nRF5340: SMP Server with external XIP sample with image revert possibility
Hi all,
by default, the "nRF5340: SMP Server with external XIP" sample does not support reverting images in case DFU was not successful. In other words, it does not swap slots, it just copies the new image over the old one. This is caused by the config CONFIG_BOOT_UPGRADE_ONLY being set to "y".
I had no luck building the sample with CONFIG_BOOT_UPGRADE_ONLY=n. I had a look into C:\ncs\v2.6.1\nrf\modules\mcuboot\nrf5340_exip_image.conf and I can see that this config is set to "y" there. Also there is a note stating that this config is needed to make simultaneous multi image update possible. Does this mean that the only way to achieve multi image DFU for nrf5340 with part of code in QSPI flash is to have this config set to y? Or to make the question more generic - is there a way to have the posibility of reverting images after update in this multi image + QSPI XIP scenario?
Thanks!
    I had discussion with the bootloader devs and the conclusion is that the combination you're asking for is not supported. It cannot be supported because of a dependency of MCUboot which is closer described here: https://github.com/mcu-tools/mcuboot/issues/1950
    Andreas
    so the final conclusion is that if one wants multi-image update, there's no way revert, correct?
    Many thanks for your help!
    Best Regards,
    Ladivin
    From my understanding, this is not supported for the nRF5340. This might be different for the nRF54L15 (which uses "regular" MCUboot DFU) and nRF54L20 (which uses SUIT).
    Andreas
  • Hi Andreas,
    I apologize for revisiting our previous discussion, but I have one more question.
    I understand our conclusion about the lack of revert options for the 3-image update on the nRF5340, and I won't dispute it.
    I want to confirm something: since SDK version 2.8.0, the "nRF5340: SMP Server with external XIP" sample allows for "direct XIP" mode, which does enable revert options. In the configuration (like "sysbuild_no_network_core_directxip.conf"), the network core is empty. This indicates that a network core update isn't possible, but does it also mean the network core must be empty?
    I'm asking, because I would like to know if it's possible to update only 2 images (the application and external flash) via BLE and still have the revert option.
    Thank you very much in advance. This is a bit difficult to explain, so if more details are needed, just let me know Slight smile
    Best,
    Ladivin
  • Hi again Ladivin,
    No worries, always good to discuss complex questions a bit closer to understand them better.
    That's a good question. SB_CONFIG_NETCORE_NONE=y sets the netcore empty, as you say, meaning that you don't have anything on the network core. But if you want to an update of only 2 images (app and external flash) via BLE this indicates that you have something on the netcore i.e the hci_ipc companion component (previously known as child image), meaning that you conflict with SB_CONFIG_NETCORE_NONE=y.
    My understanding of this config is that it's only for non-BLE configurations of the nRF5340, meaning that you won't be able to perform FOTA over BLE since the network core is empty. It might be useful if you have a multi-MCU board where another BLE compatible device receives the XIP_no_netcore__directxip image, sends it over serial to the nRF5340 which has an empty netcore over serial and then MCUboot on the 5340_no_netcore performs the update using that image.
    Andreas
