nRF internal flash utilized for MCUboot, external for FS
I been struggling with this issue for a couple of days and can't manage to find the reason behind it.
About the project:
We are developing a IoT device firmware based on nRF9160 SiP. We are using first-stage immutable bootloader (MCUboot) and also LittleFS file system. System was working fine whilst it was running only on internal flash. Once we enabled external flash, we dedicated all of its memory for file logging. Since this is a multi-image build the Partition Manager is used to generate flash partitions. At the beginning the PM created MCUboot secondary image on external flash, because `CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n`by default was set to y but we changed that. At this point everything seems to be okay - MCUboot both partitions are on internal flash but filesystem is on external
The issue:
For over-the-air upgrade we use block-wise transfer and receive FW chunk by chunk from server and saved the chunk to secondary mcuboot_image slot using `flash_img_buffered_write`. After enabling external flash, flash_img_buffered_write causes secure fault which causes the system to reset. With default `partitions.yml` generated file the fault is on the first call. When I tried to add `pm_static.yml` file at some point the fault happened later but the fault still existed.
What have I tried:
I've tried creating and playing around with `pm_static.yml` file partition properties and at some point even placements but didn't manage to make it work. I also tried to replicate partitions as it was when the system worked only on internal flash just moved the littlefs_storage to external_flash partition. I have checked that when partition context passed to flash_img_buffered_write is with correct ID and address, `pm_static.yml` partition properties seems to be logical. With addr2line.exe returns that the faulting line is at `nrf_nvmc.h:378` which is a call to write a word. I tried to find a similar issue in this forum but without luck. I believe the issue is because of incorrect partitioning because at some point while I was playing with some partition properties the Secure fault was introduced only later - after couple of chunks was already saved in flash not on the first call as it is most of the time
Resources:
Here is the generated partitions.yml file which out of the box was causing secure fault on first write call
EMPTY_0:
  address: 0xc000
  end_address: 0x10000
  placement:
    before:
    - mcuboot_pad
  region: flash_primary
app:
  address: 0x18000
  end_address: 0x88000
external_flash:
  address: 0x6000
  end_address: 0x400000
  region: external_flash
littlefs_storage:
  address: 0x0
  device: DT_CHOSEN(nordic_pm_ext_flash)
  end_address: 0x6000
  placement:
    before:
    - tfm_storage
    - end
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x10000
  end_address: 0x10200
  placement:
    align:
      start: 0x8000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x10000
  orig_span: &id001
  - app
  - tfm
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x10200
  orig_span: &id002
  - app
  - tfm
  span: *id002
mcuboot_secondary:
  address: 0x88000
  end_address: 0x100000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x8000
    align_next: 0x8000
  share_size:
  - mcuboot_primary
mcuboot_sram:
  address: 0x20000000
  end_address: 0x20008000
  orig_span: &id003
  - tfm_sram
  region: sram_primary
  span: *id003
nrf_modem_lib_ctrl:
  address: 0x20008000
  end_address: 0x200084e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - tfm_sram
    - start
nrf_modem_lib_rx:
  address: 0x2000a568
  end_address: 0x2000c568
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20008000
  orig_span: &id004
  - nrf_modem_lib_ctrl
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id004
nrf_modem_lib_tx:
  address: 0x200084e8
  end_address: 0x2000a568
  inside:
  - sram_nonsecure
  placement:
    after:
otp:
  address: 0xff8108
  end_address: 0xff83fc
  region: otp
sram_nonsecure:
  address: 0x20008000
  end_address: 0x20040000
  orig_span: &id005
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id005
sram_primary:
  address: 0x2000c568
sram_secure:
  address: 0x20000000
  orig_span: &id006
  - tfm_sram
  span: *id006
tfm:
  address: 0x10200
  end_address: 0x18000
  inside:
  placement:
    before:
    - app
tfm_nonsecure:
  address: 0x18000
  orig_span: &id007
  - app
  span: *id007
tfm_secure:
  address: 0x10000
  orig_span: &id008
  - mcuboot_pad
  - tfm
  span: *id008
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
Here is my pm_static.yml file which I added based on `partitions.yml` output when everything was on internal flash.
EMPTY_0:
  address: 0xc000
  placement:
    before:
    - mcuboot_pad
EMPTY_1:
  address: 0xf0000
  placement:
    after:
    - mcuboot_secondary
app:
  address: 0x18000
  end_address: 0x80000
external_flash:
  address: 0x6000
  end_address: 0x800000
littlefs_storage:
  address: 0x0
  end_address: 0x6000
  inside:
  - nonsecure_storage
  placement:
    before:
    - end
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x10000
  placement:
    align:
      start: 0x8000
    before:
mcuboot_primary:
  address: 0x10000
  orig_span: &id001
  - mcuboot_pad
  - tfm
  - app
  sharers: 0x1
  span: *id001
  address: 0x10200
  orig_span: &id002
  - app
  - tfm
  span: *id002
mcuboot_secondary:
  address: 0x80000
  end_address: 0xf0000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x8000
  share_size:
  - mcuboot_primary
mcuboot_sram:
  address: 0x20000000
  orig_span: &id003
  - tfm_sram
  span: *id003
nonsecure_storage:
  address: 0x0
  end_address: 0x6000
  orig_span: &id004
  - littlefs_storage
  span: *id004
nrf_modem_lib_ctrl:
  address: 0x20008000
  inside:
  - sram_nonsecure
  placement:
    after:
    - tfm_sram
    - start
nrf_modem_lib_rx:
  address: 0x2000a568
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20008000
  orig_span: &id005
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id005
nrf_modem_lib_tx:
  address: 0x200084e8
  inside:
  - sram_nonsecure
  placement:
    after:
otp:
  address: 0xff8108
  region: otp
sram_nonsecure:
  address: 0x20008000
  orig_span: &id006
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id006
sram_primary:
  address: 0x2000c568
sram_secure:
  address: 0x20000000
  orig_span: &id007
  - tfm_sram
  span: *id007
tfm:
  address: 0x10200
  inside:
  placement:
    before:
    - app
tfm_nonsecure:
  address: 0x18000
  orig_span: &id008
  - app
  span: *id008
tfm_secure:
  address: 0x10000
  orig_span: &id009
  - mcuboot_pad
  - tfm
  span: *id009
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
Below is the output from the exception call if that helps with anything
[00:00:07.133,087] <err> os: ***** SECURE FAULT *****
[00:00:07.133,178] <err> os:   Address: 0x80000
[00:00:07.133,209] <err> os:   Attribution unit violation
[00:00:07.133,239] <err> os: r0/a1:  0x00080000  r1/a2:  0x96f3b83d  r2/a3:  0x40039000
[00:00:07.133,270] <err> os: r3/a4:  0x80000000 r12/ip:  0x2001aac4 r14/lr:  0x0002a55b
[00:00:07.133,300] <err> os:  xpsr:  0x81000000
[00:00:07.133,300] <err> os: Faulting instruction address (r15/pc): 0x0002a4a2
[00:00:07.133,422] <err> os: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
[00:00:07.133,514] <err> os: Current thread: 0x2000d5b0 (unknown)
To me seems to be okay - app tries to write from non-secure region to non-secure region, the partition address's don't overlap, the partition context is correct.. Maybe somebody with a fresh pair of eyes can spot the issue right away.
EDIT: Almost forgot to mention, I am developing on a custom board but the issue can be replicated on DK. Working with SDK V2.6.0
Andris
    Sorry for the late response.
    So I tried to put both (app and mcuboot_secondary) in tfm_nonsecure region (I read the response in email and did not see the edited comment there). As for a surprise, the app was able to download and update firmware! Why mcuboot_secondary slot shouldn't be placed in tfm_nonsecure region and why it works if it shouldn't be there?
    I also check if the code was greyed out as you asked. In editor it did not seem to be greyed out but I also tried to launch the debugger and step over these instructions and they were not executed. Also I have not seen greyed out code in VS code at all so I believe this feature is not really working correctly on my machine.
    By the looks the security attribute for the region is correctly set, but the update still fails
     So the problem is kind of fixed when app and mcuboot_secondary is placed in tfm_nonsecure region. Can I leave it like this or this setup might introduce some bugs later on? If this is not the correct setup let me know how else I can help you with debugging this issue
    Andris
  • Hi Andris,
    I think it would be good if we could understand the root cause for why it failed in the first place so we don't risk masking others problem in the configuration.
    Did you select TF-M as the active build context before you browsed the file?
    It is more that it should not have been necessary. I was not able to reproduce the issue here when I tried to replicate your memory layout.
    Please check region 10 instead of 15. Region 10 starts at address 0x80000, same as your secondary slot.
    Yes I did select TF-M as active build context before opening the file
    Also region 10 is non_secure right before flash_img_buffered_write
    Unfortunately I can't send you the project. I'll try to replicate this issue with some existing examples
  • Hi Vidar,
    I managed to replicate this issue in littlefs example by adding nrf9160 overlay file, the pm_static.yml and enabling MCUboot. Only difference I try to write random 1KB of data in secondary slot but I guess it shouldn't matter. Also the writing to secondary slot happens only once but with a loop you can increase the data written to secondary slot.
    Here is the project zip 5661.replicate_bug.zip
    Hope this helps
    Andris
  • Hi Andris,
    Thanks for providing this sample code. The problem with this project is that it does not disable CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY symbol. This causes the TF-M build to not set this flag as it assumes that secondary partition will be placed in external flash:
    Please make sure you have this line in your CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n prj.conf file.
    Vidar
