MCUboot flash overflow
I am encountering a flash overflow issue in MCUboot when enabling external flash over SPI. After configuring SPI memory in the .conf file and adding external flash support in the .dts file, the bootloader's memory usage increases. This leads to a compilation error, with the flash memory exceeding the allocated size by 7 kB. Below are the details of my setup.
Environment:
  • NCS Version: 2.7.0
  • Default MCUboot Size: 48 kB
  • Current MCUboot Memory Usage:
    • Without external flash (SPI/QSPI): ~43 kB
    • With external SPI flash defined (not used, only internal flash utilized in ): Overflow by 7 kB
Configurations and Files:
1. Device Tree (.dts)
chosen {
    zephyr,sram = &sram0;
    zephyr,flash = &flash0;
    zephyr,code-partition = &slot0_partition;
    nordic,pm-ext-flash = &mx25l12833f;
&spi1 {
    status = "okay";
    pinctrl-0 = <&spi1_default>;
    pinctrl-1 = <&spi1_sleep>;
    cs-gpios = <&gpio0 21 GPIO_ACTIVE_LOW>;
    mx25l12833f: mx25l12833f@0 {
        compatible = "jedec,spi-nor";
        reg = <0>;
        spi-max-frequency = <8000000>;
        sfdp-bfp = [
            e5 20 19 00  /* SFDP Header */
            ff 00 ff 00  /* Erase Command, Write Granularity */
            eb 44 55 ff  /* 4KB Erase Command, Page Size */
            ff ff ff ff  /* Other Command Set */
        jedec-id = [ c2 20 18 ];
        size = <DT_SIZE_M(128)>;
        has-dpd;
        t-enter-dpd = <10000>;
        t-exit-dpd = <5000>;
        status = "okay";
&flash0 {
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        boot_partition: partition@0 {
            label = "mcuboot";
            reg = <0x00000000 0xC000>;
        slot0_partition: partition@C000 {
            label = "image-0";
            reg = <0x0000C000 0xE0000>;
        storage_partition: partition@EC000 {
            label = "storage";
            reg = <0x000EC000 0x14000>;
2. Partition Manager (pm_static.yml)
external_flash:
  address: 0x0
  size: 0x1000000  # 16 MB
  device: DT_CHOSEN(nordic_pm_ext_flash)
  region: external_flash
app:
  address: 0xc200
  region: flash_primary
mcuboot:
  address: 0x0
mcuboot_pad:
  address: 0xc000
  size: 0x200  # 48 KB
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - mcuboot_pad
  - app
  size: 0xE0000   # 920 KB
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  span: *id002
settings_storage:
  address: 0xEC000
mcuboot_secondary:
  address: 0xF20000
  placement:
    align:
      start: 0x4
3. Application Configuration (prj.conf)
# FLASH usage optimization
CONFIG_SIZE_OPTIMIZATIONS=y
CONFIG_COMPILER_OPT="-DNDEBUG"
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_REBOOT=y
CONFIG_THREAD_NAME=y
# FPU
CONFIG_FPU=y
CONFIG_FP_HARDABI=y
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_SERIAL=y
CONFIG_WATCHDOG=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_STREAM_FLASH=y
# Flash occupancy optimization
CONFIG_TIMESLICING=n
CONFIG_LOG=n
CONFIG_PRINTK=n
CONFIG_NCS_BOOT_BANNER=n
CONFIG_BOOT_BANNER=n
CONFIG_ASSERT=n
CONFIG_CONSOLE=n
CONFIG_EARLY_CONSOLE=n
CONFIG_DYNAMIC_INTERRUPTS=n
# Enable MCUMGR
CONFIG_MCUMGR=y
CONFIG_IMG_MANAGER=y
CONFIG_ZCBOR=y
CONFIG_DISABLE_FLASH_PATCH=y
CONFIG_SPI_NOR_IDLE_IN_DPD=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# SYS CONFIG
CONFIG_SETTINGS=y
CONFIG_CPU_LOAD=y
# TIMER
CONFIG_NRFX_TIMER1=n
CONFIG_USB_CDC_TERMINAL=y
CONFIG_UART_ASYNC_API=n
CONFIG_USB_DEVICE_STACK=y
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
# Enable nordic security backend and PSA APIs
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
CONFIG_PSA_WANT_GENERATE_RANDOM=y
CONFIG_PSA_WANT_KEY_TYPE_AES=y
CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y
CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
# Using hardware crypto accelerator
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
4. MCUboot Configuration (mcuboot.conf)
CONFIG_MULTITHREADING=y
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_CONSOLE_HANDLER=n
CONFIG_FLASH=y
Problem: Defining external SPI flash in the configuration (even without actively using it for MCUboot) causes the bootloader size to increase by ~9 kB. This results in a compilation error due to flash memory overflow by ~7 kB. I suspect the issue lies in additional driver inclusion or configuration conflicts caused by enabling SPI flash.
Even with configuration of memory layout like below without using external memory for mcuboot, defining external memory over SPI in .dts causes flash overflow:
&flash0 {
	partitions {
		#size-cells = <1>;
			label = "mcuboot";
			reg = <0x000000000 0xC000>;
			label = "image-0";
			reg = <0x0000C000 0x77000>;
		slot1_partition: partition@83000 {
			label = "image-1";
			reg = <0x00083000 0x77000>;
		storage_partition: partition@FA000 {
			label = "storage";
			reg = <0x000FA000 0x00006000>;
app:
  address: 0xc200
mcuboot:
  address: 0x0
mcuboot_pad:
  address: 0xc000
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - mcuboot_pad
  - app
  span: *id001
  address: 0xc200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x83000
settings_storage:
  address: 0xFA000
Questions:
  1. What could be causing this significant increase in MCUboot memory usage?
  2. Are there optimization steps or alternative configurations to mitigate this flash memory usage?
  • Please give me some suggestions if you find something that I could change and will reduce memory size.
  • Also I have one more question cause when I add external flash in devicetree:
    &spi1 {
    	status = "okay";
    		reg = <0>;
    		sfdp-bfp = [
    		e5 20 19 00  /* 1st DWORD: SFDP Header */
    		ff 00 ff 00  /* 2nd DWORD: Erase Command, Write Granularity */
    		eb 44 55 ff  /* 3rd DWORD: 4KB Erase Command, Page Size */
    		ff ff ff ff  /* 4th DWORD: Other Command Set */
    		ff 00 00 00  /* 5th DWORD: Fast Read Commands */
    		00 00 00 00  /* 6th DWORD: Extended Addressing */
    		00 00 00 00  /* 7th DWORD: Other Settings */
    		00 00 00 00  /* 8th DWORD: Reserved/Other */
    		size = <DT_SIZE_M(128)>; /* 128 Megabits */
    		has-dpd;
    		status = "okay";
    and change memory layout to version without external flash:
    app:
      address: 0xc200
    mcuboot:
      address: 0x0
    mcuboot_pad:
      address: 0xc000
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - mcuboot_pad
      - app
      span: *id001
      address: 0xc200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x83000
    settings_storage:
      address: 0xFA000
    &flash0 {
    	partitions {
    		#size-cells = <1>;
    			label = "mcuboot";
    			label = "image-0";
    			label = "image-1";
    			label = "storage";
    I disable SPI and SPI_NOR in mcuboot.conf, everything compiles but it doesn't start on my board, if I remove external flash from .dts then the code runs ok. What could be the reason ?
  • It seems like the main relevant difference is that the new version enables CONFIG_LOG. Disabling this should free up some space.
    Diff:
    --- v1.8.0_config	2024-11-20 15:30:17.907344987 +0100
    +++ v2.7.0_config	2024-11-20 15:30:49.603068415 +0100
    @@ -8,6 +8,7 @@
     CONFIG_MCUBOOT_NRF_CLEANUP_PERIPHERAL=y
     CONFIG_BOOT_ERASE_PROGRESSIVELY=y
     # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    +# CONFIG_MCUBOOT_CLEANUP_UNUSABLE_SECONDARY is not set
     CONFIG_MCUBOOT=y
     CONFIG_BOOT_USE_MBEDTLS=y
     CONFIG_NRFXLIB_CRYPTO=y
    @@ -22,22 +23,23 @@
     CONFIG_BOOT_SIGNATURE_TYPE_RSA_LEN=2048
     # CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 is not set
     # CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
    -# CONFIG_MCUBOOT_CLEANUP_ARM_CORE is not set
    +CONFIG_MCUBOOT_CLEANUP_ARM_CORE=y
     CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
     # CONFIG_BOOT_HW_KEY is not set
     CONFIG_BOOT_VALIDATE_SLOT0=y
    +CONFIG_BOOT_PREFER_SWAP_MOVE=y
     # CONFIG_BOOT_SWAP_USING_SCRATCH is not set
     # CONFIG_BOOT_UPGRADE_ONLY is not set
     CONFIG_BOOT_SWAP_USING_MOVE=y
     # CONFIG_BOOT_DIRECT_XIP is not set
    +# CONFIG_BOOT_RAM_LOAD is not set
    +# CONFIG_BOOT_FIRMWARE_LOADER is not set
     # CONFIG_BOOT_BOOTSTRAP is not set
    -# CONFIG_BOOT_SWAP_SAVE_ENCTLV is not set
    -# CONFIG_BOOT_ENCRYPT_RSA is not set
    -# CONFIG_BOOT_ENCRYPT_EC256 is not set
    -# CONFIG_BOOT_ENCRYPT_X25519 is not set
    +CONFIG_BOOT_ENCRYPTION_SUPPORT=y
    +# CONFIG_BOOT_ENCRYPT_IMAGE is not set
     CONFIG_BOOT_MAX_IMG_SECTORS=1024
    -# CONFIG_MEASURED_BOOT is not set
    -# CONFIG_BOOT_SHARE_DATA is not set
    +CONFIG_BOOT_SHARE_BACKEND_DISABLED=y
    +# CONFIG_BOOT_SHARE_BACKEND_EXTERNAL is not set
     CONFIG_BOOT_FIH_PROFILE_OFF=y
     # CONFIG_BOOT_FIH_PROFILE_LOW is not set
     # CONFIG_BOOT_FIH_PROFILE_MEDIUM is not set
    @@ -45,19 +47,21 @@
     CONFIG_BOOT_USB_DFU_NO=y
     # CONFIG_BOOT_USB_DFU_WAIT is not set
     # CONFIG_BOOT_USB_DFU_GPIO is not set
    -CONFIG_ZEPHYR_TRY_MASS_ERASE=y
     # CONFIG_BOOT_USE_BENCH is not set
     # CONFIG_MCUBOOT_LOG_LEVEL_OFF is not set
     # CONFIG_MCUBOOT_LOG_LEVEL_ERR is not set
     # CONFIG_MCUBOOT_LOG_LEVEL_WRN is not set
     CONFIG_MCUBOOT_LOG_LEVEL_INF=y
     # CONFIG_MCUBOOT_LOG_LEVEL_DBG is not set
    +# CONFIG_MCUBOOT_LOG_LEVEL_DEFAULT is not set
     CONFIG_MCUBOOT_LOG_LEVEL=3
     CONFIG_MCUBOOT_LOG_THREAD_STACK_SIZE=768
    +# CONFIG_MCUBOOT_INDICATION_LED is not set
     # CONFIG_MCUBOOT_SERIAL is not set
     # CONFIG_BOOT_INTR_VEC_RELOC is not set
     CONFIG_UPDATEABLE_IMAGE_NUMBER=1
     CONFIG_BOOT_WATCHDOG_FEED=y
    +# CONFIG_MCUBOOT_ACTION_HOOKS is not set
     # end of MCUBoot settings
     CONFIG_MCUBOOT_DEVICE_SETTINGS=y
    @@ -67,42 +71,116 @@
     CONFIG_USB_DEVICE_PRODUCT="MCUBOOT"
    -CONFIG_GPIO=y
    -CONFIG_SPI=y
    -# CONFIG_I2C is not set
    -# CONFIG_KSCAN is not set
    +# CONFIG_INPUT is not set
     # CONFIG_WIFI is not set
    -CONFIG_NET_CONFIG_IEEE802154_DEV_NAME=""
    -# CONFIG_FT800 is not set
    +# CONFIG_MIPI_DSI is not set
     # CONFIG_MODEM is not set
    -CONFIG_GPIO_NRF_P1=y
    -CONFIG_BOARD="nt_22_1737_nrf52840"
    -CONFIG_SOC="nRF52840_QIAA"
    -CONFIG_SOC_SERIES="nrf52"
    +CONFIG_SPI=y
     CONFIG_NUM_IRQS=48
     CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    -CONFIG_WATCHDOG=y
    -CONFIG_HEAP_MEM_POOL_SIZE=0
    +CONFIG_FLASH_SIZE=1024
    +CONFIG_FLASH_BASE_ADDRESS=0x0
    +CONFIG_MP_MAX_NUM_CPUS=1
    +CONFIG_PLATFORM_SPECIFIC_INIT=y
    +CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
     CONFIG_ROM_START_OFFSET=0
    -# CONFIG_PM is not set
    +CONFIG_PINCTRL=y
    +CONFIG_BUILD_OUTPUT_BIN=y
    +CONFIG_XIP=y
    +CONFIG_MAIN_STACK_SIZE=10240
    +CONFIG_IDLE_STACK_SIZE=320
    +CONFIG_HAS_FLASH_LOAD_OFFSET=y
    +# CONFIG_SRAM_VECTOR_TABLE is not set
    +CONFIG_CPU_HAS_ARM_MPU=y
    +# CONFIG_COUNTER is not set
    +# CONFIG_SHARED_INTERRUPTS is not set
     # CONFIG_PM_DEVICE is not set
    -CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    -CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    -# CONFIG_CORTEX_M_SYSTICK is not set
    -CONFIG_CLOCK_CONTROL=y
    -CONFIG_NRF_RTC_TIMER=y
    -CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    -CONFIG_BUILD_OUTPUT_HEX=y
    +CONFIG_TICKLESS_KERNEL=y
    +CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    +CONFIG_USE_DT_CODE_PARTITION=y
    +CONFIG_FLASH_LOAD_OFFSET=0x0
     # CONFIG_FPU is not set
    -CONFIG_FLASH_SIZE=1024
    -CONFIG_FLASH_BASE_ADDRESS=0x0
    -CONFIG_MBEDTLS=y
    -CONFIG_TEST_EXTRA_STACKSIZE=0
    -# CONFIG_GPIO_MCUX is not set
    +# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    +CONFIG_GPIO=y
    +# CONFIG_SERIAL is not set
     # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
     # CONFIG_TINYCRYPT is not set
    -# CONFIG_SERIAL is not set
    -# CONFIG_SRAM_VECTOR_TABLE is not set
    +CONFIG_MBEDTLS=y
    +# CONFIG_MEMC is not set
    +CONFIG_KERNEL_ENTRY="__start"
    +# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    +# CONFIG_DYNAMIC_INTERRUPTS is not set
    +# CONFIG_CACHE is not set
    +CONFIG_LOG=y
    +# CONFIG_CODE_DATA_RELOCATION is not set
    +CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    +CONFIG_DCACHE_LINE_SIZE=32
    +CONFIG_GEN_IRQ_VECTOR_TABLE=y
    +CONFIG_SOC="nrf52840"
    +# CONFIG_RESET is not set
    +CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    +CONFIG_NRF_RTC_TIMER=y
    +CONFIG_LOG_DOMAIN_NAME=""
    +CONFIG_BUILD_OUTPUT_HEX=y
    +CONFIG_CLOCK_CONTROL=y
    +CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    +CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    +# CONFIG_SYSCON is not set
    +CONFIG_ENTROPY_INIT_PRIORITY=50
    +CONFIG_FLASH_INIT_PRIORITY=50
    +CONFIG_GEN_ISR_TABLES=y
    +CONFIG_GEN_IRQ_START_VECTOR=0
    +CONFIG_GEN_SW_ISR_TABLE=y
    +CONFIG_SRAM_OFFSET=0
    +# CONFIG_REBOOT is not set
    +# CONFIG_POWER_DOMAIN is not set
    +# CONFIG_CONSOLE is not set
    +CONFIG_SOC_SERIES="nrf52"
    +CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    +CONFIG_SPI_NOR=y
    +CONFIG_ISR_STACK_SIZE=2048
    +CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
    +# CONFIG_SCHED_CPU_MASK is not set
    +# CONFIG_WATCHDOG is not set
    +CONFIG_ICACHE_LINE_SIZE=32
    +# Devicetree Info
    +CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
    +CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
    +CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
    +CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
    +CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    +CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    +CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    +CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
    +CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    +CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    +CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
    +# end of Devicetree Info
     # Modules
    @@ -113,24 +191,32 @@
    -# nrf (/root/ncs/nrf)
    +# nrf (/root/ncs/v2.7.0/nrf)
    +# CONFIG_MBOX is not set
     CONFIG_NUM_METAIRQ_PRIORITIES=0
    -CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    -CONFIG_MAIN_STACK_SIZE=10240
     # CONFIG_INIT_STACKS is not set
    +CONFIG_MPSL_WORK_STACK_SIZE=1024
    +# CONFIG_MBEDTLS_ENABLE_HEAP is not set
     # Nordic nRF Connect
     CONFIG_WARN_EXPERIMENTAL=y
    -CONFIG_PRIVILEGED_STACK_SIZE=1024
    -# CONFIG_ENTROPY_GENERATOR is not set
     CONFIG_INIT_ARCH_HW_AT_BOOT=y
    -# CONFIG_NORDIC_QSPI_NOR is not set
     CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    +# CONFIG_GETOPT is not set
     # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    -CONFIG_LOG_DEFAULT_LEVEL=0
    +# Image build variants
    +CONFIG_NCS_MCUBOOT_IN_BUILD=y
    +# end of Image build variants
    +# Subsystems
     # Bootloader
    @@ -140,6 +226,8 @@
     CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
     # CONFIG_B0_MIN_PARTITION_SIZE is not set
     CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    +# CONFIG_IS_SECURE_BOOTLOADER is not set
    +CONFIG_IS_BOOTLOADER_IMG=y
     # CONFIG_SECURE_BOOT_CRYPTO is not set
    @@ -152,36 +240,38 @@
     CONFIG_SB_VALIDATION_METADATA_OFFSET=0
     CONFIG_SB_VALIDATE_FW_SIGNATURE=y
     # end of Secure Boot firmware validation
    +# CONFIG_SECURE_BOOT_STORAGE is not set
     # end of Bootloader
     # Bluetooth Low Energy
    +CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
     # BLE over nRF RPC
    +CONFIG_HEAP_MEM_POOL_SIZE=0
     # end of BLE over nRF RPC
     # end of Bluetooth Low Energy
     # DFU
    -# DFU
    +# CONFIG_DFU_MULTI_IMAGE is not set
     # CONFIG_DFU_TARGET is not set
     # end of DFU
    -# end of DFU
     # CONFIG_ESB is not set
    +# CONFIG_EMDS is not set
     # Peripheral CPU DFU (PCD)
     # CONFIG_PCD is not set
     # CONFIG_PCD_APP is not set
    +CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
     # CONFIG_PCD_NET is not set
     # end of Peripheral CPU DFU (PCD)
    @@ -192,8 +282,10 @@
     # Application protocols
    -# CONFIG_NRF_CLOUD_MQTT is not set
    -# CONFIG_NRF_CLOUD_REST is not set
    +# nRF Cloud
     # Client ID (nRF Cloud Device ID)
    @@ -202,19 +294,53 @@
     CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
     # end of Client ID (nRF Cloud Device ID)
    +# CONFIG_NRF_CLOUD_MQTT is not set
    +# CONFIG_NRF_CLOUD_FOTA is not set
    +CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
    +CONFIG_FOTA_DL_TIMEOUT_MIN=15
    +# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    +# CONFIG_NRF_CLOUD_REST is not set
    +# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
    +# CONFIG_NRF_CLOUD_ALERT is not set
    +# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    +# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    +# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    +# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    +# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    +CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    +CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=0
    +CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    +# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
    +CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    +# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    +# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    +# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    +# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    +# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    +CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    +CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=0
    +# CONFIG_NRF_CLOUD_COAP is not set
    +# Send shadow info sections on initial connect (MQTT/CoAP)
    +# end of Send shadow info sections on initial connect (MQTT/CoAP)
     # CONFIG_NRF_CLOUD_GATEWAY is not set
     # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
     # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
     # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    -CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
    +# CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
     # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    -CONFIG_NRF_CLOUD_LOG_LEVEL=3
    +CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    +CONFIG_NRF_CLOUD_LOG_LEVEL=0
    +# end of nRF Cloud
     # CONFIG_REST_CLIENT is not set
     # CONFIG_DOWNLOAD_CLIENT is not set
     # CONFIG_AWS_IOT is not set
     # CONFIG_AWS_JOBS is not set
     # CONFIG_AZURE_IOT_HUB is not set
    -# CONFIG_CLOUD_API is not set
     # Self-Registration (Zi ZHu Ce)
    @@ -224,6 +350,10 @@
     # CONFIG_ICAL_PARSER is not set
     # CONFIG_FTP_CLIENT is not set
     # CONFIG_LWM2M_CLIENT_UTILS is not set
    +# CONFIG_WIFI_CREDENTIALS is not set
    +# CONFIG_WIFI_CREDENTIALS_STATIC is not set
    +# CONFIG_MQTT_HELPER is not set
    +# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
     # end of Application protocols
     # end of Networking
    @@ -245,47 +375,41 @@
     # CONFIG_NFC_TNEP_CH is not set
     # end of NFC
    -# CONFIG_PROFILER is not set
    +# CONFIG_APP_EVENT_MANAGER is not set
    +# CONFIG_NRF_PROFILER is not set
    +# CONFIG_FW_INFO is not set
    -# SPM
    +# Debug
    -# CONFIG_SPM is not set
    -# CONFIG_IS_SPM is not set
    -# end of SPM
    -# CONFIG_FW_INFO is not set
    -# CONFIG_PPI_TRACE is not set
     # CONFIG_CPU_LOAD is not set
    +# CONFIG_PPI_TRACE is not set
    +# end of Debug
    -# Nordic MPSL
    +# Multiprotocol service layer (MPSL)
    -# CONFIG_MPSL_CX is not set
    -# CONFIG_MPSL_CX_LOG_LEVEL_OFF is not set
    -# CONFIG_MPSL_CX_LOG_LEVEL_ERR is not set
    -# CONFIG_MPSL_CX_LOG_LEVEL_WRN is not set
    -CONFIG_MPSL_CX_LOG_LEVEL_INF=y
    -# CONFIG_MPSL_CX_LOG_LEVEL_DBG is not set
    -CONFIG_MPSL_CX_LOG_LEVEL=3
    +# CONFIG_MPSL_FEM_ONLY is not set
     # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
     # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
     # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
     # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    -CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
    +# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
     # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    -CONFIG_MPSL_FEM_LOG_LEVEL=3
    +CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    +CONFIG_MPSL_FEM_LOG_LEVEL=0
     CONFIG_MPSL_THREAD_COOP_PRIO=8
    -CONFIG_MPSL_SIGNAL_STACK_SIZE=1024
     CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
     # CONFIG_MPSL_ASSERT_HANDLER is not set
    +CONFIG_MPSL_LOW_PRIO_IRQN=25
     # CONFIG_MPSL_LOG_LEVEL_OFF is not set
     # CONFIG_MPSL_LOG_LEVEL_ERR is not set
     # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    -CONFIG_MPSL_LOG_LEVEL_INF=y
    +# CONFIG_MPSL_LOG_LEVEL_INF is not set
     # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    -CONFIG_MPSL_LOG_LEVEL=3
    -# end of Nordic MPSL
    +CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    +CONFIG_MPSL_LOG_LEVEL=0
    +# end of Multiprotocol service layer (MPSL)
     # Partition Manager
    @@ -301,22 +425,16 @@
     # end of Zephyr subsystem configurations
    -# Zephyr samples configurations
    -# end of Zephyr samples configurations
     # NCS subsystem configurations
    -# NCS samples configurations
    -# end of NCS samples configurations
     # CONFIG_PM_SINGLE_IMAGE is not set
    +CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
     CONFIG_PM_EXTERNAL_FLASH_BASE=0
    +CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    +CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/spi@40004000/mx25l12833f@0"
    +CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=134217728
     CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    +# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
     CONFIG_PM_SRAM_BASE=0x20000000
     CONFIG_PM_SRAM_SIZE=0x40000
     # end of Partition Manager
    @@ -334,11 +452,29 @@
     # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
     # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
     # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    -CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
    +# CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
     # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    -CONFIG_MGMT_FMFU_LOG_LEVEL=3
    +CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    +CONFIG_MGMT_FMFU_LOG_LEVEL=0
     # end of Full Modem Firmware Update Management(FMFU)
    +# SUIT-based Firmware Update Management
    +CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS=100
    +CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS=y
    +CONFIG_MGMT_SUITFU_GRP_IMG=y
    +CONFIG_MGMT_SUITFU_IMAGE_NUMBER=0
    +# CONFIG_MGMT_SUITFU_GRP_SUIT is not set
    +# CONFIG_MGMT_SUITFU_LOG_LEVEL_OFF is not set
    +# CONFIG_MGMT_SUITFU_LOG_LEVEL_ERR is not set
    +# CONFIG_MGMT_SUITFU_LOG_LEVEL_WRN is not set
    +# CONFIG_MGMT_SUITFU_LOG_LEVEL_INF is not set
    +# CONFIG_MGMT_SUITFU_LOG_LEVEL_DBG is not set
    +CONFIG_MGMT_SUITFU_LOG_LEVEL_DEFAULT=y
    +CONFIG_MGMT_SUITFU_LOG_LEVEL=0
    +# end of SUIT-based Firmware Update Management
     # CONFIG_CAF is not set
    @@ -346,84 +482,242 @@
     # end of Nordic IEEE 802.15.4
    -# CONFIG_CDDL_GEN is not set
    +# CONFIG_DM_MODULE is not set
    -# Libraries
    +# nRF Security
    -# CONFIG_AGPS_LOG_LEVEL_OFF is not set
    -# CONFIG_AGPS_LOG_LEVEL_ERR is not set
    -# CONFIG_AGPS_LOG_LEVEL_WRN is not set
    -CONFIG_AGPS_LOG_LEVEL_INF=y
    -# CONFIG_AGPS_LOG_LEVEL_DBG is not set
    -CONFIG_AGPS_LOG_LEVEL=3
    +# CONFIG_NORDIC_SECURITY_BACKEND is not set
    +# CONFIG_NRF_SECURITY is not set
    +# CONFIG_MBEDTLS_MEMORY_DEBUG is not set
    +# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    +# CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    +# CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_DES is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    +# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
    +# CONFIG_PSA_WANT_ALG_CCM is not set
    +# CONFIG_PSA_WANT_ALG_GCM is not set
    +# CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    +# CONFIG_PSA_WANT_ALG_CBC_MAC is not set
    +# CONFIG_PSA_WANT_ALG_CMAC is not set
    +# CONFIG_PSA_WANT_ALG_HMAC is not set
    +# CONFIG_PSA_WANT_ALG_SHA_1 is not set
    +# CONFIG_PSA_WANT_ALG_SHA_224 is not set
    +# CONFIG_PSA_WANT_ALG_SHA_384 is not set
    +# CONFIG_PSA_WANT_ALG_SHA_512 is not set
    +# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    +# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    +# CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    +# CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    +# CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    +# CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    +# CONFIG_PSA_WANT_ALG_SM3 is not set
    +# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    +# CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    +# CONFIG_PSA_WANT_ALG_MD2 is not set
    +# CONFIG_PSA_WANT_ALG_MD4 is not set
    +# CONFIG_PSA_WANT_ALG_MD5 is not set
    +# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    +# CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    +# CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    +# CONFIG_PSA_WANT_ALG_CFB is not set
    +# CONFIG_PSA_WANT_ALG_CTR is not set
    +# CONFIG_PSA_WANT_ALG_OFB is not set
    +# CONFIG_PSA_WANT_ALG_XTS is not set
    +# CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    +# CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    +# CONFIG_PSA_WANT_ALG_ECDH is not set
    +# CONFIG_PSA_WANT_ALG_FFDH is not set
    +# CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    +# CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    +# CONFIG_PSA_WANT_ALG_ECDSA is not set
    +# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    +# CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    +# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    +# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    +# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    +# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    +# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    +# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    +# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    +# CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    +# CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    +# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    +# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    +# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    +# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    +# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    +# CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    +# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    +# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    +# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    +# CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    +# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    +# CONFIG_PSA_WANT_ALG_JPAKE is not set
    +# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    +# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    +# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    +# CONFIG_PSA_WANT_ALG_SRP_6 is not set
    +# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    +# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    +# CONFIG_PSA_WANT_ALG_ED25519PH is not set
    +# CONFIG_PSA_WANT_ALG_ED448PH is not set
    +# end of nRF Security
    +# Audio Module
    +# CONFIG_AUDIO_MODULE_TEST is not set
    +CONFIG_AUDIO_MODULE_NAME_SIZE=20
    +# CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
    +# CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
    +# CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
    +# CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
    +# CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
    +CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
    +CONFIG_AUDIO_MODULE_LOG_LEVEL=0
    +# end of Audio Module
    +# CONFIG_TRUSTED_STORAGE is not set
    +# SUIT provisioning
    +# CONFIG_SUIT_MPI_GENERATE is not set
    +# end of SUIT provisioning
    +# CONFIG_SUIT is not set
    +# CONFIG_MBEDTLS_ZEPHYR_ENTROPY is not set
    +# end of Subsystems
    +# CONFIG_WPA_SUPP is not set
    +CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=0
    +CONFIG_POSIX_MAX_FDS=4
    +# CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    +# CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    +# CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    +# CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    +# CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    +CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    +CONFIG_WFA_QT_LOG_LEVEL=0
    +# CONFIG_WFA_QT_CONTROL_APP is not set
    +CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    +CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    +CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
    +CONFIG_WPAS_READY_TIMEOUT_MS=10000
    -# Binary libraries
    +# Libraries
    -# end of Binary libraries
    -# CONFIG_ADP536X is not set
    -# AT Command driver
    +# Binary libraries
    -# end of AT Command driver
    +# end of Binary libraries
     # CONFIG_AT_MONITOR is not set
    -# CONFIG_DISABLE_FLASH_PATCH is not set
    +CONFIG_FLASH_PATCH_WARN=y
     # CONFIG_LTE_LINK_CONTROL is not set
    -CONFIG_FPROTECT=y
     CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
     CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    -CONFIG_FPROTECT_ENABLE_NO_ACCESS=y
    -CONFIG_FPROTECT_ENABLE_IS_PROTECTED=y
    -# AT Host Library for nrf91
    -# end of AT Host Library for nrf91
    +CONFIG_FPROTECT=y
    +# CONFIG_FPROTECT_APP is not set
    +# CONFIG_AT_CMD_CUSTOM is not set
     # CONFIG_DK_LIBRARY is not set
     # CONFIG_MODEM_INFO is not set
    -CONFIG_RESET_ON_FATAL_ERROR=y
    -# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    -# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    -# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    -CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y
    -# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    -CONFIG_FATAL_ERROR_LOG_LEVEL=3
    +# CONFIG_RESET_ON_FATAL_ERROR is not set
     # CONFIG_SMS is not set
    -# CONFIG_SUPL_CLIENT_LIB is not set
     # CONFIG_DATE_TIME is not set
    +# CONFIG_HW_ID_LIBRARY is not set
     # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
     # CONFIG_WAVE_GEN_LIB is not set
     # CONFIG_HW_UNIQUE_KEY_LOAD is not set
    +CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
     CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
    -CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1500
     # CONFIG_MODEM_JWT is not set
    +# CONFIG_LOCATION is not set
    +# CONFIG_QOS is not set
    +# CONFIG_SFLOAT is not set
    +# CONFIG_CONTIN_ARRAY is not set
    +# CONFIG_PCM_MIX is not set
    +# CONFIG_TONE is not set
    +# CONFIG_PSCM is not set
    +# CONFIG_DATA_FIFO is not set
    +# CONFIG_FEM_AL_LIB is not set
    +# CONFIG_SAMPLE_RATE_CONVERTER is not set
    +CONFIG_NCS_BOOT_BANNER=y
    +CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="MCUboot"
    +CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    +CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
     # end of Libraries
     # Device Drivers
     # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    +CONFIG_ENTROPY_CC3XX=y
     CONFIG_HW_CC3XX=y
     # CONFIG_ETH_RTT is not set
     CONFIG_SENSOR=y
     # CONFIG_SENSOR_SIM is not set
    +# CONFIG_SENSOR_STUB is not set
     # CONFIG_PMW3360 is not set
     # CONFIG_PAW3212 is not set
    -# GPS Drivers
    -# CONFIG_GPS_SIM is not set
    -# end of GPS Drivers
     # CONFIG_NRF_SW_LPUART is not set
    -CONFIG_FLASH=y
    -# CONFIG_FLASH_NOP_DEVICE is not set
    +CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    +# CONFIG_FLASH_RPC is not set
     # end of Device Drivers
    @@ -431,14 +725,25 @@
     # end of External libraries
    +# Test
    +CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
     # CONFIG_UNITY is not set
    +# Mocks
    +# CONFIG_MOCK_NRF_MODEM_AT is not set
    +# end of Mocks
    +# end of Test
     # end of Nordic nRF Connect
     CONFIG_ZEPHYR_NRF_MODULE=y
    -# end of nrf (/root/ncs/nrf)
    +# end of nrf (/root/ncs/v2.7.0/nrf)
    -# mcuboot (/root/ncs/bootloader/mcuboot)
    +# mcuboot (/root/ncs/v2.7.0/bootloader/mcuboot)
    @@ -450,49 +755,223 @@
     # end of MCUboot
     CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    -# end of mcuboot (/root/ncs/bootloader/mcuboot)
    +# end of mcuboot (/root/ncs/v2.7.0/bootloader/mcuboot)
    +# mbedtls (/root/ncs/v2.7.0/modules/crypto/mbedtls)
    +CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    +# PSA RNG support
    +# end of PSA RNG support
    +# PSA key type support
    +# end of PSA key type support
    -# trusted-firmware-m (/root/ncs/modules/tee/tfm)
    +# PSA AEAD support
    +# end of PSA AEAD support
    +# PSA MAC support
    +# end of PSA MAC support
    +# PSA Hash support
    +# end of PSA Hash support
    +# PSA Cipher support
    +# end of PSA Cipher support
    +# PSA Key agreement support
    +# end of PSA Key agreement support
    +# PSA Key derivation support
    +# end of PSA Key derivation support
    +# PSA Asymmetric support
    +# Elliptic Curve type support
    +# end of Elliptic Curve type support
    +# end of PSA Asymmetric support
    +CONFIG_MBEDTLS_BUILTIN=y
    +# CONFIG_MBEDTLS_LIBRARY is not set
    +# CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    +CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1500
    +# CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    +# CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    +# CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    +# CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    +# CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    +CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    +CONFIG_MBEDTLS_LOG_LEVEL=0
    +# CONFIG_MBEDTLS_DEBUG is not set
    +# CONFIG_MBEDTLS_TEST is not set
    +CONFIG_MBEDTLS_INIT=y
    +# CONFIG_MBEDTLS_ZEROIZE_ALT is not set
    +CONFIG_APP_LINK_WITH_MBEDTLS=y
    +# end of mbedtls (/root/ncs/v2.7.0/modules/crypto/mbedtls)
    +# oberon-psa-crypto (/root/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
    +CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    +# end of oberon-psa-crypto (/root/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
    +# trusted-firmware-m (/root/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
    -# CONFIG_TFM_MINIMAL is not set
     CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    -# CONFIG_MBEDTLS_ENABLE_HEAP is not set
    -# end of trusted-firmware-m (/root/ncs/modules/tee/tfm)
    +# end of trusted-firmware-m (/root/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
    +CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    +CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
    -# cjson (/root/ncs/modules/lib/cjson)
    +# cjson (/root/ncs/v2.7.0/modules/lib/cjson)
     CONFIG_ZEPHYR_CJSON_MODULE=y
    -# end of cjson (/root/ncs/modules/lib/cjson)
    +# end of cjson (/root/ncs/v2.7.0/modules/lib/cjson)
    -# pelion-dm (/root/ncs/modules/lib/pelion-dm)
    +# azure-sdk-for-c (/root/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
    -CONFIG_ZEPHYR_PELION_DM_MODULE=y
    -# end of pelion-dm (/root/ncs/modules/lib/pelion-dm)
    +# CONFIG_AZURE_SDK is not set
    +CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    +# end of azure-sdk-for-c (/root/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
    -# cddl-gen (/root/ncs/modules/lib/cddl-gen)
    +# cirrus-logic (/root/ncs/v2.7.0/modules/hal/cirrus-logic)
    -CONFIG_ZEPHYR_CDDL_GEN_MODULE=y
    -# end of cddl-gen (/root/ncs/modules/lib/cddl-gen)
    +# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    +CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    +# end of cirrus-logic (/root/ncs/v2.7.0/modules/hal/cirrus-logic)
    -# memfault-firmware-sdk (/root/ncs/modules/lib/memfault-firmware-sdk)
    +# openthread (/root/ncs/v2.7.0/modules/lib/openthread)
    +# CONFIG_OPENTHREAD is not set
    +CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    +# end of openthread (/root/ncs/v2.7.0/modules/lib/openthread)
    +# suit-generator (/root/ncs/v2.7.0/modules/lib/suit-generator)
    +CONFIG_SUIT_ENVELOPE_TEMPLATE=""
    +CONFIG_SUIT_ENVELOPE_TARGET=""
    +CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
    +CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
    +# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
    +CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    +# end of suit-generator (/root/ncs/v2.7.0/modules/lib/suit-generator)
    +# suit-processor (/root/ncs/v2.7.0/modules/lib/suit-processor)
    +# CONFIG_SUIT_PROCESSOR is not set
    +CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
    +CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    +# end of suit-processor (/root/ncs/v2.7.0/modules/lib/suit-processor)
    +# memfault-firmware-sdk (/root/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
     # CONFIG_MEMFAULT is not set
     CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    -# end of memfault-firmware-sdk (/root/ncs/modules/lib/memfault-firmware-sdk)
    +# end of memfault-firmware-sdk (/root/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
    -# CANopenNode (/root/ncs/modules/lib/canopennode)
    +# coremark (/root/ncs/v2.7.0/modules/benchmark/coremark)
    +# CONFIG_COREMARK is not set
    +CONFIG_ZEPHYR_COREMARK_MODULE=y
    +# end of coremark (/root/ncs/v2.7.0/modules/benchmark/coremark)
    +# canopennode (/root/ncs/v2.7.0/modules/lib/canopennode)
     CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    -# end of CANopenNode (/root/ncs/modules/lib/canopennode)
    +# end of canopennode (/root/ncs/v2.7.0/modules/lib/canopennode)
    +# chre (/root/ncs/v2.7.0/modules/lib/chre)
    +CONFIG_ZEPHYR_CHRE_MODULE=y
    +# CONFIG_CHRE is not set
    +# end of chre (/root/ncs/v2.7.0/modules/lib/chre)
    +# lz4 (/root/ncs/v2.7.0/modules/lib/lz4)
    +CONFIG_ZEPHYR_LZ4_MODULE=y
    +# CONFIG_LZ4 is not set
    +# end of lz4 (/root/ncs/v2.7.0/modules/lib/lz4)
    -# hal_nordic (/root/ncs/modules/hal/nordic)
    +# nanopb (/root/ncs/v2.7.0/modules/lib/nanopb)
    +CONFIG_ZEPHYR_NANOPB_MODULE=y
    +# CONFIG_NANOPB is not set
    +# end of nanopb (/root/ncs/v2.7.0/modules/lib/nanopb)
    +CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    +# zscilib (/root/ncs/v2.7.0/modules/lib/zscilib)
    +# CONFIG_ZSL is not set
    +CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    +# end of zscilib (/root/ncs/v2.7.0/modules/lib/zscilib)
    +# cmsis (/root/ncs/v2.7.0/modules/hal/cmsis)
    +CONFIG_ZEPHYR_CMSIS_MODULE=y
    +CONFIG_HAS_CMSIS_CORE=y
    +CONFIG_HAS_CMSIS_CORE_M=y
    +# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    +# end of cmsis (/root/ncs/v2.7.0/modules/hal/cmsis)
    +# cmsis-dsp (/root/ncs/v2.7.0/modules/lib/cmsis-dsp)
    +CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    +# CONFIG_CMSIS_DSP is not set
    +# end of cmsis-dsp (/root/ncs/v2.7.0/modules/lib/cmsis-dsp)
    +# cmsis-nn (/root/ncs/v2.7.0/modules/lib/cmsis-nn)
    +CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    +# CONFIG_CMSIS_NN is not set
    +# end of cmsis-nn (/root/ncs/v2.7.0/modules/lib/cmsis-nn)
    +# fatfs (/root/ncs/v2.7.0/modules/fs/fatfs)
    +CONFIG_ZEPHYR_FATFS_MODULE=y
    +# end of fatfs (/root/ncs/v2.7.0/modules/fs/fatfs)
    +# hal_nordic (/root/ncs/v2.7.0/modules/hal/nordic)
     CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
     CONFIG_HAS_NORDIC_DRIVERS=y
    @@ -510,10 +989,22 @@
     # nrfx drivers
    +# nrfx drivers logging
    +# CONFIG_NRFX_CLOCK_LOG is not set
    +# CONFIG_NRFX_GPIOTE_LOG is not set
    +# CONFIG_NRFX_NVMC_LOG is not set
    +# CONFIG_NRFX_PPI_LOG is not set
    +# CONFIG_NRFX_SPIM_LOG is not set
    +# CONFIG_NRFX_WDT_LOG is not set
    +# end of nrfx drivers logging
    +# CONFIG_MPSL is not set
     CONFIG_NRFX_CLOCK=y
     # CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED is not set
     # CONFIG_NRFX_COMP is not set
    -# CONFIG_NRFX_EGU is not set
     # CONFIG_NRFX_EGU0 is not set
     # CONFIG_NRFX_EGU1 is not set
     # CONFIG_NRFX_EGU2 is not set
    @@ -521,290 +1012,232 @@
     # CONFIG_NRFX_EGU4 is not set
     # CONFIG_NRFX_EGU5 is not set
     CONFIG_NRFX_GPIOTE=y
    -# CONFIG_NRFX_I2S is not set
    -# CONFIG_NRFX_LPCOMP is not set
    +CONFIG_NRFX_GPIOTE0=y
    +# CONFIG_NRFX_I2S0 is not set
     # CONFIG_NRFX_NFCT is not set
     CONFIG_NRFX_NVMC=y
     # CONFIG_NRFX_PDM is not set
     # CONFIG_NRFX_POWER is not set
    -# CONFIG_NRFX_PPI is not set
    -# CONFIG_NRFX_PWM is not set
    +CONFIG_NRFX_PPI=y
     # CONFIG_NRFX_PWM0 is not set
     # CONFIG_NRFX_PWM1 is not set
     # CONFIG_NRFX_PWM2 is not set
     # CONFIG_NRFX_PWM3 is not set
    -# CONFIG_NRFX_QDEC is not set
    +# CONFIG_NRFX_QDEC0 is not set
     # CONFIG_NRFX_QSPI is not set
     # CONFIG_NRFX_RNG is not set
    -# CONFIG_NRFX_RTC is not set
     # CONFIG_NRFX_RTC0 is not set
     # CONFIG_NRFX_RTC1 is not set
     # CONFIG_NRFX_RTC2 is not set
     # CONFIG_NRFX_SAADC is not set
    -# CONFIG_NRFX_SPI is not set
    -# CONFIG_NRFX_SPI0 is not set
    -# CONFIG_NRFX_SPI1 is not set
    -# CONFIG_NRFX_SPI2 is not set
     CONFIG_NRFX_SPIM=y
    -# CONFIG_NRFX_SPIM0 is not set
    +CONFIG_NRFX_SPIM0=y
     CONFIG_NRFX_SPIM1=y
     # CONFIG_NRFX_SPIM2 is not set
     # CONFIG_NRFX_SPIM3 is not set
    -# CONFIG_NRFX_SPIS is not set
    -# CONFIG_NRFX_SPIS0 is not set
    -# CONFIG_NRFX_SPIS1 is not set
    -# CONFIG_NRFX_SPIS2 is not set
     # CONFIG_NRFX_SYSTICK is not set
     # CONFIG_NRFX_TEMP is not set
    -# CONFIG_NRFX_TIMER is not set
     # CONFIG_NRFX_TIMER0 is not set
     # CONFIG_NRFX_TIMER1 is not set
     # CONFIG_NRFX_TIMER2 is not set
     # CONFIG_NRFX_TIMER3 is not set
     # CONFIG_NRFX_TIMER4 is not set
    -# CONFIG_NRFX_TWI is not set
    -# CONFIG_NRFX_TWI0 is not set
    -# CONFIG_NRFX_TWI1 is not set
    -# CONFIG_NRFX_TWIM is not set
     # CONFIG_NRFX_TWIM0 is not set
     # CONFIG_NRFX_TWIM1 is not set
    -# CONFIG_NRFX_TWIS is not set
    -# CONFIG_NRFX_TWIS0 is not set
    -# CONFIG_NRFX_TWIS1 is not set
    -# CONFIG_NRFX_UART is not set
    -# CONFIG_NRFX_UART0 is not set
    -# CONFIG_NRFX_UARTE is not set
     # CONFIG_NRFX_UARTE0 is not set
     # CONFIG_NRFX_UARTE1 is not set
    -# CONFIG_NRFX_USBD is not set
     CONFIG_NRFX_WDT=y
     CONFIG_NRFX_WDT0=y
    -# CONFIG_NRFX_PRS is not set
    +# Peripheral Resource Sharing module
     # CONFIG_NRFX_PRS_BOX_0 is not set
     # CONFIG_NRFX_PRS_BOX_1 is not set
     # CONFIG_NRFX_PRS_BOX_2 is not set
     # CONFIG_NRFX_PRS_BOX_3 is not set
     # CONFIG_NRFX_PRS_BOX_4 is not set
    +# end of Peripheral Resource Sharing module
    -# end of hal_nordic (/root/ncs/modules/hal/nordic)
    +# end of hal_nordic (/root/ncs/v2.7.0/modules/hal/nordic)
    -# loramac-node (/root/ncs/modules/lib/loramac-node)
    +# hal_st (/root/ncs/v2.7.0/modules/hal/st)
    +CONFIG_ZEPHYR_HAL_ST_MODULE=y
    +# end of hal_st (/root/ncs/v2.7.0/modules/hal/st)
    +CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    +CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    +# liblc3 (/root/ncs/v2.7.0/modules/lib/liblc3)
    +CONFIG_ZEPHYR_LIBLC3_MODULE=y
    +# end of liblc3 (/root/ncs/v2.7.0/modules/lib/liblc3)
    +# littlefs (/root/ncs/v2.7.0/modules/fs/littlefs)
    +CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    +# end of littlefs (/root/ncs/v2.7.0/modules/fs/littlefs)
    +# loramac-node (/root/ncs/v2.7.0/modules/lib/loramac-node)
     CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
     # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    -# end of loramac-node (/root/ncs/modules/lib/loramac-node)
    +# end of loramac-node (/root/ncs/v2.7.0/modules/lib/loramac-node)
    -# lz4 (/root/ncs/modules/lib/lz4)
    +# lvgl (/root/ncs/v2.7.0/modules/lib/gui/lvgl)
    -CONFIG_ZEPHYR_LZ4_MODULE=y
    -# CONFIG_LZ4 is not set
    -# end of lz4 (/root/ncs/modules/lib/lz4)
    +CONFIG_ZEPHYR_LVGL_MODULE=y
    +# end of lvgl (/root/ncs/v2.7.0/modules/lib/gui/lvgl)
    +CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    +CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    +CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    -# mbedtls (/root/ncs/modules/crypto/mbedtls)
    +# picolibc (/root/ncs/v2.7.0/modules/lib/picolibc)
    -CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    -CONFIG_MBEDTLS_BUILTIN=y
    -# CONFIG_MBEDTLS_LIBRARY is not set
    -# CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    -# CONFIG_MBEDTLS_DEBUG is not set
    -# CONFIG_MBEDTLS_MEMORY_DEBUG is not set
    -# CONFIG_MBEDTLS_TEST is not set
    -CONFIG_APP_LINK_WITH_MBEDTLS=y
    -# end of mbedtls (/root/ncs/modules/crypto/mbedtls)
    +# CONFIG_PICOLIBC_MODULE is not set
    +CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    +# end of picolibc (/root/ncs/v2.7.0/modules/lib/picolibc)
    -# nanopb (/root/ncs/modules/lib/nanopb)
    +# segger (/root/ncs/v2.7.0/modules/debug/segger)
    -CONFIG_ZEPHYR_NANOPB_MODULE=y
    -# CONFIG_NANOPB is not set
    -# end of nanopb (/root/ncs/modules/lib/nanopb)
    +CONFIG_ZEPHYR_SEGGER_MODULE=y
    +CONFIG_HAS_SEGGER_RTT=y
    +# CONFIG_USE_SEGGER_RTT is not set
    +# end of segger (/root/ncs/v2.7.0/modules/debug/segger)
    +CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    -# TraceRecorder (/root/ncs/modules/debug/TraceRecorder)
    +# uoscore-uedhoc (/root/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
    -CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
    -# end of TraceRecorder (/root/ncs/modules/debug/TraceRecorder)
    +CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    +# end of uoscore-uedhoc (/root/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
    -# nrfxlib (/root/ncs/nrfxlib)
    +# zcbor (/root/ncs/v2.7.0/modules/lib/zcbor)
    +CONFIG_ZEPHYR_ZCBOR_MODULE=y
    +# CONFIG_ZCBOR is not set
    +# end of zcbor (/root/ncs/v2.7.0/modules/lib/zcbor)
    +# nrfxlib (/root/ncs/v2.7.0/nrfxlib)
     # Nordic nrfxlib
    -# CONFIG_NRF_MODEM_LOG is not set
    +# nrf_modem (Modem library)
    +# end of nrf_modem (Modem library)
     CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
     # CONFIG_NFC_T2T_NRFXLIB is not set
     # CONFIG_NFC_T4T_NRFXLIB is not set
    -# CONFIG_MPSL is not set
     # Crypto libraries for nRF5x SOCs.
    -CONFIG_CRYPTOCELL_CC310_USABLE=y
    -CONFIG_CRYPTOCELL_USABLE=y
    +CONFIG_HAS_HW_NRF_CC3XX=y
     # CONFIG_NRF_OBERON is not set
     CONFIG_NRF_CC3XX_PLATFORM=y
    -# CONFIG_HW_CC3XX_INTERRUPT is not set
     CONFIG_CC3XX_MUTEX_LOCK=y
     # CONFIG_CC3XX_ATOMIC_LOCK is not set
     # end of Crypto libraries for nRF5x SOCs.
    -# Nordic Security
    -# CONFIG_NORDIC_SECURITY_BACKEND is not set
    -# end of Nordic Security
     # CONFIG_NRF_RPC is not set
     CONFIG_NRF_802154_SOURCE_NRFXLIB=y
     # CONFIG_GZLL is not set
    +# CONFIG_NRF_DM is not set
    +# CONFIG_NRF_FUEL_GAUGE is not set
     # end of Nordic nrfxlib
     CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    -# end of nrfxlib (/root/ncs/nrfxlib)
    +# end of nrfxlib (/root/ncs/v2.7.0/nrfxlib)
    -# connectedhomeip (/root/ncs/modules/lib/matter)
    +# connectedhomeip (/root/ncs/v2.7.0/modules/lib/matter)
     # CONFIG_CHIP is not set
    -# CONFIG_CHIP_NFC_COMMISSIONING is not set
     CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    -# end of connectedhomeip (/root/ncs/modules/lib/matter)
    +# end of connectedhomeip (/root/ncs/v2.7.0/modules/lib/matter)
    -# Optional modules. Make sure they're installed, via the project manifest.
    -# CONFIG_CIVETWEB is not set
    -CONFIG_HAS_CMSIS_CORE=y
    -CONFIG_HAS_CMSIS_CORE_M=y
     # CONFIG_LIBMETAL is not set
    +# CONFIG_LVGL is not set
     # CONFIG_HAS_MEC_HAL is not set
    +# CONFIG_HAS_MPFS_HAL is not set
    +# CONFIG_HAS_MEC5_HAL is not set
     # CONFIG_OPENAMP is not set
    -# CONFIG_SOF is not set
     # CONFIG_MIPI_SYST_LIB is not set
     # CONFIG_HAS_TELINK_DRIVERS is not set
    -# CONFIG_TINYCBOR is not set
     CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    +# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
     # Unavailable modules, please install those via the project manifest.
    +# hal_gigadevice module not available.
    +# Trusted-firmware-a module not available.
    +# THRIFT module not available.
    +# CONFIG_ACPI is not set
     # end of Modules
    +CONFIG_BOARD="nt_22_1737_nrf52840x"
    +CONFIG_BOARD_REVISION=""
    +CONFIG_BOARD_TARGET="nt_22_1737_nrf52840x/nrf52840"
     # CONFIG_NET_DRIVERS is not set
    -CONFIG_BOARD_NT_22_1737_NRF52840=y
    +CONFIG_BOARD_NT_22_1737_NRF52840X=y
    +CONFIG_BOARD_NT_22_1737_NRF52840X_NRF52840=y
    +CONFIG_BOARD_QUALIFIERS="nrf52840"
     # Board Options
     # CONFIG_BOARD_ENABLE_DCDC is not set
     CONFIG_BT_CLI_SERVICE_SECURITY_ENABLE=y
    -# CONFIG_USB_CDC_TERMINAL is not set
    +CONFIG_USB_CDC_TERMINAL=y
    +CONFIG_USE_CCXX_DRIVER=y
    +CONFIG_USE_SX1280_DRIVER=y
    +CONFIG_DEV_TYPE=41
    +CONFIG_USE_MC3479_DRIVER=y
     CONFIG_USE_SPI_NRFX=y
     # end of Board Options
    -# CONFIG_SOC_SERIES_BEETLE is not set
    -# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    -# CONFIG_SOC_SERIES_MPS2 is not set
    -# CONFIG_SOC_SERIES_MPS3 is not set
    -# CONFIG_SOC_SERIES_MUSCA_B1 is not set
    -# CONFIG_SOC_SERIES_MUSCA_S1 is not set
    -# CONFIG_SOC_SERIES_SAM3X is not set
    -# CONFIG_SOC_SERIES_SAM4E is not set
    -# CONFIG_SOC_SERIES_SAM4L is not set
    -# CONFIG_SOC_SERIES_SAM4S is not set
    -# CONFIG_SOC_SERIES_SAME70 is not set
    -# CONFIG_SOC_SERIES_SAMV71 is not set
    -# CONFIG_SOC_SERIES_SAMD20 is not set
    -# CONFIG_SOC_SERIES_SAMD21 is not set
    -# CONFIG_SOC_SERIES_SAMD51 is not set
    -# CONFIG_SOC_SERIES_SAME51 is not set
    -# CONFIG_SOC_SERIES_SAME53 is not set
    -# CONFIG_SOC_SERIES_SAME54 is not set
    -# CONFIG_SOC_SERIES_SAMR21 is not set
    -# CONFIG_SOC_SERIES_VALKYRIE is not set
    -# CONFIG_SOC_SERIES_VIPER is not set
    -# CONFIG_SOC_SERIES_PSOC62 is not set
    -# CONFIG_SOC_SERIES_PSOC63 is not set
    -# CONFIG_SOC_SERIES_XMC_4XXX is not set
    -# CONFIG_SOC_SERIES_MEC1501X is not set
    -# CONFIG_SOC_SERIES_MEC1701X is not set
    -# CONFIG_SOC_SERIES_MEC172X is not set
    -# CONFIG_SOC_SERIES_NRF51X is not set
    -CONFIG_SOC_SERIES_NRF52X=y
    -# CONFIG_SOC_SERIES_NRF53X is not set
    -# CONFIG_SOC_SERIES_NRF91X is not set
    -# CONFIG_SOC_SERIES_NPCX7 is not set
    -# CONFIG_SOC_SERIES_NPCX9 is not set
    -# CONFIG_SOC_SERIES_M48X is not set
    -# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    -# CONFIG_SOC_SERIES_IMX7_M4 is not set
    -# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    -# CONFIG_SOC_SERIES_IMX_RT is not set
    -# CONFIG_SOC_SERIES_IMX_RT6XX is not set
    -# CONFIG_SOC_SERIES_KINETIS_K2X is not set
    -# CONFIG_SOC_SERIES_KINETIS_K6X is not set
    -# CONFIG_SOC_SERIES_KINETIS_K8X is not set
    -# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    -# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    -# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    -# CONFIG_SOC_SERIES_KINETIS_KWX is not set
    -# CONFIG_SOC_SERIES_LPC11U6X is not set
    -# CONFIG_SOC_SERIES_LPC54XXX is not set
    -# CONFIG_SOC_SERIES_LPC55XXX is not set
    -# CONFIG_SOC_EOS_S3 is not set
    -# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    -# CONFIG_SOC_SERIES_EFM32GG11B is not set
    -# CONFIG_SOC_SERIES_EFM32HG is not set
    -# CONFIG_SOC_SERIES_EFM32JG12B is not set
    -# CONFIG_SOC_SERIES_EFM32PG12B is not set
    -# CONFIG_SOC_SERIES_EFM32PG1B is not set
    -# CONFIG_SOC_SERIES_EFM32WG is not set
    -# CONFIG_SOC_SERIES_EFR32BG13P is not set
    -# CONFIG_SOC_SERIES_EFR32FG13P is not set
    -# CONFIG_SOC_SERIES_EFR32FG1P is not set
    -# CONFIG_SOC_SERIES_EFR32MG12P is not set
    -# CONFIG_SOC_SERIES_EFR32MG21 is not set
    -# CONFIG_SOC_SERIES_STM32F0X is not set
    -# CONFIG_SOC_SERIES_STM32F1X is not set
    -# CONFIG_SOC_SERIES_STM32F2X is not set
    -# CONFIG_SOC_SERIES_STM32F3X is not set
    -# CONFIG_SOC_SERIES_STM32F4X is not set
    -# CONFIG_SOC_SERIES_STM32F7X is not set
    -# CONFIG_SOC_SERIES_STM32G0X is not set
    -# CONFIG_SOC_SERIES_STM32G4X is not set
    -# CONFIG_SOC_SERIES_STM32H7X is not set
    -# CONFIG_SOC_SERIES_STM32L0X is not set
    -# CONFIG_SOC_SERIES_STM32L1X is not set
    -# CONFIG_SOC_SERIES_STM32L4X is not set
    -# CONFIG_SOC_SERIES_STM32L5X is not set
    -# CONFIG_SOC_SERIES_STM32MP1X is not set
    -# CONFIG_SOC_SERIES_STM32U5X is not set
    -# CONFIG_SOC_SERIES_STM32WBX is not set
    -# CONFIG_SOC_SERIES_STM32WLX is not set
    -# CONFIG_SOC_TI_LM3S6965 is not set
    -# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    -# CONFIG_SOC_SERIES_CC32XX is not set
    -# CONFIG_SOC_SERIES_MSP432P4XX is not set
    -# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
     # Hardware Configuration
    -CONFIG_CPU_HAS_ARM_MPU=y
    -CONFIG_HAS_SWO=y
     CONFIG_SOC_FAMILY="nordic_nrf"
    -CONFIG_SOC_FAMILY_NRF=y
    +CONFIG_SOC_FAMILY_NORDIC_NRF=y
    +CONFIG_SOC_SERIES_NRF52X=y
    +CONFIG_SOC_NRF52840=y
    +CONFIG_SOC_NRF52840_QIAA=y
    +# CONFIG_MFD is not set
    +# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
     CONFIG_HAS_HW_NRF_ACL=y
     CONFIG_HAS_HW_NRF_CC310=y
     CONFIG_HAS_HW_NRF_CCM=y
     CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
     CONFIG_HAS_HW_NRF_CLOCK=y
    -CONFIG_HAS_HW_NRF_COMP=y
     CONFIG_HAS_HW_NRF_ECB=y
     CONFIG_HAS_HW_NRF_EGU0=y
     CONFIG_HAS_HW_NRF_EGU1=y
    @@ -814,40 +1247,18 @@
     CONFIG_HAS_HW_NRF_EGU5=y
     CONFIG_HAS_HW_NRF_GPIO0=y
     CONFIG_HAS_HW_NRF_GPIO1=y
    -CONFIG_HAS_HW_NRF_GPIOTE=y
    -CONFIG_HAS_HW_NRF_I2S=y
    -CONFIG_HAS_HW_NRF_LPCOMP=y
    +CONFIG_HAS_HW_NRF_GPIOTE0=y
     CONFIG_HAS_HW_NRF_MWU=y
    -CONFIG_HAS_HW_NRF_NFCT=y
     CONFIG_HAS_HW_NRF_NVMC_PE=y
    -CONFIG_HAS_HW_NRF_PDM=y
     CONFIG_HAS_HW_NRF_POWER=y
     CONFIG_HAS_HW_NRF_PPI=y
    -CONFIG_HAS_HW_NRF_PWM0=y
    -CONFIG_HAS_HW_NRF_PWM1=y
    -CONFIG_HAS_HW_NRF_PWM2=y
    -CONFIG_HAS_HW_NRF_PWM3=y
    -CONFIG_HAS_HW_NRF_QDEC=y
    -CONFIG_HAS_HW_NRF_QSPI=y
     CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    -CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
     CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
     CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    +CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
     CONFIG_HAS_HW_NRF_RNG=y
    -CONFIG_HAS_HW_NRF_RTC0=y
    -CONFIG_HAS_HW_NRF_RTC1=y
    -CONFIG_HAS_HW_NRF_RTC2=y
    -CONFIG_HAS_HW_NRF_SAADC=y
    -CONFIG_HAS_HW_NRF_SPI0=y
    -CONFIG_HAS_HW_NRF_SPI1=y
    -CONFIG_HAS_HW_NRF_SPI2=y
     CONFIG_HAS_HW_NRF_SPIM0=y
     CONFIG_HAS_HW_NRF_SPIM1=y
    -CONFIG_HAS_HW_NRF_SPIM2=y
    -CONFIG_HAS_HW_NRF_SPIM3=y
    -CONFIG_HAS_HW_NRF_SPIS0=y
    -CONFIG_HAS_HW_NRF_SPIS1=y
    -CONFIG_HAS_HW_NRF_SPIS2=y
     CONFIG_HAS_HW_NRF_SWI0=y
     CONFIG_HAS_HW_NRF_SWI1=y
     CONFIG_HAS_HW_NRF_SWI2=y
    @@ -855,66 +1266,48 @@
     CONFIG_HAS_HW_NRF_SWI4=y
     CONFIG_HAS_HW_NRF_SWI5=y
     CONFIG_HAS_HW_NRF_TEMP=y
    -CONFIG_HAS_HW_NRF_TIMER0=y
    -CONFIG_HAS_HW_NRF_TIMER1=y
    -CONFIG_HAS_HW_NRF_TIMER2=y
    -CONFIG_HAS_HW_NRF_TIMER3=y
    -CONFIG_HAS_HW_NRF_TIMER4=y
    -CONFIG_HAS_HW_NRF_TWI0=y
    -CONFIG_HAS_HW_NRF_TWI1=y
    -CONFIG_HAS_HW_NRF_TWIM0=y
    -CONFIG_HAS_HW_NRF_TWIM1=y
    -CONFIG_HAS_HW_NRF_TWIS0=y
    -CONFIG_HAS_HW_NRF_TWIS1=y
    -CONFIG_HAS_HW_NRF_UART0=y
     CONFIG_HAS_HW_NRF_UARTE0=y
    -CONFIG_HAS_HW_NRF_UARTE1=y
     CONFIG_HAS_HW_NRF_USBD=y
    -CONFIG_HAS_HW_NRF_WDT=y
    -CONFIG_NRF_HW_RTC1_RESERVED=y
    -CONFIG_SOC_NRF52840=y
    -# CONFIG_SOC_NRF52805_CAAA is not set
    -# CONFIG_SOC_NRF52810_QFAA is not set
    -# CONFIG_SOC_NRF52811_QFAA is not set
    -# CONFIG_SOC_NRF52820_QDAA is not set
    -# CONFIG_SOC_NRF52832_CIAA is not set
    -# CONFIG_SOC_NRF52832_QFAA is not set
    -# CONFIG_SOC_NRF52832_QFAB is not set
    -# CONFIG_SOC_NRF52833_QIAA is not set
    -CONFIG_SOC_NRF52840_QIAA=y
    -CONFIG_GPIO_AS_PINRESET=y
    +CONFIG_HAS_HW_NRF_WDT0=y
    +# CONFIG_GPIO_AS_PINRESET is not set
     CONFIG_NRF_ENABLE_ICACHE=y
    +CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    +CONFIG_NRF_SOC_SECURE_SUPPORTED=y
     # CONFIG_NFCT_PINS_AS_GPIOS is not set
    -CONFIG_NRF_APPROTECT_USE_UICR=y
    -# CONFIG_NRF_APPROTECT_LOCK is not set
    +# CONFIG_NRF_APPROTECT_USE_UICR is not set
    +CONFIG_NRF_APPROTECT_LOCK=y
     # CONFIG_NRF_TRACE_PORT is not set
    +CONFIG_GPIO_INIT_PRIORITY=40
     # CONFIG_SOC_LOG_LEVEL_OFF is not set
     # CONFIG_SOC_LOG_LEVEL_ERR is not set
     # CONFIG_SOC_LOG_LEVEL_WRN is not set
    -CONFIG_SOC_LOG_LEVEL_INF=y
    +# CONFIG_SOC_LOG_LEVEL_INF is not set
     # CONFIG_SOC_LOG_LEVEL_DBG is not set
    -CONFIG_SOC_LOG_LEVEL=3
    +CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    +CONFIG_SOC_LOG_LEVEL=0
     # end of Hardware Configuration
     CONFIG_SOC_COMPATIBLE_NRF=y
     CONFIG_SOC_COMPATIBLE_NRF52X=y
    +CONFIG_ARCH="arm"
    +CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    +# CONFIG_EXTRA_EXCEPTION_INFO is not set
    +CONFIG_CPU_CORTEX=y
    +# CONFIG_ARM_MPU is not set
    +CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=4
    +# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
     # ARM Options
    -CONFIG_ARCH="arm"
    -CONFIG_CPU_CORTEX=y
    -# CONFIG_CODE_DATA_RELOCATION is not set
    -# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
     CONFIG_CPU_CORTEX_M=y
    +# CONFIG_ARM_ZIMAGE_HEADER is not set
     CONFIG_ISA_THUMB2=y
     CONFIG_ASSEMBLER_ISA_THUMB2=y
     CONFIG_COMPILER_ISA_THUMB2=y
     CONFIG_STACK_ALIGN_DOUBLE_WORD=y
     # CONFIG_RUNTIME_NMI is not set
    -CONFIG_PLATFORM_SPECIFIC_INIT=y
     CONFIG_FAULT_DUMP=2
    -CONFIG_ARM_STACK_PROTECTION=y
     CONFIG_FP16=y
     CONFIG_FP16_IEEE=y
     # CONFIG_FP16_ALT is not set
    @@ -928,24 +1321,18 @@
     CONFIG_ARMV7_M_ARMV8_M_FP=y
    -# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    +# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    -CONFIG_GEN_ISR_TABLES=y
     # CONFIG_ZERO_LATENCY_IRQS is not set
     # CONFIG_SW_VECTOR_RELAY is not set
     # CONFIG_CORTEX_M_DWT is not set
    -# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    +# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    +# CONFIG_TRAP_UNALIGNED_ACCESS is not set
    +# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
     CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
     # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    -# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    -CONFIG_GEN_IRQ_VECTOR_TABLE=y
    -CONFIG_ARM_MPU=y
    -CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    -CONFIG_MPU_STACK_GUARD=y
    -CONFIG_MPU_ALLOW_FLASH_WRITE=y
    -# CONFIG_CUSTOM_SECTION_ALIGN is not set
    -CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    +CONFIG_HAS_SWO=y
     # end of ARM Options
     CONFIG_ARM=y
    @@ -954,54 +1341,49 @@
     # General Architecture Options
    +# CONFIG_SEMIHOST is not set
     # CONFIG_ARCH_LOG_LEVEL_OFF is not set
     # CONFIG_ARCH_LOG_LEVEL_ERR is not set
     # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    -CONFIG_ARCH_LOG_LEVEL_INF=y
    +# CONFIG_ARCH_LOG_LEVEL_INF is not set
     # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    -CONFIG_ARCH_LOG_LEVEL=3
    -# CONFIG_MPU_LOG_LEVEL_OFF is not set
    -# CONFIG_MPU_LOG_LEVEL_ERR is not set
    -# CONFIG_MPU_LOG_LEVEL_WRN is not set
    -CONFIG_MPU_LOG_LEVEL_INF=y
    -# CONFIG_MPU_LOG_LEVEL_DBG is not set
    -CONFIG_MPU_LOG_LEVEL=3
    -CONFIG_HW_STACK_PROTECTION=y
    -# CONFIG_USERSPACE is not set
    -CONFIG_KOBJECT_TEXT_AREA=256
    -CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    -CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    +CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    +CONFIG_ARCH_LOG_LEVEL=0
    +CONFIG_LITTLE_ENDIAN=y
     CONFIG_GEN_PRIV_STACKS=y
     # CONFIG_STACK_GROWS_UP is not set
     # Interrupt Configuration
    -# CONFIG_DYNAMIC_INTERRUPTS is not set
    -CONFIG_GEN_SW_ISR_TABLE=y
    -CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
    -CONFIG_GEN_IRQ_START_VECTOR=0
    -# CONFIG_EXTRA_EXCEPTION_INFO is not set
    +CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    +# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    +CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    +# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    +CONFIG_EXCEPTION_DEBUG=y
    +# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
     # end of Interrupt Configuration
     # end of General Architecture Options
    -CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
     CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    -CONFIG_ARCH_HAS_STACK_PROTECTION=y
    -CONFIG_ARCH_HAS_USERSPACE=y
    -CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
     CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
     CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
     CONFIG_ARCH_SUPPORTS_COREDUMP=y
     CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    +CONFIG_ARCH_SUPPORTS_ROM_START=y
     CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
     CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    +CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
     CONFIG_ARCH_HAS_THREAD_ABORT=y
    +CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
     CONFIG_CPU_HAS_FPU=y
     CONFIG_CPU_HAS_MPU=y
    -CONFIG_MPU=y
    -CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    -CONFIG_SRAM_REGION_PERMISSIONS=y
    +# CONFIG_MPU is not set
    +# DSP Options
    +# end of DSP Options
     # Floating Point Options
    @@ -1011,10 +1393,10 @@
     # Cache Options
    -# CONFIG_CACHE_MANAGEMENT is not set
     # end of Cache Options
     CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    +# CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
     # General Kernel Options
    @@ -1022,9 +1404,10 @@
     # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
     # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
     # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    -CONFIG_KERNEL_LOG_LEVEL_INF=y
    +# CONFIG_KERNEL_LOG_LEVEL_INF is not set
     # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    -CONFIG_KERNEL_LOG_LEVEL=3
    +CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    +CONFIG_KERNEL_LOG_LEVEL=0
     CONFIG_NUM_COOP_PRIORITIES=16
     CONFIG_NUM_PREEMPT_PRIORITIES=15
     CONFIG_MAIN_THREAD_PRIORITY=0
    @@ -1032,18 +1415,19 @@
     CONFIG_PREEMPT_ENABLED=y
     CONFIG_PRIORITY_CEILING=-127
     # CONFIG_SCHED_DEADLINE is not set
    -# CONFIG_SCHED_CPU_MASK is not set
    -CONFIG_IDLE_STACK_SIZE=320
    -CONFIG_ISR_STACK_SIZE=2048
    -CONFIG_THREAD_STACK_INFO=y
    +# CONFIG_THREAD_STACK_INFO is not set
     # CONFIG_THREAD_CUSTOM_DATA is not set
    -CONFIG_ERRNO=y
     CONFIG_SCHED_DUMB=y
     # CONFIG_SCHED_SCALABLE is not set
     # CONFIG_SCHED_MULTIQ is not set
     # CONFIG_WAITQ_SCALABLE is not set
     CONFIG_WAITQ_DUMB=y
    -CONFIG_DEVICE_HANDLE_PADDING=0
    +# Misc Kernel related options
    +CONFIG_ERRNO=y
    +# end of Misc Kernel related options
     # Kernel Debugging and Metrics
    @@ -1054,12 +1438,19 @@
     # CONFIG_THREAD_RUNTIME_STATS is not set
     # end of Kernel Debugging and Metrics
    +# CONFIG_OBJ_CORE is not set
    -# Work Queue Options
    +# System Work Queue Options
    -CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
     # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    -# end of Work Queue Options
    +# end of System Work Queue Options
    +# Barrier Operations
    +CONFIG_BARRIER_OPERATIONS_ARCH=y
    +# end of Barrier Operations
     # Atomic Operations
    @@ -1073,162 +1464,87 @@
     CONFIG_TIMESLICING=y
     CONFIG_TIMESLICE_SIZE=0
     CONFIG_TIMESLICE_PRIORITY=0
    -# CONFIG_POLL is not set
    +# CONFIG_TIMESLICE_PER_THREAD is not set
     # end of Timer API Options
     # Other Kernel Object Options
    +# CONFIG_POLL is not set
     # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
     CONFIG_NUM_MBOX_ASYNC_MSGS=10
    -CONFIG_NUM_PIPE_ASYNC_MSGS=10
    +# CONFIG_EVENTS is not set
    +# CONFIG_PIPES is not set
     CONFIG_KERNEL_MEM_POOL=y
    +# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
     # end of Other Kernel Object Options
     CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
     CONFIG_SWAP_NONATOMIC=y
     CONFIG_SYS_CLOCK_EXISTS=y
     CONFIG_TIMEOUT_64BIT=y
    -CONFIG_XIP=y
    +CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    -# Initialization Priorities
    +# Security Options
    -CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    -CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    -CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    -CONFIG_APPLICATION_INIT_PRIORITY=90
    -# end of Initialization Priorities
    +# CONFIG_STACK_CANARIES is not set
    +CONFIG_STACK_POINTER_RANDOM=0
    +# end of Security Options
    -# Security Options
    +# Memory Domains
    -# end of Security Options
    +# end of Memory Domains
     # SMP Options
     CONFIG_MP_NUM_CPUS=1
    +# CONFIG_TICKET_SPINLOCKS is not set
     # end of SMP Options
    -CONFIG_TICKLESS_KERNEL=y
    +CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    +# CONFIG_THREAD_LOCAL_STORAGE is not set
     # end of General Kernel Options
    -CONFIG_HAS_DTS=y
    -CONFIG_HAS_DTS_GPIO=y
    -CONFIG_HAS_DTS_WDT=y
    -# Device Drivers
    +# Device Options
    -# CONFIG_IEEE802154 is not set
    -# CONFIG_LORA is not set
    -# CONFIG_CONSOLE is not set
    -CONFIG_HAS_SEGGER_RTT=y
    -CONFIG_USE_SEGGER_RTT=y
    -# CONFIG_SEGGER_RTT_CUSTOM_LOCKING is not set
    -CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    -CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    -CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    -CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    -CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    -CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    -# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    -# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    -CONFIG_SEGGER_RTT_MODE=0
    -# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    -CONFIG_SEGGER_RTT_SECTION_NONE=y
    -# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    -# CONFIG_EC_HOST_CMD_PERIPH is not set
    -# CONFIG_MDIO is not set
    +# CONFIG_DEVICE_DEPS is not set
    +# CONFIG_DEVICE_MUTABLE is not set
    +# end of Device Options
    -# Interrupt Controllers
    +# Initialization Priorities
    -# CONFIG_SWERV_PIC is not set
    -# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    -# CONFIG_INTC_ESP32 is not set
    -# end of Interrupt Controllers
    +CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    +CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    +CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    +CONFIG_APPLICATION_INIT_PRIORITY=90
    +# end of Initialization Priorities
    -# Timer Drivers
    +# Virtual Memory Support
    -# CONFIG_HPET_TIMER is not set
    -CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    -# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    -# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    -CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    -CONFIG_SYSTEM_CLOCK_DISABLE=y
    -# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    -# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    -CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    -CONFIG_TICKLESS_CAPABLE=y
    -# end of Timer Drivers
    +# end of Virtual Memory Support
    -# CONFIG_PCIE is not set
    -# CONFIG_PCIE_ENDPOINT is not set
    -# CONFIG_GPIO_LOG_LEVEL_OFF is not set
    -# CONFIG_GPIO_LOG_LEVEL_ERR is not set
    -# CONFIG_GPIO_LOG_LEVEL_WRN is not set
    -CONFIG_GPIO_LOG_LEVEL_INF=y
    -# CONFIG_GPIO_LOG_LEVEL_DBG is not set
    -CONFIG_GPIO_LOG_LEVEL=3
    -# CONFIG_GPIO_DW is not set
    -# CONFIG_GPIO_MCP23S17 is not set
    -CONFIG_GPIO_NRFX=y
    -CONFIG_GPIO_NRF_INIT_PRIORITY=40
    -CONFIG_GPIO_NRF_P0=y
    -CONFIG_GPIO_NRF_INT_EDGE_USING_GPIOTE=y
    -# CONFIG_GPIO_NRF_INT_EDGE_USING_SENSE is not set
    -# CONFIG_GPIO_ITE_IT8XXX2 is not set
    -# CONFIG_GPIO_INTEL is not set
    -# CONFIG_GPIO_XLNX_AXI is not set
    -# CONFIG_GPIO_EMUL is not set
    -# CONFIG_GPIO_SNPS_CREG is not set
    -# CONFIG_FXL6408_LOG_LEVEL_OFF is not set
    -# CONFIG_FXL6408_LOG_LEVEL_ERR is not set
    -# CONFIG_FXL6408_LOG_LEVEL_WRN is not set
    -CONFIG_FXL6408_LOG_LEVEL_INF=y
    -# CONFIG_FXL6408_LOG_LEVEL_DBG is not set
    -CONFIG_FXL6408_LOG_LEVEL=3
    -# CONFIG_SHARED_IRQ is not set
    -# CONFIG_SPI_ASYNC is not set
    -# CONFIG_SPI_SLAVE is not set
    -CONFIG_SPI_INIT_PRIORITY=70
    -CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    -# CONFIG_SPI_LOG_LEVEL_OFF is not set
    -# CONFIG_SPI_LOG_LEVEL_ERR is not set
    -# CONFIG_SPI_LOG_LEVEL_WRN is not set
    -CONFIG_SPI_LOG_LEVEL_INF=y
    -# CONFIG_SPI_LOG_LEVEL_DBG is not set
    -CONFIG_SPI_LOG_LEVEL=3
    -# CONFIG_SPI_EMUL is not set
    -CONFIG_SPI_NRFX=y
    -CONFIG_SPI_1_NRF_SPIM=y
    -CONFIG_SPI_1_NRF_ORC=0xff
    -CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    -# CONFIG_SPI_OC_SIMPLE is not set
    -# CONFIG_SPI_XLNX_AXI_QUADSPI is not set
    -# CONFIG_I2S is not set
    -# CONFIG_PWM is not set
    -# CONFIG_PINMUX is not set
    +# Device Drivers
     # CONFIG_ADC is not set
    -# CONFIG_DAC is not set
    -# CONFIG_WDT_DISABLE_AT_BOOT is not set
    -# CONFIG_WDT_LOG_LEVEL_OFF is not set
    -# CONFIG_WDT_LOG_LEVEL_ERR is not set
    -# CONFIG_WDT_LOG_LEVEL_WRN is not set
    -CONFIG_WDT_LOG_LEVEL_INF=y
    -# CONFIG_WDT_LOG_LEVEL_DBG is not set
    -CONFIG_WDT_LOG_LEVEL=3
    -CONFIG_WDT_NRFX=y
    -CONFIG_WDT_ITE_WARNING_LEADING_TIME_MS=500
    +# CONFIG_AUDIO is not set
    +# CONFIG_AUXDISPLAY is not set
    +# CONFIG_BBRAM is not set
    +# CONFIG_CAN is not set
    +# CONFIG_CHARGER is not set
     # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
     # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
     # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    -CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
    +# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
     # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    -CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    +CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    +CONFIG_CLOCK_CONTROL_LOG_LEVEL=0
     CONFIG_CLOCK_CONTROL_NRF=y
     # CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL is not set
    @@ -1236,6 +1552,7 @@
     # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
     # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
     CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
    +CONFIG_CLOCK_CONTROL_NRF_DRIVER_CALIBRATION=y
     CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=y
     CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_PERIOD=4000
     CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=1
    @@ -1251,139 +1568,303 @@
     # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
     # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
     CONFIG_CLOCK_CONTROL_NRF_ACCURACY=250
    -# CONFIG_PTP_CLOCK is not set
    -# CONFIG_IPM is not set
    +# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    +# CONFIG_COREDUMP_DEVICE is not set
    +# CONFIG_CRYPTO is not set
    +# CONFIG_DAC is not set
    +# CONFIG_DAI is not set
    +# CONFIG_DISK_DRIVERS is not set
    +# CONFIG_DISPLAY is not set
    +# CONFIG_DMA is not set
    +# CONFIG_EDAC is not set
    +# CONFIG_EEPROM is not set
    +CONFIG_ENTROPY_GENERATOR=y
    +# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    +# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    +# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    +# CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    +# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    +CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    +CONFIG_ENTROPY_LOG_LEVEL=0
    +CONFIG_ENTROPY_NRF5_RNG=y
    +CONFIG_ENTROPY_NRF5_BIAS_CORRECTION=y
    +CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    +CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    +CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    +CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    +CONFIG_ENTROPY_HAS_DRIVER=y
    +# CONFIG_ESPI is not set
     CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    +CONFIG_FLASH_HAS_EX_OP=y
     CONFIG_FLASH_HAS_PAGE_LAYOUT=y
     CONFIG_FLASH_JESD216=y
    -# CONFIG_FLASH_JESD216_API is not set
    +CONFIG_FLASH=y
     # CONFIG_FLASH_LOG_LEVEL_OFF is not set
     # CONFIG_FLASH_LOG_LEVEL_ERR is not set
     # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    -CONFIG_FLASH_LOG_LEVEL_INF=y
    +# CONFIG_FLASH_LOG_LEVEL_INF is not set
     # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    -CONFIG_FLASH_LOG_LEVEL=3
    +CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    +CONFIG_FLASH_LOG_LEVEL=0
    +# CONFIG_FLASH_JESD216_API is not set
     CONFIG_FLASH_PAGE_LAYOUT=y
    -# CONFIG_SPI_FLASH_AT45 is not set
    +# CONFIG_FLASH_EX_OP_ENABLED is not set
     CONFIG_SOC_FLASH_NRF=y
     CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
     # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
     # CONFIG_SOC_FLASH_NRF_UICR is not set
     # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    -CONFIG_SPI_NOR=y
     CONFIG_SPI_NOR_SFDP_MINIMAL=y
     # CONFIG_SPI_NOR_SFDP_DEVICETREE is not set
     # CONFIG_SPI_NOR_SFDP_RUNTIME is not set
     CONFIG_SPI_NOR_INIT_PRIORITY=80
     CONFIG_SPI_NOR_CS_WAIT_DELAY=0
    +CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY=y
     CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
     # CONFIG_SPI_NOR_IDLE_IN_DPD is not set
    -# CONFIG_FLASH_SIMULATOR is not set
    +# CONFIG_FPGA is not set
    +# CONFIG_FUEL_GAUGE is not set
    +# CONFIG_GNSS is not set
    +# CONFIG_GPIO_LOG_LEVEL_OFF is not set
    +# CONFIG_GPIO_LOG_LEVEL_ERR is not set
    +# CONFIG_GPIO_LOG_LEVEL_WRN is not set
    +# CONFIG_GPIO_LOG_LEVEL_INF is not set
    +# CONFIG_GPIO_LOG_LEVEL_DBG is not set
    +CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    +CONFIG_GPIO_LOG_LEVEL=0
    +# CONFIG_GPIO_GET_DIRECTION is not set
    +# CONFIG_GPIO_GET_CONFIG is not set
    +# CONFIG_GPIO_HOGS is not set
    +# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    +CONFIG_GPIO_NRFX=y
    +CONFIG_GPIO_NRFX_INTERRUPT=y
    +# CONFIG_HWINFO is not set
    +# CONFIG_HWSPINLOCK is not set
    +# CONFIG_I2C is not set
    +# CONFIG_I2S is not set
    +# CONFIG_I3C is not set
    +# Interrupt controller drivers
    +CONFIG_INTC_INIT_PRIORITY=40
    +# CONFIG_INTC_LOG_LEVEL_OFF is not set
    +# CONFIG_INTC_LOG_LEVEL_ERR is not set
    +# CONFIG_INTC_LOG_LEVEL_WRN is not set
    +# CONFIG_INTC_LOG_LEVEL_INF is not set
    +# CONFIG_INTC_LOG_LEVEL_DBG is not set
    +CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    +CONFIG_INTC_LOG_LEVEL=0
    +# CONFIG_INTC_ESP32 is not set
    +# end of Interrupt controller drivers
    +# CONFIG_IPM is not set
    +# CONFIG_KSCAN is not set
    +# CONFIG_LED is not set
    +# CONFIG_LED_STRIP is not set
    +# CONFIG_LORA is not set
    +# CONFIG_MDIO is not set
    +# CONFIG_MIPI_DBI is not set
    +# Miscellaneous Drivers
    +# CONFIG_TIMEAWARE_GPIO is not set
    +# end of Miscellaneous Drivers
    +# CONFIG_MM_DRV is not set
    +# CONFIG_PCIE is not set
    +# CONFIG_PCIE_ENDPOINT is not set
    +# CONFIG_PECI is not set
    +# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    +# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    +# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    +# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    +# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    +CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    +CONFIG_PINCTRL_LOG_LEVEL=0
    +CONFIG_PINCTRL_STORE_REG=y
    +# CONFIG_PINCTRL_DYNAMIC is not set
    +CONFIG_PINCTRL_NRF=y
    +# CONFIG_PM_CPU_OPS is not set
    +# CONFIG_PS2 is not set
    +# CONFIG_PTP_CLOCK is not set
    +# CONFIG_PWM is not set
    +# CONFIG_REGULATOR is not set
    +# CONFIG_RETAINED_MEM is not set
    +# CONFIG_RTC is not set
    +# CONFIG_SDHC is not set
     # CONFIG_SENSOR_LOG_LEVEL_OFF is not set
     # CONFIG_SENSOR_LOG_LEVEL_ERR is not set
     # CONFIG_SENSOR_LOG_LEVEL_WRN is not set
    -CONFIG_SENSOR_LOG_LEVEL_INF=y
    +# CONFIG_SENSOR_LOG_LEVEL_INF is not set
     # CONFIG_SENSOR_LOG_LEVEL_DBG is not set
    -CONFIG_SENSOR_LOG_LEVEL=3
    +CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y
    +CONFIG_SENSOR_LOG_LEVEL=0
     CONFIG_SENSOR_INIT_PRIORITY=90
    +# CONFIG_SENSOR_ASYNC_API is not set
    +# CONFIG_SENSOR_INFO is not set
     # Device Drivers
    -# CONFIG_ADXL362 is not set
    -# CONFIG_ADXL372 is not set
    -# CONFIG_BME280 is not set
    -# CONFIG_BMI160 is not set
    -# CONFIG_BMP388 is not set
    -# CONFIG_DHT is not set
    -# CONFIG_GROVE_SENSORS is not set
    -# CONFIG_ICM42605 is not set
    -# CONFIG_IIS2DH is not set
    -# CONFIG_IIS2DLPC is not set
    -# CONFIG_IIS2ICLX is not set
    -# CONFIG_IIS2MDC is not set
    -# CONFIG_IIS3DHHC is not set
    -# CONFIG_ISM330DHCX is not set
    -# CONFIG_LIS2DH is not set
    -# CONFIG_LIS2DS12 is not set
    -# CONFIG_LIS2DW12 is not set
    -# CONFIG_LIS2MDL is not set
    -# CONFIG_LPS22HH is not set
    -# CONFIG_LSM6DSL is not set
    -# CONFIG_LSM6DSO is not set
    -# CONFIG_MAX6675 is not set
    -# CONFIG_MS5607 is not set
     CONFIG_TEMP_NRF5=y
    -# CONFIG_QDEC_NRFX is not set
    -# CONFIG_SM351LT is not set
    -# CONFIG_COUNTER is not set
    -# CONFIG_DMA is not set
    -# CONFIG_USB_DEVICE_DRIVER is not set
    -# CONFIG_CRYPTO is not set
    -# CONFIG_DISPLAY is not set
    -# CONFIG_LED_STRIP is not set
    -# CONFIG_LED is not set
    -# CONFIG_CAN is not set
    -# CONFIG_AUDIO is not set
    -# CONFIG_NEURAL_NET_ACCEL is not set
    -# CONFIG_HWINFO is not set
    -# CONFIG_ESPI is not set
    -# CONFIG_PS2 is not set
    -# CONFIG_VIDEO is not set
    -# CONFIG_EEPROM is not set
    -# CONFIG_PECI is not set
    -# CONFIG_PECI_INTERRUPT_DRIVEN is not set
    -# CONFIG_REGULATOR is not set
    -# CONFIG_MEMC is not set
    -# CONFIG_VIRTUALIZATION is not set
    -# CONFIG_EDAC is not set
    -# CONFIG_PM_CPU_OPS is not set
    +# CONFIG_SMBUS is not set
    +# CONFIG_SPI_ASYNC is not set
    +# CONFIG_SPI_RTIO is not set
    +# CONFIG_SPI_SLAVE is not set
    +# CONFIG_SPI_EXTENDED_MODES is not set
    +CONFIG_SPI_INIT_PRIORITY=50
    +CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    +# CONFIG_SPI_LOG_LEVEL_OFF is not set
    +# CONFIG_SPI_LOG_LEVEL_ERR is not set
    +# CONFIG_SPI_LOG_LEVEL_WRN is not set
    +# CONFIG_SPI_LOG_LEVEL_INF is not set
    +# CONFIG_SPI_LOG_LEVEL_DBG is not set
    +CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    +CONFIG_SPI_LOG_LEVEL=0
    +CONFIG_SPI_NRFX=y
    +CONFIG_SPI_NRFX_SPIM=y
    +CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    +CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    -# Miscellaneous Drivers
    +# Timer drivers
    -# end of Miscellaneous Drivers
    +# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    +# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    +CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    +CONFIG_TICKLESS_CAPABLE=y
    +CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    +# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    +# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    +# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    +CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    +# end of Timer drivers
    -# CONFIG_DISK_DRIVERS is not set
    -# CONFIG_CACHE is not set
    -# CONFIG_SYSCON is not set
    -# CONFIG_BBRAM is not set
    -# CONFIG_FPGA is not set
    +# CONFIG_USB_BC12 is not set
    +# CONFIG_UDC_DRIVER is not set
    +# CONFIG_UHC_DRIVER is not set
    +# CONFIG_UVB is not set
    +# CONFIG_USB_DEVICE_DRIVER is not set
    +# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    +# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    +# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    +# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    +# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    +CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    +CONFIG_NRF_USBD_COMMON_LOG_LEVEL=0
    +# CONFIG_NRF_USBD_COMMON is not set
    +# CONFIG_USBC_TCPC_DRIVER is not set
    +# CONFIG_USBC_LOG_LEVEL_OFF is not set
    +# CONFIG_USBC_LOG_LEVEL_ERR is not set
    +# CONFIG_USBC_LOG_LEVEL_WRN is not set
    +# CONFIG_USBC_LOG_LEVEL_INF is not set
    +# CONFIG_USBC_LOG_LEVEL_DBG is not set
    +CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    +CONFIG_USBC_LOG_LEVEL=0
    +# CONFIG_USBC_VBUS_DRIVER is not set
    +# CONFIG_USBC_PPC_DRIVER is not set
    +# CONFIG_VIDEO is not set
    +# CONFIG_VIRTUALIZATION is not set
    +# CONFIG_W1 is not set
    +# CONFIG_REQUIRES_FULL_LIBC is not set
    +# CONFIG_REQUIRES_FLOAT_PRINTF is not set
    +CONFIG_FULL_LIBC_SUPPORTED=y
    +CONFIG_MINIMAL_LIBC_SUPPORTED=y
    +CONFIG_NEWLIB_LIBC_SUPPORTED=y
    +CONFIG_PICOLIBC_SUPPORTED=y
     # C Library
    -CONFIG_SUPPORT_MINIMAL_LIBC=y
     CONFIG_MINIMAL_LIBC=y
    +# CONFIG_PICOLIBC is not set
     # CONFIG_NEWLIB_LIBC is not set
     # CONFIG_EXTERNAL_LIBC is not set
     CONFIG_HAS_NEWLIB_LIBC_NANO=y
    +CONFIG_COMMON_LIBC_ABORT=y
    +CONFIG_COMMON_LIBC_GMTIME_R=y
    +CONFIG_COMMON_LIBC_MALLOC=y
    +CONFIG_COMMON_LIBC_CALLOC=y
    +CONFIG_COMMON_LIBC_REALLOCARRAY=y
    +CONFIG_COMMON_LIBC_STRNLEN=y
    +CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
     CONFIG_MINIMAL_LIBC_MALLOC=y
    -CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
    +CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=-2
     CONFIG_MINIMAL_LIBC_CALLOC=y
     CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
     # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
    -CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
     # CONFIG_MINIMAL_LIBC_RAND is not set
    +CONFIG_MINIMAL_LIBC_TIME=y
    +# CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
    +CONFIG_NEED_LIBC_MEM_PARTITION=y
     # end of C Library
    +# C++ Language Support
    +# CONFIG_CPP is not set
    +# Deprecated
    +# CONFIG_CPLUSPLUS is not set
    +# CONFIG_LIB_CPLUSPLUS is not set
    +# end of Deprecated
    +# end of C++ Language Support
    +# CONFIG_CRC is not set
     # Additional libraries
    -# CONFIG_LVGL is not set
    -# OS Support Library
    +# Hash Function Support
    +# CONFIG_SYS_HASH_FUNC32 is not set
    +# end of Hash Function Support
    +# Hashmap (Hash Table) Support
    +# CONFIG_SYS_HASH_MAP is not set
    +# end of Hashmap (Hash Table) Support
    +# Heap and Memory Allocation
    -# CONFIG_JSON_LIBRARY is not set
    -# CONFIG_RING_BUFFER is not set
    -# CONFIG_BASE64 is not set
     # CONFIG_SYS_HEAP_VALIDATE is not set
    +# CONFIG_SYS_HEAP_STRESS is not set
    +# CONFIG_SYS_HEAP_INFO is not set
     CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    +# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    +# CONFIG_SYS_HEAP_LISTENER is not set
    +# CONFIG_SYS_HEAP_SMALL_ONLY is not set
    +# CONFIG_SYS_HEAP_BIG_ONLY is not set
    +CONFIG_SYS_HEAP_AUTO=y
    +# CONFIG_MULTI_HEAP is not set
    +# CONFIG_SHARED_MULTI_HEAP is not set
    +# end of Heap and Memory Allocation
    +# Memory Blocks
    +# CONFIG_SYS_MEM_BLOCKS is not set
    +# end of Memory Blocks
    +# OS Support Library
    +# CONFIG_FDTABLE is not set
     # CONFIG_PRINTK_SYNC is not set
     # CONFIG_MPSC_PBUF is not set
    -CONFIG_REBOOT=y
    +# CONFIG_SPSC_PBUF is not set
    +CONFIG_HAS_POWEROFF=y
    +# CONFIG_POWEROFF is not set
     # CONFIG_CBPRINTF_COMPLETE is not set
     CONFIG_CBPRINTF_NANO=y
     CONFIG_CBPRINTF_FULL_INTEGRAL=y
    @@ -1391,40 +1872,111 @@
     # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
     # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
     CONFIG_CBPRINTF_LIBC_SUBSTS=y
    +# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    +# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    +# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    +# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    +# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    +CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    +CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=0
     # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
     # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    +CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
     # end of OS Support Library
    -CONFIG_POSIX_MAX_FDS=4
    +# POSIX API Support
    +# POSIX Options
     # CONFIG_POSIX_API is not set
    -# CONFIG_PTHREAD_IPC is not set
    +# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
     # CONFIG_POSIX_CLOCK is not set
    -CONFIG_MAX_TIMER_COUNT=5
    -# CONFIG_POSIX_MQUEUE is not set
    +# CONFIG_POSIX_CONFSTR is not set
    +# CONFIG_POSIX_ENV is not set
    +# CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set
    +# CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set
    +# CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set
    +# CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set
    +# CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set
    +CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y
    +CONFIG_POSIX_ENV_LOG_LEVEL=0
     # CONFIG_EVENTFD is not set
    -# CONFIG_OPENAMP_RSC_TABLE is not set
    -# Util libraries
    +# File descriptor table options
    +# end of File descriptor table options
     # CONFIG_FNMATCH is not set
    -# CONFIG_GETOPT is not set
    -# end of Util libraries
    +# CONFIG_GETENTROPY is not set
    +# CONFIG_POSIX_MQUEUE is not set
    +# sem_t support
    +CONFIG_SEM_VALUE_MAX=32767
    +CONFIG_SEM_NAMELEN_MAX=16
    +# end of sem_t support
    +# Signal support
    +CONFIG_POSIX_RTSIG_MAX=0
    +# CONFIG_POSIX_SIGNAL is not set
    +# end of Signal support
    +# CONFIG_POSIX_PUTMSG is not set
    +# Sysconf support
    +# CONFIG_POSIX_SYSCONF is not set
    +CONFIG_POSIX_PAGE_SIZE_BITS=6
    +# end of Sysconf support
    +# CONFIG_POSIX_SYSLOG is not set
    +# CONFIG_TIMER is not set
    +# CONFIG_POSIX_UNAME is not set
    +# end of POSIX Options
    +# POSIX Shell Utilities
    +# end of POSIX Shell Utilities
    +# end of POSIX API Support
    +# CONFIG_OPENAMP_RSC_TABLE is not set
    +# CONFIG_SMF is not set
    +CONFIG_LIBGCC_RTLIB=y
    +# Utility Library
    +# CONFIG_JSON_LIBRARY is not set
    +# CONFIG_RING_BUFFER is not set
    +CONFIG_NOTIFY=y
    +# CONFIG_BASE64 is not set
    +CONFIG_ONOFF=y
    +# CONFIG_WINSTREAM is not set
    +# CONFIG_UTF8 is not set
    +# end of Utility Library
     # end of Additional libraries
    -# Sub Systems and OS Services
    +# Subsystems and OS Services
    +# CONFIG_BINDESC is not set
     # CONFIG_BT is not set
     # Controller Area Network (CAN) bus subsystem
    -# CONFIG_ISOTP is not set
     # end of Controller Area Network (CAN) bus subsystem
     # CONFIG_CONSOLE_SUBSYS is not set
    -# CONFIG_CPLUSPLUS is not set
     # System Monitoring Options
    @@ -1439,21 +1991,23 @@
     # CONFIG_STACK_USAGE is not set
     # CONFIG_STACK_SENTINEL is not set
     CONFIG_PRINTK=y
    -# CONFIG_EARLY_CONSOLE is not set
    +CONFIG_EARLY_CONSOLE=y
     # CONFIG_ASSERT is not set
     # CONFIG_FORCE_NO_ASSERT is not set
     CONFIG_ASSERT_VERBOSE=y
     # CONFIG_ASSERT_NO_FILE_INFO is not set
     # CONFIG_ASSERT_NO_COND_INFO is not set
     # CONFIG_ASSERT_NO_MSG_INFO is not set
    +# CONFIG_ASSERT_TEST is not set
     # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
     # CONFIG_DEBUG_INFO is not set
    -# CONFIG_OPENOCD_SUPPORT is not set
     # CONFIG_DEBUG_THREAD_INFO is not set
     # CONFIG_DEBUG_COREDUMP is not set
     # end of Debugging Options
    +# CONFIG_MIPI_STP_DECODER is not set
     # CONFIG_DISK_ACCESS is not set
    +# CONFIG_DSP is not set
     # CONFIG_EMUL is not set
     # CONFIG_CHARACTER_FRAMEBUFFER is not set
    @@ -1469,35 +2023,60 @@
     # Inter Processor Communication
     # CONFIG_RPMSG_SERVICE is not set
    -# CONFIG_RPMSG_MULTI_INSTANCE is not set
     # CONFIG_IPC_SERVICE is not set
     # end of Inter Processor Communication
     # CONFIG_JWT is not set
    -CONFIG_LOG=y
    +# CONFIG_LLEXT is not set
    +# Linkable loadable Extension Development Kit (EDK)
    +CONFIG_LLEXT_EDK_NAME="llext-edk"
    +# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
    +# end of Linkable loadable Extension Development Kit (EDK)
    +# Logging
    +CONFIG_LOG_CORE_INIT_PRIORITY=0
     # CONFIG_LOG_MODE_DEFERRED is not set
    -# CONFIG_LOG2_MODE_DEFERRED is not set
    -# CONFIG_LOG2_MODE_IMMEDIATE is not set
     # CONFIG_LOG_MODE_IMMEDIATE is not set
     CONFIG_LOG_MODE_MINIMAL=y
     # CONFIG_LOG_FRONTEND is not set
    -CONFIG_LOG_MINIMAL=y
    +# CONFIG_LOG_FRONTEND_OPT_API is not set
    +# CONFIG_LOG_CUSTOM_HEADER is not set
    +# CONFIG_LOG_MULTIDOMAIN is not set
     # Logging levels filtering
    +CONFIG_LOG_DEFAULT_LEVEL=0
     CONFIG_LOG_OVERRIDE_LEVEL=0
     CONFIG_LOG_MAX_LEVEL=4
     # end of Logging levels filtering
    +# Processing
    +# end of Processing
     # Misc
    -CONFIG_LOG2_USE_VLA=y
    -# CONFIG_LOG2_ALWAYS_RUNTIME is not set
    -# CONFIG_LOG2_FMT_SECTION is not set
    +CONFIG_LOG_USE_VLA=y
    +CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    +# CONFIG_LOG_ALWAYS_RUNTIME is not set
    +# CONFIG_LOG_FMT_SECTION is not set
    +# CONFIG_LOG_FMT_STRING_VALIDATE is not set
    +# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
     # end of Misc
    +# CONFIG_LOG_OUTPUT is not set
    +# end of Logging
    +# CONFIG_MEM_ATTR is not set
     # Device Management
    @@ -1508,13 +2087,11 @@
     # CONFIG_EC_HOST_CMD is not set
     # end of Host command handler subsystem
    -# CONFIG_MCUMGR is not set
    -# CONFIG_HAWKBIT is not set
    -# CONFIG_UPDATEHUB is not set
     # CONFIG_OSDP is not set
     # end of Device Management
     # CONFIG_MODBUS is not set
    +# CONFIG_MODEM_MODULES is not set
     # Networking
    @@ -1524,37 +2101,50 @@
     # end of Networking
    -# Portability
    -# end of Portability
     # Power Management
    -# CONFIG_SYS_POWER_MANAGEMENT is not set
    -# CONFIG_DEVICE_POWER_MANAGEMENT is not set
     # end of Power Management
    -# CONFIG_SHELL is not set
    -# CONFIG_STATS is not set
    -# CONFIG_USB_DEVICE_STACK is not set
    -# CONFIG_IMG_MANAGER is not set
    +# Portability
    +# end of Portability
     # Random Number Generators
     # CONFIG_TEST_RANDOM_GENERATOR is not set
    +CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    +CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    +# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    +CONFIG_CSPRNG_ENABLED=y
    +CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    +# CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
     # end of Random Number Generators
    +# CONFIG_RTIO is not set
    +# SD
    +# CONFIG_MMC_STACK is not set
    +# CONFIG_SDMMC_STACK is not set
    +# CONFIG_SDIO_STACK is not set
    +# end of SD
    +# CONFIG_SETTINGS is not set
    +# CONFIG_SHELL is not set
    +# CONFIG_STATS is not set
     # Storage
     CONFIG_FLASH_MAP=y
     # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    +# CONFIG_FLASH_MAP_LABELS is not set
     # CONFIG_STREAM_FLASH is not set
     # end of Storage
    -# CONFIG_SETTINGS is not set
     # CONFIG_TASK_WDT is not set
    @@ -1562,15 +2152,25 @@
     # CONFIG_ZTEST is not set
     # CONFIG_ZTEST_MOCKING is not set
    +# CONFIG_ZTRESS is not set
     # CONFIG_TEST is not set
    +CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    +# CONFIG_FORCE_COVERAGE is not set
     # CONFIG_TEST_USERSPACE is not set
     # end of Testing
     # CONFIG_TIMING_FUNCTIONS is not set
     # CONFIG_TRACING is not set
    -# end of Sub Systems and OS Services
    +# CONFIG_USB_DEVICE_STACK is not set
    +# CONFIG_USB_DEVICE_STACK_NEXT is not set
    +# CONFIG_USB_HOST_STACK is not set
    +# CONFIG_USBC_STACK is not set
    +# CONFIG_ZBUS is not set
    +# CONFIG_MODULES is not set
    +# end of Subsystems and OS Services
    -CONFIG_TOOLCHAIN_GNUARMEMB=y
    +CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    +CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
     # Build and Link Features
    @@ -1582,17 +2182,13 @@
     # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
     CONFIG_LINKER_ORPHAN_SECTION_WARN=y
     # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    -CONFIG_HAS_FLASH_LOAD_OFFSET=y
    -CONFIG_USE_DT_CODE_PARTITION=y
    -CONFIG_FLASH_LOAD_OFFSET=0x0
     CONFIG_FLASH_LOAD_SIZE=0xc000
    +CONFIG_ROM_END_OFFSET=0
     CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
     CONFIG_LD_LINKER_TEMPLATE=y
     # CONFIG_CMAKE_LINKER_GENERATOR is not set
     # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    -CONFIG_KERNEL_ENTRY="__start"
     CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    -CONFIG_SRAM_OFFSET=0
     # Linker Sections
    @@ -1600,19 +2196,39 @@
     # CONFIG_LINKER_USE_BOOT_SECTION is not set
     # CONFIG_LINKER_USE_PINNED_SECTION is not set
     CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    +CONFIG_LINKER_LAST_SECTION_ID=y
    +CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    +CONFIG_LINKER_USE_RELAX=y
     # end of Linker Sections
    +CONFIG_LINKER_ITERABLE_SUBALIGN=4
    +CONFIG_LINKER_DEVNULL_SUPPORT=y
    +# CONFIG_LINKER_DEVNULL_MEMORY is not set
     # end of Linker Options
     # Compiler Options
    +# CONFIG_STD_C90 is not set
    +CONFIG_STD_C99=y
    +# CONFIG_STD_C11 is not set
    +# CONFIG_STD_C17 is not set
    +# CONFIG_STD_C23 is not set
    +CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    +# CONFIG_GNU_C_EXTENSIONS is not set
     # CONFIG_CODING_GUIDELINE_CHECK is not set
    -# CONFIG_NATIVE_APPLICATION is not set
    +CONFIG_COMPILER_FREESTANDING=y
     CONFIG_SIZE_OPTIMIZATIONS=y
     # CONFIG_SPEED_OPTIMIZATIONS is not set
     # CONFIG_DEBUG_OPTIMIZATIONS is not set
     # CONFIG_NO_OPTIMIZATIONS is not set
    +# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    +# CONFIG_COMPILER_SAVE_TEMPS is not set
    +CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
     CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    +CONFIG_FORTIFY_SOURCE_NONE=y
    +# CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
    +# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
     CONFIG_COMPILER_OPT=""
     # CONFIG_MISRA_SANE is not set
     # end of Compiler Options
    @@ -1626,20 +2242,28 @@
     CONFIG_KERNEL_BIN_NAME="zephyr"
     CONFIG_OUTPUT_STAT=y
    -CONFIG_OUTPUT_DISASSEMBLY=y
    -# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
    +# CONFIG_OUTPUT_SYMBOLS is not set
    +# CONFIG_OUTPUT_DISASSEMBLY is not set
     CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
     # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
     # CONFIG_BUILD_NO_GAP_FILL is not set
    -CONFIG_BUILD_OUTPUT_BIN=y
     # CONFIG_BUILD_OUTPUT_EXE is not set
     # CONFIG_BUILD_OUTPUT_S19 is not set
     # CONFIG_BUILD_OUTPUT_UF2 is not set
     # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    +# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    +# CONFIG_BUILD_ALIGN_LMA is not set
     # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
     # CONFIG_MAKEFILE_EXPORTS is not set
     CONFIG_BUILD_OUTPUT_META=y
    +# CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
    +CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    +CONFIG_CHECK_INIT_PRIORITIES=y
    +# CONFIG_EMIT_ALL_SYSCALLS is not set
     # end of Build Options
    +CONFIG_WARN_DEPRECATED=y
    +CONFIG_ENFORCE_ZEPHYR_STDINT=y
     # end of Build and Link Features
    @@ -1648,9 +2272,3 @@
     # CONFIG_IS_BOOTLOADER is not set
     # CONFIG_BOOTLOADER_BOSSA is not set
     # end of Boot Options
    -# Compatibility
    -CONFIG_COMPAT_INCLUDES=y
    -# end of Compatibility
    I also confirmed here that it is still possible to enable the SPI NOR driver in the bootloader and make it fit into the 48K region:
    peripheral_lbs_spi_dfu.zip
