Extend number of devices for PAwR (Coded PHY)
Hi all !
I'm writing this message because I'm having problems trying to increase the number of devices in PAwR (I use Coded PHY).
I based my development on the SDK 2.8.0 example (Periodic_adv_conn / Periodic_sync_conn). I also tried Periodic_adv_rsp / Periodic_sync_rsp examples without success.
I've modified it so that I don't have to connect every time via on the TX side:
bt_conn_le_create_synced function()
On the RX side, I have a fixed subevent and slot numbers to answer to TX.
Based on SDK example, I can exchange data with 25 devices (5 subevents / 5 slots)
I used the following configuration:
#define NUM_RSP_SLOTS 5
#define NUM_SUBEVENTS 5
#define SUBEVENT_INTERVAL 0x30
static const struct bt_le_per_adv_param per_adv_params = {
	.interval_min = 0xFF,
	.interval_max = 0xFF,
	.options = 0,
	.num_subevents = NUM_SUBEVENTS,
	.subevent_interval = SUBEVENT_INTERVAL,
	.response_slot_delay = 0x5,
	.response_slot_spacing = 0x50,
	.num_response_slots = NUM_RSP_SLOTS,
When I try to increase the number of devices (8 subevents / 20 slots per subevent), I don't get the same behavior.
Below are the timings I use depending on the number of subevents and slots.
#define NUM_RSP_SLOTS 20
#define NUM_SUBEVENTS 8
	.interval_min = 0x960,
	.interval_max = 0x960,
	.options = 0,
	.subevent_interval = 0xF0,
	.response_slot_delay = 0x10,
I saw that the PAwR feature is still experimental in the las version of the SDK, could this be related or is there something I'm doing wrong?
Thank you in advance for your answers or feedbacks.
Yann
  • Hi Hieu,
    I prepared a modified version of the periodic_adv/sync_conn example with my PAwR timings.
    Can you please have a look on it ?
    You can try from your side if you want, I used a nrf52840dk for the ADV side and only one nrf52840dk for the SYNC side and it's not possible to exchange data.
    You will find diff to easily see my changes.
    ADV Side
    diff --git a/src/main.c b/src/main.c
    index 49c1c52..b04a8b4 100644
    --- a/src/main.c
    +++ b/src/main.c
    @@ -9,22 +9,40 @@
     #include <zephyr/bluetooth/gap.h>
     #include <zephyr/bluetooth/hci.h>
    -#define NUM_RSP_SLOTS	  5
    -#define NUM_SUBEVENTS	  5
    -#define PACKET_SIZE	  5
    +#define NUM_RSP_SLOTS	  20
    +#define NUM_SUBEVENTS	  8
    +// #define NUM_RSP_SLOTS	  5
    +// #define NUM_SUBEVENTS	  5
    +#define PACKET_SIZE	      5
    +#define BT_LE_EXT_ADV_NCONN_CODED BT_LE_ADV_PARAM(BT_LE_ADV_OPT_EXT_ADV | \
    +                        BT_LE_ADV_OPT_CODED, \
    +					    BT_GAP_ADV_FAST_INT_MIN_2, \
    +					    BT_GAP_ADV_FAST_INT_MAX_2, NULL)
    -	.interval_min = 0xFF,
    -	.interval_max = 0xFF,
    +	.interval_min = 0x960,
    +	.interval_max = 0x960,
     	.options = 0,
    -	.subevent_interval = SUBEVENT_INTERVAL,
    -	.response_slot_delay = 0x5,
    +	.subevent_interval = 0xF0,
    +	.response_slot_delay = 0x10,
    +// static const struct bt_le_per_adv_param per_adv_params = {
    +// 	.interval_min = 0xFF,
    +// 	.interval_max = 0xFF,
    +// 	.options = 0,
    +// 	.num_subevents = NUM_SUBEVENTS,
    +// 	.subevent_interval = SUBEVENT_INTERVAL,
    +// 	.response_slot_delay = 0x5,
    +// 	.response_slot_spacing = 0x50,
    +// 	.num_response_slots = NUM_RSP_SLOTS,
     static struct bt_le_per_adv_subevent_data_params subevent_data_params[NUM_SUBEVENTS];
     static struct net_buf_simple bufs[NUM_SUBEVENTS];
     static uint8_t backing_store[NUM_SUBEVENTS][PACKET_SIZE];
    @@ -73,46 +91,12 @@ static struct bt_conn *default_conn;
     static void response_cb(struct bt_le_ext_adv *adv, struct bt_le_per_adv_response_info *info,
     			struct net_buf_simple *buf)
    -	int err;
    -	bt_addr_le_t peer;
    -	char addr_str[BT_ADDR_LE_STR_LEN];
    -	struct bt_conn_le_create_synced_param synced_param;
    -	struct bt_le_conn_param conn_param;
     	if (!buf) {
     		return;
    -	if (default_conn) {
    -		/* Do not initiate new connections while already connected */
    -		return;
    -	bt_addr_le_copy(&peer, &bt_addr_le_none);
    -	bt_data_parse(buf, get_address, &peer);
    -	if (bt_addr_le_eq(&peer, &bt_addr_le_none)) {
    -		/* No address found */
    -		return;
    -	bt_addr_le_to_str(&peer, addr_str, sizeof(addr_str));
    -	printk("Connecting to %s in subevent %d\n", addr_str, info->subevent);
    -	synced_param.peer = &peer;
    -	synced_param.subevent = info->subevent;
    -	/* Choose same interval as PAwR advertiser to avoid scheduling conflicts */
    -	conn_param.interval_min = SUBEVENT_INTERVAL;
    -	conn_param.interval_max = SUBEVENT_INTERVAL;
    -	/* Default values */
    -	conn_param.latency = 0;
    -	conn_param.timeout = 400;
    -	err = bt_conn_le_create_synced(adv, &synced_param, &conn_param, &default_conn);
    -	if (err) {
    -		printk("Failed to initiate connection (err %d)", err);
    +    printk("RX DATA : SUB %u SLOT %u DATA %X%X%X%X%X\n", info->subevent, info->response_slot,
    +        buf->data[0], buf->data[1], buf->data[2], buf->data[3], buf->data[4]);
     static const struct bt_le_ext_adv_cb adv_cb = {
    @@ -183,7 +167,7 @@ int main(void)
     	/* Create a non-connectable advertising set */
    -	err = bt_le_ext_adv_create(BT_LE_EXT_ADV_NCONN, &adv_cb, &pawr_adv);
    +	err = bt_le_ext_adv_create(BT_LE_EXT_ADV_NCONN_CODED, &adv_cb, &pawr_adv);
     	if (err) {
     		printk("Failed to create advertising set (err %d)\n", err);
     		return 0;
    SYNC side
    index db858ef..172acf8 100644
    --- a/src/main.c
    +++ b/src/main.c
    @@ -57,6 +57,7 @@ static void term_cb(struct bt_le_per_adv_sync *sync,
     static struct bt_le_per_adv_response_params rsp_params;
     NET_BUF_SIMPLE_DEFINE_STATIC(rsp_buf, sizeof(bt_addr_le_t) + 2 * sizeof(uint8_t));
    +uint8_t myDummyBuf[] = {0x11, 0x22, 0x33, 0x44, 0x55};
     static void recv_cb(struct bt_le_per_adv_sync *sync,
     		    const struct bt_le_per_adv_sync_recv_info *info, struct net_buf_simple *buf)
    @@ -79,25 +80,17 @@ static void recv_cb(struct bt_le_per_adv_sync *sync,
     		rsp_params.response_subevent = info->subevent;
     		rsp_params.response_slot = 0;
    -		err = bt_le_oob_get_local(BT_ID_DEFAULT, &oob);
    -		if (err) {
    -			printk("Failed to get OOB data (err %d)\n", err);
    -			return;
    -		bt_addr_le_to_str(&oob.addr, addr_str, sizeof(addr_str));
    -		printk("Responding with own addr: %s\n", addr_str);
    -		net_buf_simple_add_u8(&rsp_buf, sizeof(bt_addr_le_t));
    -		net_buf_simple_add_u8(&rsp_buf, BT_DATA_LE_BT_DEVICE_ADDRESS);
    -		net_buf_simple_add_mem(&rsp_buf, &oob.addr.a, sizeof(oob.addr.a));
    -		net_buf_simple_add_u8(&rsp_buf, oob.addr.type);
    +        net_buf_simple_add_mem(&rsp_buf, myDummyBuf, sizeof(myDummyBuf));
     		err = bt_le_per_adv_set_response_data(sync, &rsp_params, &rsp_buf);
     		if (err) {
     			printk("Failed to send response (err %d)\n", err);
    +        else
    +            printk("Response data sent : 0x%2X:0x%2X:0x%2X:0x%2X:0x%2X\n",
    +                myDummyBuf[0], myDummyBuf[1], myDummyBuf[2], myDummyBuf[3], myDummyBuf[4]);
     	} else if (buf) {
     		printk("Received empty indication: subevent %d\n", info->subevent);
     	} else {
    @@ -198,7 +191,7 @@ int main(void)
     	bt_le_scan_cb_register(&scan_callbacks);
     	bt_le_per_adv_sync_cb_register(&sync_callbacks);
    -	err = bt_le_scan_start(BT_LE_SCAN_ACTIVE, NULL);
    +	err = bt_le_scan_start(BT_LE_SCAN_CODED_ACTIVE, NULL);
     	if (err) {
     		printk("failed (err %d)\n", err);
    Yann
  • Hi Yann,
    I am unfortunately not available right now and only return next week. Do you mind waiting until then?
    Hieu
  • Hi Hieu,
    No problem, I can wait.
    Thank you.
    Yann
  • Hi Yann,
    I cannot reproduce the issue. Your changes work just fine for me. I didn't apply the patch with git but hand-picked each change and test incrementally. However, the result shouldn't be different.
    Here are my main files, just to be sure.
    periodic_adv_conn - main.c
     * Copyright (c) 2023 Nordic Semiconductor ASA
    #include <zephyr/bluetooth/conn.h>
    #define SAMPLE_INTERVAL_MIN 0xFF
    #define SAMPLE_INTERVAL_MAX 0xFF
    #define RESPONSE_SLOT_DELAY 0x5
    // #define NUM_RSP_SLOTS	  20
    // #define NUM_SUBEVENTS	  8
    // #define PACKET_SIZE	  5
    // #define SUBEVENT_INTERVAL 0xF0
    // #define SAMPLE_INTERVAL_MIN 0x960
    // #define SAMPLE_INTERVAL_MAX 0x960
    // #define RESPONSE_SLOT_DELAY 0x10
    	.interval_min = SAMPLE_INTERVAL_MIN,
    	.interval_max = SAMPLE_INTERVAL_MAX,
    	.options = 0,
    	.response_slot_delay = RESPONSE_SLOT_DELAY,
    BUILD_ASSERT(ARRAY_SIZE(bufs) == ARRAY_SIZE(subevent_data_params));
    BUILD_ASSERT(ARRAY_SIZE(backing_store) == ARRAY_SIZE(subevent_data_params));
    static void request_cb(struct bt_le_ext_adv *adv, const struct bt_le_per_adv_data_request *request)
    	int err;
    	uint8_t to_send;
    	/* Continuously send the same dummy data and listen to all response slots */
    	to_send = MIN(request->count, ARRAY_SIZE(subevent_data_params));
    	for (size_t i = 0; i < to_send; i++) {
    		subevent_data_params[i].subevent =
    			(request->start + i) % per_adv_params.num_subevents;
    		subevent_data_params[i].response_slot_start = 0;
    		subevent_data_params[i].response_slot_count = NUM_RSP_SLOTS;
    		subevent_data_params[i].data = &bufs[i];
    	err = bt_le_per_adv_set_subevent_data(adv, to_send, subevent_data_params);
    	if (err) {
    		printk("Failed to set subevent data (err %d)\n", err);
    static bool get_address(struct bt_data *data, void *user_data)
    	bt_addr_le_t *addr = user_data;
    	if (data->type == BT_DATA_LE_BT_DEVICE_ADDRESS) {
    		memcpy(addr->a.val, data->data, sizeof(addr->a.val));
    		addr->type = data->data[sizeof(addr->a)];
    		return false;
    	return true;
    	// int err;
    	// bt_addr_le_t peer;
    	// char addr_str[BT_ADDR_LE_STR_LEN];
    	// struct bt_conn_le_create_synced_param synced_param;
    	// struct bt_le_conn_param conn_param;
    	// if (!buf) {
    	// 	return;
    	// if (default_conn) {
    	// 	/* Do not initiate new connections while already connected */
    	// 	return;
    	// bt_addr_le_copy(&peer, &bt_addr_le_none);
    	// bt_data_parse(buf, get_address, &peer);
    	// if (bt_addr_le_eq(&peer, &bt_addr_le_none)) {
    	// 	/* No address found */
    	// 	return;
    	// bt_addr_le_to_str(&peer, addr_str, sizeof(addr_str));
    	// printk("Connecting to %s in subevent %d\n", addr_str, info->subevent);
    	// synced_param.peer = &peer;
    	// synced_param.subevent = info->subevent;
    	// /* Choose same interval as PAwR advertiser to avoid scheduling conflicts */
    	// conn_param.interval_min = SUBEVENT_INTERVAL;
    	// conn_param.interval_max = SUBEVENT_INTERVAL;
    	// /* Default values */
    	// conn_param.latency = 0;
    	// conn_param.timeout = 400;
    	// err = bt_conn_le_create_synced(adv, &synced_param, &conn_param, &default_conn);
    	// if (err) {
    	// 	printk("Failed to initiate connection (err %d)", err);
    	printk("RX DATA : SUB %u SLOT %u DATA %02X%02X%02X%02X%02X\n", info->subevent, info->response_slot,
    	.pawr_data_request = request_cb,
    	.pawr_response = response_cb,
    static void connected_cb(struct bt_conn *conn, uint8_t err)
    	printk("Connected (err 0x%02X)\n", err);
    	__ASSERT(conn == default_conn, "Unexpected connected callback");
    	if (err) {
    		bt_conn_unref(default_conn);
    		default_conn = NULL;
    static void disconnected_cb(struct bt_conn *conn, uint8_t reason)
    	printk("Disconnected, reason 0x%02X %s\n", reason, bt_hci_err_to_str(reason));
    	__ASSERT(conn == default_conn, "Unexpected disconnected callback");
    BT_CONN_CB_DEFINE(conn_cb) = {
    	.connected = connected_cb,
    	.disconnected = disconnected_cb,
    static void init_bufs(void)
    	/* Set up some dummy data to send */
    	for (size_t i = 0; i < ARRAY_SIZE(backing_store); i++) {
    		backing_store[i][0] = ARRAY_SIZE(backing_store[i]) - 1;
    		backing_store[i][1] = BT_DATA_MANUFACTURER_DATA;
    		backing_store[i][2] = 0x59; /* Nordic */
    		backing_store[i][3] = 0x00;
    		net_buf_simple_init_with_data(&bufs[i], &backing_store[i],
    					      ARRAY_SIZE(backing_store[i]));
    static const struct bt_data ad[] = {
    	BT_DATA(BT_DATA_NAME_COMPLETE, CONFIG_BT_DEVICE_NAME, sizeof(CONFIG_BT_DEVICE_NAME) - 1),
    	int err;
    	struct bt_le_ext_adv *pawr_adv;
    	init_bufs();
    	printk("Starting Periodic Advertising Demo\n");
    	/* Initialize the Bluetooth Subsystem */
    	err = bt_enable(NULL);
    	if (err) {
    		printk("Bluetooth init failed (err %d)\n", err);
    		return 0;
    	// err = bt_le_ext_adv_create(BT_LE_EXT_ADV_NCONN, &adv_cb, &pawr_adv);
    	if (err) {
    		return 0;
    	/* Set advertising data to have complete local name set */
    	err = bt_le_ext_adv_set_data(pawr_adv, ad, ARRAY_SIZE(ad), NULL, 0);
    	if (err) {
    		printk("Failed to set advertising data (err %d)\n", err);
    		return 0;
    	/* Set periodic advertising parameters */
    	err = bt_le_per_adv_set_param(pawr_adv, &per_adv_params);
    	if (err) {
    		printk("Failed to set periodic advertising parameters (err %d)\n", err);
    		return 0;
    	/* Enable Periodic Advertising */
    	err = bt_le_per_adv_start(pawr_adv);
    	if (err) {
    		printk("Failed to enable periodic advertising (err %d)\n", err);
    		return 0;
    	printk("Start Periodic Advertising\n");
    	err = bt_le_ext_adv_start(pawr_adv, BT_LE_EXT_ADV_START_DEFAULT);
    	if (err) {
    		printk("Failed to start extended advertising (err %d)\n", err);
    		return 0;
    	while (true) {
    		k_sleep(K_SECONDS(1));
    	return 0;
    periodic_sync_conn - main.c
    #include <zephyr/sys/util.h>
    #define NAME_LEN 30
    static K_SEM_DEFINE(sem_per_adv, 0, 1);
    static K_SEM_DEFINE(sem_per_sync, 0, 1);
    static K_SEM_DEFINE(sem_connected, 0, 1);
    static K_SEM_DEFINE(sem_disconnected, 0, 1);
    static bool per_adv_found;
    static bt_addr_le_t per_addr;
    static uint8_t per_sid;
    static void sync_cb(struct bt_le_per_adv_sync *sync, struct bt_le_per_adv_sync_synced_info *info)
    	struct bt_le_per_adv_sync_subevent_params params;
    	uint8_t subevents[1];
    	char le_addr[BT_ADDR_LE_STR_LEN];
    	int err;
    	bt_addr_le_to_str(info->addr, le_addr, sizeof(le_addr));
    	printk("Synced to %s with %d subevents\n", le_addr, info->num_subevents);
    	params.properties = 0;
    	params.num_subevents = 1;
    	params.subevents = subevents;
    	subevents[0] = 0;
    	err = bt_le_per_adv_sync_subevent(sync, &params);
    	if (err) {
    		printk("Failed to set subevents to sync to (err %d)\n", err);
    	k_sem_give(&sem_per_sync);
    		    const struct bt_le_per_adv_sync_term_info *info)
    	printk("Sync terminated (reason %d)\n", info->reason);
    	int err;
    	struct bt_le_oob oob;
    	if (default_conn) {
    		/* Only respond with address if not already connected */
    		return;
    	if (buf && buf->len) {
    		/* Respond with own address for the advertiser to connect to */
    		net_buf_simple_reset(&rsp_buf);
    		rsp_params.request_event = info->periodic_event_counter;
    		rsp_params.request_subevent = info->subevent;
    		// err = bt_le_oob_get_local(BT_ID_DEFAULT, &oob);
    		// if (err) {
    		// 	printk("Failed to get OOB data (err %d)\n", err);
    		// 	return;
    		// bt_addr_le_to_str(&oob.addr, addr_str, sizeof(addr_str));
    		// printk("Responding with own addr: %s\n", addr_str);
    		// net_buf_simple_add_u8(&rsp_buf, sizeof(bt_addr_le_t));
    		// net_buf_simple_add_u8(&rsp_buf, BT_DATA_LE_BT_DEVICE_ADDRESS);
    		// net_buf_simple_add_mem(&rsp_buf, &oob.addr.a, sizeof(oob.addr.a));
    		// net_buf_simple_add_u8(&rsp_buf, oob.addr.type);
    		if (err) {
    	} else if (buf) {
    	} else {
    		printk("Failed to receive indication: subevent %d\n", info->subevent);
    static struct bt_le_per_adv_sync_cb sync_callbacks = {
    	.synced = sync_cb,
    	.term = term_cb,
    	.recv = recv_cb,
    	if (err) {
    		return;
    	default_conn = bt_conn_ref(conn);
    	k_sem_give(&sem_connected);
    	k_sem_give(&sem_disconnected);
    static bool data_cb(struct bt_data *data, void *user_data)
    	char *name = user_data;
    	uint8_t len;
    	switch (data->type) {
    	case BT_DATA_NAME_SHORTENED:
    	case BT_DATA_NAME_COMPLETE:
    		len = MIN(data->data_len, NAME_LEN - 1);
    		memcpy(name, data->data, len);
    		name[len] = '\0';
    		return false;
    		return true;
    static void scan_recv(const struct bt_le_scan_recv_info *info, struct net_buf_simple *buf)
    	char name[NAME_LEN];
    	(void)memset(name, 0, sizeof(name));
    	bt_data_parse(buf, data_cb, name);
    	if (strcmp(name, "PAwR conn sample")) {
    		return;
    	if (!per_adv_found && info->interval) {
    		per_adv_found = true;
    		per_sid = info->sid;
    		bt_addr_le_copy(&per_addr, info->addr);
    		k_sem_give(&sem_per_adv);
    static struct bt_le_scan_cb scan_callbacks = {
    	.recv = scan_recv,
    	struct bt_le_per_adv_sync_param sync_create_param;
    	struct bt_le_per_adv_sync *sync;
    	int err;
    	printk("Starting Periodic Advertising with Responses Synchronization Demo\n");
    	if (err) {
    		return 0;
    	// err = bt_le_scan_start(BT_LE_SCAN_ACTIVE, NULL);
    	if (err) {
    		return 0;
    	err = k_sem_take(&sem_per_adv, K_FOREVER);
    	if (err) {
    		return 0;
    	printk("Found periodic advertising.\n");
    	printk("Creating Periodic Advertising Sync");
    	bt_addr_le_copy(&sync_create_param.addr, &per_addr);
    	sync_create_param.options = 0;
    	sync_create_param.sid = per_sid;
    	sync_create_param.skip = 0;
    	sync_create_param.timeout = 0xaa;
    	err = bt_le_per_adv_sync_create(&sync_create_param, &sync);
    	if (err) {
    		printk("Failed to create sync (err %d)\n", err);
    		return 0;
    	printk("Waiting for periodic sync\n");
    	err = k_sem_take(&sem_per_sync, K_FOREVER);
    	if (err) {
    		printk("Failed (err %d)\n", err);
    		return 0;
    	printk("Periodic sync established.\n");
    	err = bt_le_scan_stop();
    	if (err) {
    		printk("Failed to stop scanning (err %d)\n", err);
    	printk("Stopped scanning\n");
    	do {
    		err = k_sem_take(&sem_connected, K_FOREVER);
    		if (err) {
    			return 0;
    		printk("Disconnecting\n");
    		err = bt_conn_disconnect(default_conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
    		if (err) {
    			return 0;
    		err = k_sem_take(&sem_disconnected, K_FOREVER);
    		if (err) {
    			return 0;
    	} while (true);
    Hieu
  • Hi Hieu,
    Thank you for your answer.
    In the file periodic_adv_conn - main.c I see that you have used the following parameters:
    Is it possible for you to try with the parameters that I sent you ?
    Because with 5 slots and 5 subevents (Default example values) it also works on my side.
    Thank you,
    Yann
