REQUEST AN IOS VERSION DFU UPGRADE PROCESS
DFU is now implemented on ipads and iphones, as well as on Android phones, and the app platform is nRF Connect. The problem is that the firmware upgrade can be achieved normally with an Android phone; The ipad can connect and read data, but it can't use the DFU function; iPhones can't connect to Bluetooth; Observe the log information in the process of iPad DFU, and observe <debug> nrf_dfu_validation: CRC check of app failed. What is the reason for such a sentence as Return 1? And the IPAD can establish a connection with the firmware bluetooth, but the iphone15 can't establish a connection, what could be the problem?
The version of SDK is 17.0.2;
The following is the information for the wrong printing:
  1. 00> <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
    00>
    00> <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
    00>
    00> <info> app: Inside main
    00>
    00> <debug> app: In nrf_bootloader_init
    00>
    00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    00>
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    00>
    00> <debug> nrf_dfu_settings: Using settings page.
    00>
    00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    00>
    00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    00>
    00> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    00>
    00>
    00> <debug> app: Enter nrf_bootloader_fw_activate
    00>
    00> <info> app: No firmware to activate.
    00>
    00> <debug> nrf_dfu_validation: CRC check of app failed. Return 1
    00>
    00> <debug> app: App is valid
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
    00>
  • Hello Vidar,
    Does your application use the GATT module to handle data length update requests?
    Yes, I added the relevant setting functions according to the example-"ble_app_uart",
    err_code = nrf_ble_gatt_init(&m_gatt,gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt,NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    however,it did not work.Somehow, the program went into NRF_FAULT_ID_SD_ASSERT state after receiving a 0X22 error reply.Do I need to do anything extra in the handler?
    I’m looking forward for your reply!
    Anny
  • Hello Anny,
    And you have not implemented any handling of these events in your application? Do you see the same issue if you attempt to connect with the original ble_app_uart example?
  • Hi Vidar,
    I just made a judgment to determine the change in the MTU value.
    The original routine works fine on one of the boards used, and the connection works fine. But the program doesn't work on my PCB board
  • Hi Anny,
    Can you post some code snippets showing how you are handling MTU and Data length extension?
    Were you able to run the original ble_app_uart example on your custom board, or have you only tested with your project?
  • Hi Vidar,
    1.I use “nrf_ble_gatt_att_mtu_periph_set”to set the MTU size of the GATT server.The GATT event callback determines the update status of the MTU:
    • void gatt_evt_handler(nrf_ble_gatt_t * p_gatt,nrf_ble_gatt_evt_t const * p_evt)
      if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
      NRF_LOG_INFO("Data len is set to 0x%X(%d)",
      p_evt->params.att_mtu_effective-OPCODE_LENGTH-HANDLE_LENGTH,
    2.I only tested with my project,since routine example don't work on my board
