this, the bootloader will not know which flash device to use for accessing the partitions in 'external_flash'. In my sample, I had a board overlay to set this 'chosen' (/peripheral_lbs_fota_enc/sysbuild/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay)
    	chosen {
    		nordic,pm-ext-flash = &mx25r64;
  • This is the start of my `app.overlay`:
     &zephyr_udc0 {
        cdc_acm_uart0 {
            compatible = "zephyr,cdc-acm-uart";
        chosen {
       Disable QSPI peripheral, to not get the Zephyr QSPI driver linked in,
       which would clash with drivers/flash_memory.cpp
    &qspi {
        status = "disabled";
    I've disabled the qspi-disable part of the overlay file, but still there are some entries in `flash_map` with `fa_dev` set to 0 (and the resulting dts still does not contain the required chosen value):
    (gdb) p/x *flash_map@flash_map_entries
    $3 = {{
        fa_id = 0x0,
        pad16 = 0x0,
        fa_off = 0x0,
        fa_size = 0x10000,
        fa_dev = 0x94b0
        fa_id = 0x1,
        pad16 = 0x0,
        fa_off = 0x0,
        fa_size = 0x40000,
        fa_dev = 0x949c
        fa_id = 0x2,
        pad16 = 0x0,
        fa_off = 0x0,
        fa_size = 0xe0000,
        fa_dev = 0x0
        fa_id = 0x3,
        pad16 = 0x0,
        fa_off = 0x10000,
        fa_size = 0x200,
        fa_dev = 0x94b0
        fa_id = 0x4,
        pad16 = 0x0,
        fa_off = 0x10000,
        fa_size = 0xe0000,
        fa_dev = 0x94b0
        fa_id = 0x5,
        pad16 = 0x0,
        fa_off = 0x10200,
        fa_size = 0xdfe00,
        fa_dev = 0x94b0
        fa_id = 0x6,
        pad16 = 0x0,
        fa_off = 0x10200,
        fa_size = 0xdfe00,
        fa_dev = 0x94b0
        fa_id = 0x7,
        pad16 = 0x0,
        fa_off = 0x40000,
        fa_size = 0x0,
        fa_dev = 0x949c
        fa_id = 0x8,
        pad16 = 0x0,
        fa_off = 0xe0000,
        fa_size = 0x40000,
        fa_dev = 0x0
        fa_id = 0x9,
        pad16 = 0x0,
        fa_off = 0xf0000,
        fa_size = 0x10000,
        fa_dev = 0x94b0
        fa_id = 0xa,
        pad16 = 0x0,
        fa_off = 0x120000,
        fa_size = 0x6e0000,
        fa_dev = 0x0
    The number of entries in the array corresponds with the number of entries in pm_static.yml, but the order seems to be different.
    The only warning I receive from the `* Running CMake for mcuboot *` is about the RTT configuration. For the application cmake run, I got this warning:
        warning: UPDATEABLE_IMAGE_NUMBER (defined at /Users/todi/bloomlife/zephyr-
        workspace/nrf/samples/common/mcumgr_bt_ota_dfu/Kconfig:88, subsys/dfu/Kconfig:95) was assigned the
        value '2' but got the value ''. Check these unsatisfied dependencies:
        (((BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS) && SOC_SERIES_NRF53X &&
        NCS_SAMPLE_MCUMGR_BT_OTA_DFU) || (!MCUBOOT && IMG_MANAGER)) (=n). See
        http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UPDATEABLE_IMAGE_NUMBER and/or look up
        UPDATEABLE_IMAGE_NUMBER in the menuconfig/guiconfig interface. The Application Development Primer,
        Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
        helpful too.
    Could that be a hint as to where the problem is?
