Auracast example
I am using NCS v2.8.0.
After successfully running the headset example with one gateway, one left channel receiver and one right channel receiver am trying to get the Auracast example working, so I can connect three receivers to the gateway.
I added CONFIG_TRANSPORT_BIS=Y to prj.cfg, but after compiling and programming the system functionality did not change to Auracast. Do I need to change something to nrf5340_audio_dk_devices.json as well? The current one see below. I also did not find any references to CONFIG_TRANSPORT_BIS in the source code of v2.8.0. Do I miss something?
"nrf5340_audio_dk_snr": 1050111739,
"nrf5340_audio_dk_dev": "headset",
"channel": "left"
"nrf5340_audio_dk_snr": 1050156869,
"nrf5340_audio_dk_dev": "gateway",
"channel": "NA"
"nrf5340_audio_dk_snr": 1050128347,
"channel": "right"
  • Hi! I installed it using the Toolchain Manager. I did not know the cmd prompt had to be opened using the Toolchain Manager. Maybe this can be added to the build instructions on this page: Building and running nRF5340 Audio applications
    I get a different error now with the stereo_bis_receiver_pre270 branch. See below.
    I do not get this error when building the standard v2.8.0 nrf5340_audio example.
    I hope you can help me. We really want to use the NRF5340 in our product, but the build system is a bit problematic now...
    (v2.8.0) C:\ncs\v2.8.0\sdk-nrf\applications\nrf5340_audio\tools\buildprog> buildprog.py -c both -b debug -d both
    No programmer/debugger connected to PC
    No snrs connected
    | snr | snr conn | device | only reboot | core app programmed | core net programmed |
    | 1050121107 | ←[33mFalse←[0m | headset | Not selected | Selected | Selected |
    | 1050197742 | ←[33mFalse←[0m | gateway | Not selected | Selected | Selected |
    | 1000 | ←[33mFalse←[0m | headset | Not selected | Selected | Selected |
    Invoking build step
    Net core uses precompiled hex or child image
    Run: west build C:\ncs\v2.8.0\sdk-nrf\applications\nrf5340_audio -b nrf5340_audio_dk/nrf5340/cpuapp --sysbuild -d C:\ncs\v2.8.0\sdk-nrf\applications\nrf5340_audio\build\dev_headset\build_debug -DCONFIG_AUDIO_DEV=1
    usage: west [-h] [-z ZEPHYR_BASE] [-v] [-V] <command> ...
    west: unknown command "build"; workspace C:\ncs\v2.8.0 does not define this extension command -- try "west help"
    File "C:\ncs\v2.8.0\sdk-nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 418, in <module>
    __main()
    File "C:\ncs\v2.8.0\sdk-nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 401, in __main
    __build_module(build_cfg, options)
    File "C:\ncs\v2.8.0\sdk-nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 176, in __build_module
    raise Exception("cmake error: " + str(ret_val))
    Exception: cmake error: 1
    It's a branch of NCS v2.7.0. Please use NCS v2.7.0 to build.
  • Hi. I still have issues with building. It takes too much time, so I gave up for now... Is stereo support planned in a later SDK version? Then I will just wait for this I guess.
