Now I want a packet (8 bytes) to be sent out at 8k, but now it is only about 5k, I did not set the ack, is there a way to verify that the ack reaches 8k,The library currently in use is nrf5_sdk_17.1.0
40 us is the ramp-up time of the radio. This will be required when the radio changes mode (ie. TX->RX or RX->TX).
NCS has the configuration of always keeping the radio in TX mode, via config CONFIG_ESB_NEVER_DISABLE_TX. This is not a feature that is available in nRF5 SDK "nrf_esb".
shsh said:Thank you very much, but how can I communicate with TX without ack? RX sends 1 or 2 packets of data to TX from time to time.
You could buffer up samples (ie. 2 x 8 bytes), and send them with auto-acking enabled for instance. This should allow you to use 2*125 us for specific frames, which should allow you to use ACK-payload with a small payload from the PRX device.
Or you can manually go into RX on the PTX side to receive from the PRX.
Håkon
I found a very interesting phenomenon that if RX enables automatic ACK, regardless of whether TX requests ACK or not, RX receives 220us. This period is the same as TX requests ACK, and RX will return to normal only when RX's automatic ACK is turned off
Can you share your configuration (both PRX and PTX) and how you send the payload (ie. if noack flag is set / unset)?
This question seems to have been missed as well:
Håkon Alseth said:Do you mean that it takes longer time, or that the evt "NRF_ESB_EVENT_TX_FAILED" is being raised?
It is important to check the events on both sides to see if the procedure goes as expected.
Håkon
