[Android MCP App] Showing "connect button" at a beacon?
/****************   Test Condition   **********************/
Phone: Nexus 5 (Android 6.0.1)
nRF Beacon Kit
MCP App Version 4.0.3
B1
Raw Data
Hi, I use a nRF Beacon kit. I didn't change the firmware of the beacon.
As far as I know, beacon is a non-connectable peripheral.
As a result, that "connect button" seems questionable to me.
It doesn't connect even if I press it. :D
Anyways, my questions are
  1. There's really no way that beacon (peripheral) can be connected with a central (ex. iPhone)
without changing the services and characteristics?
(I think this question has really came frequently :D)
Then, personally, I think that "connect button" for beacons
should be removed like the old MCP app.
  1. Then, is there an example that a peripheral acts both a scanner and advertising peripheral?
I hope for a scenario like the following:
Central device (ex. iPhone) comes near the beacon which is advertising data. ->
(Suppose this beacon does not use other services such as HID or NUS, only advertising beacon.)
The iPhone then sends a scan response request to that beacon. ->
(I'm not sure if central devices sends that packet when it gets advertising data from a beacon.)
The beacon gets the scan response request packet and blinks the LED.
Of course, if there are multiple beacons near the central device, it will be tricky.
However, let's assume there's one beacon and one central.
Is this scenario possible? Plus, making the beacon to both scan and advertise (doing both of this is also questionable though) will fit this scenario?
-Best Regards
**/Edited, @ Võ Thanh Hiếu /
event
Thanks, you are meaning here?
I'm using SDK 7.2 and Softdevice S110.
The beacon example doesn't have this on_ble_event.
Anyways, I will try it out. Thanks~
**/Edited 2, @ Võ Thanh Hiếu, Test Result /
Hi, Võ Thanh Hiếu. Thanks for your tip and other references, I got some results, maybe? :D
Ref. 1 Stefan Birnir Sverrisson's answer
Ref. 2 Petter Myhre's answer
Change
Result
The problem is this "peer address" change doesn't it?
Sorry if I dragged this question quite long. This will be my last one.
-Best Regards
  • @Võ Thanh Hiếu, Thanks for your guidance.
    I will give it a shot.
    /****** Edited, Questions about the code **********/
    In the beacon example (nRF5_SDK_XX\examples\ble_peripheral\ble_app_beacon),
    the ble_stack_init function only enables stack and does not register SoftDevice handler modules
    for BLE events such as ble_evt_dispatch (which calls on_ble_evt) or sys_evt_dispatch.
    Then after enabling the BLE stack, should I call sd_ble_opt_set before initializing advertising data
    and add ble_evt_dispatch and sys_evt_dispatch?
  • I think calling sd_ble_opt_set() somewhere inside ble_stack_init() sounds better than what I suggested you doing (adding anywhere before starting advertising). The code would make more sense that way. I am not really sure where in ble_stack_init() though.
    But technically it doesn't seem to matter a whole lot where you call sd_ble_opt_set(). It doesn't have any note or warning in its SDK documentation entry. When I tested the code, I added that right before calling ble_advertising_start()and it worked fine. I just told you to add it before you call ble_advertising_start() because once you start advertising, you would also start receiving scan response. You would want to be ready to receive those events before then.
    I guess a Nord
    Also, just updated my question to answer your update regarding peer_addr.
  • As a side note, I think we have divert pretty far away from your first question/question title. The thread is now about getting BLE_GAP_EVT_SCAN_REQ_REPORT to work more than the Android app. Perhaps this is a good time to split that question to another page.
  • I see. I will wrap this quetions now. I really appreciate your dedication.
