Our product has reached the mass production stage and needs to be burned using the nrfutil command, but the burning result is inconsistent with the result of vscode
We need to test the pin and RF so we modify some code in radio_test
ncs2.8.0
IC: REVB
According to the following link, the configuration is successful
docs.nordicsemi.com/.../ug_nrf54h20_gs.html
radio_test
I will attach my project.
When I use vscode to burn, it works fine. I can test that a pin is high level when powered on and becomes low level after 3s.
But when I use nrf54h20_factory_test\build\nrf54h20_factory_test\zephyr\generated_nrfutil_batch.json burn firmware it doesn't work.
nrfutil device erase --traits jlink --x-family nrf54h --core Application --all nrfutil device erase --traits jlink --x-family nrf54h --core Network --all nrfutil device reset --reset-kind RESET_PIN nrfutil device program --traits jlink --x-family nrf54h --core Application --firmware suit_mpi_application_merged.hex nrfutil device fw-verify --firmware suit_mpi_application_merged.hex nrfutil device program --traits jlink --x-family nrf54h --core Network --firmware suit_mpi_radio_merged.hex nrfutil device fw-verify --firmware suit_mpi_radio_merged.hex nrfutil device program --traits jlink --x-family nrf54h --core Application --firmware suit_installed_envelopes_application_merged.hex nrfutil device fw-verify --firmware suit_installed_envelopes_application_merged.hex nrfutil device program --traits jlink --x-family nrf54h --core Network --firmware uicr_merged.hex nrfutil device fw-verify --firmware uicr_merged.hex nrfutil device reset --reset-kind RESET_PIN
