Adafruit Feather nrf52840 Express Power Usage
When using the adafruit feather nrf52840, the lowest I can seem to get power usage is around 400uA (including with the boards/nordic/poweroff sample).
This is my device overlay file:
&radio {
        zephyr,pm-device-runtime-auto;
&gpio0 {
        status = "okay";
        label = "GPIO_0";
        sense-edge-mask = <0xffffffff>;
&gpio1 {
        status = "okay";
        label = "GPIO_1";
        zephyr,user {
                latch-en-gpios = <&gpio0 31 GPIO_ACTIVE_HIGH>;
                wp-gpios = < &gpio0 8 GPIO_ACTIVE_LOW>;
                hold-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
        leds {
                compatible = "gpio-leds";
                blue_led: led_0 {
                        gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>;
                        label = "Blue LED (D7)";
&i2c1 {
        lis2dh@18 {
                compatible = "st,lis2dh";
                reg = <0x18>;
                label = "LIS2DH";
                irq-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>, <&gpio0 30 GPIO_ACTIVE_HIGH>;
                disconnect-sdo-sa0-pull-up;
&ieee802154 {
        status = "disabled";
&pinctrl {
    spi2_default: spi2_default {
                group1 {
                        psels = <NRF_PSEL(SPIM_SCK, 0, 21)>,
                                <NRF_PSEL(SPIM_MOSI, 0, 20)>,
                                <NRF_PSEL(SPIM_MISO, 0, 24)>;
        spi2_sleep: spi2_sleep {
                group1 {
                        low-power-enable;
&spi0 {
&spi1 {
&spi3 {
&qspi {
&rng {
&temp {
&usbd {
&i2c0 {
&uart0 {
&wdt {
And my prj.conf:
# General
CONFIG_HEAP_MEM_POOL_SIZE=65536
# power management & savings
#CONFIG_PM=y # should not work on nrf52840
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
CONFIG_PM_DEVICE_SYSTEM_MANAGED=y # only in zephyr 3.7.0
CONFIG_SERIAL=n
CONFIG_UART_CONSOLE=n
# some more low power
CONFIG_FLASH=n
CONFIG_SPI=y
CONFIG_I2C=y
CONFIG_USB_DEVICE_STACK=n
CONFIG_BOOT_BANNER=n
CONFIG_CONSOLE=n
CONFIG_DEBUG=n
# enable low freq clocks
#CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
#CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y #this will not be valid for all devices
# lower tick rate
#CONFIG_SYS_CLOCK_TICKS_PER_SEC=100
# Logging
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
# Bluetooth
CONFIG_BT=y
## Sensing
CONFIG_BT_OBSERVER=y
CONFIG_BT_SCAN=y
CONFIG_GPIO=y
CONFIG_ADC=y
CONFIG_ADC_NRFX_SAADC=y
## Broadcasting
CONFIG_BT_DEVICE_NAME="s_beacon"
CONFIG_BT_BROADCASTER=y
CONFIG_BT_PERIPHERAL=y
400uA still seems quite high to me. Is there anything I haven't thought of?
  • I am measuring the current by putting a multimeter in series with the board (which is being powered via the BAT pin)
    I don't think I can send you the full application, but I get the same results with the sample in samples/boards/nordic/poweroff with my overlay and prj.conf (with CONFIG_POWEROFF=y added, CONFIG_SERIAL set to y and uart0 in my overlay re-enabled for compatibility, as the sample manually disables the serial port). So if possible I would like to use that sample as a basis for this.
  • Ok. Feel free to upload any sample that will reproduce what you are seeing.
    Also, you can't reliably trust readings done on a multimeter, because the current consumption is not stable. For most parts, it is very little current, but there will be some spikes that are charging some capacitors. So depending on how the multimeter works, some may sample at random times, some may use the peaks only. So you need to either use an oscilloscope, or the Power Profiler Kit II, which will give you a graph, and more accurate current measurements.
    If you upload a sample, I can measure it running on a DK. I don't know how it behaves on your 3rd party board, or what other components that are present on that board that may draw current. On the DK it is possible to isolate the reading to only measure the chip, and bypass the LEDs and the debugger and the other components on the board.
    Edvin
  • system_off_sample.zip
    This is the sample I have been using. It is taken straight from the zephyr samples, but with my prj.conf and overlay file.
    I know of the limitations of using a multimeter, but both my own multimeter as well as the benchtop multimeter they have at my university lab (which has graphing functionality) show the ~400uA measurement as a stable baseline, with some peaks higher than that.
    On the DK, measuring only the chip, this sample should give very low power consumption. I suspect the issue I have is specific to my board.
  • This is what I measure when building for the nRF52840DK with the project that you sent. I used the prj.conf.old file (renamed it prj.conf).
    I also tried renaming your boards\adafruit_feather_nrf52840.overlay to boards\nrf52840dk_nrf52840.overlay, but I had to remove the aliases: reg1, because it didn't compile (it is not defined in the DK's .dts files).
    And the current consumption was identical. So either it is related to the reg1, or there is some other component on the board that is drawing power. Are any of the LEDs lighting up?
    BR,
    Edvin
  • None of the LED's are lighting up.
    The main components that can be taking up power according to me are the voltage regulator, the pullup resistor on the EN-pin (link to the board's schematic) and the so-called "neopixel" (an WS2812B RGB led that's soldered onto the board by default and supposedly has a fairly high quiescent current draw)
