Corrupt I2C scanning when adding load to the system
How to reproduce the issue:
We have used the standard hello_world sample application in the zephyr repository. CONFIG_I2C, CONFIG_SHELL and CONFIG_I2C_SHELL configurations are added to the sample application. We have also changed the i2c2 clock-frequency to use I2C_BITRATE_STANDARD in an overlay since the device that we intend to connect only supports this bitrate. Using the “i2c scan i2c@a000” from the shell we can see that the GPIO expander is correctly detected at address 0x21. However, if we add load to the application (k_sleep(K_MSEC(1)); in a while 1 loop) doing a scan will often result in more devices showing up at random addresses.
HW setup: nRF9151-DK (0.9.0, 2024.30). The board configuration utility has been used to enable the IO Expander (I2C) on the board.
SW setup:  nRF Connect SDK v2.7.0, Modem FW: mfw_nrf91x1_2.0.2
Toolchain: nRF Connect SDK Toolchain v2.7.0
  • Working (non-loaded system, only the GPIO expander is detected):
uart:~$ > i2c scan i2c@a000
i2c scan i2c@a000
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:             -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- 21 -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
1 devices found on i2c@a000
  • Non-working (loaded system, other devices than the GPIO expander detected):
i2c scan i2c@a000
00:             -- -- -- -- -- -- 0a -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- 59 -- -- -- -- -- --
70: -- -- -- -- -- -- 76 --
4 devices found on i2c@a000
Looking at the I2C clock and data lines (corresponding to the incorrect scan above) we see that there is a dip on the lines before address 0x0a is scanned and this gets detected as a device present as shown in the snippet below.
The next snippet shows the same scan where the GPIO expander is detected (correctly) at address 0x21 later in the sequence.
Changes to the hello_world sample application in the zephyr repository:
diff --git a/samples/hello_world/i2c.conf b/samples/hello_world/i2c.conf
new file mode 100644
index 00000000000..5c9f7c9b0e3
--- /dev/null
+++ b/samples/hello_world/i2c.conf
@@ -0,0 +1,4 @@
+CONFIG_I2C=y
+CONFIG_SHELL=y
+CONFIG_I2C_SHELL=y
diff --git a/samples/hello_world/i2c.overlay b/samples/hello_world/i2c.overlay
index 00000000000..5ee0212715c
--- /dev/null
+++ b/samples/hello_world/i2c.overlay
@@ -0,0 +1,3 @@
+&i2c2 {
+             clock-frequency = <I2C_BITRATE_STANDARD>;
diff --git a/samples/hello_world/src/main.c b/samples/hello_world/src/main.c
index c550ab461cb..33d2176bbaa 100644
--- a/samples/hello_world/src/main.c
+++ b/samples/hello_world/src/main.c
@@ -4,11 +4,19 @@
+#include <zephyr/kernel.h>
#include <stdio.h>
               printf("Hello World! %s\n", CONFIG_BOARD_TARGET);
+#if 0
+             while (1)
+                             k_sleep(K_MSEC(1));
+#endif
               return 0;
Please let us know if this an issue with the I2C or if we are using the system incorrectly.
Daniel.
