-DSB_CONFIG_BOOT_SIGNATURE_KEY_FILE in comand line causes error due to malformated string
Hello
I would like to sign an image temporarily with west CMake options as described in Enabling a bootloader chain using sysbuild using the comand line:
-DSB_CONFIG_BOOT_SIGNATURE_KEY_FILE=\"priv.pem\"
In it's final state I would like to specify an absolute path, where the keyfile is stored. It seems as if I am not able to provide the proper format for the path value "D:\priv.pem".
I applied this also to the example "sysbuild\with_MCUboot" and use the nrf sdk v2.7.0. The result is still a malformat for the string.
PS C:\Users\User1> west build --pristine  --sysbuild  -b nrf52840dk/nrf52840 with_mcuboot  -d with_mcuboot/build -- -DSB_CONFIG_BOOT_SIGNATURE_KEY_FILE=\"D:\priv.pem\"
-- west build: making build dir C:\Users\User1\with_mcuboot\build pristine
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/ce3b5ff664/opt/bin/python.exe (found suitable version "3.9.13", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.7.0/zephyr/.cache
-- Board: nrf52840dk, qualifiers: nrf52840
C:/Users/User1/with_mcuboot/build/zephyr/misc/generated/extra_kconfig_options.conf:2: warning: malformed string literal in assignment to BOOT_SIGNATURE_KEY_FILE (defined at C:/ncs/v2.7.0/zephyr/share/sysbuild\images\bootloader/Kconfig:58). Assignment ignored.Parsing C:/ncs/v2.7.0/zephyr/share/sysbuild/Kconfig
Loaded configuration 'C:/Users/User1/with_mcuboot/build/_sysbuild/empty.conf'
Merged configuration 'C:/Users/User1/with_mcuboot/sysbuild.conf'
Merged configuration 'C:/Users/User1/with_mcuboot/build/zephyr/misc/generated/extra_kconfig_options.conf'
error: Aborting due to Kconfig warnings
CMake Error at C:/ncs/v2.7.0/zephyr/cmake/modules/kconfig.cmake:392 (message):
  command failed with return code: 1
  cmake/modules/sysbuild_kconfig.cmake:101 (include)
  cmake/modules/sysbuild_default.cmake:17 (include)
  C:/ncs/v2.7.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  C:/ncs/v2.7.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  C:/ncs/v2.7.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
See also "C:/Users/User1/with_mcuboot/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/ce3b5ff664/opt/bin/python.exe '-BC:\Users\User1\with_mcuboot\build' -GNinja -DBOARD=nrf52840dk/nrf52840 '-DSB_CONFIG_BOOT_SIGNATURE_KEY_FILE=\E:\priv.pem\' '-SC:\ncs\v2.7.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\Users\User1\with_mcuboot'
setting the absolut path in the sysbuild.conf (SB_CONFIG_BOOT_SIGNATURE_KEY_FILE) compiles without error. I tried a lot of combinations but don't seem to get this to work.Also placing the priv.pm in the west topdir and using the example =\"priv.pem\" os not working.
Any idea what I am doing wrong?
  • Hi MTB,
    As Abhijith explained, the malformed string issue is due to escaping the quote. Now that we resolved that issue, all that is left is to provide the correct path.
    I tested. Please just use absolute path with the quote changes that Abhijith gave you.
    To be absolutely sure we are on the same page, I mean, on Windows, it would be something like -DSOME_CONFIG='\"C:/some/path/file_name.ext\"'
    And for what it's worth, I tested before my last answer. It works.
