BLE advertising cannot be stop without hardware crash
Hye,
using the nrf 2.4.2 toolchain
i have an unsolvable problem about ble on a nrf52840 based project with imu, i2s strip led, buttons, spi speaker...
i have a classic ble enable process at startup after everthing else initialized (i try disabling all around too... same)
i get a systematic crash on advertising stop with bt_le_adv_stop();
i tried a lot of things about irq conflict or configs...
i tried to put in thread allowing to start and stop advertising few times but a crash anyway
it just reboot with HARDWARE reset cause (12).
relevant config is for now:
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="XXX"
CONFIG_BT_GATT_CLIENT=y
#CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BT_EXT_ADV=y
CONFIG_ZERO_LATENCY_IRQS=y
CONFIG_BT_LL_SW_SPLIT=y
CONFIG_BT_CTLR_ULL_HIGH_PRIO=2
CONFIG_BT_MAX_CONN=1
CONFIG_ISR_STACK_SIZE=1024
CONFIG_BT_DIS=y
CONFIG_BT_DIS_FW_REV=y
CONFIG_BT_DIS_MODEL="xxxxxx"
CONFIG_BT_DIS_MANUF="xxxxxx"
CONFIG_BT_DIS_PNP=n
CONFIG_BT_SETTINGS=y
CONFIG_BT_GATT_CACHING=n
CONFIG_BT_DIS_SETTINGS=y
CONFIG_BT_THROUGHPUT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_BUF_ACL_RX_SIZE=502
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_L2CAP_TX_MTU=498
also the project use FOTA:
CONFIG_MCUMGR=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_STAT=y
CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_DISABLE_FLASH_PATCH=y
thanks
  • After insvestigation, it appear that a call to a settings_save_one() function just after the ble stop break the execution without explicite exception and reset cause 0x12 HARDWARE_RESET.
    After disabling watchdog, the same problem reset with cause 0x10 BROWN_OUT.
    Finally i manage to avoid the crash by moving the settings_save_one() call before the ble stop...
    but i still do not know what's exactly going on...
    i did not found any irq conflict and tried a lot a configuration variation about it...
    same behaviour with all others sensors disabled and uninitilaized... maybe dts.?
    i didn't try on DK for now...
  • Where do you see 0x12 and 0x10?
    And where do you call settings_save_one()? Is this something you added to your application, or is it something that is part of the default bt_le_adv_stop() API?
    Edvin
  • i see the reset cause at the beginning of my app after reboot, using the reset cause api.
    settings_save_one() call is in my app and was called after the bt_le_adv_stop(). but debugger stop in bt_le_adv_stop() ????
    moving settings_save_one() call before the bt_le_adv_stop() solve the crash !!
    Sorry, this may be obvious, but I have not seen it. Can you please specify what API that is?
    unless you are done with this issue, of course.
    And if it is possible to reproduce in a DK, that would make it easier to understand what's going on.
    Edvin
  • uint32_t reset_cause;
    int err = hwinfo_get_reset_cause(&reset_cause);
    CONFIG_HWINFO=y in prj.conf
    i would prefer to understand...
    will take a moment in DK... if some time to do it...
