Read network core app version from app core (nRF5340, v2.6.1) to confirm successful update
We tried using pcd_network_core_app_version() to read the network core version (presumably set by CONFIG_FW_INFO_FIRMWARE_VERSION in our hci_ipc.conf) from the app core. To do this, we set the following flags to the app core prj.conf:
CONFIG_PCD=y
CONFIG_PCD_APP=y
CONFIG_FW_INFO=y
CONFIG_PCD_READ_NETCORE_APP_VERSION=y
However, we got a build error: "/opt/nordic/ncs/v2.6.1/zephyr/subsys/dfu/boot/mcuboot.c:23:10: fatal error: zephyr/fw_info.h: No such file or directory"
Went in mcuboot.c and updated the include to: #include <fw_info.h>. Now it builds. But it does not run.
Is there an example out there of how to do this properly?
Ever
  • Please see attached .config files from build, maybe we are still missing something. We also tried by enabling CONFIG_NRF53_MULTI_IMAGE_UPDATE=y and it still failed.
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    CONFIG_SPI=y
    CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
    CONFIG_BT_HCI_VS_EXT=y
    CONFIG_BOARD="pendant_nrf5340_cpunet"
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_SRAM_SIZE=64
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_BT_CTLR=y
    CONFIG_NUM_IRQS=30
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF5340_CPUNET_QKAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=256
    CONFIG_FLASH_BASE_ADDRESS=0x1000000
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_CLOCK_CONTROL=y
    CONFIG_PINCTRL=y
    # CONFIG_WATCHDOG is not set
    CONFIG_HEAP_MEM_POOL_SIZE=8192
    CONFIG_ROM_START_OFFSET=0
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_NRF_RTC_TIMER=y
    # CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET is not set
    CONFIG_LOG_DOMAIN_NAME="net"
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_MEMC is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_TINYCRYPT=y
    # CONFIG_SERIAL is not set
    CONFIG_MAIN_STACK_SIZE=512
    # CONFIG_SRAM_VECTOR_TABLE is not set
    # CONFIG_USE_DT_CODE_PARTITION is not set
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=256
    # CONFIG_PM_DEVICE is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (/opt/nordic/ncs/v2.6.1/nrf)
    CONFIG_MBOX=y
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
    # CONFIG_INIT_STACKS is not set
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=2048
    # CONFIG_GETOPT is not set
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # CONFIG_NCS_SAMPLE_EMPTY_APP_CORE_CHILD_IMAGE is not set
    # CONFIG_NCS_SAMPLE_DTM_REMOTE_HCI_CHILD_IMAGE is not set
    # Image build variants
    CONFIG_NCS_MCUBOOT_IN_BUILD=y
    # end of Image build variants
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION=y
    # Subsystems
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    CONFIG_SECURE_BOOT=y
    CONFIG_BOOTLOADER_PROVISION_HEX=y
    # CONFIG_B0_BUILD_STRATEGY_USE_HEX_FILE is not set
    # CONFIG_B0_BUILD_STRATEGY_SKIP_BUILD is not set
    CONFIG_B0_BUILD_STRATEGY_FROM_SOURCE=y
    CONFIG_SB_PRIVATE_KEY_PROVIDED=y
    CONFIG_SB_SIGNING_PYTHON=y
    # CONFIG_SB_SIGNING_OPENSSL is not set
    # CONFIG_SB_SIGNING_CUSTOM is not set
    CONFIG_SB_SIGNING_KEY_FILE=""
    CONFIG_SB_SIGNING_COMMAND=""
    CONFIG_SB_SIGNING_PUBLIC_KEY=""
    CONFIG_SB_PUBLIC_KEY_FILES=""
    # CONFIG_SB_DEBUG_SIGNATURE_PUBLIC_KEY_LAST is not set
    CONFIG_SB_MONOTONIC_COUNTER=y
    CONFIG_SB_NUM_VER_COUNTER_SLOTS=240
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7800
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_HASH=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LL_SOFTDEVICE=y
    CONFIG_BT_CTLR_DF_SUPPORT=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    CONFIG_BT_RX_STACK_SIZE=768
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=4000000
    CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y
    CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=4000000
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
    CONFIG_BT_CTLR_FAL_SIZE=8
    CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
    # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
    CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
    # CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
    # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
    CONFIG_BT_CTLR_SDC_BIG_RESERVED_TIME_US=1600
    CONFIG_BT_CTLR_SDC_CIG_RESERVED_TIME_US=1300
    CONFIG_BT_CTLR_SDC_CIS_SUBEVENT_LENGTH_US=0
    # end of SoftDevice Controller
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    CONFIG_BT_REMOTE_VERSION=y
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=7
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
    CONFIG_BT_BUF_CMD_TX_SIZE=65
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_HCI_VS_EVT is not set
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_LONG_WQ is not set
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=0
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    CONFIG_BT_ECC=y
    # CONFIG_BT_TINYCRYPT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    CONFIG_FOTA_DL_TIMEOUT_MIN=15
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_FOTA_POLL is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_COAP is not set
    # Send shadow info sections on initial connect (MQTT/CoAP)
    # end of Send shadow info sections on initial connect (MQTT/CoAP)
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    CONFIG_FW_INFO=y
    # CONFIG_FW_INFO_API is not set
    CONFIG_FW_INFO_OFFSET=0x200
    CONFIG_FW_INFO_FIRMWARE_VERSION=5
    CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
    CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
    CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
    CONFIG_FW_INFO_HARDWARE_ID=53
    CONFIG_FW_INFO_VERSION=2
    CONFIG_FW_INFO_CRYPTO_ID=0
    CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
    CONFIG_FW_INFO_MAGIC_LEN=12
    CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
    CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
    # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
    # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # CONFIG_SHELL_IPC is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    # CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=26
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_BASE_ADDRESS=0x21000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_PM_SRAM_BASE=0x21000000
    CONFIG_PM_SRAM_SIZE=0x10000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CBC_MAC is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_SM3 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD2 is not set
    # CONFIG_PSA_WANT_ALG_MD4 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_FFDH is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    # Audio Module
    # CONFIG_AUDIO_MODULE_TEST is not set
    CONFIG_AUDIO_MODULE_NAME_SIZE=20
    # end of Audio Module
    # CONFIG_TRUSTED_STORAGE is not set
    # end of Subsystems
    # CONFIG_WPA_SUPP is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # Binary libraries
    # CONFIG_BT_LL_ACS_NRF53 is not set
    # Log levels
    # end of Log levels
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x800
    CONFIG_FPROTECT_BLOCK_SIZE=0x800
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_MULTITHREADING_LOCK=y
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_SMS is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x800
    # CONFIG_MODEM_JWT is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    # CONFIG_IPC_UART is not set
    CONFIG_CLOCK_CONTROL_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/opt/nordic/ncs/v2.6.1/nrf)
    # mcuboot (/opt/nordic/ncs/v2.6.1/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/opt/nordic/ncs/v2.6.1/bootloader/mcuboot)
    # mbedtls (/opt/nordic/ncs/v2.6.1/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    # PSA RNG support
    # end of PSA RNG support
    # PSA key type support
    # end of PSA key type support
    # PSA AEAD support
    # end of PSA AEAD support
    # PSA MAC support
    # end of PSA MAC support
    # PSA Hash support
    # end of PSA Hash support
    # PSA Cipher support
    # end of PSA Cipher support
    # PSA Key agreement support
    # end of PSA Key agreement support
    # PSA Key derivation support
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # Elliptic Curve type support
    # end of Elliptic Curve type support
    # end of PSA Asymmetric support
    # end of mbedtls (/opt/nordic/ncs/v2.6.1/modules/crypto/mbedtls)
    # trusted-firmware-m (/opt/nordic/ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m)
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/opt/nordic/ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (/opt/nordic/ncs/v2.6.1/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/opt/nordic/ncs/v2.6.1/modules/lib/cjson)
    # azure-sdk-for-c (/opt/nordic/ncs/v2.6.1/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (/opt/nordic/ncs/v2.6.1/modules/lib/azure-sdk-for-c)
    # cirrus-logic (/opt/nordic/ncs/v2.6.1/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (/opt/nordic/ncs/v2.6.1/modules/hal/cirrus-logic)
    # openthread (/opt/nordic/ncs/v2.6.1/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (/opt/nordic/ncs/v2.6.1/modules/lib/openthread)
    # memfault-firmware-sdk (/opt/nordic/ncs/v2.6.1/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/opt/nordic/ncs/v2.6.1/modules/lib/memfault-firmware-sdk)
    # canopennode (/opt/nordic/ncs/v2.6.1/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/opt/nordic/ncs/v2.6.1/modules/lib/canopennode)
    # chre (/opt/nordic/ncs/v2.6.1/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/opt/nordic/ncs/v2.6.1/modules/lib/chre)
    # lz4 (/opt/nordic/ncs/v2.6.1/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (/opt/nordic/ncs/v2.6.1/modules/lib/lz4)
    # nanopb (/opt/nordic/ncs/v2.6.1/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/opt/nordic/ncs/v2.6.1/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (/opt/nordic/ncs/v2.6.1/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (/opt/nordic/ncs/v2.6.1/modules/lib/zscilib)
    # cmsis (/opt/nordic/ncs/v2.6.1/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (/opt/nordic/ncs/v2.6.1/modules/hal/cmsis)
    # cmsis-dsp (/opt/nordic/ncs/v2.6.1/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (/opt/nordic/ncs/v2.6.1/modules/lib/cmsis-dsp)
    # cmsis-nn (/opt/nordic/ncs/v2.6.1/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (/opt/nordic/ncs/v2.6.1/modules/lib/cmsis-nn)
    # fatfs (/opt/nordic/ncs/v2.6.1/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (/opt/nordic/ncs/v2.6.1/modules/fs/fatfs)
    # hal_nordic (/opt/nordic/ncs/v2.6.1/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # CONFIG_NRFX_CLOCK is not set
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_GPIOTE0 is not set
    CONFIG_NRFX_IPC=y
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_WDT0 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of nrfx drivers
    # end of hal_nordic (/opt/nordic/ncs/v2.6.1/modules/hal/nordic)
    CONFIG_ZEPHYR_ST_MODULE=y
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # liblc3 (/opt/nordic/ncs/v2.6.1/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (/opt/nordic/ncs/v2.6.1/modules/lib/liblc3)
    # littlefs (/opt/nordic/ncs/v2.6.1/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/opt/nordic/ncs/v2.6.1/modules/fs/littlefs)
    # loramac-node (/opt/nordic/ncs/v2.6.1/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/opt/nordic/ncs/v2.6.1/modules/lib/loramac-node)
    # lvgl (/opt/nordic/ncs/v2.6.1/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/opt/nordic/ncs/v2.6.1/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # picolibc (/opt/nordic/ncs/v2.6.1/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (/opt/nordic/ncs/v2.6.1/modules/lib/picolibc)
    # segger (/opt/nordic/ncs/v2.6.1/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (/opt/nordic/ncs/v2.6.1/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (/opt/nordic/ncs/v2.6.1/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (/opt/nordic/ncs/v2.6.1/modules/lib/uoscore-uedhoc)
    # zcbor (/opt/nordic/ncs/v2.6.1/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (/opt/nordic/ncs/v2.6.1/modules/lib/zcbor)
    # memory (/Users/ever/Developer/pendant/src/memory)
    CONFIG_FLASH_FTL=y
    CONFIG_FLASH_FTL_INIT_PRIORITY=80
    CONFIG_ZEPHYR_MEMORY_MODULE=y
    # end of memory (/Users/ever/Developer/pendant/src/memory)
    # nrfxlib (/opt/nordic/ncs/v2.6.1/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    # end of nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_NRF_OBERON=y
    # CONFIG_NRF_CC310_BL is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_LC3_PLC_DISABLED is not set
    CONFIG_LC3_ENC_CHAN_MAX=1
    CONFIG_LC3_DEC_CHAN_MAX=1
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/opt/nordic/ncs/v2.6.1/nrfxlib)
    # connectedhomeip (/opt/nordic/ncs/v2.6.1/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/opt/nordic/ncs/v2.6.1/modules/lib/matter)
    CONFIG_LIBMETAL=y
    CONFIG_LIBMETAL_SRC_PATH="libmetal"
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    CONFIG_OPENAMP=y
    CONFIG_OPENAMP_SRC_PATH="open-amp"
    CONFIG_OPENAMP_MASTER=y
    CONFIG_OPENAMP_SLAVE=y
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    # CONFIG_TINYCRYPT_SHA256 is not set
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    # CONFIG_TINYCRYPT_AES_CMAC is not set
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=8192
    CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=6
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION=""
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_PENDANT_NRF5340_CPUNET=y
    # Board Options
    CONFIG_MBOX_NRFX_IPC=y
    # CONFIG_LOCAL_STORAGE is not set
    # CONFIG_DISABLE_WIFI is not set
    # CONFIG_PROTO1_BOARD is not set
    CONFIG_DOMAIN_CPUAPP_BOARD="pendant_nrf5340_cpuapp"
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF54HX is not set
    # CONFIG_SOC_SERIES_NRF54LX is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3XX is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RA4M1 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_RENESAS_RZT2M is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_ACL=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CCM_HEADERMASK=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_DFE=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF5340_CPUNET=y
    # CONFIG_SOC_NRF5340_CPUAPP_QKAA is not set
    CONFIG_SOC_NRF5340_CPUNET_QKAA=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
    CONFIG_NRF_ENABLE_CACHE=y
    # CONFIG_NRF53_SYNC_RTC is not set
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUNET=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_ARM_ON_ENTER_CPU_IDLE_PREPARE_HOOK=y
    CONFIG_ARM_ON_EXIT_CPU_IDLE=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    CONFIG_LITTLE_ENDIAN=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
    # General Kernel Options
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CLOCK_CONTROL_NPCX_SUPP_APB4=y
    # CONFIG_CLOCK_CONTROL_NPCX_SUPP_FIU1 is not set
    # CONFIG_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    # CONFIG_FLASH is not set
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    # CONFIG_HWINFO is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    CONFIG_MBOX_INIT_PRIORITY=40
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SMBUS is not set
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=70
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_NRF_GRTC_TIMER is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    CONFIG_PICOLIBC_HEAP_SIZE=-2
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    # CONFIG_CRC is not set
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_FDTABLE is not set
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    # CONFIG_MPSC_PBUF is not set
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    CONFIG_REBOOT=y
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_POSIX_MQUEUE is not set
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    CONFIG_BT_HCI_RAW=y
    # CONFIG_BT_HCI_RAW_H4 is not set
    CONFIG_BT_HCI_RAW_RESERVE=1
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # end of Bluetooth Host
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_ECDH_SUPPORT=y
    CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
    # CONFIG_BT_LL_SW_SPLIT is not set
    # BLE Controller configuration
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
    # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_1 is not set
    CONFIG_BT_CTLR_TX_PWR_0=y
    # CONFIG_BT_CTLR_TX_PWR_MINUS_1 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_2 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_5 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_6 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_7 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
    CONFIG_BT_CTLR_TX_PWR_DBM=0
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
    # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
    # BLE Controller features
    CONFIG_BT_CTLR_LE_ENC=y
    CONFIG_BT_CTLR_ECDH=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_LE_PING=y
    CONFIG_BT_CTLR_DATA_LENGTH=y
    CONFIG_BT_CTLR_PHY=y
    CONFIG_BT_CTLR_CONN_RSSI=y
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    CONFIG_BT_CTLR_FILTER_ACCEPT_LIST=y
    CONFIG_BT_CTLR_PRIVACY=y
    CONFIG_BT_CTLR_RL_SIZE=8
    CONFIG_BT_CTLR_EXT_SCAN_FP=y
    CONFIG_BT_CTLR_PHY_2M=y
    CONFIG_BT_CTLR_PHY_CODED=y
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    # CONFIG_BT_CTLR_ADV_EXT is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_CENTRAL_ISO is not set
    # CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_SHELL is not set
    # CONFIG_BT_EAD is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    CONFIG_IPC_SERVICE=y
    CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
    CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
    CONFIG_IPC_SERVICE_RPMSG=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
    # CONFIG_IPC_SERVICE_ICMSG is not set
    # CONFIG_IPC_SERVICE_ICMSG_ME is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Logging
    # CONFIG_LOG is not set
    # CONFIG_LOG_OUTPUT is not set
    # end of Logging
    CONFIG_MEM_ATTR=y
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    # CONFIG_FLASH_MAP is not set
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # nRF5340 Network Core Bootloader Sample Settings
    # CONFIG_NETBOOT_MIN_PARTITION_SIZE is not set
    CONFIG_B0N_SIZE=0x8580
    # end of nRF5340 Network Core Bootloader Sample Settings
    # Zephyr Kernel
    CONFIG_SPI=y
    CONFIG_SRAM_SIZE=64
    CONFIG_NUM_IRQS=30
    # CONFIG_PINCTRL is not set
    CONFIG_HEAP_MEM_POOL_SIZE=0
    CONFIG_GPIO=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=128
    # CONFIG_TINYCRYPT is not set
    CONFIG_MAIN_STACK_SIZE=1024
    # Devicetree Info
    # Modules
    # CONFIG_MBOX is not set
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # Subsystems
    # Bootloader
    CONFIG_IS_SECURE_BOOTLOADER=y
    # CONFIG_SECURE_BOOT_DEBUG is not set
    CONFIG_IS_BOOTLOADER_IMG=y
    CONFIG_SECURE_BOOT_CRYPTO=y
    CONFIG_SB_ECDSA_SECP256R1=y
    CONFIG_SB_SHA256=y
    CONFIG_SB_SIGNATURE_LEN=64
    CONFIG_SB_PUBLIC_KEY_LEN=64
    CONFIG_SB_HASH_LEN=32
    # CONFIG_SB_CRYPTO_OBERON_ECDSA_SECP256R1 is not set
    # CONFIG_SB_CRYPTO_CLIENT_ECDSA_SECP256R1 is not set
    CONFIG_SB_CRYPTO_NO_ECDSA_SECP256R1=y
    CONFIG_SB_CRYPTO_OBERON_SHA256=y
    # CONFIG_SB_CRYPTO_CLIENT_SHA256 is not set
    # CONFIG_SB_CRYPTO_NO_SHA256 is not set
    CONFIG_BL_ROT_VERIFY_EXT_API_UNUSED=y
    # CONFIG_BL_ROT_VERIFY_EXT_API_OPTIONAL is not set
    # CONFIG_BL_ROT_VERIFY_EXT_API_REQUIRED is not set
    # CONFIG_BL_ROT_VERIFY_EXT_API_ENABLED is not set
    CONFIG_BL_SHA256_EXT_API_UNUSED=y
    # CONFIG_BL_SHA256_EXT_API_OPTIONAL is not set
    # CONFIG_BL_SHA256_EXT_API_REQUIRED is not set
    # CONFIG_BL_SHA256_EXT_API_ENABLED is not set
    CONFIG_BL_SECP256R1_EXT_API_UNUSED=y
    # CONFIG_BL_SECP256R1_EXT_API_OPTIONAL is not set
    # CONFIG_BL_SECP256R1_EXT_API_REQUIRED is not set
    # CONFIG_BL_SECP256R1_EXT_API_ENABLED is not set
    CONFIG_SECURE_BOOT_VALIDATION=y
    CONFIG_BL_VALIDATE_FW_EXT_API_UNUSED=y
    # CONFIG_BL_VALIDATE_FW_EXT_API_OPTIONAL is not set
    # CONFIG_BL_VALIDATE_FW_EXT_API_REQUIRED is not set
    # CONFIG_BL_VALIDATE_FW_EXT_API_ENABLED is not set
    CONFIG_SECURE_BOOT_STORAGE=y
    # end of Bootloader
    # BLE over nRF RPC
    # DFU
    # end of DFU
    CONFIG_PCD_NET=y
    CONFIG_PCD_READ_NETCORE_APP_VERSION=y
    # CONFIG_PCD_USE_CONSTANTS is not set
    # CONFIG_PCD_LOG_LEVEL_OFF is not set
    # CONFIG_PCD_LOG_LEVEL_ERR is not set
    # CONFIG_PCD_LOG_LEVEL_WRN is not set
    # CONFIG_PCD_LOG_LEVEL_INF is not set
    # CONFIG_PCD_LOG_LEVEL_DBG is not set
    CONFIG_PCD_LOG_LEVEL_DEFAULT=y
    CONFIG_PCD_LOG_LEVEL=3
    CONFIG_PCD_BUF_SIZE=512
    # Networking
    # nRF Cloud
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # end of Networking
    # NFC
    # end of NFC
    CONFIG_FW_INFO=y
    CONFIG_FW_INFO_FIRMWARE_VERSION=1
    # Debug
    # end of Debug
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # Partition Manager
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # nRF Security
    # Audio Module
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_MODULE_LOG_LEVEL=3
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # Libraries
    # Binary libraries
    # Log levels
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set
    CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_HCI_VSC_LOG_LEVEL=3
    # end of Log levels
    CONFIG_FPROTECT=y
    # CONFIG_FPROTECT_APP is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
    CONFIG_FATAL_ERROR_LOG_LEVEL=3
    # end of Libraries
    # Device Drivers
    # Test
    # Mocks
    # end of Mocks
    # end of Test
    # MCUboot
    # end of MCUboot
    # PSA RNG support
    # PSA AEAD support
    # PSA MAC support
    # PSA Hash support
    # Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_IPC is not set
    CONFIG_NRFX_NVMC=y
    CONFIG_FLASH_FTL=y
    # Nordic nrfxlib
    # CONFIG_MPSL is not set
    CONFIG_NRF_OBERON=y
    # CONFIG_LIBMETAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=3
    # end of Modules
    # Board Options
    CONFIG_HAS_SWO=y
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    CONFIG_ISA_THUMB2=y
    CONFIG_FAULT_DUMP=2
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_ARM_MPU is not set
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=4
    CONFIG_ARM=y
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    # CONFIG_MPU is not set
    # Cache Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    # CONFIG_MULTITHREADING is not set
    CONFIG_NUM_PREEMPT_PRIORITIES=0
    CONFIG_MAIN_THREAD_PRIORITY=-2
    CONFIG_LIBC_ERRNO=y
    # CONFIG_ERRNO is not set
    CONFIG_SCHED_DUMB=y
    CONFIG_WAITQ_DUMB=y
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-2
    # Atomic Operations
    # Timer API Options
    # CONFIG_POLL is not set
    CONFIG_XIP=y
    # Security Options
    # SMP Options
    # CONFIG_TICKLESS_KERNEL is not set
    # Device Options
    # Device Drivers
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    # CONFIG_ENTROPY_GENERATOR is not set
    CONFIG_FLASH=y
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_FLASH_LOG_LEVEL=3
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    # Timer drivers
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # C Library
    CONFIG_PICOLIBC=y
    # end of C Library
    # Deprecated
    # end of Deprecated
    CONFIG_NOTIFY=y
    CONFIG_ONOFF=y
    CONFIG_REBOOT=y
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=3
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=3
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=3
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=3
    # CONFIG_BT is not set
    # Debugging Options
    CONFIG_PRINTK=y
    CONFIG_ASSERT=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_ASSERT_NO_COND_INFO=y
    CONFIG_ASSERT_NO_MSG_INFO=y
    # CONFIG_IMG_MANAGER is not set
    # File Systems
    # CONFIG_IPC_SERVICE is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    # CONFIG_LOG_MODE_DEFERRED is not set
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    CONFIG_LOG_MODE_MINIMAL=y
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    CONFIG_LOG_DEFAULT_MINIMAL=y
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    # end of Processing
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # end of Misc
    # end of Logging
    # CONFIG_MEM_ATTR is not set
    # Device Management
    # Networking
    # CONFIG_NET_BUF is not set
    # end of Networking
    # Power Management
    # Portability
    # SD
    # end of SD
    # Storage
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_ERASE=y
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    # Testing
    # end of Testing
    # Linker Options
    # Linker Sections
    # Compiler Options
    # Build Options
    # Boot Options
    # end of Zephyr Kernel
    app_core.config
    mcuboot.config
  • Hi Ever,
    I was checking a little bit internally. It seems that it's not possible to read the net core image version from the application on app core. It's possible to do so from the MCUBoot but not from the app.
    This has been asked before: NRF5340 GET NETCORE FW_INFO FROM APPCORE
    The reason for that is that the B0n doesn't run when the application is running. It's only run when MCUBoot running and that when MCUBoot can communicate with B0n via PCD library.
    Please be aware that the downgrade avoidance feature is available by default in MCUBoot. My assumption is that you want to read the netcore version to avoid having to download old image version ?
    One workaround I can think of is to modify MCUBoot to read the image version on each boot and find away to send that to the application, for example via writing to flash or RAM.
