How to change pwm period on runtime in ncs?
I'm trying to play some sounds on a piezo with the help of the pwm. I tried to set the period with pwm_set_dt but only the first call is successful and every subsequent call raised an error.
Here is my test code:
    for(uint16_t i = 400; i < 800; i++)
        int ret = pwm_set_dt(&piezo_pwm_pos, PWM_HZ(i),
						   PWM_HZ(i) / 2);
        LOG_DBG("pwm_set_dt = %d", ret);
        ret = pwm_set_dt(&piezo_pwm_neg, PWM_HZ(i),
						   PWM_HZ(i) / 2);
        k_msleep(10);
The results looked like this:
00> D: pwm_set_dt = 0
00> E: Incompatible period.
00> D: pwm_set_dt = -22
I didn't find anything in the documentation of pwm_set for the error 22.
How can I change period and pulse while the pwm is running?
Christian
    in your case you just changed the period of one pin. If I do it also for only one channel everything works. I want to set two pins exactly inverted with changing frequency over time as seen in the image below.
    But I only can change the frequency for one channel or set it once for two channels. It's not possible to change the frequency while the pwm is active. I could change the frequency if I disable the pwm for both channels before setting the new frequency, but this results in an interrupted output sound on the piezo.
    How can I invert channel 1 in relation to channel 0?
    Christian
  • Try using the  pwm_set_cycles() function. And use PWM_POLARITY_NORMAL on one channel, and
    PWM_POLARITY_INVERTED on the other. Snippet:
    ret = pwm_set_cycles(pwm_led0->dev, pwm_led0->channel, period_cycles, period_cycles / 2,
    	PWM_POLARITY_INVERTED);
    ret = pwm_set_cycles(pwm_led1->dev, pwm_led1->channel, period_cycles, period_cycles / 2,
    		PWM_POLARITY_NORMAL);
    you already suggested this, but it also results in "Incompatible period." and the functions return -EINVAL after the first time. Is it a problem, that I call these functions from a timeout handler?
    In the nrf5 SDK there was NRF_DRV_PWM_EVT_FINISHED. In this event handler I could change the frequency of the pwm and it results in a nice alarm sound. Why is this not possible with the nrf connect SDK.
  • Ah, right!
    How do you define these channels?
    If you do it like this in the dts:
    https://github.com/nrfconnect/sdk-zephyr/blob/v3.7.99-ncs2/boards/nordic/nrf52dk/nrf52dk_nrf52832.dts#L48-L53
    you can have e.g. pwm_led_0 with PWM_POLARITY_INVERTED,
    and define a pwm_led_1 with PWM_POLARITY_NORMAL
  • It's defined like this:
    pwmpiezo0 {
    		compatible = "pwm-leds";
    		status = "okay";
    		piezo_pwm_pos: piezo_pwm_pos {
    				status = "okay";
    				pwms = <&pwm1 0 PWM_HZ(7500) PWM_POLARITY_NORMAL>;
    				label = "Piezo positive";
    		piezo_pwm_neg: piezo_pwm_neg {
    				status = "okay";
    				pwms = <&pwm1 1 PWM_HZ(7500) PWM_POLARITY_INVERTED>;
    				label = "Piezo negative";
    One of the pins is already inverted. I then call
    ret = pwm_set_dt(&piezo_pwm_pos, PWM_HZ(m_piezo_params.frequency),
    					PWM_HZ(m_piezo_params.frequency) / 2);
    ret = pwm_set_dt(&piezo_pwm_neg, PWM_HZ(m_piezo_params.frequency),
    within a timeout handler every x ms. If m_piezo_params.frequency stays the same, the function calls return 0. But if I change the frequency it breaks after the first timeout.
