Hi Amanda,
Thank you for providing the test project.
I have incorporated some of the configuration settings from your code into my custom board's source code. Setting CONFIG_MCUMGR_BUF_SIZE=2475 resolved the UART issue for mcumgr in the application.
Now I could be able to successfully transfer my complete file to the External Flash.
However, I have noticed that transferring a 137 KB file takes approximately 1 minute and 10 seconds. Is there any potential to reduce this transfer time?
I have attempted to increase CONFIG_MCUMGR_BUF_SIZE and utilize MTU values of 512 and 1024 as arguments for mcumgr, but these adjustments have not yielded any improvement.
I would appreciate any insights or suggestions on how to optimize this transfer process.
MK V
MK_V said:Is there any potential to reduce this transfer time?
Check out this post. Maybe you can try the latest version of NCS v2.8.0.
MK_V said:I have attempted to increaseCONFIG_MCUMGR_BUF_SIZEand utilize MTU values of 512 and 1024 as arguments for mcumgr, but these adjustments have not yielded any improvement.
I can increase CONFIG_MCUMGR_BUF_SIZE and CONFIG_MCUMGR_SMP_UART_MTU to 2475 without issue by using the following command with my test project.
west build -p -b nrf52840dk_nrf52840 zephyr/samples/subsys/mgmt/mcumgr/smp_svr -- -DOVERLAY_CONFIG='overlay-fs.conf;overlay-serial.conf' -DCONFIG_MCUMGR_BUF_SIZE=2475 -DCONFIG_MCUMGR_SMP_UART_MTU=2475 && west flash --recover
-Amanda H.
After this change, could you able to observe improvement in file transfer speed and overall upload time?
Thanks! I will check it out!
As this post indicated mcumgr is known to be quite slow.
For now, see MCUBOOT slow with nRF52840 / Zephyr / USB CDC_ACM protocol for how to speed up mcumgr or use other alternatives than mcumgr-native-cli. See https://docs.zephyrproject.org/latest/services/device_mgmt/mcumgr.html for a list. Most of these will be faster than the old tool.
Sure, Thanks!
