I am trying to extend an older 1.7.0 SDK to add functional BT support, which currently only has serial port communications. i don't really understand the terms for the functional parts, and understand the sdk is replaced with new..
the provider has provided source for their firmware which provides serial port communications to control operation only in old sdk 1.7.0 format
I need to use some other approach..
I would like to use pairing to connect my app to the local device
and then the local device would be ble central
and remotes would be ble peripheral
today the 'same' firmware is loaded on both identical devices
but my testing will have a different local device using the 52840 and the remote is 52833
so my firmware update should be able to distinguish how to operate, I 'think' this is different boards and different binary builds.
my app would pair with the local device (should only ever connect to ONE local device, during initial setup, the device is nearby)
there 'is' a possibility that there COULD be multiple instances of the same local device within bt range, so want to preclude ever seeing talking to others
in the future these devices would be BT6 with channel sounding support. but still architected this way to minimize dependencies.
data traffic from app to local device is low, done with BT notification (using ble)..
I suppose I could store persistent data on both app device and local device with some key/identifier to be able to use only ble (one of the future devices says single mode bt, aka ble only)
but I still don't understand how to configure the 1.7.0 sdk to add the function that I can use.   the java config app assumes you know what the words/terminology means
and understand the concurrence (this function and not that) restrictions..
the provider has another instance using the 1.7.0 sdk  with BT ble peripheral only (but does not have serial port comms at all)
extending their firmware is an exercise for the user (me!).. so trying to get my head around the config
I can build each w the segger IDE, so that part is ready.
I have flashed the build with the IDE as well and command line tools.. so have that
have ble code that does most of what I want in both ios and android.. so have ble experience.  now to get runtime in the right config..
