mesh dfu timeout
Hello
I'm exploring the mesh dfu transfer, get some strange results
Here is the setup
1 distributor, 1 target
On the distributor I start  the transfer with mesh models dfd start 0 0 command
In about 40 minutes it completes, and the image is applied but I get a timeout message on the distributor side
However on the target I see a message from the mcuboot that the new message was applied successfully - and actually it is working just fine
Log from the distributor and the target below
Another question
The progress in the JSON below is "50" which I think is because the function that calculates progress divides by 2:
Function cmd_dfd_receivers_get()  in dfd.c  has this lihe
uint8_t progress = bt_mesh_dfu_cli_progress(&dfd_srv->dfu) / 2;
However if I use
mesh models dfu cli progress command it returns
DFU progress: 100 %
Bug?
Thank you
Andy
Logs
Distributor
rtt:~$ [00:40:51.061,126] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
rtt:~$ [00:40:51.061,157] <dbg> bt_mesh_dfu_cli: dfu_complete:
rtt:~$ [00:40:51.061,187] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 0, phase: 1, apply: 1
rtt:~$ Distribution phase changed to Applying Update
rtt:~$ [00:40:51.061,218] <dbg> bt_mesh_dfu_cli: apply:
rtt:~$ rtt:~$ [00:40:51.061,248] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 1 targets
rtt:~$ rtt:~$ [00:40:51.271,606] <dbg> bt_mesh_dfu_cli: handle_status: 0 phase: 6, cur state: 4
rtt:~$ [00:40:51.271,636] <dbg> bt_mesh_dfu_cli: handle_status: Target 0x01a2 receiving transfer
rtt:~$ rtt:~$ [00:41:00.282,928] <dbg> bt_mesh_blob_cli: retry_timeout: 5
rtt:~$ rtt:~$ [00:41:09.441,864] <dbg> bt_mesh_blob_cli: retry_timeout: 4
rtt:~$ rtt:~$ [00:41:18.604,400] <dbg> bt_mesh_blob_cli: retry_timeout: 3
rtt:~$ rtt:~$ [00:41:27.766,143] <dbg> bt_mesh_blob_cli: retry_timeout: 2
rtt:~$ rtt:~$ [00:41:36.924,011] <dbg> bt_mesh_blob_cli: retry_timeout: 1
rtt:~$ [00:41:36.924,041] <dbg> bt_mesh_blob_cli: retry_timeout: Transfer timed out.
rtt:~$ [00:41:36.924,041] <dbg> bt_mesh_blob_cli: drop_remaining_targets:
rtt:~$ [00:41:36.924,072] <wrn> bt_mesh_blob_cli: Dropping 0x01a2: 9
rtt:~$ [00:41:36.924,072] <err> bt_mesh_dfu_cli: Target 0x01a2 failed: 3
rtt:~$ [00:41:36.924,102] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
rtt:~$ [00:41:36.924,102] <dbg> bt_mesh_dfu_cli: dfu_failed: 3
rtt:~$ [00:41:36.924,133] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 3, phase: 3, apply: 1
rtt:~$ Distribution phase changed to Failed
rtt:~$ rtt:~$ mesh models dfd receivers-get 0 1
"target_cnt": 1,
"targets": {
"0": { "blob_addr": 418, "phase": 6, "status": 3, "blob_status": 9, "progress": 50, "img_idx": 0 }
Target
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
Current image version: 2.1.0+8
~$ Firmware upload started
~$ Firmware upload succeeded
Applying the new firmware
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x1, image_ok=0x3
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: test
I: Starting swap using move algorithm.
I: Bootloader chainload address offset: 0x8000
I: Jumping to the first image slot
Current image version: 2.1.0+9
