Flashing an application using the Actinius I/O Serial Programmer
Hi. I'm trying to flash the Cell Fund Lesson 4, Exercise 1 app – Reading buttons and controlling LEDs over MQTT, to an Icarus IoT Board v2 using the Actinius I/O Serial Programmer via usb.
I'm using SDK v2.8.0 and have flashed this successfully to the Thingy91.
I tried clean builds, and also tried including the following to prj.conf for the Icarus IoT Board v2 build with board target actinius_icarus/nrf9160/ns
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_BUILD_OUTPUT_BIN=y
App builds fine, but I can't find the app_update.bin file. (or zephyr.signed.bin) and trying to flash any other *.bin file from the <path>MQTT_broker\IcarusBuild\MQTT_broker\zephyr folder gives an "Upload failed Firmware is not a valid device image." message.
What am I doing wrong?
  • Proper functionality verified. I'm able to flash to the Icarus IoT.
    Nothing special about any of the builds. Add build configuration - Select board, and build configuration.
    west build --build-dir path/nRF/SMS_Notifier/Icarus_build path/nRF/SMS_Notifier --pristine --board actinius_icarus/nrf9160/ns -- -DNCS_TOOLCHAIN_VERSION=NONE
    west build --build-dir path/nRF/SMS_Notifier/Thingy91_build path/nRF/SMS_Notifier --pristine --board thingy91/nrf9160/ns -- -DNCS_TOOLCHAIN_VERSION=NONE
    I've tried with different applications too. Same result. I'm feeling dumb as a brick here, and probably is by missing something basic. I'm new to Nordic environment. Trying to learn to see if it has potential for our project.
    Since you are using NCS v2.8.0, sysbuild is included in your build. There is a change related to MCUboot from previous NCS versions. If you do not already have it, you should create sysbuild.conf in your project root directory and add the line SB_CONFIG_BOOTLOADER_MCUBOOT=y there. You can get more information about this in Sample with MCUboot.
    Dejan
  • Thank you for looking into this. I've seen CONFIG_BOOTLOADER_MCUBOOT=y referenced many places, but not CB_CONFIG_BOOTLOADER_MCUBOOT=y. Anyways. Got these errors after trying a new build with sysbuild.conf in my root, and the line SB_CONFIG_BOOTLOADER_MCUBOOT=y
    "resource": "/cmake/modules/sysbuild_extensions.cmake",
    "owner": "nrf-connect",
    "severity": 8,
    "message": "CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):",
    "source": "cmake",
    "startLineNumber": 514,
    "startColumn": 1,
    "endLineNumber": 514,
    "endColumn": 2147483647
    "resource": "/c:/ncs/v2.8.0/zephyr/cmake/modules/extensions.cmake",
    "severity": 8,
    "message": "CMake Error at C:/ncs/v2.8.0/zephyr/cmake/modules/extensions.cmake:2842 (message):",
    "source": "cmake",
    "startLineNumber": 2842,
    "startColumn": 1,
    "endLineNumber": 2842,
    See also "path/nRF/SMS_Notifier/I_IoT_build/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\2d382dcd92\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/2d382dcd92/opt/bin/python.exe '-Bpath\nRF\SMS_Notifier\I_IoT_build' -GNinja -DBOARD=actinius_icarus/nrf9160/ns -DNCS_TOOLCHAIN_VERSION=NONE '-SC:\ncs\v2.8.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=path\nRF\SMS_Notifier'
    Do you still have CONFIG_BOOTLOADER_MCUBOOT=y  in your project configuration?
    Please make sure that there is no typo. Correct configuration option is SB_CONFIG_BOOTLOADER_MCUBOOT.
    Dejan
  • Yes, I tried including CB_CONFIG_BOOTLOADER_MCUBOOT=y in sysbuild.conf. Build fails.
    Tried including it in an new app and build with same result.
    Also tried building for the circuitdojo_feather/nrf9160/ns, but all builds fail.
    Errors after last try
    "severity": 8,
    "source": "cmake",
    "startColumn": 1,
    "severity": 8,
    "source": "cmake",
    "startColumn": 1,
    "resource": "/c:/path/path/nRF/Blinky/AI_build",
    "owner": "Kconfig no context",
    "severity": 4,
    "message": "Kconfig Language Server cannot start for build 'AI_build'. Try rebuilding or do the pristine build to fix this issue.",
    "startLineNumber": 1,
    "startColumn": 1,
    "endLineNumber": 1,
    "endColumn": 1
    I have tried rebuild and Pristine build.
