Building mesh dfu sample for nRF52840 dongle
Hello
I am trying to build  the Zephyr mesh distributor sample on the nRF 52840 dongle
It builds and runs just find on the nRF52840 DK
But when I try to build for the dongle I get a link error the image is too big to fit in the flash and a lot of other warnings
Tried to disable logging to make the image smaller  - no luck
Log below
Please help
Thank you
---------nrf5284dongle-build.zip-----------------------------------
    Have you looked at our Memory footprint optimization guide? This gives recommendations for how to reduce the memory footprint of your application.
    Marte
  • Yes. Most of them apply to RAM although some do apply to flash
    Tried several, no luck
    Question
    The distributor sample has the mcuboot bootloader.
    What happens if I overwrite the Open DFU bootloader that is present on the dongle and just use  the mcuboot to start my app ?
    Any side effects I should be aware of?
    Using MCUboot only is basically the option "3. Using an External Debug Probe" mentioned earlier in this thread. It does require you to connect with a programmer for the initial programming. After that, further DFU can be done over USB using MCUboot. Please note that any application must then be built for use with MCUboot only, which has implications for memory layout.
    If at some point you want to "factory reset" the dongle into the state it was shipped with from us, then you need to use a programmer in order to get back to the nRF5 based DFU bootloader. Apart from that, if you are happy with using MCUboot, then the Dongle will now work just as any other custom product out in the field.
    Terje
  • My main hurdle now is that the image does not fit - about 7000 bytes short. Suppose I solve that problem and now I have the image that contains mcuboot and my application. If I load it on a dongle using nRF programmer, will my app run? I need mcuboot  because I plan to use the dongle to distribute firmware updates via mesh
    The application should run, yes, provided that you use the right board files and configurations, and that your application doesn't have any errors stopping it from running. If you have not got there yet over the holidays, I recommend trying with a simple sample from the SDK, which should fit already, to get some experience with running applications with MCUboot on the nRF52 Dongle.
    Terje
