ncs 2.7.0 SPI nor flash build error
I got below build error:, actually I referred C:\ncs\v2.7.0\zephyr\samples\drivers\jesd216; my externl SPI NOR flash is p25q32h and my target is to build a file system such as fatfs on the flash. I also checked the sample under  C:\ncs\v2.7.0\zephyr\samples\drivers\spi_flash\boards and set CONFIG_NORDIC_QSPI_NOR, it has the same build exception.
c:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_0_config+0x0): undefined reference to `__device_dts_ord_85'
collect2.exe: error: ld returned 1 exit status
1. DTS
&pinctrl {
	i2c0_default: i2c0_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 0, 10)>, <NRF_PSEL(TWIM_SDA, 0, 9)>;
	spi1_default: spi1_default {
		group1 {
			psels = <NRF_PSEL(SPIM_MISO, 0, 14)>,
					<NRF_PSEL(SPIM_MOSI, 0, 15)>,
					<NRF_PSEL(SPIM_SCK, 0, 17)>;
&spi1 {
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-names = "default";
	p25q32h: p25q32h@0 {
        compatible = "jedec,spi-nor";
        reg = <0>;  // SPI Flash 从设备地址
        spi-max-frequency = <8000000>;  // SPI 最大频率
        label = "p25q32h";
        size = <0x2000000>;  // 32MB
		jedec-id = [85 60 16];
	cs-gpios = <&gpio0 16 0>;
2. prj.conf
CONFIG_FLASH=y
CONFIG_FLASH_JESD216_API=y
# Assume the standard SPI NOR flash driver.  If the device uses
# another driver add an override configuration in boards/.
CONFIG_SPI=y
CONFIG_SPI_NOR=y
  • Change NCS SDK to 2.6.2 fix this issue.
    &spi0 {
    	status = "okay";
    	pinctrl-0 = <&spi0_default>;
    	cs-gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
    		reg = <0>;
    		label = "p25q32h";
    		status = "okay";
    		partitions {
                #address-cells = <1>;
                #size-cells = <1>;
                spi_storage_partition: partition@0 {
                    label = "spi_storage";
                    reg = <0x00000000 0x00400000>;
