Hi Support team,
I am using nRF9160 module and i want run two server on the module, one is modbus server and other is CoAP server. so is it possible to run both server simultaneously ?
Dvl
Hi Support team,
Dvl
Hi Dejan Simonovic,
FYI, by last test i found that when i open coap server, the fd count reached to 2, then i create modbus TCP server and fd value will be 3, but during accept API, it return -1 and errno 23, so i just dont understand that if socket create and bind is success then why it fails at accept API !!
Please let me know if you have any idea..?
thanks,
Dvl
Hi Dvl,
Can you provide more details on what exactly you have done and try to achieve?
Do you use any security?
Could you please provide a log showing the error?
Dejan
Hi Dejan Simonovic,
to make you batter understanding i have attaching complete project zip and debug log file, it very simple project that i am trying to implement, if your are engineer then you might able to understand the flow of code from main.c/main() function.
for compilation i am usinng the SDK version 2.4.0
1. Here is the debug log file
*** Booting nRF Connect SDK v3.5.99-ncs1 *** [00:00:00.333,648] <inf> main: [142]main [00:00:02.605,895] <inf> main: RSP : +CEREG: 0,4 OK [00:00:03.614,898] <inf> main: RSP : +CEREG: 0,2,"2BDC","0340830A",7 OK [00:00:04.623,931] <inf> main: RSP : +CEREG: 0,2,"2BDC","0340830A",7 OK [00:00:05.624,572] <inf> main: RSP : +CEREG: 0,2,"2BDC","0340830A",7 OK [00:00:06.625,427] <inf> main: RSP : +CEREG: 0,2,"2BDC","0340830A",7 OK [00:00:07.626,007] <inf> main: RSP : +CEREG: 0,1,"2BDC","0340830A",7 OK [00:00:07.626,647] <inf> CoAP_APP: coap_service_start : 0 [00:00:08.626,708] <inf> CoAP_APP: coap_service_is_running : 1 [00:00:09.626,922] <inf> main: [67]StartTCPServer [00:00:09.626,953] <inf> main: Project : CoAPAndServer [00:00:09.627,349] <inf> main: [76]StartTCPServer >> socket >> serv >> 3 [00:00:09.627,685] <inf> main: Started TCP server example on port 502, 0 [00:00:09.627,716] <err> main: error: accept: 23, -1 [00:00:09.827,850] <err> main: error: accept: 23, -1 [00:00:10.027,984] <err> main: error: accept: 23, -1 [00:00:10.228,088] <err> main: error: accept: 23, -1 [00:00:10.428,192] <err> main: error: accept: 23, -1 [00:00:10.628,295] <err> main: error: accept: 23, -1 [00:00:10.828,369] <err> main: error: accept: 23, -1 [00:00:11.028,503] <err> main: error: accept: 23, -1 [00:00:11.228,637] <err> main: error: accept: 23, -1 [00:00:11.428,741] <err> main: error: accept: 23, -1 [00:00:11.628,845] <err> main: error: accept: 23, -1 [00:00:11.828,948] <err> main: error: accept: 23, -1 [00:00:12.029,022] <err> main: error: accept: 23, -1 [00:00:12.229,156] <err> main: error: accept: 23, -1 [00:00:12.429,290] <err> main: error: accept: 23, -1 [00:00:12.629,394] <err> main: error: accept: 23, -1 [00:00:12.829,498] <err> main: error: accept: 23, -1 [00:00:13.029,602] <err> main: error: accept: 23, -1 [00:00:13.229,675] <err> main: error: accept: 23, -1
2. main.c file
* Copyright (c) 2019 Nordic Semiconductor ASA
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <modem/nrf_modem_lib.h>
#include <nrf_modem_at.h>
#include <zephyr/net/socket.h>
#include "CoAP/CoAP.h"
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
char response[512];
uint8_t RecvBuff[512];
// TCP Server Implementation ----------
static int SeverRcevHandler(int client)
int rc;
int errno;
struct pollfd fd = {
.fd = client,
.events = POLLIN
rc = poll(&fd, 1, MSEC_PER_SEC * 10);
if (rc < 0) {
LOG_WRN("poll() error: %d", -errno);
return -errno;
} else if (rc == 0) {
LOG_WRN("poll() timeout");
return -EAGAIN;
rc = recv(client, RecvBuff, sizeof(RecvBuff), 0);
if (rc <= 0) {
return rc == 0 ? -ENOTCONN : -errno;
LOG_HEXDUMP_DBG(RecvBuff, sizeof(RecvBuff), "RecvBuff:>");
if (send(client, RecvBuff, strlen(RecvBuff), 0) < 0) {
return -errno;
return errno;
int StartTCPServer(void)
int serv;
struct sockaddr_in bind_addr;
static int counter;
int err = 0;
char *Server_Addr_str = "70.25.147.111";
uint32_t Server_Addr_u32 = 0;
uint16_t Server_port = 502;
char *next = 0;
LOG_INF("[%d]%s", __LINE__, __func__);
serv = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
if (serv < 0) {
LOG_ERR("error: socket: %d", errno);
return 0;
LOG_INF("[%d]%s >> socket >> serv >> %d", __LINE__, __func__, serv);
Server_Addr_u32 = strtol(Server_Addr_str, &next, 10);
Server_Addr_u32 = Server_Addr_u32 << 8;
Server_Addr_u32 |= strtol(&next[1], &next, 10);
bind_addr.sin_family = AF_INET;
bind_addr.sin_addr.s_addr = htonl(Server_Addr_u32);// htonl(INADDR_ANY); // INADDR_ANY
bind_addr.sin_port = htons(Server_port);
if (bind(serv, (struct sockaddr *)&bind_addr, sizeof(bind_addr)) < 0) {
LOG_ERR("error: bind: %d", errno);
return 0;
if (listen(serv, 5) < 0) {
LOG_ERR("error: listen: %d", errno);
return 0;
errno = 0;
LOG_INF("Started TCP server example on port %d, %d", Server_port, errno);
LOG_DBG("Entering infinite while Loop %d", __LINE__);
while (1) {
struct sockaddr_in client_addr;
socklen_t client_addr_len = sizeof(client_addr);
char addr_str[INET_ADDRSTRLEN];
int client;
int rc;
client = accept(serv, (struct sockaddr *)&client_addr,
&client_addr_len);
if (client < 0) {
LOG_ERR("error: accept: %d, %d", errno, client);
k_msleep(200);
continue;
inet_ntop(client_addr.sin_family, &client_addr.sin_addr,
addr_str, sizeof(addr_str));
LOG_INF("Connection #%d from %s",
counter++, addr_str);
do {
rc = SeverRcevHandler(client);
k_msleep(1);
} while (!rc);
close(client);
LOG_INF("Connection from %s closed, errno %d",
addr_str, rc);
return 0;
void main(void)
int err = 0;
LOG_INF("Project : CoAPAndServer");
err = nrf_modem_lib_init();
if (err < 0)
LOG_ERR("Modem library init failed, err: %d", err);
return;
k_msleep(1000);
err = nrf_modem_at_cmd(response, sizeof(response), "AT+CFUN=1");
if (err) // This condition will true, When there is an error occured
LOG_ERR("CFUN Failed %d", err);
return;
do // Check Network in do..while();
k_sleep(K_SECONDS(1)); // Delay between two iteration
err = nrf_modem_at_cmd(response, sizeof(response), "AT+CEREG?");
if (err) // true, when error
LOG_ERR("ERR : %d, %s", err, response);
LOG_INF("RSP : %s", response);
} while(!strstr(response, "+CEREG: 0,1"));
CoAPSetup();
k_msleep(1000);
StartTCPServer();
while(1)
// RTC_Read(); // RTC Read test
// SHT40_Test(); // SHT40, NOTE : check mutex lock
// vI2cScan(); // NOTE : check mutex lock
// char DisplayValue[20] = {0};
// snprintf(DisplayValue, 20, "%.1f C\n%.1f RH\n%.1f H", fReadTemprature(), fReadHumidity(), fReadHumidex());
// DisplayString(DisplayValue);
// LOG_INF("%s", DisplayValue);
k_msleep(5000);
/* [ Thread Tree ]
Start_SysInit_Thread() --> Start_Network_Check_Thread() // Create new thread and distory self
Start_Network_Check_Thread() --> Start_Get_APN_Thread((uint32_t)1000); // Create new thread and distory self
Start_Get_APN_Thread((uint32_t)1000); --> Start_ModbusServer() // Create new thread and distory self
Start_ModbusServer() // This one runs forever
3. Coap server related source file
* @file : CoAP.c
#include <zephyr/net/coap_service.h>
#include "CoAP.h"
int tcp_socket = 0;
LOG_MODULE_REGISTER(CoAP_APP, LOG_LEVEL_INF);
static const uint16_t my_service_port = 5683;
COAP_SERVICE_DEFINE(my_service, "70.25.147.111", &my_service_port, COAP_SERVICE_AUTOSTART);
static int my_get(struct coap_resource *resource, struct coap_packet *request,
struct sockaddr *addr, socklen_t addr_len)
static const char *msg = "Hello, This is CoAP Server !!";
uint8_t data[CONFIG_COAP_SERVER_MESSAGE_SIZE];
struct coap_packet response;
uint16_t id;
uint8_t token[COAP_TOKEN_MAX_LEN];
uint8_t tkl, type;
LOG_INF("my_get from COAP");
type = coap_header_get_type(request);
id = coap_header_get_id(request);
tkl = coap_header_get_token(request, token);
/* Determine response type */
type = (type == COAP_TYPE_CON) ? COAP_TYPE_ACK : COAP_TYPE_NON_CON;
coap_packet_init(&response, data, sizeof(data), COAP_VERSION_1, type, tkl, token,
COAP_RESPONSE_CODE_CONTENT, id);
/* Set content format */
coap_append_option_int(&response, COAP_OPTION_CONTENT_FORMAT,
COAP_CONTENT_FORMAT_TEXT_PLAIN);
/* Append payload */
coap_packet_append_payload_marker(&response);
coap_packet_append_payload(&response, (uint8_t *)msg, strlen(msg));
/* Send to response back to the client */
return coap_resource_send(resource, &response, addr, addr_len, NULL);
static int my_put(struct coap_resource *resource, struct coap_packet *request,
/* ... Handle the incoming request ... */
/* Return a CoAP response code as a shortcut for an empty ACK message */
return COAP_RESPONSE_CODE_CHANGED;
static const char * const my_resource_path[] = { "test", NULL };
COAP_RESOURCE_DEFINE(my_resource, my_service, {
.path = my_resource_path,
.get = my_get,
.put = my_put,
void CoAPSetup(void)
LOG_INF("coap_service_start : %d", coap_service_start(&my_service));
k_msleep(1000);
LOG_INF("coap_service_is_running : %d", coap_service_is_running(&my_service));
4. Complete Project, you might able to compile this project using nRF SDK 2.6.0
I hope you might get idea from this information to understand the issue, and if you are not an engineer then please show this information to engineer, he might solve this or will give clear information of this issue.
Best Regard,
Dhaval
Hi Dhaval,
I have not been able to build your sample project in NCS v2.6.0 with provided config files. Building was successful only when commenting out lines in nrf9160dk_nrf9160_ns.conf file, but then I could not see the same log. Can you please provide your build command and specify correct configuration for building the sample and reproducing the error on nrf9160-dk?
Dejan
Hi Dejan Simonovic, thanks for the effort and sorry for the confusion
1. Please let me know how you are building the code, for your information I am building using VS code.
2. Please use below sample for DK,
Please Note that you need to change the IP address with your SIM IP address, you can replace your IP address at STATIC_IP_STR define in CoAP.h file.
FYI, I am using SIM card with Public Static IP
I hope this might work
thanks,
Dvl
