Nordic Developer Academy BLE NUS Example with Pairing and Bonding: various problems
Hi Support Team,
I am encountering various problems with the Developer Academy example found here:
https://academy.nordicsemi.com/courses/bluetooth-low-energy-fundamentals/lessons/lesson-4-bluetooth-le-data-exchange/topic/blefund-lesson-4-exercise-3/
1. Unable to debug without GATT errors
To overcome this issue I used logging but:
2. Logging is not working. None of the LOG directives is working
The cause why I need this is:
3. I set CONFIG_BT_NUS_SECURITY_ENABLED=y but nothing happend - security is not working
Could you tell me at least how to get the security in the example working?
Also logging is needed
Many thanks in advance.
Regards, Andreas
  • Thank you for the feedback. I will get back to you tomorrow.
  • Today I tried building and running blefund_less4_exer3_solution. First I verified that I could build the application and transfer data back and forth using nRF Connect for Mobile. Then I changed to CONFIG_BT_NUS_SECURITY_ENABLED=y and did a pristine build before flashing the application to nRF5340dk_nrf5340_cpuapp_ns. The sample worked as expected, using nRF Connect SDK v2.6.0.
    Have you tried building and flashing the solution?
    Which nRF Connect SDK version are you using?
    How do you verify that security is not working?
  • Andreas Schurz said:
    The security implementation is already in the course example and can be activated by setting CONFIG_BT_NUS_SECURITY_ENABLED=y
    Code-Snipped - already within the code:
    One trick is to add a warning in your project, withing the ifdef for the kconfig that you are intending to use. That way the string you enter next to #warning will be printed when you build the code, only if that kconfig is active. See an example below:
    #ifdef CONFIG_BT_NUS_SECURITY_ENABLED
    #warning "Verifying that BT_NUS_SECURITY_ENABLED is enabled."
    static void security_changed(struct bt_conn *conn, bt_security_t level, enum bt_security_err err)
    	if (!err) {
    		LOG_INF("Security changed: %s level %u", addr, level);
    	} else {
    		LOG_WRN("Security failed: %s level %u err %d", addr, level, err);
  • Hi Helsing,
    I have indeed built and flashed the application.
    I am expecting pairing, bonding and passkey exchange as implemented. This is working for other examples from the training but not this one. Instead I can Connect without any authentication and then send and receive data.
    It works just the same way it did before setting CONFIG_BT_NUS_SECURITY_ENABLED=y.
    One of the first things to happen right after connect is display the passkey:
    #if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
    static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
    	LOG_INF("Passkey for %s: %06u", addr, passkey);
    This is not happening for me.
    After this passkey has to be transmitted via app and confirmed on the board:
    static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
    	auth_conn = bt_conn_ref(conn);
    	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
    Which is also not happening for me.
    Tested on nRF52 with V2.6.1
    And the bonding workes for you?
    Regards, Andreas
  • Warning comes up then for me
    D:/bt-fund/lesson4/blefund_less4_exer3_solution/src/main.c:357:2: warning: #warning "Verifying that BT_NUS_SECURITY_ENABLED is enabled." [-Wcpp]
      357 | #warning "Verifying that BT_NUS_SECURITY_ENABLED is enabled."
