Download Client Redirect Querry
I am using download_client to get a bigger file (100KB) to my memory via LTE-M. The Files are located in a bucket and I use a shortURL to get the signedDownload URL. If I use this short URL in Download Client I get the Error "http/1.1 301 moved permanently". This seems to be correct, the URL is initialy ofcourse a redirect. But how can I handle this in my code? I couldnt find a way to read the header files with download client nor do I see any option for redirect hops or something like this. Is there even a solution? Or is it the limits of the low level integration?
Thanks for helping and best regards
daniel
    This is one option and decision is yours. It might be the easiest since there is support for HTTP transport in this new downloader library.
    Dejan
  • I solved the Redirect now manually via socket. I read the complete http response and get my URL. If anybody else ever needs this here is my function:
    #include <zephyr/net/socket.h>
    char *redirectHttp(const char *endpoint, const char *path) {
        int fd = 0;
        int err = 0;
        int bytes;
        char send_packet[200];
        char recv_buf[1024] = {};
        struct addrinfo *res;
        struct addrinfo hints = {
            .ai_family = AF_INET,
            .ai_socktype = SOCK_STREAM,
        err = getaddrinfo(endpoint, "80", &hints, &res);
        if (err) {
            LOG_ERR("[SOCKET] getaddrinfo err %d", errno);
            return 0;
        ((struct sockaddr_in *)res->ai_addr)->sin_port = htons(80);
        fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);  // Set socket to tcp without tls
        if (fd == -1) {
            LOG_ERR("[SOCKET] failed to open");
            return 0;
        char ipv4_addr[NET_IPV4_ADDR_LEN];
        inet_ntop(AF_INET, &((struct sockaddr_in *)res->ai_addr)->sin_port, ipv4_addr, sizeof(ipv4_addr));
        LOG_INF("[SOCKET] Connect to Addr IP: %s", ipv4_addr);
        err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
        if (err) {
            LOG_ERR("[SOCKET] connect() err: %d", errno);
            return 0;
        sprintf(send_packet,
                "GET %s HTTP/1.1\r\n"
                "Host: %s\r\n"
                "Accept: txt/plain\r\n\r\n",
                path, endpoint);
        bytes = send(fd, &send_packet, strlen(send_packet), 0);
        LOG_INF("[SOCKET] Sent %d bytes", bytes);
        bytes = blocking_recv(fd, recv_buf, sizeof(recv_buf), 0);
        LOG_INF("[SOCKET] Received %d bytes", bytes);
        const char *location_header = "Location: ";
        const char *start = strstr(recv_buf, location_header);
        if (start) {
            start += strlen(location_header);
            const char *end = strstr(start, "\r\n");
            if (!end) {
                end = start + strlen(start);  // End of string if no CRLF
            size_t length = end - start;
            if (length < 1024) {
                char *url = (char *)malloc(length + 1);  // Allocate memory for the URL
                strncpy(url, start, length);
                url[length] = '\0';  // Null-terminate the string
                return url;
            } else {
                LOG_ERR("[SOCKET] URL is too long to fit in the buffer");
                return 0;
        } else {
            LOG_ERR("[SOCKET] Location header not found in the response");
        return 0;
    Example Usage:
    const char *endpoint = "ul1.epaperframe.de";
    const char *path = "/tjoLta9.dl";
    char *url = redirectHttp(endpoint, path);
    printf("Redirected URL: %s\n", url);
    free(url);  // Free the allocated memory
    This ticket is solved for me now.
    This is great to hear. Thank you for the update.
    Dejan
