LSM6DSL is failing on custom board with NRF5340soc
Hi ,
I am trying to integrate LSM6DSL to BL5340 module(laird connectivity) through SPI but I am getting failed on initialization. I am noob to NRF so could someone please help to resolve it.
Thanks in advance
alaises{
imusensor         = &imu_sensor;
&spi4 {
    status = "okay";
    pinctrl-0 = <&spi4_default>;
    pinctrl-1 = <&spi4_sleep>;
    pinctrl-names = "default","sleep";
    cs-gpios = <&gpio0 11 0>;
    /* IMU Sensor 6 Axis: ST LSM6DSL */
	imu_sensor: lsm6dsl@0 {
		compatible = "st,lsm6dsl";
        status = "okay";
		reg = <0>;
		irq-gpios = <&gpio0 2 GPIO_ACTIVE_LOW>;
		spi-max-frequency = <10000000>;
/* The devicetree node identifier for the "imusensor" alias. */
#define IMU_SENSOR	DT_ALIAS(imusensor)
static const struct device *const imu_dev = DEVICE_DT_GET(IMU_SENSOR);
void imu_init(void) {
	LOG_DBG("%s ", imu_dev->name);
    /* Check if device is initialized correctly. */
	if (!device_is_ready(imu_dev)) {
        /* Not ready, do not use */
		LOG_DBG("IMU device init fail.");
        return;
    LOG_DBG("%s IMU Sensor found", imu_dev->name);
    I suggest to connect a logic analyzer to the spi pins and irq, to see what data is actually sent/received. Just to check if it looks okey (clock toggle as expected, chip select go low, data on miso/mosi etc). Maybe some of the pins are not connected or setup correctly, maybe the sensor is not working/powered as expected.
    sorry that provisions are not available in our board
    I notice you are using gpio port0 pin2, which overlap with nfc, so make sure you do the following in the overlay file:
    &uicr {
        nfct-pins-as-gpios;
    Thanks for the input I tried but facing same error
    Also, it's spelled aliases, in case that can be part of the problem.
    Sorry that's my typo mistake in overlay it was fine
    Thanks
    S.M
  • I suggest to buy an LSM6DSL module and connect to an nRF5340 DK for further debugging, then you will also be able to connect a logic analyzer to the pins in questions.
    Kenneth
