GATT services and characteristic declaration error
These are customized UUIDS declared by me
/* Custom Service Variables */
#define BT_UUID_CUSTOM_SERVICE_VAL  BT_UUID_128_ENCODE(0x821675c3, 0x4046, 0x45f9, 0xb8df, 0xcdc9da1c71a7)
#define CUSTOM_EMG_UUID BT_UUID_128_ENCODE(0x30645c07,0x5a3c,0x4f2d,0xbee5,0x7eafcbf0c790)
#define CUSTOM_BATTERY_UUID BT_UUID_128_ENCODE(0xd7b5a586,0x6191,0x4c0f,0x93e0,0xc2fa666d5ca3)
#define BT_UUID_EMG_DEV BT_UUID_DECLARE_128(BT_UUID_CUSTOM_SERVICE_VAL)
#define BT_UUID_BAT     BT_UUID_DECLARE_128(CUSTOM_BATTERY_UUID)
#define BT_UUID_EMG     BT_UUID_DECLARE_128(CUSTOM_EMG_UUID)
I call this UUIDs to define services and characteristics as follows
BT_GATT_SERVICE_DEFINE(custom_svc,
BT_GATT_PRIMARY_SERVICE(BT_UUID_EMG_DEV),
BT_GATT_CHARACTERISTIC(BT_UUID_BAT,
                       BT_GATT_CHRC_READ,
                       BT_GATT_PERM_READ,
                       read_battery,NULL,&battery_value),
BT_GATT_CHARACTERISTIC(BT_UUID_EMG,
                  BT_GATT_CHRC_READ,
                  BT_GATT_PERM_READ,
                  read_emg,NULL,&emg_value)
But I am encountering errors such as expecting a comma even if I have put a comma.
error: expected expression before ',' token
110 | read_str, NULL, BT_DIS_MODEL_REF),
75 | BT_GATT_PERM_NONE, NULL, NULL, NULL),
55 | &battery_level),
244 | read_name, write_name, bt_dev.name),
Could any one please figure me out how to solve this errors.
  • //Function definitions of BLE
    #include "ble_config.h"
    ssize_t read_battery(struct bt_conn *conn, const struct bt_gatt_attr *attr,void *buf,uint16_t len,uint16_t offset)
      const char *value= battery_value;
      return bt_gatt_attr_read(conn,attr,buf,len,offset,value,strlen(value));
    ssize_t read_emg(struct bt_conn *conn,const struct bt_gatt_attr *attr,void *buf,uint16_t len,uint16_t offset)
       const char *emg_buffer[20];
       snprintf(emg_buffer,sizeof(emg_buffer),"%s,%s",emg_value[0],emg_value[1]);
       return bt_gatt_attr_read(conn,attr,buf,len,offset,emg_buffer,strlen(emg_buffer));
    const struct  bt_data ad[]={
       BT_DATA_BYTES(BT_DATA_FLAGS,(BT_LE_AD_GENERAL|BT_LE_AD_NO_BREDR)),
       BT_DATA(BT_DATA_NAME_COMPLETE,DEVICE_NAME,DEVICE_NAME_LEN),
    const struct bt_data sd[] = {
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_CUSTOM_SERVICE_VAL),
    @ref about advertising intervals
    800 - Min Advertising Interval 500ms (800*0.625ms)
    801 - Max Advertising Interval 500.625ms (801*0.625ms)
    NULL - Indicates undirected advertising
    struct bt_le_adv_param *adv_pram = BT_LE_ADV_PARAM((BT_LE_ADV_OPT_CONNECTABLE|BT_LE_ADV_OPT_USE_IDENTITY),
                                                              800,801,NULL);
    static void update_phy(struct bt_conn *conn)
            int err;
            const struct bt_conn_le_phy_param preferred_phy = {
                    .options = BT_CONN_LE_PHY_OPT_NONE,
                    .pref_rx_phy = BT_GAP_LE_PHY_2M,
                    .pref_tx_phy = BT_GAP_LE_PHY_2M,
            err = bt_conn_le_phy_update(conn,&preferred_phy);
            if(err)
                    LOG_ERR("bt_conn_le_phy_update() returned %d",err);
    struct bt_conn *my_conn = NULL;
    void on_connected(struct bt_conn *conn,uint8_t err)
            if(err)
                    printk("Connection error %d",err);
                    return;
            printk("Connected");
            my_conn = bt_conn_ref(conn);
            struct bt_conn_info info;
            err = bt_conn_get_info(conn,&info);
            if(!err)
            double connection_interval = info.le.interval*1.25;//in ms
            uint32_t supervision_timeout = info.le.timeout*10;//in ms
            printk("Connection parameters: interval %.2f ms, latency %d intervals,timeout %d ms",connection_interval,info.le.latency,supervision_timeout);
           // update_phy(my_conn);
    void on_disconnected(struct bt_conn *conn, uint8_t reason)
       printk("Disconnected. Reason %d",reason);
       bt_conn_unref(my_conn);
    struct bt_conn_cb connection_callbacks = {
            .connected = on_connected,
            .disconnected = on_disconnected,
    void bt_ready(void)
            int err;
            err=bt_enable(NULL);
            printk("Bluetooth Intialied\n");
            err=bt_le_adv_start(adv_pram,ad,ARRAY_SIZE(ad),sd,ARRAY_SIZE(sd));
            if (err) {
    		printk("Advertising failed to start (err %d)\n", err);
    		return;
            printk("Advertising successfully started\n");
    ble_config.h
