Hi, in our project we use the nRF52832 and a external flash memory MX25L3206E connected on this pins:
Take note in this project we also use SPIM0 to manage an IMU and SPIM2 to flash with this configuration:
//! GPIO FLASH power port number
#define HARDWARE_INIT_FLASH_PORT_NUMBER 0
//! GPIO FLASH power pin number
#define HARDWARE_INIT_FLASH_POWER_PIN_NUMBER 17
//! GPIO FLASH write protect (WP) pin number
#define HARDWARE_INIT_FLASH_WP_PIN_NUMBER 5
//! GPIO FLASH hold pin number
#define HARDWARE_INIT_FLASH_HOLD_PIN_NUMBER 19
//! SPI FLASH MEMORY port number
#define HARDWARE_INIT_FLASH_SPI_PORT_NUMBER 0
//! SPI FLASH MEMORY CS pin number
#define HARDWARE_INIT_FLASH_SPI_CS_PIN_NUMBER 16
//! SPI FLASH MEMORY SCLK pin number
#define HARDWARE_INIT_FLASH_SPI_SCLK_PIN_NUMBER 18
//! SPI FLASH MEMORY MOSI pin number
#define HARDWARE_INIT_FLASH_SPI_MOSI_PIN_NUMBER 20
//! SPI FLASH MEMORY MISO pin number
#define HARDWARE_INIT_FLASH_SPI_MISO_PIN_NUMBER 21
//! SPI KX122 ACCELEROMETER SPI port number
#define HARDWARE_INIT_KX122_SPI_PORT_NUMBER 0
//! SPI KX122 ACCELEROMETER CS pin number
#define HARDWARE_INIT_KX122_SPI_CS_PIN_NUMBER 4
//! SPI KX122 ACCELEROMETER MISO pin number
#define HARDWARE_INIT_KX122_SPI_MISO_PIN_NUMBER 26
//! SPI KX122 ACCELEROMETER MOSI pin number
#define HARDWARE_INIT_KX122_SPI_MOSI_PIN_NUMBER 25
//! SPI KX122 ACCELEROMETER SCLK pin number
#define HARDWARE_INIT_KX122_SPI_SCLK_PIN_NUMBER 11
//! INT1 KX122 ACCELEROMETER interruption 1 pin number
#define HARDWARE_INIT_ACC_INT1_PIN_NUMBER 30
//! INT2 KX122 ACCELEROMETER interruption 2 pin number
#define HARDWARE_INIT_ACC_INT2_PIN_NUMBER 31
.misoPinIdentifier = HARDWARE_INIT_KX122_SPI_MISO_PIN_NUMBER,
.misoPortConfig = HARDWARE_INIT_KX122_SPI_PORT_NUMBER,
.mosiPinIdentifier = HARDWARE_INIT_KX122_SPI_MOSI_PIN_NUMBER,
.mosiPortConfig = HARDWARE_INIT_KX122_SPI_PORT_NUMBER,
.sclkPinIdentifier = HARDWARE_INIT_KX122_SPI_SCLK_PIN_NUMBER,
.sclkPortConfig = HARDWARE_INIT_KX122_SPI_PORT_NUMBER,
.ccsPinIdentifier = HARDWARE_INIT_KX122_SPI_CS_PIN_NUMBER,
.ccsPortConfig = HARDWARE_INIT_KX122_SPI_PORT_NUMBER,
.spiFrequency = HAL_SPI_FREQUENCY_1M,
.spiClockPolarity = HAL_SPI_CPOL_LOW,
.spiClockPhase = HAL_SPI_CPHA_LOTOHI,
.spiMasterInstance = NRFX_SPIM_INSTANCE(0)
.misoPinIdentifier = HARDWARE_INIT_FLASH_SPI_MISO_PIN_NUMBER,
.misoPortConfig = HARDWARE_INIT_FLASH_SPI_PORT_NUMBER,
.mosiPinIdentifier = HARDWARE_INIT_FLASH_SPI_MOSI_PIN_NUMBER,
.mosiPortConfig = HARDWARE_INIT_FLASH_SPI_PORT_NUMBER,
.sclkPinIdentifier = HARDWARE_INIT_FLASH_SPI_SCLK_PIN_NUMBER,
.sclkPortConfig = HARDWARE_INIT_FLASH_SPI_PORT_NUMBER,
.ccsPinIdentifier = HARDWARE_INIT_FLASH_SPI_CS_PIN_NUMBER,
.ccsPortConfig = HARDWARE_INIT_FLASH_SPI_PORT_NUMBER,
.spiMasterInstance = NRFX_SPIM_INSTANCE(2)
This is the prj.conf of the project:
# Drivers selection CONFIG_GPIO=y CONFIG_GPIO_AS_PINRESET=n CONFIG_SERIAL=y # UARTE #CONFIG_NRFX_UARTE1=n #CONFIG_NRFX_UARTE0=y CONFIG_LOG=n CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_WATCHDOG=y CONFIG_ADC=y CONFIG_ADC_ASYNC=y CONFIG_ADC_NRFX_SAADC=y CONFIG_PINCTRL=y CONFIG_I2C=y #CONFIG_NRFX_TWIM1=y CONFIG_FLASH=y CONFIG_SPI=y CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58=y CONFIG_NRFX_SPIM0=y CONFIG_NRFX_SPIM2=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y CONFIG_REBOOT=y #n # Power management # CONFIG_PM=y # CONFIG_PM_DEVICE=y # CONFIG_POWEROFF=y # Interrupts # CONFIG_DYNAMIC_INTERRUPTS=n # CONFIG_UART_INTERRUPT_DRIVEN=n # CONFIG_IRQ_OFFLOAD=n # Stacks and heaps # This configuration reserve 20K of RAM to HEAP, this project only has 64K # and all the code is the 98% of the RAM so we can not declare so much heap CONFIG_HEAP_MEM_POOL_SIZE= 8000 #CONFIG_HEAP_MEM_POOL_SIZE= 6144 CONFIG_MAIN_STACK_SIZE=1024 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 #CONFIG_NET_TX_STACK_SIZE=512 #ONFIG_NET_RX_STACK_SIZE=512 # CONFIG_NET_MGMT_EVENT_STACK_SIZE=2048 # Memory protection # CONFIG_THREAD_STACK_INFO=n # CONFIG_THREAD_CUSTOM_DATA=n # CONFIG_FPU=n # BLE configuration CONFIG_BT=y CONFIG_SETTINGS=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_GATT_DYNAMIC_DB=y #CONFIG_BT_PERIPHERAL_PREF_MIN_INT=6 #CONFIG_BT_PERIPHERAL_PREF_MAX_INT=9 #CONFIG_BT_PERIPHERAL_PREF_LATENCY=99 #CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400 #CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y CONFIG_BT_DEVICE_NAME="Tarsos Device" CONFIG_BT_L2CAP_TX_MTU=252 CONFIG_BT_BUF_ACL_TX_SIZE=251 CONFIG_BT_BUF_ACL_RX_SIZE=502 #CONFIG_BT_SMP=y #CONFIG_BT_SIGNING=y #CONFIG_BT_PERIPHERAL=y #CONFIG_BT_DIS=y #CONFIG_BT_ATT_PREPARE_COUNT=5 #CONFIG_BT_BAS=y #CONFIG_BT_HRS=y #CONFIG_BT_IAS=y #CONFIG_BT_PRIVACY=y #CONFIG_BT_DEVICE_APPEARANCE=833 #CONFIG_BT_DEVICE_NAME_DYNAMIC=y #CONFIG_BT_DEVICE_NAME_MAX=65 #CONFIG_BT_KEYS_OVERWRITE_OLDEST=y #CONFIG_BT_SETTINGS=y # Debug configuration CONFIG_DEBUG=y CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_DEBUG_THREAD_INFO=y
The problem is that the IMU works fine due to it rsponse his ID number and other data, but when we try to comunicate with the flash memory to see the iID number it return in our buferRX all ones,
Could you any chech this and explain why SPIM0 works fine and SPIM2 no?
Many thanks in advance.
