I was following the beginners tutorial and things were fine till i reached the section to create a project from scratch. I was able to build this project as well.
When i tried the second exercise in the series, i find that no more i am able to carry a build by adding a build configuration.
I tried running some of the sample application as well, the issue is still shown.
When i hover near the terminal i could see a window which shows the following error.
nRF Connect Process ID (PID): 24500 Command line: C:\Program Files\PowerShell\7\pwsh.exe '-noexit' '-command' 'try { . "c:\Users\siddi\AppData\Local\Programs\Microsoft VS Code\resources\app\out\vs\workbench\contrib\terminal\common\scripts\shellIntegration.ps1" } catch {}' Shell integration activated Task is running
The following extensions have contributed to this terminal's environment: Git: Enables the following features: git auth provider
But if i were to give from command prompt "west build -b nrf52840dk/nrf52840"
i can see that the build is succeeding, not sure what has resulted in this broken build system.
Using toolchain v2.7.0
Please help.
