In another thread entitled:
Change in GPIO to start/stop timer and fire interrupt
The following code is used:
NRF_GPIOTE->CONFIG[0] = (GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos)
| (myPin << GPIOTE_CONFIG_PSEL_Pos) // using GPIO 5 as input
| (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos);
//// Configure GPIOTE channel 1 as event that occurs when pin 5 changes from digital
//// low to hi.
NRF_GPIOTE->CONFIG[1] = (GPIOTE_CONFIG_POLARITY_LoToHi << GPIOTE_CONFIG_POLARITY_Pos)
| (myPin<< GPIOTE_CONFIG_PSEL_Pos) // using GPIO 5 as input
In the nRF51 RM, there is a statement: Each GPIOTE channel is associated with one physical GPIO pin through the CONFIG.PSEL field...
Is the above code breaking this rule? Are two configurations being mapped to a single pin?
Would the correct code be to look for a change, then check the PIN state in the ISR to determine whether it was HiToLo or LoToHi?
If so, what would be the recommended debounce approach?
